[PATCH 2/5] JFFS2: Import from eCos
Sun Sep 15 02:12:08 UTC 2013
Sebastian Huber wrote:
> On 2013-09-14 00:54, Chris Johns wrote:
>> Where is the device support ?
> I didn't import the flash device drivers from eCos. See <rtems/jffs2.h>
> in the RTEMS support patch for the device support. The application has
> to provide the flash access operations.
Would it make sense to have drivers added to libchip for commonly used
devices ?
Where can we find a real driver for a real device ? I feel we need real
drivers as examples in RTEMS.
I do not like the "application" needing to handle this. I think BSPs
should provide drivers and not applications. The device is specific to a
board and it is the role of the BSP to handle this sort of thing. If I
use a BSP that has suitable flash devices I would expect the BSP to
contain the support. It may be the application that enables and
configures the support given a correctly working and mapped set of
drivers from the BSP.
I regretted not providing a real driver interface to the flash memory in
the flashdisk block device. Having a real device interface means it can
be opened and managed without the file system, for example erasing or
testing the devices.
>> Clause 2 concerns me.
>> Is mixing GPLv2+exception and a BSD type license like this ok ?
> This LICENSE file is part of the Linux import patch.
Found it. Thanks.
Do any of the files that contain the reference to the LICENSE file get
installed ?
