[PATCH] score: Use unsigned long for atomic integers
Sebastian Huber
Mon Sep 2 13:11:46 UTC 2013
Use unsigned long instead of uint_fast32_t since C11 provides only a
ATOMIC_LONG_LOCK_FREE macro constant. This makes it also possible to
use properly typed integer literals like 123UL. It is now clear which
compatible type should be used for the atomic integer.
cpukit/score/include/rtems/score/atomic.h | 72 +++++++++++-----------
cpukit/score/include/rtems/score/cpustdatomic.h | 56 ++++++++--------
testsuites/smptests/smpatomic01/tasks.c | 4 +-
testsuites/smptests/smpatomic02/tasks.c | 4 +-
testsuites/smptests/smpatomic03/tasks.c | 6 +-
testsuites/smptests/smpatomic04/tasks.c | 6 +-
testsuites/smptests/smpatomic05/tasks.c | 6 +-
testsuites/smptests/smpatomic06/tasks.c | 6 +-
testsuites/smptests/smpatomic07/tasks.c | 6 +-
testsuites/smptests/smpatomic08/init.c | 78 +++++++++++-----------
10 files changed, 122 insertions(+), 122 deletions(-)
diff --git a/cpukit/score/include/rtems/score/atomic.h b/cpukit/score/include/rtems/score/atomic.h
index e085dea..b4e7a76 100644
--- a/cpukit/score/include/rtems/score/atomic.h
+++ b/cpukit/score/include/rtems/score/atomic.h
@@ -48,12 +48,12 @@ extern "C" {
* @param object an atomic type pointer of object.
* @param value a value to be stored into object.
-static inline void _Atomic_Init_uint(
- volatile Atomic_Uint *object,
- uint_fast32_t value
+static inline void _Atomic_Init_ulong(
+ volatile Atomic_Ulong *object,
+ unsigned long value
- _CPU_atomic_Init_uint(object, value);
+ _CPU_atomic_Init_ulong(object, value);
static inline void _Atomic_Init_ptr(
@@ -72,12 +72,12 @@ static inline void _Atomic_Init_ptr(
* The order shall not be ATOMIC_ORDER_RELEASE.
-static inline uint_fast32_t _Atomic_Load_uint(
+static inline unsigned long _Atomic_Load_ulong(
Atomic_Order order
- return _CPU_atomic_Load_uint( object, order );
+ return _CPU_atomic_Load_ulong( object, order );
static inline uintptr_t _Atomic_Load_ptr(
@@ -97,13 +97,13 @@ static inline uintptr_t _Atomic_Load_ptr(
* The order shall not be ATOMIC_ORDER_ACQUIRE.
-static inline void _Atomic_Store_uint(
- uint_fast32_t value,
+static inline void _Atomic_Store_ulong(
+ unsigned long value,
Atomic_Order order
- _CPU_atomic_Store_uint( object, value, order );
+ _CPU_atomic_Store_ulong( object, value, order );
static inline void _Atomic_Store_ptr(
@@ -124,13 +124,13 @@ static inline void _Atomic_Store_ptr(
* @retval a result value before add ops.
-static inline uint_fast32_t _Atomic_Fetch_add_uint(
+static inline unsigned long _Atomic_Fetch_add_ulong(
Atomic_Order order
- return _CPU_atomic_Fetch_add_uint( object, value, order );
+ return _CPU_atomic_Fetch_add_ulong( object, value, order );
static inline uintptr_t _Atomic_Fetch_add_ptr(
@@ -151,13 +151,13 @@ static inline uintptr_t _Atomic_Fetch_add_ptr(
* @retval a result value before sub ops.
-static inline uint_fast32_t _Atomic_Fetch_sub_uint(
+static inline unsigned long _Atomic_Fetch_sub_ulong(
Atomic_Order order
- return _CPU_atomic_Fetch_sub_uint( object, value, order );
+ return _CPU_atomic_Fetch_sub_ulong( object, value, order );
static inline uintptr_t _Atomic_Fetch_sub_ptr(
@@ -178,13 +178,13 @@ static inline uintptr_t _Atomic_Fetch_sub_ptr(
* @retval a result value before or ops.
-static inline uint_fast32_t _Atomic_Fetch_or_uint(
+static inline unsigned long _Atomic_Fetch_or_ulong(
Atomic_Order order
- return _CPU_atomic_Fetch_or_uint( object, value, order );
+ return _CPU_atomic_Fetch_or_ulong( object, value, order );
static inline uintptr_t _Atomic_Fetch_or_ptr(
@@ -205,13 +205,13 @@ static inline uintptr_t _Atomic_Fetch_or_ptr(
* @retval a result value before and ops.
-static inline uint_fast32_t _Atomic_Fetch_and_uint(
+static inline unsigned long _Atomic_Fetch_and_ulong(
Atomic_Order order
- return _CPU_atomic_Fetch_and_uint( object, value, order );
+ return _CPU_atomic_Fetch_and_ulong( object, value, order );
static inline uintptr_t _Atomic_Fetch_and_ptr(
@@ -232,13 +232,13 @@ static inline uintptr_t _Atomic_Fetch_and_ptr(
* @retval a result value before exchange ops.
-static inline uint_fast32_t _Atomic_Exchange_uint(
+static inline unsigned long _Atomic_Exchange_ulong(
Atomic_Order order
- return _CPU_atomic_Exchange_uint( object, value, order );
+ return _CPU_atomic_Exchange_ulong( object, value, order );
static inline uintptr_t _Atomic_Exchange_ptr(
@@ -264,15 +264,15 @@ static inline uintptr_t _Atomic_Exchange_ptr(
* @retval true if the compare exchange successully.
* @retval false if the compare exchange failed.
-static inline bool _Atomic_Compare_exchange_uint(
- uint_fast32_t *old_value,
- uint_fast32_t new_value,
+static inline bool _Atomic_Compare_exchange_ulong(
+ unsigned long *old_value,
+ unsigned long new_value,
Atomic_Order order_succ,
Atomic_Order order_fail
- return _CPU_atomic_Compare_exchange_uint( object, old_value, new_value,
+ return _CPU_atomic_Compare_exchange_ulong( object, old_value, new_value,
order_succ, order_fail );
diff --git a/cpukit/score/include/rtems/score/cpustdatomic.h b/cpukit/score/include/rtems/score/cpustdatomic.h
index 6ec5828..d5c2142 100644
--- a/cpukit/score/include/rtems/score/cpustdatomic.h
+++ b/cpukit/score/include/rtems/score/cpustdatomic.h
@@ -35,7 +35,7 @@ extern "C" {
* @brief atomic operation unsigned integer type
-typedef atomic_uint_fast32_t Atomic_Uint;
+typedef atomic_ulong Atomic_Ulong;
* @brief atomic operation unsigned integer the size of a pointer type
@@ -82,9 +82,9 @@ typedef enum {
-static inline void _CPU_atomic_Init_uint(
+static inline void _CPU_atomic_Init_ulong(
atomic_init(object, value);
@@ -106,8 +106,8 @@ static inline void _CPU_atomic_Init_ptr(
-static inline uint_fast32_t _CPU_atomic_Load_uint(
+static inline unsigned long _CPU_atomic_Load_ulong(
Atomic_Order order
@@ -131,9 +131,9 @@ static inline uintptr_t _CPU_atomic_Load_ptr(
-static inline void _CPU_atomic_Store_uint(
+static inline void _CPU_atomic_Store_ulong(
Atomic_Order order
@@ -158,9 +158,9 @@ static inline void _CPU_atomic_Store_ptr(
-static inline uint_fast32_t _CPU_atomic_Fetch_add_uint(
+static inline unsigned long _CPU_atomic_Fetch_add_ulong(
Atomic_Order order
@@ -185,9 +185,9 @@ static inline uintptr_t _CPU_atomic_Fetch_add_ptr(
-static inline uint_fast32_t _CPU_atomic_Fetch_sub_uint(
+static inline unsigned long _CPU_atomic_Fetch_sub_ulong(
Atomic_Order order
@@ -212,9 +212,9 @@ static inline uintptr_t _CPU_atomic_Fetch_sub_ptr(
-static inline uint_fast32_t _CPU_atomic_Fetch_or_uint(
+static inline unsigned long _CPU_atomic_Fetch_or_ulong(
Atomic_Order order
@@ -239,9 +239,9 @@ static inline uintptr_t _CPU_atomic_Fetch_or_ptr(
-static inline uint_fast32_t _CPU_atomic_Fetch_and_uint(
+static inline unsigned long _CPU_atomic_Fetch_and_ulong(
Atomic_Order order
@@ -266,9 +266,9 @@ static inline uintptr_t _CPU_atomic_Fetch_and_ptr(
-static inline uint_fast32_t _CPU_atomic_Exchange_uint(
+static inline unsigned long _CPU_atomic_Exchange_ulong(
Atomic_Order order
@@ -298,10 +298,10 @@ static inline uintptr_t _CPU_atomic_Exchange_ptr(
-static inline bool _CPU_atomic_Compare_exchange_uint(
+static inline bool _CPU_atomic_Compare_exchange_ulong(
diff --git a/testsuites/smptests/smpatomic01/tasks.c b/testsuites/smptests/smpatomic01/tasks.c
index 65ad81b..4dd2ff6 100644
--- a/testsuites/smptests/smpatomic01/tasks.c
+++ b/testsuites/smptests/smpatomic01/tasks.c
@@ -52,12 +52,12 @@ rtems_task Test_task(
/* Print that the task is up and running. */
/* test relaxed barrier */
- ATOMIC_LOAD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
+ ATOMIC_LOAD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
/* test acquire barrier */
- ATOMIC_LOAD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
+ ATOMIC_LOAD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
diff --git a/testsuites/smptests/smpatomic02/tasks.c b/testsuites/smptests/smpatomic02/tasks.c
index 22de08c..c5c9ba5 100644
--- a/testsuites/smptests/smpatomic02/tasks.c
+++ b/testsuites/smptests/smpatomic02/tasks.c
- ATOMIC_STORE_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
+ ATOMIC_STORE_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
/* test release barrier */
- ATOMIC_STORE_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
+ ATOMIC_STORE_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
diff --git a/testsuites/smptests/smpatomic03/tasks.c b/testsuites/smptests/smpatomic03/tasks.c
index 2c45a00..5010549 100644
--- a/testsuites/smptests/smpatomic03/tasks.c
+++ b/testsuites/smptests/smpatomic03/tasks.c
@@ -55,17 +55,17 @@ rtems_task Test_task(
- ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
+ ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
+ ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
+ ATOMIC_FETCH_ADD_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
diff --git a/testsuites/smptests/smpatomic04/tasks.c b/testsuites/smptests/smpatomic04/tasks.c
index 3630eb2..18632cd 100644
--- a/testsuites/smptests/smpatomic04/tasks.c
+++ b/testsuites/smptests/smpatomic04/tasks.c
- ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
+ ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
+ ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
+ ATOMIC_FETCH_SUB_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
diff --git a/testsuites/smptests/smpatomic05/tasks.c b/testsuites/smptests/smpatomic05/tasks.c
index 5e7da77..cf41cc1 100644
--- a/testsuites/smptests/smpatomic05/tasks.c
+++ b/testsuites/smptests/smpatomic05/tasks.c
- ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
+ ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
+ ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
+ ATOMIC_FETCH_AND_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
diff --git a/testsuites/smptests/smpatomic06/tasks.c b/testsuites/smptests/smpatomic06/tasks.c
index 772d745..a0409c7 100644
--- a/testsuites/smptests/smpatomic06/tasks.c
+++ b/testsuites/smptests/smpatomic06/tasks.c
- ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
+ ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
+ ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
+ ATOMIC_FETCH_OR_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
diff --git a/testsuites/smptests/smpatomic07/tasks.c b/testsuites/smptests/smpatomic07/tasks.c
index ab1b51c..345439b 100644
--- a/testsuites/smptests/smpatomic07/tasks.c
+++ b/testsuites/smptests/smpatomic07/tasks.c
@@ -71,17 +71,17 @@ rtems_task Test_task(
- ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
+ ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELAXED);
ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
+ ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
+ ATOMIC_CAS_NO_BARRIER(ulong, Ulong, unsigned long, cpu_num, ATOMIC_ORDER_RELEASE);
ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
diff --git a/testsuites/smptests/smpatomic08/init.c b/testsuites/smptests/smpatomic08/init.c
index 031f7c9..5e6b648 100644
--- a/testsuites/smptests/smpatomic08/init.c
+++ b/testsuites/smptests/smpatomic08/init.c
@@ -24,12 +24,12 @@
/* FIXME: Add barrier to Score */
typedef struct {
- Atomic_Uint value;
- Atomic_Uint sense;
+ Atomic_Ulong value;
+ Atomic_Ulong sense;
} SMP_barrier_Control;
typedef struct {
- uint_fast32_t sense;
+ unsigned long sense;
} SMP_barrier_State;
#define SMP_BARRIER_CONTROL_INITIALIZER \
@@ -40,26 +40,26 @@ typedef struct {
static void _SMP_barrier_Wait(
SMP_barrier_Control *control,
SMP_barrier_State *state,
- uint_fast32_t count
+ unsigned long count
- uint_fast32_t sense = ~state->sense;
- uint_fast32_t previous_value;
+ unsigned long sense = ~state->sense;
+ unsigned long previous_value;
state->sense = sense;
- previous_value = _Atomic_Fetch_add_uint(
+ previous_value = _Atomic_Fetch_add_ulong(
&control->value,
1,
if ( previous_value + 1 == count ) {
- _Atomic_Store_uint( &control->value, 0, ATOMIC_ORDER_RELAXED );
- _Atomic_Store_uint( &control->sense, sense, ATOMIC_ORDER_RELEASE );
+ _Atomic_Store_ulong( &control->value, 0, ATOMIC_ORDER_RELAXED );
+ _Atomic_Store_ulong( &control->sense, sense, ATOMIC_ORDER_RELEASE );
} else {
while (
- _Atomic_Load_uint( &control->sense, ATOMIC_ORDER_ACQUIRE ) != sense
+ _Atomic_Load_ulong( &control->sense, ATOMIC_ORDER_ACQUIRE ) != sense
/* Wait */
@@ -73,13 +73,13 @@ static void _SMP_barrier_Wait(
#define CPU_COUNT 32
typedef struct {
- Atomic_Uint stop;
+ Atomic_Ulong stop;
SMP_barrier_Control barrier;
size_t worker_count;
rtems_id stop_worker_timer_id;
- Atomic_Uint atomic_value;
- uint_fast32_t per_worker_value[CPU_COUNT];
- uint32_t normal_value;
+ Atomic_Ulong atomic_value;
+ unsigned long per_worker_value[CPU_COUNT];
+ unsigned long normal_value;
Atomic_Flag global_flag;
} test_context;
@@ -96,7 +96,7 @@ static test_context test_instance = {
static bool stop(test_context *ctx)
- return _Atomic_Load_uint(&ctx->stop, ATOMIC_ORDER_RELAXED) != 0;
+ return _Atomic_Load_ulong(&ctx->stop, ATOMIC_ORDER_RELAXED) != 0;
static bool is_master_worker(size_t worker_index)
@@ -110,14 +110,14 @@ static void test_fini(
bool atomic
- uint_fast32_t expected_value = 0;
- uint_fast32_t actual_value;
+ unsigned long expected_value = 0;
+ unsigned long actual_value;
size_t worker_index;
printf("=== atomic %s test case ==\n", test);
for (worker_index = 0; worker_index < ctx->worker_count; ++worker_index) {
- uint_fast32_t worker_value = ctx->per_worker_value[worker_index];
+ unsigned long worker_value = ctx->per_worker_value[worker_index];
expected_value += worker_value;
@@ -129,7 +129,7 @@ static void test_fini(
if (atomic) {
- actual_value = _Atomic_Load_uint(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
+ actual_value = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
} else {
actual_value = ctx->normal_value;
@@ -145,16 +145,16 @@ static void test_fini(
static void test_atomic_add_init(test_context *ctx)
- _Atomic_Init_uint(&ctx->atomic_value, 0);
+ _Atomic_Init_ulong(&ctx->atomic_value, 0);
static void test_atomic_add_body(test_context *ctx, size_t worker_index)
- uint_fast32_t counter = 0;
+ unsigned long counter = 0;
while (!stop(ctx)) {
++counter;
- _Atomic_Fetch_add_uint(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
+ _Atomic_Fetch_add_ulong(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
ctx->per_worker_value[worker_index] = counter;
@@ -173,7 +173,7 @@ static void test_atomic_flag_init(test_context *ctx)
static void test_atomic_flag_body(test_context *ctx, size_t worker_index)
while (_Atomic_Flag_test_and_set(&ctx->global_flag, ATOMIC_ORDER_ACQUIRE)) {
@@ -196,16 +196,16 @@ static void test_atomic_flag_fini(test_context *ctx)
static void test_atomic_sub_init(test_context *ctx)
static void test_atomic_sub_body(test_context *ctx, size_t worker_index)
--counter;
- _Atomic_Fetch_sub_uint(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
+ _Atomic_Fetch_sub_ulong(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
@@ -218,21 +218,21 @@ static void test_atomic_sub_fini(test_context *ctx)
static void test_atomic_compare_exchange_init(test_context *ctx)
ctx->normal_value = 0;
static void test_atomic_compare_exchange_body(test_context *ctx, size_t worker_index)
bool success;
do {
- uint_fast32_t zero = 0;
+ unsigned long zero = 0;
- success = _Atomic_Compare_exchange_uint(
+ success = _Atomic_Compare_exchange_ulong(
&ctx->atomic_value,
&zero,
1,
@@ -244,7 +244,7 @@ static void test_atomic_compare_exchange_body(test_context *ctx, size_t worker_i
++counter;
++ctx->normal_value;
- _Atomic_Store_uint(&ctx->atomic_value, 0, ATOMIC_ORDER_RELEASE);
+ _Atomic_Store_ulong(&ctx->atomic_value, 0, ATOMIC_ORDER_RELEASE);
@@ -257,26 +257,26 @@ static void test_atomic_compare_exchange_fini(test_context *ctx)
static void test_atomic_or_and_init(test_context *ctx)
static void test_atomic_or_and_body(test_context *ctx, size_t worker_index)
- uint_fast32_t the_bit = 1UL << worker_index;
- uint_fast32_t current_bit = 0;
+ unsigned long the_bit = 1UL << worker_index;
+ unsigned long current_bit = 0;
- uint_fast32_t previous;
+ unsigned long previous;
if (current_bit != 0) {
- previous = _Atomic_Fetch_and_uint(
+ previous = _Atomic_Fetch_and_ulong(
&ctx->atomic_value,
~the_bit,
current_bit = 0;
} else {
- previous = _Atomic_Fetch_or_uint(
+ previous = _Atomic_Fetch_or_ulong(
&ctx->atomic_value,
the_bit,
@@ -325,14 +325,14 @@ static void stop_worker_timer(rtems_id timer_id, void *arg)
test_context *ctx = arg;
- _Atomic_Store_uint(&ctx->stop, 1, ATOMIC_ORDER_RELAXED);
+ _Atomic_Store_ulong(&ctx->stop, 1, ATOMIC_ORDER_RELAXED);
static void start_worker_stop_timer(test_context *ctx)
rtems_status_code sc;
- _Atomic_Store_uint(&ctx->stop, 0, ATOMIC_ORDER_RELEASE);
+ _Atomic_Store_ulong(&ctx->stop, 0, ATOMIC_ORDER_RELEASE);
sc = rtems_timer_fire_after(
ctx->stop_worker_timer_id,
1.7.7
