[PATCH] dosfs: Unsigned compared against 0
Thu Sep 5 17:50:04 UTC 2013
On Thu, Sep 5, 2013 at 1:31 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Gedare.. are these from Coverity Scan? They seem
> remarkably picky otherwise. :)
Yes. I have some time to kill while I'm running some simulations.
> If they are, ask when you want another run submitted.
Will do. The patches need to be approved and committed first.
> --joel
> On 9/5/2013 12:10 PM, Gedare Bloom wrote:
>> Fix the type of "cmpltd" to be ssize_t so that assigning it to -1
>> will terminate processing as intended.
>>   cpukit/libfs/src/dosfs/msdos_dir.c |    2 +-
>>   1 files changed, 1 insertions(+), 1 deletions(-)
>> diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c
>> b/cpukit/libfs/src/dosfs/msdos_dir.c
>> index 253203c..d7f6823 100644
>> --- a/cpukit/libfs/src/dosfs/msdos_dir.c
>> +++ b/cpukit/libfs/src/dosfs/msdos_dir.c
>> @@ -78,7 +78,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t
>> count)
>>       const size_t       buf_size = converter->buffer.size;
>>       uint32_t           start = 0;
>>       ssize_t            ret = 0;
>> -    uint32_t           cmpltd = 0;
>> +    ssize_t            cmpltd = 0;
>>       uint32_t           j = 0, i = 0;
>>       uint32_t           bts2rd = 0;
>>       uint32_t           cur_cln = 0;
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
