[rtems commit] delete smpatomic0-7 test cases
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Oct 8 14:48:10 UTC 2013
On 10/8/2013 9:34 AM, Deng Hengyi wrote:
> Yeah, merge all the smpatomic01-07 test cases into one test case and simplify the test case.
OK. That was far from clear with the patch that just deleted all the
tests. :)
--joel
> 在 2013-10-8,下午10:28,Joel Sherrill <joel.sherrill at oarcorp.com> 写道:
>> Can you clarify why you deleted these?
>> Are you adding replacement tests for this code?
>> On 10/8/2013 9:01 AM, Sebastian Huber wrote:
>>> Module: rtems
>>> Branch: master
>>> Commit: 27a034ef13e70493eb8457821b87346ee96ee4f8
>>> Changeset: http://git.rtems.org/rtems/commit/?id=27a034ef13e70493eb8457821b87346ee96ee4f8
>>> Author: WeiY <wei.a.yang at gmail.com>
>>> Date: Sat Sep 28 14:54:37 2013 +0800
>>> testsuites/smptests/Makefile.am | 7 --
>>> testsuites/smptests/configure.ac | 7 --
>>> testsuites/smptests/smpatomic01/Makefile.am | 20 -----
>>> testsuites/smptests/smpatomic01/init.c | 72 -----------------
>>> testsuites/smptests/smpatomic01/smpatomic01.doc | 23 ------
>>> testsuites/smptests/smpatomic01/smpatomic01.scn | 28 -------
>>> testsuites/smptests/smpatomic01/system.h | 50 ------------
>>> testsuites/smptests/smpatomic01/tasks.c | 73 -----------------
>>> testsuites/smptests/smpatomic02/Makefile.am | 20 -----
>>> testsuites/smptests/smpatomic02/init.c | 72 -----------------
>>> testsuites/smptests/smpatomic02/smpatomic02.doc | 23 ------
>>> testsuites/smptests/smpatomic02/smpatomic02.scn | 28 -------
>>> testsuites/smptests/smpatomic02/system.h | 50 ------------
>>> testsuites/smptests/smpatomic02/tasks.c | 73 -----------------
>>> testsuites/smptests/smpatomic03/Makefile.am | 20 -----
>>> testsuites/smptests/smpatomic03/init.c | 72 -----------------
>>> testsuites/smptests/smpatomic03/smpatomic03.doc | 23 ------
>>> testsuites/smptests/smpatomic03/smpatomic03.scn | 29 -------
>>> testsuites/smptests/smpatomic03/system.h | 50 ------------
>>> testsuites/smptests/smpatomic03/tasks.c | 81 -------------------
>>> testsuites/smptests/smpatomic04/Makefile.am | 20 -----
>>> testsuites/smptests/smpatomic04/init.c | 72 -----------------
>>> testsuites/smptests/smpatomic04/smpatomic04.doc | 23 ------
>>> testsuites/smptests/smpatomic04/smpatomic04.scn | 29 -------
>>> testsuites/smptests/smpatomic04/system.h | 50 ------------
>>> testsuites/smptests/smpatomic04/tasks.c | 81 -------------------
>>> testsuites/smptests/smpatomic05/Makefile.am | 20 -----
>>> testsuites/smptests/smpatomic05/init.c | 72 -----------------
>>> testsuites/smptests/smpatomic05/smpatomic05.doc | 23 ------
>>> testsuites/smptests/smpatomic05/smpatomic05.scn | 29 -------
>>> testsuites/smptests/smpatomic05/system.h | 50 ------------
>>> testsuites/smptests/smpatomic05/tasks.c | 81 -------------------
>>> testsuites/smptests/smpatomic06/Makefile.am | 20 -----
>>> testsuites/smptests/smpatomic06/init.c | 72 -----------------
>>> testsuites/smptests/smpatomic06/smpatomic06.doc | 23 ------
>>> testsuites/smptests/smpatomic06/smpatomic06.scn | 29 -------
>>> testsuites/smptests/smpatomic06/system.h | 50 ------------
>>> testsuites/smptests/smpatomic06/tasks.c | 81 -------------------
>>> testsuites/smptests/smpatomic07/Makefile.am | 20 -----
>>> testsuites/smptests/smpatomic07/init.c | 72 -----------------
>>> testsuites/smptests/smpatomic07/smpatomic07.doc | 24 ------
>>> testsuites/smptests/smpatomic07/smpatomic07.scn | 29 -------
>>> testsuites/smptests/smpatomic07/system.h | 50 ------------
>>> testsuites/smptests/smpatomic07/tasks.c | 97 -----------------------
>>> 44 files changed, 0 insertions(+), 1938 deletions(-)
>>> diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
>>> index 55d612f..d8b5a3e 100644
>>> --- a/testsuites/smptests/Makefile.am
>>> +++ b/testsuites/smptests/Makefile.am
>>> @@ -12,13 +12,6 @@ SUBDIRS += smp07
>>> SUBDIRS += smp08
>>> SUBDIRS += smp09
>>> if ATOMIC
>>> -SUBDIRS += smpatomic01
>>> -SUBDIRS += smpatomic02
>>> -SUBDIRS += smpatomic03
>>> -SUBDIRS += smpatomic04
>>> -SUBDIRS += smpatomic05
>>> -SUBDIRS += smpatomic06
>>> -SUBDIRS += smpatomic07
>>> SUBDIRS += smpatomic08
>>> endif
>>> SUBDIRS += smplock01
>>> diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
>>> index 05b9056..35f704d 100644
>>> --- a/testsuites/smptests/configure.ac
>>> +++ b/testsuites/smptests/configure.ac
>>> @@ -46,13 +46,6 @@ smp06/Makefile
>>> smp07/Makefile
>>> smp08/Makefile
>>> smp09/Makefile
>>> -smpatomic01/Makefile
>>> -smpatomic02/Makefile
>>> -smpatomic03/Makefile
>>> -smpatomic04/Makefile
>>> -smpatomic05/Makefile
>>> -smpatomic06/Makefile
>>> -smpatomic07/Makefile
>>> smpatomic08/Makefile
>>> smplock01/Makefile
>>> smpmigration01/Makefile
>>> diff --git a/testsuites/smptests/smpatomic01/Makefile.am b/testsuites/smptests/smpatomic01/Makefile.am
>>> deleted file mode 100644
>>> index 7bd5502..0000000
>>> --- a/testsuites/smptests/smpatomic01/Makefile.am
>>> +++ /dev/null
>>> @@ -1,20 +0,0 @@
>>> -rtems_tests_PROGRAMS = smpatomic01
>>> -smpatomic01_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>> -dist_rtems_tests_DATA = smpatomic01.scn
>>> -dist_rtems_tests_DATA += smpatomic01.doc
>>> -include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
>>> -include $(top_srcdir)/../automake/compile.am
>>> -include $(top_srcdir)/../automake/leaf.am
>>> -AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>>> -LINK_OBJS = $(smpatomic01_OBJECTS)
>>> -LINK_LIBS = $(smpatomic01_LDLIBS)
>>> -smpatomic01$(EXEEXT): $(smpatomic01_OBJECTS) $(smpatomic01_DEPENDENCIES)
>>> - @rm -f smpatomic01$(EXEEXT)
>>> - $(make-exe)
>>> -include $(top_srcdir)/../automake/local.am
>>> diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
>>> index f7dfa11..0000000
>>> --- a/testsuites/smptests/smpatomic01/init.c
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> - * Copyright (c) 2012 Deng Hengyi.
>>> - * This test case is to test atomic load operation.
>>> - * The license and distribution terms for this file may be
>>> - * found in the file LICENSE in this distribution or at
>>> - * http://www.rtems.com/license/LICENSE.
>>> -#ifdef HAVE_CONFIG_H
>>> -#include "config.h"
>>> -#endif
>>> -#define CONFIGURE_INIT
>>> -#include "system.h"
>>> -rtems_task Init(
>>> - rtems_task_argument argument
>>> - int i;
>>> - char ch;
>>> - rtems_id id;
>>> - rtems_status_code status;
>>> - bool allDone;
>>> - /* XXX - Delay a bit to allow debug messages from
>>> - * startup to print. This may need to go away when
>>> - * debug messages go away.
>>> - locked_print_initialize();
>>> - /* Put start of test message */
>>> - locked_printf( "\n\n*** SMPatomic01 TEST ***\n" );
>>> - /* Initialize the TaskRan array */
>>> - for ( i=0; i<rtems_smp_get_processor_count() ; i++ ) {
>>> - TaskRan[i] = false;
>>> - /* Create and start tasks for each processor */
>>> - for ( i=1; i< rtems_smp_get_processor_count() ; i++ ) {
>>> - ch = '0' + i;
>>> - status = rtems_task_create(
>>> - rtems_build_name( 'T', 'A', ch, ' ' ),
>>> - 1,
>>> - RTEMS_MINIMUM_STACK_SIZE,
>>> - RTEMS_DEFAULT_MODES,
>>> - RTEMS_DEFAULT_ATTRIBUTES,
>>> - &id
>>> - directive_failed( status, "task create" );
>>> - status = rtems_task_start( id, Test_task, i+1 );
>>> - directive_failed( status, "task start" );
>>> - /* Wait on the all tasks to run */
>>> - while (1) {
>>> - allDone = true;
>>> - for ( i=1; i<rtems_smp_get_processor_count() ; i++ ) {
>>> - if (TaskRan[i] == false)
>>> - allDone = false;
>>> - if (allDone) {
>>> - locked_printf( "\n\n*** END OF TEST SMPatomic01 ***\n" );
>>> - rtems_test_exit( 0 );
>>> diff --git a/testsuites/smptests/smpatomic01/smpatomic01.doc b/testsuites/smptests/smpatomic01/smpatomic01.doc
>>> index 3d83245..0000000
>>> --- a/testsuites/smptests/smpatomic01/smpatomic01.doc
>>> +++ /dev/null
>>> @@ -1,23 +0,0 @@
>>> -# COPYRIGHT (c) 1989-2012.
>>> -# On-Line Applications Research Corporation (OAR).
>>> -# The license and distribution terms for this file may be
>>> -# found in the file LICENSE in this distribution or at
>>> -# http://www.rtems.com/license/LICENSE.
>>> -This file describes the directives and concepts tested by this test set.
>>> -test set name: smpatomic01
>>> -directives:
>>> - _Atomic_Load_int
>>> - _Atomic_Load_long
>>> - _Atomic_Load_ptr
>>> - _Atomic_Load_32
>>> - _Atomic_Load_64
>>> -concepts:
>>> -+ Ensure that the atomic load operations listed above behave as defined.
>>> diff --git a/testsuites/smptests/smpatomic01/smpatomic01.scn b/testsuites/smptests/smpatomic01/smpatomic01.scn
>>> index dba0d5c..0000000
>>> --- a/testsuites/smptests/smpatomic01/smpatomic01.scn
>>> +++ /dev/null
>>> @@ -1,28 +0,0 @@
>>> -*** SMPatomic01 TEST ***
>>> -CPU1 _Atomic_Load_int: SUCCESS
>>> -CPU2 _Atomic_Load_int: SUCCESS
>>> -CPU3 _Atomic_Load_int: SUCCESS
>>> -CPU1 _Atomic_Load_long: SUCCESS
>>> -CPU2 _Atomic_Load_long: SUCCESS
>>> -CPU3 _Atomic_Load_long: SUCCESS
>>> -CPU1 _Atomic_Load_ptr: SUCCESS
>>> -CPU3 _Atomic_Load_ptr: SUCCESS
>>> -CPU2 _Atomic_Load_ptr: SUCCESS
>>> -CPU1 _Atomic_Load_32: SUCCESS
>>> -CPU2 _Atomic_Load_32: SUCCESS
>>> -CPU3 _Atomic_Load_32: SUCCESS
>>> -*** END OF TEST SMPatomic01 ***
>>> diff --git a/testsuites/smptests/smpatomic01/system.h b/testsuites/smptests/smpatomic01/system.h
>>> index da314a2..0000000
>>> --- a/testsuites/smptests/smpatomic01/system.h
>>> +++ /dev/null
>>> @@ -1,50 +0,0 @@
>>> - * COPYRIGHT (c) 1989-2011.
>>> - * On-Line Applications Research Corporation (OAR).
>>> -#include "tmacros.h"
>>> -#include "test_support.h"
>>> -/* functions */
>>> -rtems_task Init(
>>> -rtems_task Test_task(
>>> -/* configuration information */
>>> -#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>>> -#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>> -#define CONFIGURE_SMP_APPLICATION
>>> -#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 4
>>> -#define CONFIGURE_MAXIMUM_TASKS \
>>> - (1 + CONFIGURE_SMP_MAXIMUM_PROCESSORS)
>>> -#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>> -#include <rtems/confdefs.h>
>>> -/* global variables */
>>> - * Keep the names and IDs in global variables so another task can use them.
>>> -TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
>>> - * Handy macros and static inline functions
>>> -/* end of include file */
>>> diff --git a/testsuites/smptests/smpatomic01/tasks.c b/testsuites/smptests/smpatomic01/tasks.c
>>> index 4dd2ff6..0000000
>>> --- a/testsuites/smptests/smpatomic01/tasks.c
>>> +++ /dev/null
>>> @@ -1,73 +0,0 @@
>>> -#endif
>>> -#include <stdlib.h>
>>> -#include <rtems/rtems/atomic.h>
>>> -#define TEST_REPEAT 1000
>>> -#define ATOMIC_LOAD_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
>>> - Atomic_##TYPE t; \
>>> - R_TYPE a; \
>>> - R_TYPE b; \
>>> - unsigned int i; \
>>> - for (i = 0; i < TEST_REPEAT; i++){ \
>>> - b = (R_TYPE)rand(); \
>>> - atomic_init(&t, b); \
>>> - a = _Atomic_Load_##NAME(&t, mem_bar); \
>>> - rtems_test_assert(a == b); \
>>> - locked_printf("\nCPU%d Atomic_Load_" #NAME ": SUCCESS\n", cpuid); \
>>> - uint32_t cpu_num;
>>> - char name[5];
>>> - char *p;
>>> - /* Get the task name */
>>> - p = rtems_object_get_name( RTEMS_SELF, 5, name );
>>> - rtems_test_assert( p != NULL );
>>> - /* Get the CPU Number */
>>> - cpu_num = rtems_smp_get_current_processor();
>>> - /* Print that the task is up and running. */
>>> - /* test relaxed barrier */
>>> - ATOMIC_LOAD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - /* test acquire barrier */
>>> - ATOMIC_LOAD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> -// ATOMIC_LOAD_NO_BARRIER(64, cpu_num);
>>> - /* Set the flag that the task is up and running */
>>> - TaskRan[cpu_num] = true;
>>> - /* Drop into a loop which will keep this task on
>>> - * running on the cpu.
>>> - while(1);
>>> diff --git a/testsuites/smptests/smpatomic02/Makefile.am b/testsuites/smptests/smpatomic02/Makefile.am
>>> index 04fc5e4..0000000
>>> --- a/testsuites/smptests/smpatomic02/Makefile.am
>>> +++ /dev/null
>>> @@ -1,20 +0,0 @@
>>> -rtems_tests_PROGRAMS = smpatomic02
>>> -smpatomic02_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>> -dist_rtems_tests_DATA = smpatomic02.scn
>>> -dist_rtems_tests_DATA += smpatomic02.doc
>>> -LINK_OBJS = $(smpatomic02_OBJECTS)
>>> -LINK_LIBS = $(smpatomic02_LDLIBS)
>>> -smpatomic02$(EXEEXT): $(smpatomic02_OBJECTS) $(smpatomic02_DEPENDENCIES)
>>> - $(make-exe)
>>> diff --git a/testsuites/smptests/smpatomic02/init.c b/testsuites/smptests/smpatomic02/init.c
>>> index 9e0da4b..0000000
>>> --- a/testsuites/smptests/smpatomic02/init.c
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> - * This test case is to test atomic store operation.
>>> -#endif
>>> -rtems_task Init(
>>> - int i;
>>> - char ch;
>>> - rtems_id id;
>>> - bool allDone;
>>> - locked_printf( "\n\n*** SMPatomic02 TEST ***\n" );
>>> - ch = '0' + i;
>>> - 1,
>>> - &id
>>> - while (1) {
>>> - allDone = true;
>>> - allDone = false;
>>> - if (allDone) {
>>> - locked_printf( "\n\n*** END OF TEST SMPatomic02 ***\n" );
>>> diff --git a/testsuites/smptests/smpatomic02/smpatomic02.doc b/testsuites/smptests/smpatomic02/smpatomic02.doc
>>> index d1ab4f5..0000000
>>> --- a/testsuites/smptests/smpatomic02/smpatomic02.doc
>>> +++ /dev/null
>>> @@ -1,23 +0,0 @@
>>> -test set name: smpatomic02
>>> -directives:
>>> - _Atomic_Store_int
>>> - _Atomic_Store_long
>>> - _Atomic_Store_ptr
>>> - _Atomic_Store_32
>>> - _Atomic_Store_64
>>> -concepts:
>>> -+ Ensure that the atomic store operations listed above behave as defined.
>>> diff --git a/testsuites/smptests/smpatomic02/smpatomic02.scn b/testsuites/smptests/smpatomic02/smpatomic02.scn
>>> index de8fe2c..0000000
>>> --- a/testsuites/smptests/smpatomic02/smpatomic02.scn
>>> +++ /dev/null
>>> @@ -1,28 +0,0 @@
>>> -*** SMPatomic02 TEST ***
>>> -CPU1 _Atomic_Store_int: SUCCESS
>>> -CPU2 _Atomic_Store_int: SUCCESS
>>> -CPU3 _Atomic_Store_int: SUCCESS
>>> -CPU1 _Atomic_Store_long: SUCCESS
>>> -CPU2 _Atomic_Store_long: SUCCESS
>>> -CPU3 _Atomic_Store_long: SUCCESS
>>> -CPU1 _Atomic_Store_ptr: SUCCESS
>>> -CPU3 _Atomic_Store_ptr: SUCCESS
>>> -CPU2 _Atomic_Store_ptr: SUCCESS
>>> -CPU1 _Atomic_Store_32: SUCCESS
>>> -CPU2 _Atomic_Store_32: SUCCESS
>>> -CPU3 _Atomic_Store_32: SUCCESS
>>> -*** END OF TEST SMPatomic02 ***
>>> diff --git a/testsuites/smptests/smpatomic02/system.h b/testsuites/smptests/smpatomic02/system.h
>>> --- a/testsuites/smptests/smpatomic02/system.h
>>> +++ /dev/null
>>> @@ -1,50 +0,0 @@
>>> -/* functions */
>>> -rtems_task Init(
>>> diff --git a/testsuites/smptests/smpatomic02/tasks.c b/testsuites/smptests/smpatomic02/tasks.c
>>> index c5c9ba5..0000000
>>> --- a/testsuites/smptests/smpatomic02/tasks.c
>>> +++ /dev/null
>>> @@ -1,73 +0,0 @@
>>> -#endif
>>> -#define ATOMIC_STORE_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
>>> - R_TYPE a; \
>>> - R_TYPE b; \
>>> - unsigned int i; \
>>> - _Atomic_Store_##NAME(&t, b, mem_bar); \
>>> - a = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_ACQUIRE); \
>>> - locked_printf("\nCPU%d Atomic_Store_" #NAME ": SUCCESS\n", cpuid); \
>>> - uint32_t cpu_num;
>>> - char name[5];
>>> - char *p;
>>> - ATOMIC_STORE_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - /* test release barrier */
>>> - ATOMIC_STORE_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>> - ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>> -// ATOMIC_STORE_NO_BARRIER(64, cpu_num);
>>> - while(1);
>>> diff --git a/testsuites/smptests/smpatomic03/Makefile.am b/testsuites/smptests/smpatomic03/Makefile.am
>>> index cebd323..0000000
>>> --- a/testsuites/smptests/smpatomic03/Makefile.am
>>> +++ /dev/null
>>> @@ -1,20 +0,0 @@
>>> -rtems_tests_PROGRAMS = smpatomic03
>>> -smpatomic03_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>> -dist_rtems_tests_DATA = smpatomic03.scn
>>> -dist_rtems_tests_DATA += smpatomic03.doc
>>> -LINK_OBJS = $(smpatomic03_OBJECTS)
>>> -LINK_LIBS = $(smpatomic03_LDLIBS)
>>> -smpatomic03$(EXEEXT): $(smpatomic03_OBJECTS) $(smpatomic03_DEPENDENCIES)
>>> - @rm -f smpatomic03$(EXEEXT)
>>> - $(make-exe)
>>> diff --git a/testsuites/smptests/smpatomic03/init.c b/testsuites/smptests/smpatomic03/init.c
>>> index bf5b2a0..0000000
>>> --- a/testsuites/smptests/smpatomic03/init.c
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> - * This test case is to test atomic add operation.
>>> -#endif
>>> -rtems_task Init(
>>> - int i;
>>> - char ch;
>>> - rtems_id id;
>>> - bool allDone;
>>> - locked_printf( "\n\n*** SMPatomic03 TEST ***\n" );
>>> - ch = '0' + i;
>>> - 1,
>>> - &id
>>> - while (1) {
>>> - allDone = true;
>>> - allDone = false;
>>> - if (allDone) {
>>> - locked_printf( "\n\n*** END OF TEST SMPatomic03 ***\n" );
>>> diff --git a/testsuites/smptests/smpatomic03/smpatomic03.doc b/testsuites/smptests/smpatomic03/smpatomic03.doc
>>> index d70a37c..0000000
>>> --- a/testsuites/smptests/smpatomic03/smpatomic03.doc
>>> +++ /dev/null
>>> @@ -1,23 +0,0 @@
>>> -test set name: smpatomic03
>>> -directives:
>>> - _Atomic_Fetch_add_int
>>> - _Atomic_Fetch_add_long
>>> - _Atomic_Fetch_add_ptr
>>> - _Atomic_Fetch_add_32
>>> - _Atomic_Fetch_add_64
>>> -concepts:
>>> -+ Ensure that the atomic add operations listed above behave as defined.
>>> diff --git a/testsuites/smptests/smpatomic03/smpatomic03.scn b/testsuites/smptests/smpatomic03/smpatomic03.scn
>>> index 92d3846..0000000
>>> --- a/testsuites/smptests/smpatomic03/smpatomic03.scn
>>> +++ /dev/null
>>> @@ -1,29 +0,0 @@
>>> -*** SMPatomic03 TEST ***
>>> -CPU2 _Atomic_Fetch_add_int: SUCCESS
>>> -CPU1 _Atomic_Fetch_add_int: SUCCESS
>>> -CPU3 _Atomic_Fetch_add_int: SUCCESS
>>> -CPU2 _Atomic_Fetch_add_long: SUCCESS
>>> -CPU2 _Atomic_Fetch_add_ptr: SUCCESS
>>> -CPU3 _Atomic_Fetch_add_long: SUCCESS
>>> -CPU1 _Atomic_Fetch_add_long: SUCCESS
>>> -CPU1 _Atomic_Fetch_add_ptr: SUCCESS
>>> -CPU2 _Atomic_Fetch_add_32: SUCCESS
>>> -CPU3 _Atomic_Fetch_add_ptr: SUCCESS
>>> -CPU1 _Atomic_Fetch_add_32: SUCCESS
>>> -CPU3 _Atomic_Fetch_add_32: SUCCESS
>>> -*** END OF TEST SMPatomic03 ***
>>> diff --git a/testsuites/smptests/smpatomic03/system.h b/testsuites/smptests/smpatomic03/system.h
>>> --- a/testsuites/smptests/smpatomic03/system.h
>>> +++ /dev/null
>>> @@ -1,50 +0,0 @@
>>> -/* functions */
>>> -rtems_task Init(
>>> diff --git a/testsuites/smptests/smpatomic03/tasks.c b/testsuites/smptests/smpatomic03/tasks.c
>>> index 5010549..0000000
>>> --- a/testsuites/smptests/smpatomic03/tasks.c
>>> +++ /dev/null
>>> @@ -1,81 +0,0 @@
>>> -#endif
>>> -#define ATOMIC_FETCH_ADD_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
>>> - R_TYPE a; \
>>> - R_TYPE b; \
>>> - R_TYPE c; \
>>> - unsigned int i; \
>>> - a = (R_TYPE)(rand() % ((R_TYPE)-1 / 2)); \
>>> - b = (R_TYPE)(rand() % ((R_TYPE)-1 / 2)); \
>>> - _Atomic_Store_##NAME(&t, a, ATOMIC_ORDER_RELEASE); \
>>> - _Atomic_Fetch_add_##NAME(&t, b, mem_bar); \
>>> - c = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_ACQUIRE); \
>>> - rtems_test_assert(c == (R_TYPE)(a + b)); \
>>> - locked_printf("\nCPU%d Atomic_Fetch_add_" #NAME ": SUCCESS\n", cpuid); \
>>> - uint32_t cpu_num;
>>> - char name[5];
>>> - char *p;
>>> - ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>> - ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>> -// ATOMIC_FETCH_ADD_NO_BARRIER(64, cpu_num);
>>> - while(1);
>>> diff --git a/testsuites/smptests/smpatomic04/Makefile.am b/testsuites/smptests/smpatomic04/Makefile.am
>>> index 6b71e10..0000000
>>> --- a/testsuites/smptests/smpatomic04/Makefile.am
>>> +++ /dev/null
>>> @@ -1,20 +0,0 @@
>>> -rtems_tests_PROGRAMS = smpatomic04
>>> -smpatomic04_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>> -dist_rtems_tests_DATA = smpatomic04.scn
>>> -dist_rtems_tests_DATA += smpatomic04.doc
>>> -LINK_OBJS = $(smpatomic04_OBJECTS)
>>> -LINK_LIBS = $(smpatomic04_LDLIBS)
>>> -smpatomic04$(EXEEXT): $(smpatomic04_OBJECTS) $(smpatomic04_DEPENDENCIES)
>>> - @rm -f smpatomic04$(EXEEXT)
>>> - $(make-exe)
>>> diff --git a/testsuites/smptests/smpatomic04/init.c b/testsuites/smptests/smpatomic04/init.c
>>> index 8398515..0000000
>>> --- a/testsuites/smptests/smpatomic04/init.c
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> - * This test case is to test atomic sub operation.
>>> -#endif
>>> -rtems_task Init(
>>> - int i;
>>> - char ch;
>>> - rtems_id id;
>>> - bool allDone;
>>> - locked_printf( "\n\n*** SMPatomic04 TEST ***\n" );
>>> - ch = '0' + i;
>>> - 1,
>>> - &id
>>> - while (1) {
>>> - allDone = true;
>>> - allDone = false;
>>> - if (allDone) {
>>> - locked_printf( "\n\n*** END OF TEST SMPatomic04 ***\n" );
>>> diff --git a/testsuites/smptests/smpatomic04/smpatomic04.doc b/testsuites/smptests/smpatomic04/smpatomic04.doc
>>> index afa91ba..0000000
>>> --- a/testsuites/smptests/smpatomic04/smpatomic04.doc
>>> +++ /dev/null
>>> @@ -1,23 +0,0 @@
>>> -test set name: smpatomic04
>>> -directives:
>>> - _Atomic_Fetch_sub_int
>>> - _Atomic_Fetch_sub_long
>>> - _Atomic_Fetch_sub_ptr
>>> - _Atomic_Fetch_sub_32
>>> - _Atomic_Fetch_sub_64
>>> -concepts:
>>> -+ Ensure that the atomic sub operations listed above behave as defined.
>>> diff --git a/testsuites/smptests/smpatomic04/smpatomic04.scn b/testsuites/smptests/smpatomic04/smpatomic04.scn
>>> index a47d27d..0000000
>>> --- a/testsuites/smptests/smpatomic04/smpatomic04.scn
>>> +++ /dev/null
>>> @@ -1,29 +0,0 @@
>>> -*** SMPatomic04 TEST ***
>>> -CPU2 _Atomic_Fetch_sub_int: SUCCESS
>>> -CPU1 _Atomic_Fetch_sub_int: SUCCESS
>>> -CPU3 _Atomic_Fetch_sub_int: SUCCESS
>>> -CPU2 _Atomic_Fetch_sub_long: SUCCESS
>>> -CPU3 _Atomic_Fetch_sub_long: SUCCESS
>>> -CPU1 _Atomic_Fetch_sub_long: SUCCESS
>>> -CPU3 _Atomic_Fetch_sub_ptr: SUCCESS
>>> -CPU1 _Atomic_Fetch_sub_ptr: SUCCESS
>>> -CPU2 _Atomic_Fetch_sub_ptr: SUCCESS
>>> -CPU3 _Atomic_Fetch_sub_32: SUCCESS
>>> -CPU1 _Atomic_Fetch_sub_32: SUCCESS
>>> -CPU2 _Atomic_Fetch_sub_32: SUCCESS
>>> -*** END OF TEST SMPatomic04 ***
>>> diff --git a/testsuites/smptests/smpatomic04/system.h b/testsuites/smptests/smpatomic04/system.h
>>> --- a/testsuites/smptests/smpatomic04/system.h
>>> +++ /dev/null
>>> @@ -1,50 +0,0 @@
>>> -/* functions */
>>> -rtems_task Init(
>>> diff --git a/testsuites/smptests/smpatomic04/tasks.c b/testsuites/smptests/smpatomic04/tasks.c
>>> index 18632cd..0000000
>>> --- a/testsuites/smptests/smpatomic04/tasks.c
>>> +++ /dev/null
>>> @@ -1,81 +0,0 @@
>>> -#endif
>>> -#define ATOMIC_FETCH_SUB_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
>>> - R_TYPE a; \
>>> - R_TYPE b; \
>>> - R_TYPE c; \
>>> - unsigned int i; \
>>> - _Atomic_Fetch_sub_##NAME(&t, b, mem_bar); \
>>> - rtems_test_assert(c == (R_TYPE)(a - b)); \
>>> - locked_printf("\nCPU%d Atomic_Fetch_sub_" #NAME ": SUCCESS\n", cpuid); \
>>> - uint32_t cpu_num;
>>> - char name[5];
>>> - char *p;
>>> - ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>> - ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>> -// ATOMIC_FETCH_SUB_NO_BARRIER(64, cpu_num);
>>> - while(1);
>>> diff --git a/testsuites/smptests/smpatomic05/Makefile.am b/testsuites/smptests/smpatomic05/Makefile.am
>>> index 0d4489d..0000000
>>> --- a/testsuites/smptests/smpatomic05/Makefile.am
>>> +++ /dev/null
>>> @@ -1,20 +0,0 @@
>>> -rtems_tests_PROGRAMS = smpatomic05
>>> -smpatomic05_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>> -dist_rtems_tests_DATA = smpatomic05.scn
>>> -dist_rtems_tests_DATA += smpatomic05.doc
>>> -LINK_OBJS = $(smpatomic05_OBJECTS)
>>> -LINK_LIBS = $(smpatomic05_LDLIBS)
>>> -smpatomic05$(EXEEXT): $(smpatomic05_OBJECTS) $(smpatomic05_DEPENDENCIES)
>>> - @rm -f smpatomic05$(EXEEXT)
>>> - $(make-exe)
>>> diff --git a/testsuites/smptests/smpatomic05/init.c b/testsuites/smptests/smpatomic05/init.c
>>> index 9a1947e..0000000
>>> --- a/testsuites/smptests/smpatomic05/init.c
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> - * This test case is to test atomic and operation.
>>> -#endif
>>> -rtems_task Init(
>>> - int i;
>>> - char ch;
>>> - rtems_id id;
>>> - bool allDone;
>>> - locked_printf( "\n\n*** SMPatomic05 TEST ***\n" );
>>> - ch = '0' + i;
>>> - 1,
>>> - &id
>>> - while (1) {
>>> - allDone = true;
>>> - allDone = false;
>>> - if (allDone) {
>>> - locked_printf( "\n\n*** END OF TEST SMPatomic05 ***\n" );
>>> diff --git a/testsuites/smptests/smpatomic05/smpatomic05.doc b/testsuites/smptests/smpatomic05/smpatomic05.doc
>>> index 9ef47b1..0000000
>>> --- a/testsuites/smptests/smpatomic05/smpatomic05.doc
>>> +++ /dev/null
>>> @@ -1,23 +0,0 @@
>>> -test set name: smpatomic05
>>> -directives:
>>> - _Atomic_Fetch_and_int
>>> - _Atomic_Fetch_and_long
>>> - _Atomic_Fetch_and_ptr
>>> - _Atomic_Fetch_and_32
>>> - _Atomic_Fetch_and_64
>>> -concepts:
>>> -+ Ensure that the atomic and operations listed above behave as defined.
>>> diff --git a/testsuites/smptests/smpatomic05/smpatomic05.scn b/testsuites/smptests/smpatomic05/smpatomic05.scn
>>> index f297e3c..0000000
>>> --- a/testsuites/smptests/smpatomic05/smpatomic05.scn
>>> +++ /dev/null
>>> @@ -1,29 +0,0 @@
>>> -*** SMPatomic05 TEST ***
>>> -CPU2 _Atomic_Fetch_and_int: SUCCESS
>>> -CPU3 _Atomic_Fetch_and_int: SUCCESS
>>> -CPU1 _Atomic_Fetch_and_int: SUCCESS
>>> -CPU2 _Atomic_Fetch_and_long: SUCCESS
>>> -CPU2 _Atomic_Fetch_and_ptr: SUCCESS
>>> -CPU3 _Atomic_Fetch_and_long: SUCCESS
>>> -CPU1 _Atomic_Fetch_and_long: SUCCESS
>>> -CPU2 _Atomic_Fetch_and_32: SUCCESS
>>> -CPU3 _Atomic_Fetch_and_ptr: SUCCESS
>>> -CPU1 _Atomic_Fetch_and_ptr: SUCCESS
>>> -CPU3 _Atomic_Fetch_and_32: SUCCESS
>>> -CPU1 _Atomic_Fetch_and_32: SUCCESS
>>> -*** END OF TEST SMPatomic05 ***
>>> diff --git a/testsuites/smptests/smpatomic05/system.h b/testsuites/smptests/smpatomic05/system.h
>>> --- a/testsuites/smptests/smpatomic05/system.h
>>> +++ /dev/null
>>> @@ -1,50 +0,0 @@
>>> -/* functions */
>>> -rtems_task Init(
>>> diff --git a/testsuites/smptests/smpatomic05/tasks.c b/testsuites/smptests/smpatomic05/tasks.c
>>> index cf41cc1..0000000
>>> --- a/testsuites/smptests/smpatomic05/tasks.c
>>> +++ /dev/null
>>> @@ -1,81 +0,0 @@
>>> -#endif
>>> -#define ATOMIC_FETCH_AND_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
>>> - R_TYPE a; \
>>> - R_TYPE b; \
>>> - R_TYPE c; \
>>> - unsigned int i; \
>>> - _Atomic_Fetch_and_##NAME(&t, b, mem_bar); \
>>> - rtems_test_assert(c == (R_TYPE)(a & b)); \
>>> - locked_printf("\nCPU%d Atomic_Fetch_and_" #NAME ": SUCCESS\n", cpuid); \
>>> - uint32_t cpu_num;
>>> - char name[5];
>>> - char *p;
>>> - ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>> - ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>> -// ATOMIC_FETCH_AND_NO_BARRIER(64, cpu_num);
>>> - while(1);
>>> diff --git a/testsuites/smptests/smpatomic06/Makefile.am b/testsuites/smptests/smpatomic06/Makefile.am
>>> index c3a0645..0000000
>>> --- a/testsuites/smptests/smpatomic06/Makefile.am
>>> +++ /dev/null
>>> @@ -1,20 +0,0 @@
>>> -rtems_tests_PROGRAMS = smpatomic06
>>> -smpatomic06_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>> -dist_rtems_tests_DATA = smpatomic06.scn
>>> -dist_rtems_tests_DATA += smpatomic06.doc
>>> -LINK_OBJS = $(smpatomic06_OBJECTS)
>>> -LINK_LIBS = $(smpatomic06_LDLIBS)
>>> -smpatomic06$(EXEEXT): $(smpatomic06_OBJECTS) $(smpatomic06_DEPENDENCIES)
>>> - @rm -f smpatomic06$(EXEEXT)
>>> - $(make-exe)
>>> diff --git a/testsuites/smptests/smpatomic06/init.c b/testsuites/smptests/smpatomic06/init.c
>>> index 06f1f61..0000000
>>> --- a/testsuites/smptests/smpatomic06/init.c
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> - * This test case is to test atomic or operation.
>>> -#endif
>>> -rtems_task Init(
>>> - int i;
>>> - char ch;
>>> - rtems_id id;
>>> - bool allDone;
>>> - locked_printf( "\n\n*** SMPatomic06 TEST ***\n" );
>>> - ch = '0' + i;
>>> - 1,
>>> - &id
>>> - while (1) {
>>> - allDone = true;
>>> - allDone = false;
>>> - if (allDone) {
>>> - locked_printf( "\n\n*** END OF TEST SMPatomic06 ***\n" );
>>> diff --git a/testsuites/smptests/smpatomic06/smpatomic06.doc b/testsuites/smptests/smpatomic06/smpatomic06.doc
>>> index 8c9e85f..0000000
>>> --- a/testsuites/smptests/smpatomic06/smpatomic06.doc
>>> +++ /dev/null
>>> @@ -1,23 +0,0 @@
>>> -test set name: smpatomic06
>>> -directives:
>>> - _Atomic_Fetch_or_int
>>> - _Atomic_Fetch_or_long
>>> - _Atomic_Fetch_or_ptr
>>> - _Atomic_Fetch_or_32
>>> - _Atomic_Fetch_or_64
>>> -concepts:
>>> -+ Ensure that the atomic or operations listed above behave as defined.
>>> diff --git a/testsuites/smptests/smpatomic06/smpatomic06.scn b/testsuites/smptests/smpatomic06/smpatomic06.scn
>>> index 70a606e..0000000
>>> --- a/testsuites/smptests/smpatomic06/smpatomic06.scn
>>> +++ /dev/null
>>> @@ -1,29 +0,0 @@
>>> -*** SMPatomic06 TEST ***
>>> -CPU2 _Atomic_Fetch_or_int: SUCCESS
>>> -CPU2 _Atomic_Fetch_or_long: SUCCESS
>>> -CPU3 _Atomic_Fetch_or_int: SUCCESS
>>> -CPU1 _Atomic_Fetch_or_int: SUCCESS
>>> -CPU2 _Atomic_Fetch_or_ptr: SUCCESS
>>> -CPU3 _Atomic_Fetch_or_long: SUCCESS
>>> -CPU2 _Atomic_Fetch_or_32: SUCCESS
>>> -CPU1 _Atomic_Fetch_or_long: SUCCESS
>>> -CPU3 _Atomic_Fetch_or_ptr: SUCCESS
>>> -CPU1 _Atomic_Fetch_or_ptr: SUCCESS
>>> -CPU3 _Atomic_Fetch_or_32: SUCCESS
>>> -CPU1 _Atomic_Fetch_or_32: SUCCESS
>>> -*** END OF TEST SMPatomic06 ***
>>> diff --git a/testsuites/smptests/smpatomic06/system.h b/testsuites/smptests/smpatomic06/system.h
>>> --- a/testsuites/smptests/smpatomic06/system.h
>>> +++ /dev/null
>>> @@ -1,50 +0,0 @@
>>> -/* functions */
>>> -rtems_task Init(
>>> diff --git a/testsuites/smptests/smpatomic06/tasks.c b/testsuites/smptests/smpatomic06/tasks.c
>>> index a0409c7..0000000
>>> --- a/testsuites/smptests/smpatomic06/tasks.c
>>> +++ /dev/null
>>> @@ -1,81 +0,0 @@
>>> -#endif
>>> -#define ATOMIC_FETCH_OR_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
>>> - R_TYPE a; \
>>> - R_TYPE b; \
>>> - R_TYPE c; \
>>> - unsigned int i; \
>>> - _Atomic_Fetch_or_##NAME(&t, b, mem_bar); \
>>> - rtems_test_assert(c == (R_TYPE)(a | b)); \
>>> - locked_printf("\nCPU%d Atomic_Fetch_or_" #NAME ": SUCCESS\n", cpuid); \
>>> - uint32_t cpu_num;
>>> - char name[5];
>>> - char *p;
>>> - ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>> - ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>> -// ATOMIC_FETCH_OR_NO_BARRIER(64, cpu_num);
>>> - while(1);
>>> diff --git a/testsuites/smptests/smpatomic07/Makefile.am b/testsuites/smptests/smpatomic07/Makefile.am
>>> index 5e623ea..0000000
>>> --- a/testsuites/smptests/smpatomic07/Makefile.am
>>> +++ /dev/null
>>> @@ -1,20 +0,0 @@
>>> -rtems_tests_PROGRAMS = smpatomic07
>>> -smpatomic07_SOURCES = init.c tasks.c system.h ../../support/src/locked_print.c
>>> -dist_rtems_tests_DATA = smpatomic07.scn
>>> -dist_rtems_tests_DATA += smpatomic07.doc
>>> -LINK_OBJS = $(smpatomic07_OBJECTS)
>>> -LINK_LIBS = $(smpatomic07_LDLIBS)
>>> -smpatomic07$(EXEEXT): $(smpatomic07_OBJECTS) $(smpatomic07_DEPENDENCIES)
>>> - @rm -f smpatomic07$(EXEEXT)
>>> - $(make-exe)
>>> diff --git a/testsuites/smptests/smpatomic07/init.c b/testsuites/smptests/smpatomic07/init.c
>>> index be9c216..0000000
>>> --- a/testsuites/smptests/smpatomic07/init.c
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> - * This test case is to test atomic compare and exchange operation.
>>> -#endif
>>> -rtems_task Init(
>>> - int i;
>>> - char ch;
>>> - rtems_id id;
>>> - bool allDone;
>>> - locked_printf( "\n\n*** SMPatomic07 TEST ***\n" );
>>> - ch = '0' + i;
>>> - 1,
>>> - &id
>>> - while (1) {
>>> - allDone = true;
>>> - allDone = false;
>>> - if (allDone) {
>>> - locked_printf( "\n\n*** END OF TEST SMPatomic07 ***\n" );
>>> diff --git a/testsuites/smptests/smpatomic07/smpatomic07.doc b/testsuites/smptests/smpatomic07/smpatomic07.doc
>>> index a931ad5..0000000
>>> --- a/testsuites/smptests/smpatomic07/smpatomic07.doc
>>> +++ /dev/null
>>> @@ -1,24 +0,0 @@
>>> -test set name: smpatomic07
>>> -directives:
>>> - _Atomic_Compare_exchange_int
>>> - _Atomic_Compare_exchange_long
>>> - _Atomic_Compare_exchange_ptr
>>> - _Atomic_Compare_exchange_32
>>> - _Atomic_Compare_exchange_64
>>> -concepts:
>>> -+ Ensure that the atomic compare and exchange operations listed above behave
>>> - as defined.
>>> diff --git a/testsuites/smptests/smpatomic07/smpatomic07.scn b/testsuites/smptests/smpatomic07/smpatomic07.scn
>>> index 800c4c5..0000000
>>> --- a/testsuites/smptests/smpatomic07/smpatomic07.scn
>>> +++ /dev/null
>>> @@ -1,29 +0,0 @@
>>> -*** SMPatomic07 TEST ***
>>> -CPU1 _Atomic_Compare_exchange_int: SUCCESS
>>> -CPU3 _Atomic_Compare_exchange_int: SUCCESS
>>> -CPU2 _Atomic_Compare_exchange_int: SUCCESS
>>> -CPU2 _Atomic_Compare_exchange_long: SUCCESS
>>> -CPU2 _Atomic_Compare_exchange_ptr: SUCCESS
>>> -CPU2 _Atomic_Compare_exchange_32: SUCCESS
>>> -CPU3 _Atomic_Compare_exchange_long: SUCCESS
>>> -CPU1 _Atomic_Compare_exchange_long: SUCCESS
>>> -CPU1 _Atomic_Compare_exchange_ptr: SUCCESS
>>> -CPU3 _Atomic_Compare_exchange_ptr: SUCCESS
>>> -CPU1 _Atomic_Compare_exchange_32: SUCCESS
>>> -CPU3 _Atomic_Compare_exchange_32: SUCCESS
>>> -*** END OF TEST SMPatomic07 ***
>>> diff --git a/testsuites/smptests/smpatomic07/system.h b/testsuites/smptests/smpatomic07/system.h
>>> --- a/testsuites/smptests/smpatomic07/system.h
>>> +++ /dev/null
>>> @@ -1,50 +0,0 @@
>>> -/* functions */
>>> -rtems_task Init(
>>> diff --git a/testsuites/smptests/smpatomic07/tasks.c b/testsuites/smptests/smpatomic07/tasks.c
>>> index 345439b..0000000
>>> --- a/testsuites/smptests/smpatomic07/tasks.c
>>> +++ /dev/null
>>> @@ -1,97 +0,0 @@
>>> -#endif
>>> -#define ATOMIC_CAS_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
>>> - R_TYPE a; \
>>> - R_TYPE b; \
>>> - unsigned int i; \
>>> - int r; \
>>> - a = rand() % (R_TYPE)-1; \
>>> - b = a + 1; \
>>> - r = _Atomic_Compare_exchange_##NAME(&t, &b, a - 1, mem_bar, memory_order_relaxed);\
>>> - if(r != 0){ \
>>> - locked_printf("\ntask%d: Atomic_Compare_exchange_" #NAME ": FAILED\n", (unsigned int)cpuid); \
>>> - rtems_test_exit( 0 ); \
>>> - r = _Atomic_Compare_exchange_##NAME(&t, &a, a - 1, mem_bar, memory_order_relaxed);\
>>> - b = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_ACQUIRE); \
>>> - if((r == 0) ||((r != 0) && ((a - 1) != b))){ \
>>> - b = a + 1; \
>>> - r = _Atomic_Compare_exchange_##NAME(&t, &b, a, mem_bar, memory_order_relaxed); \
>>> - if(r != 0){ \
>>> - locked_printf("\nCPU%d Atomic_Compare_exchange_" #NAME ": SUCCESS\n", cpuid); \
>>> - uint32_t cpu_num;
>>> - char name[5];
>>> - char *p;
>>> - ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
>>> - ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
>>> - ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
>>> - ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
>>> -// ATOMIC_CAS_NO_BARRIER(64, cpu_num);
>>> - while(1);
>>> rtems-vc mailing list
>>> rtems-vc at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-vc
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
