[PATCH] Colon in module path fix
Fri Sep 6 02:56:42 UTC 2013
Mohammed Khoory wrote:
> This patch fixes an issue in the RTL target code that occurs when trying to
> load a RAP/ELF module that is located in a directory which has a colon in
> it.
Looks fine to me. Thanks.
> Note: I based this commit off Peng Fan's repository.
Peng, please add your repo and I will pull it in and push with your changes.
