[PATCH 3/6] libmm-libbsp-shared. Files shared between all target BSPs and low-level implementations for libmm. These shared files contain mm.h which is a link between high-level score api and low-level implemenation of libmm. mm.h contains function declarations which should be implemented by target BSP to support libmm. no_memorymanagement.c contains stubs for BSPs that do not support libmm.
Hesham Moustafa
heshamelmatary at gmail.com
Thu Sep 12 18:00:34 UTC 2013
On Thu, Sep 12, 2013 at 2:55 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Sep 12, 2013 at 2:59 AM, Hesham AL-Matary
> <heshamelmatary at gmail.com> wrote:
> > c/src/lib/libbsp/shared/include/mm.h | 36
> > c/src/lib/libbsp/shared/src/no_memorymanagement.c | 21 +++++++++++++
> > 2 files changed, 57 insertions(+)
> > create mode 100644 c/src/lib/libbsp/shared/include/mm.h
> > create mode 100644 c/src/lib/libbsp/shared/src/no_memorymanagement.c
> > diff --git a/c/src/lib/libbsp/shared/include/mm.h
> b/c/src/lib/libbsp/shared/include/mm.h
> > new file mode 100644
> > index 0000000..f2ac71c
> > --- /dev/null
> > +++ b/c/src/lib/libbsp/shared/include/mm.h
> > @@ -0,0 +1,36 @@
> > + * Copyright (c) 2013 Gedare Bloom.
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > + * http://www.rtems.com/license/LICENSE.
> > +#ifndef __LIBBSP_MM_H
> > +#define __LIBBSP_MM_H
> > +#include <stdint.h>
> > +#include <stdlib.h>
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#endif
> > +typedef struct {
> > + uint32_t begin;
> > + uint32_t end;
> > + uint32_t flags;
> > +} mm_init_start_config;
> Should begin/end be uintptr_t? This structure appears to be unused
> here, so perhaps it should be left out?
> I copied the struct definition from arm-cp15-start.h so that
mm_config_table.c
can include it and recognize such a type.
I can't include arm-cp15-start.h (which it has an exact definition)
to mm_config_table.c because there will be a multiple-definition
compilation error (as arm-cp15-start.h implements some routines) because
mm.c also includes it.
> > +void bsp_memory_management_initialize(void);
> > +void bsp_memory_management_set_attributes(
> > + uintptr_t base,
> > + size_t size,
> > + uint32_t attr
> > +#ifdef __cplusplus
> > +#endif
> > +#endif
> > diff --git a/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> b/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> > index 0000000..1a5fc63
> > --- /dev/null
> > +++ b/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> > @@ -0,0 +1,21 @@
> > + * Copyright (c) 2013 Hesham AL-Matary
> > +#include <rtems.h>
> > +#include <libbsp/mm.h>
> > +void bsp_memory_management_initialize( void ) { }
> > + uintptr_t base,
> > + size_t size,
> > + uint32_t flags
> > 1.8.3.1
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130912/0bce9a57/attachment.html>
