[PATCH] Added PIC details to docs
Tue Sep 17 17:46:53 UTC 2013
Committed.
You have really had to dig around in the dirt
but have gotten the hang of it. The BSPs are
the product of a lot of coders over a long
period of time and it is hard to move them all
to the "new right" place. We learn as we go
along and want to do things clearer, better,
and share more code.
You had a very broad task of figuring out what was
the right way amongst all the not so right ways. :)
I hope you stay involved. I want to address
the issues the script found.
Thanks.
On 9/16/2013 9:32 AM, Vipul Nayyar wrote:
>  doc/bsp_howto/support.t | 70 +++++++++++++++++++++++++++++++++++++++++++++++++
>  1 file changed, 70 insertions(+)
> diff --git a/doc/bsp_howto/support.t b/doc/bsp_howto/support.t
> index 9d89b81..843093a 100644
> --- a/doc/bsp_howto/support.t
> +++ b/doc/bsp_howto/support.t
> @@ -283,3 +283,73 @@ Interrupt Controller model which does not require the BSP to implement
>  @code{set_vector}.  BSPs for these architectures must provide a different
>  set of support routines.
> + at section Programmable Interrupt Controller API
> +A BSP can use the PIC API to install Interrupt Service Routines through
> +a set of generic methods. In order to do so, the header files
> +libbsp/shared/include/irq-generic.h and libbsp/shared/include/irq-info.h
> +must be included by the bsp specific irq.h file present in the include/
> +directory. The irq.h acts as a BSP interrupt support configuration file which
> +is used to define some important MACROS. It contains the declarations for
> +any required global functions like bsp_interrupt_dispatch(). Thus later on,
> +every call to the PIC interface requires including <bsp/irq.h>
> +The generic interrupt handler table is intitalized by invoking the
> + at code{bsp_interrupt_initialize()} method from bsp_start() in the bspstart.c
> +file which sets up this table to store the ISR addresses, whose size is based
> +on the definition of macros, BSP_INTERRUPT_VECTOR_MIN & BSP_INTERRUPT_VECTOR_MAX
> +in include/bsp.h
> +For the generic handler table to properly function, some bsp specific code is
> +required, that should be present in irq/irq.c . The bsp-specific functions required
> +to be writen by the BSP developer are :
> + at itemize @bullet
> + at findex bsp_interrupt_facility_initialize()
> + at item @code{bsp_interrupt_facility_initialize()} contains bsp specific interrupt
> +initialization code(Clear Pending interrupts by modifying registers, etc.).
> +This method is called from bsp_interrupt_initialize() internally while setting up
> +the table.
> + at findex bsp_interrupt_handler_default()
> + at item @code{bsp_interrupt_handler_default()} acts as a fallback handler when
> +no ISR address has been provided corresponding to a vector in the table.
> + at findex bsp_interrupt_dispatch()
> + at item @code{bsp_interrupt_dispatch()} service the ISR by handling
> +any bsp specific code & calling the generic method bsp_interrupt_handler_dispatch()
> +which in turn services the interrupt by running the ISR after looking it up in
> +the table. It acts as an entry to the interrupt switchboard, since the bsp
> +branches to this function at the time of occurrence of an interrupt.
> + at findex bsp_interrupt_vector_enable()
> + at item @code{bsp_interrupt_vector_enable()} enables interrupts and is called in
> +irq-generic.c while setting up the table.
> + at findex bsp_interrupt_vector_disable()
> + at item @code{bsp_interrupt_vector_disable()} disables interrupts and is called in
> +irq-generic.c while setting up the table & during other important parts.
> + at end itemize
> +An interrupt handler is installed or removed with the help of the following functions :
> + at example
> + at group
> +rtems_status_code rtems_interrupt_handler_install(   /* returns status code */
> +  rtems_vector_number vector,                        /* interrupt vector */
> +  const char *info,                           /* custom identification text */
> +  rtems_option options,                              /* Type of Interrupt */
> +  rtems_interrupt_handler handler,                   /* interrupt handler */
> +  void *arg  /* parameter to be passed to handler at the time of invocation */
> +rtems_status_code rtems_interrupt_handler_remove(   /* returns status code */
> +  void *arg                          /* parameter to be passed to handler */
> + at end group
> + at end example
> -- 1.7.11.7
