[PATCH 2/2] dosfs: Ensure initially the sector size is used as bdbuf block size
Ralf Kirchner
ralf.kirchner at embedded-brains.de
Fri Oct 18 07:37:26 UTC 2013
cpukit/libfs/src/dosfs/fat.c | 9 +++++++++
1 Datei geändert, 9 Zeilen hinzugefügt(+)
diff --git a/cpukit/libfs/src/dosfs/fat.c b/cpukit/libfs/src/dosfs/fat.c
index f81bc7b..92e81d3 100644
--- a/cpukit/libfs/src/dosfs/fat.c
+++ b/cpukit/libfs/src/dosfs/fat.c
@@ -544,6 +544,15 @@ fat_init_volume_info(fat_fs_info_t *fs_info, const char *device)
for (vol->sec_log2 = 0, i = vol->bps; (i & 1) == 0;
i >>= 1, vol->sec_log2++);
+ /* Assign the sector size as bdbuf block size for now.
+ * If possible the bdbuf block size will get increased to the cluster
+ * size at the end of this method for better performance */
+ sc = rtems_bdbuf_set_block_size (vol->dd, vol->bps, true);
+ if (sc != RTEMS_SUCCESSFUL)
+ close(vol->fd);
+ rtems_set_errno_and_return_minus_one( EINVAL );
vol->bytes_per_block = vol->bps;
vol->bytes_per_block_log2 = vol->sec_log2;
vol->sectors_per_block = 1;
1.7.10.4
