C++ static constructors and SMP
Chris Johns
chrisj at rtems.org
Wed Oct 23 19:29:31 UTC 2013
On 23/10/2013 10:31 pm, Joel Sherrill wrote:
> Is this a case of two threads running the init table or an application thread running and using a global object before running the init table is complete?
No just one thread as there is only 1 call to the code that manages the
Init table and so creates and starts the Init task(s). The secondary
core(s) are held waiting until all the initialisation of RTEMS is done
then enter the multitasking state.
The start multitasking call releases the secondary core(s) (1 core in
the case of the Zynq) and it enters the _Thread_Handler. We do not know
if this is the Init task or an idle thread. If the idle thread core
catches the ctor call it will head down that path. The primary core
returns from starting the secondary core(s) and enters _Thread_Dispatch
in the context of Init and continues to run it. If code in the Init uses
an object yet to be constructed you break.
> Constructor order is another problem but I didn't think that had anything to do with this case.
Agreed.
