[PATCH 3/6] libmm-libbsp-shared. Files shared between all target BSPs and low-level implementations for libmm. These shared files contain mm.h which is a link between high-level score api and low-level implemenation of libmm. mm.h contains function declarations which should be implemented by target BSP to support libmm. no_memorymanagement.c contains stubs for BSPs that do not support libmm.
Hesham Moustafa
heshamelmatary at gmail.com
Thu Sep 12 18:16:52 UTC 2013
On Thu, Sep 12, 2013 at 8:06 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Actually you should not include the arm-cp15-start.h in the
> shared/include/mm.h file because that would introduce a backwards
> dependency. You could, however, include <bsp/mm.h> in arm-cp15-start.h
> to get rid of some redundancy?
> Yes, if I kept the struct definition at <bsp/mm.h> and deleted it from
arm-cp15-start.h,
that will get rid of such a redundancy. The struct definition at
arm-cp15-start.h is not useful
anymore.
> -Gedare
> On Thu, Sep 12, 2013 at 2:00 PM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
> > On Thu, Sep 12, 2013 at 2:55 PM, Gedare Bloom <gedare at rtems.org> wrote:
> >> On Thu, Sep 12, 2013 at 2:59 AM, Hesham AL-Matary
> >> > c/src/lib/libbsp/shared/include/mm.h | 36
> >> > c/src/lib/libbsp/shared/src/no_memorymanagement.c | 21 +++++++++++++
> >> > 2 files changed, 57 insertions(+)
> >> > create mode 100644 c/src/lib/libbsp/shared/include/mm.h
> >> > create mode 100644 c/src/lib/libbsp/shared/src/no_memorymanagement.c
> >> > diff --git a/c/src/lib/libbsp/shared/include/mm.h
> >> > b/c/src/lib/libbsp/shared/include/mm.h
> >> > new file mode 100644
> >> > index 0000000..f2ac71c
> >> > --- /dev/null
> >> > +++ b/c/src/lib/libbsp/shared/include/mm.h
> >> > @@ -0,0 +1,36 @@
> >> > + * Copyright (c) 2013 Gedare Bloom.
> >> > + * The license and distribution terms for this file may be
> >> > + * found in the file LICENSE in this distribution or at
> >> > + * http://www.rtems.com/license/LICENSE.
> >> > +#ifndef __LIBBSP_MM_H
> >> > +#define __LIBBSP_MM_H
> >> > +#include <stdint.h>
> >> > +#include <stdlib.h>
> >> > +#ifdef __cplusplus
> >> > +extern "C" {
> >> > +#endif
> >> > +typedef struct {
> >> > + uint32_t begin;
> >> > + uint32_t end;
> >> > + uint32_t flags;
> >> > +} mm_init_start_config;
> >> Should begin/end be uintptr_t? This structure appears to be unused
> >> here, so perhaps it should be left out?
> > I copied the struct definition from arm-cp15-start.h so that
> > mm_config_table.c
> > can include it and recognize such a type.
> > I can't include arm-cp15-start.h (which it has an exact definition)
> > to mm_config_table.c because there will be a multiple-definition
> > compilation error (as arm-cp15-start.h implements some routines) because
> > mm.c also includes it.
> >> > +void bsp_memory_management_initialize(void);
> >> > +void bsp_memory_management_set_attributes(
> >> > + uintptr_t base,
> >> > + size_t size,
> >> > + uint32_t attr
> >> > +#ifdef __cplusplus
> >> > +#endif
> >> > +#endif
> >> > diff --git a/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> >> > b/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> >> > index 0000000..1a5fc63
> >> > --- /dev/null
> >> > +++ b/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> >> > @@ -0,0 +1,21 @@
> >> > + * Copyright (c) 2013 Hesham AL-Matary
> >> > +#include <rtems.h>
> >> > +#include <libbsp/mm.h>
> >> > +void bsp_memory_management_initialize( void ) { }
> >> > + uintptr_t base,
> >> > + size_t size,
> >> > + uint32_t flags
> >> > 1.8.3.1
> >> > _______________________________________________
> >> > rtems-devel mailing list
> >> > rtems-devel at rtems.org
> >> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130912/c1cf3013/attachment.html>
