[PATCH] imfs: use safe string functions
Gedare Bloom
gedare at rtems.org
Thu Sep 5 18:45:03 UTC 2013
Replace strcpy and strcat with counted variants.
cpukit/libfs/src/imfs/imfs_load_tar.c | 8 +++++---
1 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/cpukit/libfs/src/imfs/imfs_load_tar.c b/cpukit/libfs/src/imfs/imfs_load_tar.c
index abb9f46..fd47ec2 100644
--- a/cpukit/libfs/src/imfs/imfs_load_tar.c
+++ b/cpukit/libfs/src/imfs/imfs_load_tar.c
@@ -100,10 +100,12 @@ int rtems_tarfs_load(
* - For files, create a file node with special tarfs properties.
if (linkflag == DIRTYPE) {
- strcpy(full_filename, mountpoint);
- if (full_filename[strlen(full_filename)-1] != '/')
+ int len;
+ strncpy(full_filename, mountpoint, 255);
+ if (full_filename[(len=strlen(full_filename))-1] != '/')
strcat(full_filename, "/");
- strcat(full_filename, filename);
+ ++len;
+ strncat(full_filename, filename, 256-len-1);
rv = mkdir(full_filename, S_IRWXU | S_IRWXG | S_IRWXO);
1.7.1
