[PATCH] Bash script to review BSP File Organization
Tue Sep 17 17:51:19 UTC 2013
I don't know what is wrong but it doesn't apply. :(
patching file merge-helpers/check_submission
patch: **** malformed patch at line 110: '0' to give only important stuff.
On 9/17/2013 12:24 PM, Vipul Nayyar wrote:
>  merge-helpers/check_submission | 776 +++++++++++++++++++++++++++++++----------
>  1 file changed, 590 insertions(+), 186 deletions(-)
> diff --git a/merge-helpers/check_submission b/merge-helpers/check_submission
> index e838121..90908f1 100755
> --- a/merge-helpers/check_submission
> +++ b/merge-helpers/check_submission
> @@ -1,76 +1,247 @@
> -#  Script to test for various things we want in a BSP when it is
> -#  submitted.
> -#  Test for:
> -#    - XXX
> +#! /bin/bash
> -usage()
> -cat <<EOF
> -check_submission [options] directory
> -  -b - check assuming directory is a BSP
> -  -t - check assuming directory is a test
> -  -v - verbose
> -EOF
> +# Bash Script to find discrepancies in BSP file organization.
> +# Author : Vipul Nayyar <nayyar_vipul at yahoo.com>
> -fatal()
> -  usage
> -  exit 1
> +filename="0"
> +# Passing --verbose turns verbose to 1 & gives the whole story, otherwise '0' to give only important stuff.
> +verbose="0"
> +faults="0"
> +# Passing --warnings turns warnings to 1 & gives all the critical & non-critical bsp file org. problems.
> +warnings="0"
> +flag="0"
> +calling_path=`pwd`
> +path=""
> +important="1"
> +rtems_internal=""
> +internal_done="0"
> +do_test="0"
> +format="1"
> +# Finds all rtems internal functions ( name starting with '_' & type specifier)
> +# that are defined in cpukit & libcpu
> +function find_rtems_internal(){
> +  if [[ $internal_done == "1" ]]; then
> +    return
> +  fi
> +  echo "Compiling list of RTEMS Internal functions ..."
> +  internal_files=""
> +  for k in `find -name *.c`
> +  do
> +    for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k`
> +    do
> +      if [[ $j == "_"* ]]; then
> +        j=${j%%\(}
> +        internal_files="$j $internal_files"
> +      fi
> +    done
> +  done
> +  for k in `find ../c/src/lib/libcpu/ -name *.c`
> +  do
> +    do
> +        j=${j%%\(}
> +      fi
> +    done
> +  done
> +  for k in $internal_files
> +  do
> +    if echo $rtems_internal |grep -q $k ; then
> +      echo > /dev/null
> +    else
> +      rtems_internal="$k $rtems_internal"
> +    fi
> +  done
> +  internal_done="1"
> -toggle()
> -  case $1 in
> -    no)  echo "yes" ;;
> -    yes) echo "no" ;;
> -    *)   fatal "Unknown value to toggle ($1)" ;;
> -  esac
> +# Finds all internal functions common in bsp and (cpukit + libcpu)
> +function find_bsp_internal(){
> +  bsp_methods=""
> +  common_internal_methods=""
> +# Searching for internal functions starting with '_' called(i.e ending with a ';')
> +  for i in `find -name *.c`
> +  do
> +    file_contents=`tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
> +    for j in `echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
> +    do
> +      if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
> +        echo > /dev/null
> +      else
> +        bsp_methods="${j%%\(} $bsp_methods"
> +      fi
> +    done
> +  done
> +# Identifying common fucntions between $rtems_interval & $bsp_methods
> +  for i in $rtems_internal
> +  do
> +    if [[ $i == "__asm__" || $i == "__attribute__" || $i == "__volatile__" || $i == "__"* ]];then
> +      continue
> +    fi
> +    for j in $bsp_methods
> +    do
> +      if [[ $i == $j ]]; then
> +        common_internal_methods="$j $common_internal_methods"
> +      fi
> +    done
> +  done
> +  if [[ $common_internal_methods != "" ]]; then
> +    echo -e "$bsp : RTEMS Internal functions used : \c"
> +    for i in $common_internal_methods
> +    do
> +      echo -e "${i}() \c"
> +    done
> +    flag="1"
> +  fi
> -verbose="no"
> -do_bsp="no"
> -do_test="no"
> -while getopts vbt OPT
> -do
> -    case "$OPT" in
> -        b) do_bsp="yes" ; do_test="no"  ;;
> -        t) do_bsp="no"  ; do_test="yes" ;;
> -        v) verbose=`toggle ${verbose}` ;;
> -        *) fatal ;;
> -    esac
> -done
> -########################### Grab Directory ###########################
> +# Passing 1 initially to any check function states that the file/method/header
> +# being checked is of critical nature
> +function check_file(){
> +  filename="0"
> +  if [[ $1 == 1 ]]; then
> +    important="1"
> +    shift
> +  else
> +    important="0"
> +  fi
> -shiftcount=`expr $OPTIND - 1`
> -shift $shiftcount
> +#Grabbing the path of file being evaluated from Makefile.am
> +  if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
> +    file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
> +    cd `dirname $file_path`
> +    filename=$1
> +    file_path=`pwd`
> +    cd - > /dev/null
> +    shift
> +# Checking if file lies in correct directory path
> +    for i in $*
> +    do
> +      if [[ -d $i ]]; then
> +        cd $i
> +      else
> +        continue
> +      fi
> +      if [[ "$file_path" == `pwd` ]]; then
> +        filename="$file_path/$filename"
> +        cd - >/dev/null
> +        return
> +      fi
> +      cd - > /dev/null
> +    done
> +    echo "$bsp : $filename not present in correct path"
> +    return
> +  else
> +    if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]]; then
> +      flag="1"
> +      echo "$bsp : $1 not compiled"
> +    fi
> +  fi
> -basedir=${1}
> +  filename="0"
> +  faults="1"
> +  return
> -if [ "${basedir}X" = "X" ] ; then
> -  basedir=.
> -fi
> +# Checking presence of functions in specific files
> +function check_methods(){
> +    important="1"
> +    shift
> +  else
> +    important="0"
> +  fi
> -if [ ${do_bsp} = "no" -a ${do_test} = "no" ] ; then
> -  fatal must select test or bsp check mode
> -fi
> +  for i in $*
> +  do
> -if [ ! -d ${basedir} ] ; then
> -  fatal ${basedir} is not a directory
> -fi
> +# When correct file for this function does not exist
> +    if [[ $filename == "0" ]];then
> +      if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
> +         if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]];then
> +          echo $bsp : ${i%(*}"()" present in file `grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
> +         fi
> +      fi
> +    else
> +# When correct file for this function exists
> +      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
> +        if [[ $verbose -eq "1" ]] ;then
> +          echo "$bsp : `basename $filename` : ${i%(*}() present in file"
> +        fi
> +      else
> +           fi
> +        else
> +            echo "$bsp : `basename $filename` : ${i%(*}() function does not exist in $filename "
> +            flag="1"
> +          fi
> +            faults="1"
> +        fi
> +      fi
> +    fi
> +  done
> +# Checking presence of headers installed by bsp
> +function check_header(){
> +    important="1"
> +    shift
> +  else
> +    important="0"
> +  fi
> -cd ${basedir}
> -if [ $? -ne 0 ] ; then
> -  echo Unable to cd to ${basedir}
> -  exit 1
> -fi
> +  for i in $*
> +  do
> +    if  grep -wq "$i" Makefile.am ;then
> +      if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
> +        continue
> +      fi
> +        cd `dirname $i`
> +        echo "$bsp : `basename $i` installed from directory" ${PWD##*/c/src/lib/}
> +        cd - > /dev/null
> +      fi
> +      return
> +    fi
> +  done
> +    echo "${bsp%%[\ ]*} : `basename $1` not installed "
> +    flag="1"
> +  fi
> +  filename="0"
> +  faults="1"
> +  return
>  test_its_there()
> @@ -79,7 +250,7 @@ test_its_there()
>    fi
>    grep ${2} ${1} >/dev/null
> -    echo "${2} is NOT in ${basedir}/${1}"
> +    echo "$bsp : ${2} is NOT in ${1##./}"
>    fi
> @@ -91,7 +262,7 @@ test_its_there_all_case()
>    fi
>    grep -i ${2} ${1} >/dev/null
> -    echo "${2} is NOT in ${basedir}/${1} - case independent check"
> +    echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
>    fi
> @@ -105,7 +276,7 @@ test_its_NOT_there_all_case()
>    shift
>    grep -i "${*}" ${FILE} >/dev/null
>    if [ $? -eq 0 ] ; then
> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE} - case independent check"
> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case independent check"
>    fi
> @@ -118,14 +289,14 @@ test_its_NOT_there()
>    shift
>    grep "${*}" ${FILE} >/dev/null
> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE}"
> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
>    fi
>  find_source()
>    findArgs=
> -  while getopts "cCm" OPT
> +  while getopts "cCdm" OPT
>    do
>     case "$OPT" in
>       c) findArgs="${findArgs} -o -name configure.ac" ;;
> @@ -144,145 +315,378 @@ find_source()
>    find . -name "*.[chS]" ${findArgs}
> -# Verify no lines longer than 80 columns
> -echo "=== Checking for lines greater than 79 columns"
> -find_source -m -c -C | while read f
> -do
> -  grep  ".\{80,\}" ${f} >/dev/null
> -  if [ $? -eq 0 ] ; then
> -    echo "*** ${basedir}/${f} has the following lines that are too long"
> -    grep -n '.\{80,\}' ${f}
> -  fi
> -done
> -# really need to make the copyright strings consistent in BSPs
> -echo "=== Checking for copyright notices"
> -find_source | while read f
> -do
> -  test_its_there_all_case ${f} COPYRIGHT
> -done
> -# We want CVS Id strings everywhere possible
> -echo "=== Checking for CVS Id strings"
> -find_source -d | while read f
> -do
> -  test_its_NOT_there ${f} "\$Id"
> -done
> -# We do not want the reformatted license notice
> -echo "=== Checking for reformatted RTEMS license notices"
> -do
> -  test_its_NOT_there ${f} "this file may be found in the file"
> -done
> -# We do not want spaces at the end of lines
> -echo "=== Checking for spaces at the end of lines"
> -do
> -  egrep " +$" $f >/dev/null
> -  test $? -eq 0 && echo "$f has spaces at the end of one or more lines."
> -done
> -# We do not want tabs in source files
> -echo "=== Checking for tabs in source files"
> -do
> -  grep -P '\t' $f >/dev/null
> -  if [ $? -eq 0 ]; then
> -    echo "*** ${basedir}/${f} has the following lines with tabs"
> -    grep -P '\t' $f
> -  fi
> -done
> -# We do not want GPL code
> -echo "=== Checking for hints of GPL code"
> -do
> -  test_its_NOT_there ${f} "Free Software Foundation"
> -  test_its_NOT_there ${f} "program is free software"
> -  test_its_NOT_there ${f} "General Public License"
> -done
> -# We do not want hints that there are things left to do
> -echo "=== Checking for TODO hints"
> -do
> -  test_its_NOT_there ${f} XXX
> -  test_its_NOT_there ${f} TODO
> -  test_its_NOT_there ${f} TBD
> -done
> +function check_format(){
> -# BSP specific checks
> -if [ ${do_bsp} = "yes" ] ; then
> -  # We do not want stdio in a BSP
> -  echo "=== Checking for stdio"
> +  # Verify no lines longer than 80 columns
> +  echo "=== Checking for lines greater than 80 columns"
> +  find_source -m -c -C | while read f
> +  do
> +    grep  ".\{81,\}" ${f} >/dev/null
> +    if [ $? -eq 0 ] ; then
> +      echo -e "\n$bsp : ${f#./} has more than 80 character lines"
> +      for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
> +      do
> +        echo -e "$i \c"
> +    done
> +    fi
> +  done
> +  # really need to make the copyright strings consistent in BSPs
> +  echo -e "\n=== Checking for copyright notices"
> +  find_source | while read f
> +  do
> +    test_its_there_all_case ${f} COPYRIGHT
> +  done
> +  # We want CVS Id strings everywhere possible
> +  echo "=== Checking for CVS Id strings"
> +  find_source -d | while read f
> +  do
> +    test_its_NOT_there ${f} "\$Id"
> +  done
> +  # We do not want the reformatted license notice
> +  echo "=== Checking for reformatted RTEMS license notices"
> +  do
> +    test_its_NOT_there ${f} "this file may be found in the file"
> +  done
> +  # We do not want spaces at the end of lines
> +  echo "=== Checking for spaces at the end of lines"
> +  do
> +    egrep " +$" $f >/dev/null
> +    test $? -eq 0 && echo -e "${f##./} \c"
> +  done
> +  # We do not want tabs in source files
> +  echo -e "\n=== Checking for tabs in source files"
> +  do
> +    grep -P '\t' $f >/dev/null
> +  done
> +  # We do not want GPL code
> +  echo -e "\n=== Checking for hints of GPL code"
>    do
> -    test_its_NOT_there ${f} printf
> -    test_its_NOT_there ${f} "puts("
> +    test_its_NOT_there ${f} "Free Software Foundation"
> +    test_its_NOT_there ${f} "program is free software"
> +    test_its_NOT_there ${f} "General Public License"
>    done
> -  # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
> -  #   RTEMS_BSP_BOOTCARD_OPTIONS
> -  if [ -r configure.ac ] ; then
> -    echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
> -    test_its_not_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
> -    echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
> -    test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
> +  # We do not want hints that there are things left to do
> +  echo "=== Checking for TODO hints"
> +  do
> +    test_its_NOT_there ${f} XXX
> +    test_its_NOT_there ${f} TODO
> +    test_its_NOT_there ${f} TBD
> +  done
> +# Reviewing for a BSP Starts
> +function main(){
> +  if [[ $format -eq "1" ]]; then
> +    check_format
>    fi
> -  # If not using -O2, then we really want to know
> -  # BSPs should normally use -O2
> -  echo "=== Checking for not using -O2"
> -  grep -H "\-O[013456789]" make/custom/*.cfg
> +  # We do not want stdio in a BSP
> +    echo "=== Checking for stdio"
> +    do
> +      test_its_NOT_there ${f} printf
> +      test_its_NOT_there ${f} "puts("
> +    done
> +    # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
> +    #   RTEMS_BSP_BOOTCARD_OPTIONS
> +    if [ -r configure.ac ] ; then
> +      echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
> +      test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
> +      echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
> +      test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
> +    fi
> +    # If not using -O2, then we really want to know
> +    # BSPs should normally use -O2
> +    echo "=== Checking for not using -O2"
> +    grep -H "\-O[013456789]" make/custom/*.cfg
> -  # BSPs should not turn on extra warnings
> -  echo "=== Checking for turning on extra GCC warning checks"
> -  grep -H "\-W" make/custom/*.cfg
> +    # BSPs should not turn on extra warnings
> +    echo "=== Checking for turning on extra GCC warning checks"
> +    grep -H "\-W" make/custom/*.cfg
> -  # Hopefully have some output from the tmtests
> -  echo "=== Checking for timing information"
> -  c=`ls -1 times* 2>/dev/null | wc -l`
> -  if [ ${c} -eq 0 ] ; then
> -    echo "Please run the timing tests and include the results."
> +    # Hopefully have some output from the tmtests
> +    echo "=== Checking for timing information"
> +    c=`ls -1 times* 2>/dev/null | wc -l`
> +    if [ ${c} -eq 0 ] ; then
> +      echo "Please run the timing tests and include the results."
>    fi
> -fi  ## END OF IF BSP
> +  echo -e "\n=== Starting BSP Unified way checks"
> +  flag="0"
> +  check_file 1 start.S ../shared/start/ start/
> +  if [[ $filename != "0" ]];then
> +    if grep -wq "start" "$filename" || grep -wq "_start" "$filename"; then
> +        echo "$bsp : `basename $filename` start() present in $filename"
> +      fi
> +    else
> +      echo "$bsp : `basename $filename` start() does not exist in start.S"
> +    fi
> +  fi
> +  check_file 1 bspstart.c ../../shared/ ../shared/ startup/
> +  check_methods "bsp_start"
> +  check_file 1 bspreset.c ../../shared/ ../shared/ startup/
> +  check_methods 1 "bsp_reset"
> +  check_file 1 bootcard.c ../../shared/
> +  check_header ../../shared/include/bootcard.h
> +  check_file 1 bspclean.c ../../shared/ startup/
> +  check_methods "bsp_fatal_extension"
> +  check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup ../shared/ ../shared/startup/ startup/
> +  check_methods 1 "bsp_work_area_initialize"
> +  check_file 1 bsplibc.c ../../shared/
> +  check_methods "bsp_libc_init"
> +  check_file 1 bsppost.c ../../shared/
> +  check_methods "bsp_postdriver_hook"
> +  check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/ startup/
> +  check_methods "bsp_predriver_hook"
> +  check_file gnatinstallhandler.c ../../shared/
> +  check_file sbrk.c ../../shared/ ../../shared/ startup/
> +  check_methods "sbrk"
> +  check_file stackalloc.c ../../shared/src/
> +  check_methods "bsp_stack_allocate_init" "bsp_stack_allocate" "bsp_stack_free"
> +  check_header ../../shared/include/stackalloc.h
> +  # Interrupt Files
> +  check_file 1 irq.c irq/
> +  check_methods "bsp_interrupt_vector_enable" "bsp_interrupt_vector_disable" "bsp_interrupt_facility_initialize" "bsp_interrupt_dispatch"
> +  check_header 1 include/irq.h
> +  # PIC Support
> +  check_file irq-default-handler.c ../../shared/src/
> +  check_file 1 irq-generic.c ../../shared/src/
> +  check_header 1 ../../shared/include/irq-generic.h
> +  check_file irq-info.c ../../shared/src/
> +  check_header ../../shared/include/irq-info.h
> +  check_file irq-legacy.c ../../shared/src/
> +  check_file irq-server.c ../../shared/src/
> +  check_file irq-shell.c ../../shared/src/
> +  # Real Time Clock
> +  check_file rtc-config.c rtc/
> +  check_methods "bsp_rtc_initialize" "bsp_rtc_get_time" "bsp_rtc_set_time" "bsp_rtc_probe"
> +  check_file 1 tod.c ../../shared/ tod/
> +  # Benchmark Timers
> +  check_file benchmark_timer.c benchmark_timer/
> +  check_methods "benchmark_timer_initialize" "benchmark_timer_read" "benchmark_timer_disable_subtracting_average_overhead"
> +  # Standard Headers
> +  check_header 1 include/bsp.h
> +  check_header include/bspopts.h
> +  check_header 1 ../../shared/include/coverhd.h include/coverhd.h
> +  check_header ../../shared/include/utility.h
> +  check_header 1 ../../shared/include/tm27.h include/tm27.h
> +  cd ../../../../../../cpukit
> +  find_rtems_internal
> +  cd - > /dev/null
> +  # Finding all internal functions being used in a bsp
> +  find_bsp_internal
> +  if [[ $flag == "1" ]]; then
> +    echo -e "\n"
> +  fi
>  # Test specific checks
> -if [ ${do_test} = "yes" ] ; then
> -  # find all the Makefile.am's with rtems_tests_PROGRAMS in them
> -  Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
> -  if [ "X${Makefiles}" = "X" ] ; then
> -    fatal "Unable to locate any test Makefile.am files."
> -  fi
> -  echo "=== Checking for missing test support files"
> -  for m in ${Makefiles}
> -  do
> -    directory=`dirname ${m}`
> -    if [ ${directory} = "." ] ; then
> -      directory=`pwd`
> +  if [ ${do_test} == "1" ] ; then
> +    echo -e "\n=== Starting Test specific checks"
> +    # find all the Makefile.am's with rtems_tests_PROGRAMS in them
> +    Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
> +    if [ "X${Makefiles}" = "X" ] ; then
> +      echo -e "Unable to locate any test Makefile.am files.\n"
> +      return
>      fi
> -    testName=`basename ${directory}`
> -    # Does this test have a .doc file?
> -    if [ ! -r ${directory}/${testName}.doc ] ; then
> -      echo ${testName}.doc is not present
> +    echo "=== Checking for missing test support files"
> +    for m in ${Makefiles}
> +    do
> +      directory=`dirname ${m}`
> +      if [ ${directory} = "." ] ; then
> +        directory=`pwd`
> +      fi
> +      testName=`basename ${directory}`
> +      # Does this test have a .doc file?
> +      if [ ! -r ${directory}/${testName}.doc ] ; then
> +        echo ${testName}.doc is not present
> +      fi
> +      case ${directory} in
> +        */*tmtests*) ;;
> +          # Does this test have a .scn file?
> +          if [ ! -r ${directory}/${testName}.scn ] ; then
> +            echo ${testName}.scn is not present
> +          fi
> +      esac
> +    done
> +  fi
> +# Verifying if the directory given or pwd is a valid bsp, shared architecture, or libbsp directory
> +function check_given_dir(){
> +  if echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
> +    return 0
> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
> +# BSP given
> +    bsp=${cur_dir##*/}
> +    if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp == "no_bsp" ]]; then
> +      return 0
> +    else
> +      main
>      fi
> -    case ${directory} in
> -      */*tmtests*) ;;
> -        # Does this test have a .scn file?
> -        if [ ! -r ${directory}/${testName}.scn ] ; then
> -          echo ${testName}.scn is not present
> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
> +# Shared architecture given
> +    for i in *
> +    do
> +        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_bsp" ]]; then
> +          echo -n
> +        else
> +          bsp=$i
> +          cd $bsp
> +          main
> +          cd .. > /dev/null
> +        fi
> +      fi
> +    done
> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
> +# libbsp given
> +    for i in */*/Makefile.am
> +    do
> +      i=`dirname $i`
> +        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_cpu/no_bsp" ]]; then
> +          echo -n
> +        else
> +          bsp=$i
> +          cd $bsp
> +          main
> +          cd ../../ > /dev/null
>          fi
> +      fi
> +    done
> +  else
> +    return 0
> +  fi
> +# Evaluating Command Line Arguments
> +function start(){
> +  for i in $*
> +  do
> +    case $i in
> +      "--verbose") verbose="1" # The whole story
> +      "--warnings") warnings="1" # All warnings
> +              verbose="0"
> +      "--no_format") format="0" # Disabling format checks
> +              verbose="0"
> +      "--tests") do_test="1"    # Enabling check of tests
> +             verbose="0"
> +      "--help") echo "Help to be provided"
> +      "--"* | "-"* ) echo "Invalid options provided"
> +      *) path="$path $i"  ;; # If not above options, then assumed to be a path for bsp
>      esac
>    done
> -fi
> -exit 0
> +# No path given, search for bsp from pwd
> +  if [[ -z $path ]];then
> +    path=$PWD
> +    cur_dir=`pwd`
> +    check_given_dir
> +    if [[ $? -eq 1 ]];then
> +      echo "Current directory does not seem a valid RTEMS directory"
> +    fi
> +  else
> +    for i in $path
> +    do
> +        echo > /dev/null
> +      else
> +        echo "$i is an invalid directory."
> +        continue
> +      fi
> +      cd $i
> +      cur_dir=`pwd`
> +      check_given_dir
> +        echo "$i does not seem a valid RTEMS directory"
> +      fi
> +      cd $calling_path
> +    done
> +  fi
> +# Let the Game begin !!
> +start $*
> +# End of Checks
> +if [[ $faults -eq "0" ]] ; then
> +  echo -e "\nNo faults found in BSP organization"
> +fi
> 1.7.11.7
> rtems-devel mailing list
> rtems-devel at rtems.org
