[PATCH 1/6] libmm-score-api. The high-level libmm API should be used by applications. It helps developers to manage memory by setting generic and target-independent protection and cache attributes for a region that has a start address, length, and desired memory attributes.
Hesham AL-Matary
heshamelmatary at gmail.com
Thu Sep 12 06:59:28 UTC 2013
cpukit/score/Makefile.am | 2 +
cpukit/score/include/rtems/score/mm.h | 60 ++++++++++++++++++++++++
cpukit/score/include/rtems/score/mmimpl.h | 77 +++++++++++++++++++++++++++++++
cpukit/score/preinstall.am | 8 ++++
4 files changed, 147 insertions(+)
create mode 100644 cpukit/score/include/rtems/score/mm.h
create mode 100644 cpukit/score/include/rtems/score/mmimpl.h
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index c9d2d47..b94af80 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -37,6 +37,8 @@ include_rtems_score_HEADERS += include/rtems/score/interr.h
include_rtems_score_HEADERS += include/rtems/score/isr.h
include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
include_rtems_score_HEADERS += include/rtems/score/isrlock.h
+include_rtems_score_HEADERS += include/rtems/score/mm.h
+include_rtems_score_HEADERS += include/rtems/score/mmimpl.h
include_rtems_score_HEADERS += include/rtems/score/freechain.h
include_rtems_score_HEADERS += include/rtems/score/object.h
include_rtems_score_HEADERS += include/rtems/score/objectimpl.h
diff --git a/cpukit/score/include/rtems/score/mm.h b/cpukit/score/include/rtems/score/mm.h
new file mode 100644
index 0000000..5b1bdde
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mm.h
@@ -0,0 +1,60 @@
+ * @file
+ * @brief Manages use of MPU/MMU units to provide memory management.
+ * Copyright (c) 2013 Hesham Al-Matary.
+ * Copyright (c) 2013 Gedare Bloom.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_SCORE_MM_H
+#define _RTEMS_SCORE_MM_H
+#include <stdlib.h>
+/* @defgroup SuperCoreMM Memory Management Support
+ * @ingroup Score
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief _Memory_management_Region Flags defs
+#define RTEMS_MM_REGION_BIT_READ 0
+#define RTEMS_MM_REGION_BIT_WRITE 1
+#define RTEMS_MM_REGION_BIT_EXECUTE 2
+#define RTEMS_MM_REGION_BIT_CACHE 3
+#define RTEMS_MM_REGION_BIT_DEVICE 4
+#define RTEMS_MM_REGION_BIT_SHARED 5
+#define RTEMS_MM_REGION_READ (1U << RTEMS_MM_REGION_BIT_READ)
+#define RTEMS_MM_REGION_WRITE (1U << RTEMS_MM_REGION_BIT_WRITE)
+#define RTEMS_MM_REGION_EXECUTE (1U << RTEMS_MM_REGION_BIT_EXECUTE)
+#define RTEMS_MM_REGION_CACHE (1U << RTEMS_MM_REGION_BIT_CACHE)
+#define RTEMS_MM_REGION_DEVICE (1U << RTEMS_MM_REGION_BIT_DEVICE)
+#define RTEMS_MM_REGION_SHARED (1U << RTEMS_MM_REGION_BIT_SHARED)
+void _Memory_management_Set_attributes(
+ uintptr_t base,
+ size_t size,
+ uint32_t attr
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/include/rtems/score/mmimpl.h b/cpukit/score/include/rtems/score/mmimpl.h
index 0000000..a306a1e
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mmimpl.h
@@ -0,0 +1,77 @@
+ * @file
+ * @brief Inlined Routines from the Memory Management Manager
+ * Copyright (c) 2013 Hesham AL-Matary
+#ifndef _RTEMS_SCORE_MMIMPL_H
+#define _RTEMS_SCORE_MMIMPL_H
+#ifdef RTEMS_SMP
+#include <rtems/score/smplock.h>
+#endif
+#include <stdint.h>
+#include <rtems/score/mm.h>
+#include <bsp/mm.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup SuperCoreMM
+#ifdef RTEMS_SMP
+static SMP_lock_Control mm_lock;
+#endif
+static inline void libmm_smp_lock_obtain( void )
+#ifdef RTEMS_SMP
+ _SMP_lock_Acquire( &mm_lock );
+#endif
+static inline void libmm_smp_lock_release( void )
+#ifdef RTEMS_SMP
+ _SMP_lock_Release ( &mm_lock );
+#endif
+ * @brief Calls bsp_memory_management_set_attributes.
+ uintptr_t base,
+ size_t size,
+ uint32_t attr
+ libmm_smp_lock_obtain();
+ bsp_memory_management_set_attributes(base, size, attr);
+ libmm_smp_lock_release();
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 79a18b5..4b3bfcf 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -131,6 +131,14 @@ $(PROJECT_INCLUDE)/rtems/score/isrlock.h: include/rtems/score/isrlock.h $(PROJEC
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isrlock.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isrlock.h
+$(PROJECT_INCLUDE)/rtems/score/mm.h: include/rtems/score/mm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.h
+$(PROJECT_INCLUDE)/rtems/score/mmimpl.h: include/rtems/score/mmimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mmimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mmimpl.h
$(PROJECT_INCLUDE)/rtems/score/freechain.h: include/rtems/score/freechain.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/freechain.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/freechain.h
1.8.3.1
