[PATCH 4/6] libmm-libbsp-arm-shared. libmm low-level implementation that can be shared between many ARM targets. mminit.c contains initialization function for arm-cp15 and setup page tables. After that it enables MMU and Cache unit part of BSP initialization process. mm.c translates attributes from high-level to CPU specific attributes and apply them dynamically.
Hesham Moustafa
heshamelmatary at gmail.com
Sat Sep 14 02:29:33 UTC 2013
Thanks. I will resolve these issues in the next patch.
On Fri, Sep 13, 2013 at 9:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Sep 13, 2013 at 11:25 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello Hesham AL-Matary,
> > please add a blank line after the subject in your Git commit messages.
> Also try to make your first line "short" so that the git log and email
> subject lines are legible, and insert line breaks in the "body" of
> your commit message.
> > Please have a look at the attached document regarding the low-level ARM
> > startup. In particular all functions called by the bsp_start_hook_0()
> and
> > bsp_start_hook_1() must reside in the .bsp_start_text section. Similar
> > .bsp_start_data for the data. This is very important for some BSPs which
> > operate with a boot memory map (e.g. LPC24XX with boot from external NOR
> > flash).
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130914/0a231a01/attachment.html>
