Patch: Rework of Device Driver Configuration
Tue Sep 10 06:40:16 UTC 2013
On 2013-09-09 21:30, Joel Sherrill wrote:
> + * The CONFIGURE_MAXIMUM_DRIVERS parameter is obsolete.
> + * Users should use the CONFIGURE_MAXIMUM_DYNAMIC_DRIVERS
> + * to specify the number of dynamically installed drivers.
> +#ifdef CONFIGURE_MAXIMUM_DRIVERS
> +  #error "CONFIGURE_MAXIMUM_DRIVERS is obsolete. Use CONFIGURE_MAXIMUM_DYNAMIC_DRIVERS instead"
> +#endif
I wouldn't break all existing configurations this way.  I think its only an
error if the application defines CONFIGURE_MAXIMUM_DRIVERS and
CONFIGURE_MAXIMUM_DYNAMIC_DRIVERS at once.  It is also an error if
CONFIGURE_MAXIMUM_DRIVERS < CONFIGURE_NUMBER_OF_STATIC_DRIVERS.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
