[PATCH] sparse-disk: check return value from semaphore_obtain/release
Fri Sep 6 07:43:14 UTC 2013
On 2013-09-05 20:43, Joel Sherrill wrote:
> Sebastian may want to comment on whether we should
> use 0xdeadbeef or some other unique code. He has worked
> hard on the BSP fatal errors to be unique and (I suspect)
> he will have a comment on this.
The sparse disk is only a test utility so its not worth the effort.  For the
Termios specific fatal errors would be nice.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
