[PATCH 2/6] arm-cp15-new-definitions New definitions for arm-cp15 Fault Status Register and ARMv6 control register.
Fri Sep 13 15:19:20 UTC 2013
On 2013-09-12 08:59, Hesham AL-Matary wrote:
>   c/src/lib/libcpu/arm/shared/include/arm-cp15.h | 21 +++++++++++++++++++++
>   1 file changed, 21 insertions(+)
> diff --git a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> index 0117a5e..badf96e 100644
> --- a/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> +++ b/c/src/lib/libcpu/arm/shared/include/arm-cp15.h
> @@ -7,6 +7,7 @@
> + * Copyright (c) 2013 Hesham AL-Matary
>    * Copyright (c) 2009-2013 embedded brains GmbH.  All rights reserved.
>    *  embedded brains GmbH
> @@ -139,6 +140,7 @@ extern "C" {
>   #define ARM_CP15_CTRL_NMFI (1U << 27)
>   #define ARM_CP15_CTRL_EE (1U << 25)
>   #define ARM_CP15_CTRL_VE (1U << 24)
> +#define ARM_CP15_CTRL_XP (1U << 23) // ARMv6
Please avoid // comments.
>   #define ARM_CP15_CTRL_U (1U << 22)
>   #define ARM_CP15_CTRL_FI (1U << 21)
>   #define ARM_CP15_CTRL_UWXN (1U << 20)
> @@ -173,6 +175,25 @@ extern "C" {
> + * @name Fault Status Register Defines
> +#define ARM_CP15_FAULT_STATUS_MASK 0x040F
What is the purpose of this mask?
How can I access the FSR?
> +#define ARM_CP15_FSR_ALIGNMENT_FAULT   0x00000001
> +#define ARM_CP15_FSR_BACKGROUND_FAULT  0x0000
> +#define ARM_CP15_FSR_ACCESS_PERMISSION_FAULT 0x000D
> +#define ARM_CP15_FSR_PRECISE_EXTERNAL_ABORT_FAULT 0x0008
> +#define ARM_CP15_FSR_IMPRECISE_EXTERNAL_ABORT_FAULT 0x0406
> +#define ARM_CP15_FSR_PRECISE_PARITY_ERROR_EXCEPTION 0x0006
> +#define ARM_CP15_FSR_IMPRECISE_PARITY_ERROR_EXCEPTION 0x0408
> +#define ARM_CP15_FSR_DEBUG_EVENT 0x0002
>   static inline uint32_t arm_cp15_get_id_code(void)
>     ARM_SWITCH_REGISTERS;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
