[PATCH 4/5] SMP01: possible CPU race when using byte arrays
Daniel Hellstrom
daniel at gaisler.com
Thu Oct 31 13:58:53 UTC 2013
Switch to using 32-bit variable that works better on a
32-bit CPU. This does not solve the general SMP case
though, would perhaps better to use an atomic set
here.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
testsuites/smptests/smp01/init.c | 6 +++---
testsuites/smptests/smp01/system.h | 2 +-
testsuites/smptests/smp01/tasks.c | 2 +-
3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/testsuites/smptests/smp01/init.c b/testsuites/smptests/smp01/init.c
index 3e12726..eadb26a 100644
--- a/testsuites/smptests/smp01/init.c
+++ b/testsuites/smptests/smp01/init.c
@@ -43,11 +43,11 @@ rtems_task Init(
locked_print_initialize();
/* Put start of test message */
- locked_printf( "\n\n*** SMP01 TEST ***\n" );
+ locked_printf( "\n\n*** SMP01 TEST %d ***\n", cpu_self );
/* Initialize the TaskRan array */
for ( i=0; i<rtems_smp_get_processor_count() ; i++ ) {
- TaskRan[i] = false;
+ TaskRan[i] = 0;
/* Create and start tasks for each processor */
@@ -77,7 +77,7 @@ rtems_task Init(
while (1) {
allDone = true;
- if ( i != cpu_self && TaskRan[i] == false)
+ if ( i != cpu_self && TaskRan[i] == 0)
allDone = false;
if (allDone) {
diff --git a/testsuites/smptests/smp01/system.h b/testsuites/smptests/smp01/system.h
index e360e37..5f2d5b7 100644
--- a/testsuites/smptests/smp01/system.h
+++ b/testsuites/smptests/smp01/system.h
@@ -42,7 +42,7 @@ rtems_task Test_task(
* Keep the names and IDs in global variables so another task can use them.
-TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
+TEST_EXTERN volatile int TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
void Loop( void );
diff --git a/testsuites/smptests/smp01/tasks.c b/testsuites/smptests/smp01/tasks.c
index 4eb81f1..7bd7cc4 100644
--- a/testsuites/smptests/smp01/tasks.c
+++ b/testsuites/smptests/smp01/tasks.c
@@ -35,7 +35,7 @@ rtems_task Test_task(
locked_printf(" CPU %" PRIu32 " running Task %s\n", cpu_num, name);
/* Set the flag that the task is up and running */
- TaskRan[cpu_num] = true;
+ TaskRan[cpu_num] = 1;
/* Drop into a loop which will keep this task on
1.7.0.4
