[PATCH] sparse-disk: check return value from semaphore_obtain/release
Thu Sep 5 18:43:41 UTC 2013
Sebastian may want to comment on whether we should
use 0xdeadbeef or some other unique code. He has worked
hard on the BSP fatal errors to be unique and (I suspect)
he will have a comment on this.
On 9/5/2013 1:22 PM, Gedare Bloom wrote:
> In case obtain/release is unsuccessful, cause a fatal error.
>   cpukit/libblock/src/sparse-disk.c |   11 +++++++++--
>   1 files changed, 9 insertions(+), 2 deletions(-)
> diff --git a/cpukit/libblock/src/sparse-disk.c b/cpukit/libblock/src/sparse-disk.c
> index 987ab6d..ab6a25d 100644
> --- a/cpukit/libblock/src/sparse-disk.c
> +++ b/cpukit/libblock/src/sparse-disk.c
> @@ -236,8 +236,12 @@ static int sparse_disk_read_write(
>     uint8_t                *buff;
>     size_t                  buff_size;
>     unsigned int            bytes_handled;
> +  rtems_status_code       sc;
> -  rtems_semaphore_obtain( sparse_disk->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
> +  sc = rtems_semaphore_obtain(sparse_disk->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
> +  if (sc != RTEMS_SUCCESSFUL) {
> +      rtems_fatal_error_occurred( 0xdeadbeef );
>     for ( req_buffer = 0;
>           ( 0 <= rv ) && ( req_buffer < req->bufnum );
> @@ -267,7 +271,10 @@ static int sparse_disk_read_write(
> -  rtems_semaphore_release( sparse_disk->mutex );
> +  sc = rtems_semaphore_release( sparse_disk->mutex );
>     if ( 0 > rv )
>       rtems_blkdev_request_done( req, RTEMS_IO_ERROR );
