[PATCH 4/5] SMP01: possible CPU race when using byte arrays
    Gedare Bloom
    gedare at rtems.org
    Thu Oct 31 14:37:36 UTC 2013
On Thu, Oct 31, 2013 at 10:24 AM, Sebastian Huber
> On 2013-10-31 15:18, Daniel Hellstrom wrote:
>> Bool is char, a 4 CPU 8-bit variable array will crate a race, where CPU1
>> might
>> over write CPU2 and CPU3 task execution status. There is no atomic locking
>> of
>> the TaskRan array.
> In case they write to different memory locations, there is no data race
> under the C11 memory model.
Yes this is what I thought too. I assume the LEON uses an 8-bit store
(stb) for the variables. Maybe the problem comes from the cache? If
the cache line size is 32 bits then conflicting 8-bit stores to the
same cache line could cause a problem.
> rtems-devel mailing list
> rtems-devel at rtems.org
