[PATCH] sparse-disk: check return value from semaphore_obtain/release
Gedare Bloom
gedare at rtems.org
Thu Sep 5 18:22:31 UTC 2013
In case obtain/release is unsuccessful, cause a fatal error.
cpukit/libblock/src/sparse-disk.c | 11 +++++++++--
1 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/cpukit/libblock/src/sparse-disk.c b/cpukit/libblock/src/sparse-disk.c
index 987ab6d..ab6a25d 100644
--- a/cpukit/libblock/src/sparse-disk.c
+++ b/cpukit/libblock/src/sparse-disk.c
@@ -236,8 +236,12 @@ static int sparse_disk_read_write(
uint8_t *buff;
size_t buff_size;
unsigned int bytes_handled;
+ rtems_status_code sc;
- rtems_semaphore_obtain( sparse_disk->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
+ sc = rtems_semaphore_obtain(sparse_disk->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+ if (sc != RTEMS_SUCCESSFUL) {
+ rtems_fatal_error_occurred( 0xdeadbeef );
for ( req_buffer = 0;
( 0 <= rv ) && ( req_buffer < req->bufnum );
@@ -267,7 +271,10 @@ static int sparse_disk_read_write(
- rtems_semaphore_release( sparse_disk->mutex );
+ sc = rtems_semaphore_release( sparse_disk->mutex );
if ( 0 > rv )
rtems_blkdev_request_done( req, RTEMS_IO_ERROR );
1.7.1
