[PATCH] network: Add help text for ifconfig
Ralf Kirchner
ralf.kirchner at embedded-brains.de
Wed Oct 30 15:48:17 UTC 2013
cpukit/libmisc/shell/main_ifconfig.c | 56 ++++++++++++++++++++++------------
1 Datei geändert, 37 Zeilen hinzugefügt(+), 19 Zeilen entfernt(-)
diff --git a/cpukit/libmisc/shell/main_ifconfig.c b/cpukit/libmisc/shell/main_ifconfig.c
index d81d8b0..ae79eec 100644
--- a/cpukit/libmisc/shell/main_ifconfig.c
+++ b/cpukit/libmisc/shell/main_ifconfig.c
@@ -27,6 +27,8 @@
#include <rtems/shell.h>
#include "internal.h"
+#define IFCONFIG_USAGE "Usage:\n[broadcast [<Address>]] [pointopoint [<Address>]]\n[netmask <Address>]\n[up|down] ...\n"
static int rtems_shell_main_ifconfig(
int argc,
char *argv[]
@@ -36,13 +38,14 @@ static int rtems_shell_main_ifconfig(
struct sockaddr_in dstaddr;
struct sockaddr_in netmask;
struct sockaddr_in broadcast;
- char *iface;
+ char *iface = NULL;
int f_ip = 0;
int f_ptp = 0;
int f_netmask = 0;
int f_up = 0;
int f_down = 0;
int f_bcast = 0;
+ int f_usage = 0;
int cur_idx;
int rc;
int flags;
@@ -70,16 +73,24 @@ static int rtems_shell_main_ifconfig(
iface = NULL;
cur_idx += 1;
} else {
- iface = argv[1];
- if (isdigit((unsigned char)*argv[2])) {
- if (inet_pton(AF_INET, argv[2], &ipaddr.sin_addr) < 0) {
- printf("bad ip address: %s\n", argv[2]);
- return 0;
- f_ip = 1;
- cur_idx += 3;
- } else {
+ if ( 0 == strcmp( "--help", argv[1] ) ) {
+ f_usage = 1;
cur_idx += 2;
+ } else if ( 0 == strcmp( "-help", argv[1] ) ) {
+ f_usage = 1;
+ cur_idx += 2;
+ } else {
+ iface = argv[1];
+ if (isdigit((unsigned char)*argv[2])) {
+ if (inet_pton(AF_INET, argv[2], &ipaddr.sin_addr) < 0) {
+ printf("bad ip address: %s\n", argv[2]);
+ return 0;
+ f_ip = 1;
+ cur_idx += 3;
+ } else {
+ cur_idx += 2;
@@ -169,14 +180,19 @@ static int rtems_shell_main_ifconfig(
printf("up\n");
} else if (f_down != 0) {
printf("down\n");
} else {
printf("\n");
+ } else if (f_usage != 0) {
+ printf ( "\n" );
+ printf ( IFCONFIG_USAGE );
- if ((iface == NULL) || ((f_ip == 0) && (f_down == 0) && (f_up == 0))) {
- rtems_bsdnet_show_if_stats();
- return 0;
+ if ( ! f_usage ) {
+ if ((iface == NULL) || ((f_ip == 0) && (f_down == 0) && (f_up == 0))) {
+ rtems_bsdnet_show_if_stats();
+ return 0;
flags = 0;
@@ -218,10 +234,12 @@ static int rtems_shell_main_ifconfig(
flags |= IFF_UP;
- rc = rtems_bsdnet_ifconfig(iface, SIOCSIFFLAGS, &flags);
- if (rc < 0) {
- printf("Could not set interface flags: %s\n", strerror(errno));
- return -1;
+ rc = rtems_bsdnet_ifconfig(iface, SIOCSIFFLAGS, &flags);
+ if (rc < 0) {
+ printf("Could not set interface flags: %s\n", strerror(errno));
+ return -1;
return 0;
@@ -229,7 +247,7 @@ static int rtems_shell_main_ifconfig(
rtems_shell_cmd_t rtems_shell_IFCONFIG_Command = {
"ifconfig", /* name */
- "TBD", /* usage */
+ IFCONFIG_USAGE, /* usage */
"network", /* topic */
rtems_shell_main_ifconfig, /* command */
NULL, /* alias */
1.7.10.4
