[PATCH 4/6] libmm-libbsp-arm-shared. libmm low-level implementation that can be shared between many ARM targets. mminit.c contains initialization function for arm-cp15 and setup page tables. After that it enables MMU and Cache unit part of BSP initialization process. mm.c translates attributes from high-level to CPU specific attributes and apply them dynamically.
Thu Sep 12 13:01:37 UTC 2013
On Thu, Sep 12, 2013 at 2:59 AM, Hesham AL-Matary
<heshamelmatary at gmail.com> wrote:
>  .../lib/libbsp/arm/shared/include/arm-cp15-start.h | 11 ++++--
>  c/src/lib/libbsp/arm/shared/mm.c                   | 46 ++++++++++++++++++++++
>  c/src/lib/libbsp/arm/shared/mminit.c               | 27 +++++++++++++
>  3 files changed, 80 insertions(+), 4 deletions(-)
>  create mode 100644 c/src/lib/libbsp/arm/shared/mm.c
>  create mode 100644 c/src/lib/libbsp/arm/shared/mminit.c
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> index 01f3104..b463b1f 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> @@ -1,4 +1,5 @@
> + * Copyright (c) 2013 Hesham AL-Matary.
>   * Copyright (c) 2009-2013 embedded brains GmbH.  All rights reserved.
>   *  embedded brains GmbH
> @@ -89,7 +90,7 @@ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>    /* Initialize translation table with invalid entries */
Fix this comment (assuming the change below now populates the ttb with
valid entries).
>    for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
> -    ttb [i] = 0;
> +    ttb [i] = (i << ARM_MMU_SECT_BASE_SHIFT) | ARMV7_MMU_DATA_READ_WRITE;
>    for (i = 0; i < config_count; ++i) {
> @@ -97,11 +98,13 @@ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>    /* Enable MMU and cache */
> -  ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
> +  ctrl |= ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_S | ARM_CP15_CTRL_I |
> +          ARM_CP15_CTRL_C | ARM_CP15_CTRL_M  | ARM_CP15_CTRL_XP;
>    arm_cp15_set_control(ctrl);
> -BSP_START_TEXT_SECTION static inline uint32_t
> +BSP_START_TEXT_SECTION inline uint32_t
undo this change.
>  arm_cp15_start_setup_mmu_and_cache(uint32_t ctrl_clear, uint32_t ctrl_set)
>    uint32_t ctrl = arm_cp15_get_control();
> diff --git a/c/src/lib/libbsp/arm/shared/mm.c b/c/src/lib/libbsp/arm/shared/mm.c
> new file mode 100644
> index 0000000..36e90be
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/shared/mm.c
> @@ -0,0 +1,46 @@
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#include <bsp/mm.h>
> +#include <libcpu/arm-cp15.h>
> +#include <rtems/score/mm.h>
> +#define LIBMM_REGION_IS_CACHE_ENABLED(attr) \
> +  (((attr) >> RTEMS_MM_REGION_BIT_CACHE) & 1U)
> +#define LIBMM_REGION_IS_PROTECTION_WRITE_ENABLED(attr) \
> +  (((attr) >> RTEMS_MM_REGION_BIT_WRITE) & 1U)
> +#define LIBMM_REGION_IS_DEVICE_TYPE(attr) \
> +  (((attr) >> RTEMS_MM_REGION_BIT_DEVICE) & 1U)
> +#define LIBMM_REGION_IS_SHARED_MEMORY(attr) \
> +  (((attr) >> RTEMS_MM_REGION_BIT_SHARED) & 1U)
Should these macros be provided by the score/mm.h?
> +#define ARM_MMU_BIND_SECTION_TO_CLIENT_DOMAIN \
> +  (ARM_MMU_DEFAULT_CLIENT_DOMAIN << ARM_MMU_SECT_DOMAIN_SHIFT)
> +#define LIBMM_TRANSLATE_ATTRIBUTES_TO_CPU(attr) \
> +  ((ARM_MMU_BIND_SECTION_TO_CLIENT_DOMAIN) \
> +  | (ARM_MMU_SECT_AP_0) \
> +  | (LIBMM_REGION_IS_PROTECTION_WRITE_ENABLED(attr) ? \
> +  0U : (ARM_MMU_SECT_AP_2)) \
> +  | (LIBMM_REGION_IS_CACHE_ENABLED(attr) ? \
> +  (ARM_MMU_SECT_TEX_0|ARM_MMU_SECT_C|ARM_MMU_SECT_B) : 0U) \
> +  | (LIBMM_REGION_IS_DEVICE_TYPE(attr) ? ARM_MMU_SECT_B : 0U) \
> +  | (LIBMM_REGION_IS_SHARED_MEMORY(attr) ? ARM_MMU_SECT_S : 0U) \
> +  | (ARM_MMU_SECT_DEFAULT))
This macro could properly be named something simpler since it is local
to this .c file.
> +void bsp_memory_management_set_attributes(
> +  uintptr_t base,
> +  size_t size,
> +  uint32_t attr
> +  uintptr_t end = (uint32_t)base + (uint32_t)size;
Don't cast base and size here.
> +  uint32_t section_flags = LIBMM_TRANSLATE_ATTRIBUTES_TO_CPU(attr);
> +  arm_cp15_set_translation_table_entries(base, end, section_flags);
> diff --git a/c/src/lib/libbsp/arm/shared/mminit.c b/c/src/lib/libbsp/arm/shared/mminit.c
> index 0000000..333d65c
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/shared/mminit.c
> @@ -0,0 +1,27 @@
> +#include <bsp/arm-cp15-start.h>
> +#include <bsp/linker-symbols.h>
> +#include <bsp/start.h>
> +extern const mm_init_start_config bsp_mm_config_table[];
> +extern const size_t bsp_mm_config_table_size;
> +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
> +  uint32_t ctrl = arm_cp15_get_control();
> +  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> +  ctrl,
> +  (uint32_t *) bsp_translation_table_base,
> +  ARM_MMU_DEFAULT_CLIENT_DOMAIN,
> +  &bsp_mm_config_table[0],
> +  bsp_mm_config_table_size
Fix indentation level of nested lines of arguments. Also, this
mminit.c file does not make sense until you add at least one of the
ARM bsps using it.
> 1.8.3.1
> rtems-devel mailing list
> rtems-devel at rtems.org
