[PATCH 2/5] JFFS2: Import from eCos
Mon Sep 16 07:36:36 UTC 2013
Sebastian Huber wrote:
> What do you mean with installed?
> The only header file visible to applications is the <rtems/jffs2.h> file
> which is under the RTEMS license. Everything else is only required to
> produce the JFFS2 object files.
This is fine. If the files referencing the LICENCE file are not
installed there is no issue.
