[PATCH] fstests/mdosfs_fstime: Remove test
Sebastian Huber
Fri Sep 13 15:39:51 UTC 2013
The FAT file system is not conformant with the POSIX requirements.
testsuites/fstests/Makefile.am | 1 -
testsuites/fstests/configure.ac | 1 -
testsuites/fstests/mdosfs_fstime/Makefile.am | 33 --------------------------
3 files changed, 0 insertions(+), 35 deletions(-)
delete mode 100644 testsuites/fstests/mdosfs_fstime/Makefile.am
diff --git a/testsuites/fstests/Makefile.am b/testsuites/fstests/Makefile.am
index cd5b261..ed87f1b 100644
--- a/testsuites/fstests/Makefile.am
+++ b/testsuites/fstests/Makefile.am
@@ -24,7 +24,6 @@ SUBDIRS += mdosfs_fserror
SUBDIRS += mdosfs_fspatheval
SUBDIRS += mdosfs_fsrdwr
SUBDIRS += mdosfs_fsstatvfs
-SUBDIRS += mdosfs_fstime
SUBDIRS += mimfs_fserror
SUBDIRS += mimfs_fslink
SUBDIRS += mimfs_fspatheval
diff --git a/testsuites/fstests/configure.ac b/testsuites/fstests/configure.ac
index 95ed483..571f428 100644
--- a/testsuites/fstests/configure.ac
+++ b/testsuites/fstests/configure.ac
@@ -100,7 +100,6 @@ mdosfs_fserror/Makefile
mdosfs_fspatheval/Makefile
mdosfs_fsrdwr/Makefile
mdosfs_fsstatvfs/Makefile
-mdosfs_fstime/Makefile
mimfs_fserror/Makefile
mimfs_fslink/Makefile
mimfs_fspatheval/Makefile
diff --git a/testsuites/fstests/mdosfs_fstime/Makefile.am b/testsuites/fstests/mdosfs_fstime/Makefile.am
deleted file mode 100644
index 14f58c5..0000000
--- a/testsuites/fstests/mdosfs_fstime/Makefile.am
+++ /dev/null
@@ -1,33 +0,0 @@
-rtems_tests_PROGRAMS = mdosfs_fstime
-mdosfs_fstime_SOURCES = ../fstime/test.c
-mdosfs_fstime_SOURCES += ../support/ramdisk_support.c
-mdosfs_fstime_SOURCES += ../support/fstest_support.c
-mdosfs_fstime_SOURCES += ../support/fstest_support.h
-mdosfs_fstime_SOURCES += ../support/ramdisk_support.h
-mdosfs_fstime_SOURCES += ../support/fstest.h
-mdosfs_fstime_SOURCES += ../../psxtests/include/pmacros.h
-mdosfs_fstime_SOURCES += ../mdosfs_support/fs_support.c
-mdosfs_fstime_SOURCES += ../mdosfs_support/fs_config.h
-#dist_rtems_tests_DATA = mdosfs_fstime.scn
-#dist_rtems_tests_DATA += mdosfs_fstime.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/support
-AM_CPPFLAGS += -I$(top_srcdir)/mdosfs_support
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-AM_CPPFLAGS += -I$(top_srcdir)/../psxtests/include
-LINK_OBJS = $(mdosfs_fstime_OBJECTS)
-LINK_LIBS = $(mdosfs_fstime_LDLIBS)
-mdosfs_fstime$(EXEEXT): $(mdosfs_fstime_OBJECTS) $(mdosfs_fstime_DEPENDENCIES)
- @rm -f mdosfs_fstime$(EXEEXT)
- $(make-exe)
-include $(top_srcdir)/../automake/local.am
1.7.7
