[PATCH] Bash script to review BSP File Organization
Tue Sep 17 18:09:13 UTC 2013
Hey Joel and Vipul,
I applied and committed it. Please verify.
-Gedare
On Tue, Sep 17, 2013 at 1:51 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I don't know what is wrong but it doesn't apply. :(
> patching file merge-helpers/check_submission
> patch: **** malformed patch at line 110: '0' to give only important stuff.
> On 9/17/2013 12:24 PM, Vipul Nayyar wrote:
>>  merge-helpers/check_submission | 776 +++++++++++++++++++++++++++++++----------
>>  1 file changed, 590 insertions(+), 186 deletions(-)
>> diff --git a/merge-helpers/check_submission b/merge-helpers/check_submission
>> index e838121..90908f1 100755
>> --- a/merge-helpers/check_submission
>> +++ b/merge-helpers/check_submission
>> @@ -1,76 +1,247 @@
>> -#  Script to test for various things we want in a BSP when it is
>> -#  submitted.
>> -#  Test for:
>> -#    - XXX
>> +#! /bin/bash
>> -usage()
>> -cat <<EOF
>> -check_submission [options] directory
>> -  -b - check assuming directory is a BSP
>> -  -t - check assuming directory is a test
>> -  -v - verbose
>> -EOF
>> +# Bash Script to find discrepancies in BSP file organization.
>> +# Author : Vipul Nayyar <nayyar_vipul at yahoo.com>
>> -fatal()
>> -  usage
>> -  exit 1
>> +filename="0"
>> +# Passing --verbose turns verbose to 1 & gives the whole story, otherwise '0' to give only important stuff.
>> +verbose="0"
>> +faults="0"
>> +# Passing --warnings turns warnings to 1 & gives all the critical & non-critical bsp file org. problems.
>> +warnings="0"
>> +flag="0"
>> +calling_path=`pwd`
>> +path=""
>> +important="1"
>> +rtems_internal=""
>> +internal_done="0"
>> +do_test="0"
>> +format="1"
>> +# Finds all rtems internal functions ( name starting with '_' & type specifier)
>> +# that are defined in cpukit & libcpu
>> +function find_rtems_internal(){
>> +  if [[ $internal_done == "1" ]]; then
>> +    return
>> +  fi
>> +  echo "Compiling list of RTEMS Internal functions ..."
>> +  internal_files=""
>> +  for k in `find -name *.c`
>> +  do
>> +    for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k`
>> +    do
>> +      if [[ $j == "_"* ]]; then
>> +        j=${j%%\(}
>> +        internal_files="$j $internal_files"
>> +      fi
>> +    done
>> +  done
>> +  for k in `find ../c/src/lib/libcpu/ -name *.c`
>> +  do
>> +    do
>> +        j=${j%%\(}
>> +      fi
>> +    done
>> +  done
>> +  for k in $internal_files
>> +  do
>> +    if echo $rtems_internal |grep -q $k ; then
>> +      echo > /dev/null
>> +    else
>> +      rtems_internal="$k $rtems_internal"
>> +    fi
>> +  done
>> +  internal_done="1"
>> -toggle()
>> -  case $1 in
>> -    no)  echo "yes" ;;
>> -    yes) echo "no" ;;
>> -    *)   fatal "Unknown value to toggle ($1)" ;;
>> -  esac
>> +# Finds all internal functions common in bsp and (cpukit + libcpu)
>> +function find_bsp_internal(){
>> +  bsp_methods=""
>> +  common_internal_methods=""
>> +# Searching for internal functions starting with '_' called(i.e ending with a ';')
>> +  for i in `find -name *.c`
>> +  do
>> +    file_contents=`tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
>> +    for j in `echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
>> +    do
>> +      if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
>> +        echo > /dev/null
>> +      else
>> +        bsp_methods="${j%%\(} $bsp_methods"
>> +      fi
>> +    done
>> +  done
>> +# Identifying common fucntions between $rtems_interval & $bsp_methods
>> +  for i in $rtems_internal
>> +  do
>> +    if [[ $i == "__asm__" || $i == "__attribute__" || $i == "__volatile__" || $i == "__"* ]];then
>> +      continue
>> +    fi
>> +    for j in $bsp_methods
>> +    do
>> +      if [[ $i == $j ]]; then
>> +        common_internal_methods="$j $common_internal_methods"
>> +      fi
>> +    done
>> +  done
>> +  if [[ $common_internal_methods != "" ]]; then
>> +    echo -e "$bsp : RTEMS Internal functions used : \c"
>> +    for i in $common_internal_methods
>> +    do
>> +      echo -e "${i}() \c"
>> +    done
>> +    flag="1"
>> +  fi
>> -verbose="no"
>> -do_bsp="no"
>> -do_test="no"
>> -while getopts vbt OPT
>> -do
>> -    case "$OPT" in
>> -        b) do_bsp="yes" ; do_test="no"  ;;
>> -        t) do_bsp="no"  ; do_test="yes" ;;
>> -        v) verbose=`toggle ${verbose}` ;;
>> -        *) fatal ;;
>> -    esac
>> -done
>> -########################### Grab Directory ###########################
>> +# Passing 1 initially to any check function states that the file/method/header
>> +# being checked is of critical nature
>> +function check_file(){
>> +  filename="0"
>> +  if [[ $1 == 1 ]]; then
>> +    important="1"
>> +    shift
>> +  else
>> +    important="0"
>> +  fi
>> -shiftcount=`expr $OPTIND - 1`
>> -shift $shiftcount
>> +#Grabbing the path of file being evaluated from Makefile.am
>> +  if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
>> +    file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
>> +    cd `dirname $file_path`
>> +    filename=$1
>> +    file_path=`pwd`
>> +    cd - > /dev/null
>> +    shift
>> +# Checking if file lies in correct directory path
>> +    for i in $*
>> +    do
>> +      if [[ -d $i ]]; then
>> +        cd $i
>> +      else
>> +        continue
>> +      fi
>> +      if [[ "$file_path" == `pwd` ]]; then
>> +        filename="$file_path/$filename"
>> +        cd - >/dev/null
>> +        return
>> +      fi
>> +      cd - > /dev/null
>> +    done
>> +    echo "$bsp : $filename not present in correct path"
>> +    return
>> +  else
>> +    if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]]; then
>> +      flag="1"
>> +      echo "$bsp : $1 not compiled"
>> +    fi
>> +  fi
>> -basedir=${1}
>> +  filename="0"
>> +  faults="1"
>> +  return
>> -if [ "${basedir}X" = "X" ] ; then
>> -  basedir=.
>> -fi
>> +# Checking presence of functions in specific files
>> +function check_methods(){
>> +    important="1"
>> +    shift
>> +  else
>> +    important="0"
>> +  fi
>> -if [ ${do_bsp} = "no" -a ${do_test} = "no" ] ; then
>> -  fatal must select test or bsp check mode
>> -fi
>> +  for i in $*
>> +  do
>> -if [ ! -d ${basedir} ] ; then
>> -  fatal ${basedir} is not a directory
>> -fi
>> +# When correct file for this function does not exist
>> +    if [[ $filename == "0" ]];then
>> +      if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
>> +         if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]];then
>> +          echo $bsp : ${i%(*}"()" present in file `grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
>> +         fi
>> +      fi
>> +    else
>> +# When correct file for this function exists
>> +      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
>> +        if [[ $verbose -eq "1" ]] ;then
>> +          echo "$bsp : `basename $filename` : ${i%(*}() present in file"
>> +        fi
>> +      else
>> +           fi
>> +        else
>> +            echo "$bsp : `basename $filename` : ${i%(*}() function does not exist in $filename "
>> +            flag="1"
>> +          fi
>> +            faults="1"
>> +        fi
>> +      fi
>> +    fi
>> +  done
>> +# Checking presence of headers installed by bsp
>> +function check_header(){
>> +    important="1"
>> +    shift
>> +  else
>> +    important="0"
>> +  fi
>> -cd ${basedir}
>> -if [ $? -ne 0 ] ; then
>> -  echo Unable to cd to ${basedir}
>> -  exit 1
>> -fi
>> +  for i in $*
>> +  do
>> +    if  grep -wq "$i" Makefile.am ;then
>> +      if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
>> +        continue
>> +      fi
>> +        cd `dirname $i`
>> +        echo "$bsp : `basename $i` installed from directory" ${PWD##*/c/src/lib/}
>> +        cd - > /dev/null
>> +      fi
>> +      return
>> +    fi
>> +  done
>> +    echo "${bsp%%[\ ]*} : `basename $1` not installed "
>> +    flag="1"
>> +  fi
>> +  filename="0"
>> +  faults="1"
>> +  return
>>  test_its_there()
>> @@ -79,7 +250,7 @@ test_its_there()
>>    fi
>>    grep ${2} ${1} >/dev/null
>> -    echo "${2} is NOT in ${basedir}/${1}"
>> +    echo "$bsp : ${2} is NOT in ${1##./}"
>>    fi
>> @@ -91,7 +262,7 @@ test_its_there_all_case()
>>    fi
>>    grep -i ${2} ${1} >/dev/null
>> -    echo "${2} is NOT in ${basedir}/${1} - case independent check"
>> +    echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
>>    fi
>> @@ -105,7 +276,7 @@ test_its_NOT_there_all_case()
>>    shift
>>    grep -i "${*}" ${FILE} >/dev/null
>>    if [ $? -eq 0 ] ; then
>> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE} - case independent check"
>> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case independent check"
>>    fi
>> @@ -118,14 +289,14 @@ test_its_NOT_there()
>>    shift
>>    grep "${*}" ${FILE} >/dev/null
>> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE}"
>> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
>>    fi
>>  find_source()
>>    findArgs=
>> -  while getopts "cCm" OPT
>> +  while getopts "cCdm" OPT
>>    do
>>     case "$OPT" in
>>       c) findArgs="${findArgs} -o -name configure.ac" ;;
>> @@ -144,145 +315,378 @@ find_source()
>>    find . -name "*.[chS]" ${findArgs}
>> -# Verify no lines longer than 80 columns
>> -echo "=== Checking for lines greater than 79 columns"
>> -find_source -m -c -C | while read f
>> -do
>> -  grep  ".\{80,\}" ${f} >/dev/null
>> -  if [ $? -eq 0 ] ; then
>> -    echo "*** ${basedir}/${f} has the following lines that are too long"
>> -    grep -n '.\{80,\}' ${f}
>> -  fi
>> -done
>> -# really need to make the copyright strings consistent in BSPs
>> -echo "=== Checking for copyright notices"
>> -find_source | while read f
>> -do
>> -  test_its_there_all_case ${f} COPYRIGHT
>> -done
>> -# We want CVS Id strings everywhere possible
>> -echo "=== Checking for CVS Id strings"
>> -find_source -d | while read f
>> -do
>> -  test_its_NOT_there ${f} "\$Id"
>> -done
>> -# We do not want the reformatted license notice
>> -echo "=== Checking for reformatted RTEMS license notices"
>> -do
>> -  test_its_NOT_there ${f} "this file may be found in the file"
>> -done
>> -# We do not want spaces at the end of lines
>> -echo "=== Checking for spaces at the end of lines"
>> -do
>> -  egrep " +$" $f >/dev/null
>> -  test $? -eq 0 && echo "$f has spaces at the end of one or more lines."
>> -done
>> -# We do not want tabs in source files
>> -echo "=== Checking for tabs in source files"
>> -do
>> -  grep -P '\t' $f >/dev/null
>> -  if [ $? -eq 0 ]; then
>> -    echo "*** ${basedir}/${f} has the following lines with tabs"
>> -    grep -P '\t' $f
>> -  fi
>> -done
>> -# We do not want GPL code
>> -echo "=== Checking for hints of GPL code"
>> -do
>> -  test_its_NOT_there ${f} "Free Software Foundation"
>> -  test_its_NOT_there ${f} "program is free software"
>> -  test_its_NOT_there ${f} "General Public License"
>> -done
>> -# We do not want hints that there are things left to do
>> -echo "=== Checking for TODO hints"
>> -do
>> -  test_its_NOT_there ${f} XXX
>> -  test_its_NOT_there ${f} TODO
>> -  test_its_NOT_there ${f} TBD
>> -done
>> +function check_format(){
>> -# BSP specific checks
>> -if [ ${do_bsp} = "yes" ] ; then
>> -  # We do not want stdio in a BSP
>> -  echo "=== Checking for stdio"
>> +  # Verify no lines longer than 80 columns
>> +  echo "=== Checking for lines greater than 80 columns"
>> +  find_source -m -c -C | while read f
>> +  do
>> +    grep  ".\{81,\}" ${f} >/dev/null
>> +    if [ $? -eq 0 ] ; then
>> +      echo -e "\n$bsp : ${f#./} has more than 80 character lines"
>> +      for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
>> +      do
>> +        echo -e "$i \c"
>> +    done
>> +    fi
>> +  done
>> +  # really need to make the copyright strings consistent in BSPs
>> +  echo -e "\n=== Checking for copyright notices"
>> +  find_source | while read f
>> +  do
>> +    test_its_there_all_case ${f} COPYRIGHT
>> +  done
>> +  # We want CVS Id strings everywhere possible
>> +  echo "=== Checking for CVS Id strings"
>> +  find_source -d | while read f
>> +  do
>> +    test_its_NOT_there ${f} "\$Id"
>> +  done
>> +  # We do not want the reformatted license notice
>> +  echo "=== Checking for reformatted RTEMS license notices"
>> +  do
>> +    test_its_NOT_there ${f} "this file may be found in the file"
>> +  done
>> +  # We do not want spaces at the end of lines
>> +  echo "=== Checking for spaces at the end of lines"
>> +  do
>> +    egrep " +$" $f >/dev/null
>> +    test $? -eq 0 && echo -e "${f##./} \c"
>> +  done
>> +  # We do not want tabs in source files
>> +  echo -e "\n=== Checking for tabs in source files"
>> +  do
>> +    grep -P '\t' $f >/dev/null
>> +  done
>> +  # We do not want GPL code
>> +  echo -e "\n=== Checking for hints of GPL code"
>>    do
>> -    test_its_NOT_there ${f} printf
>> -    test_its_NOT_there ${f} "puts("
>> +    test_its_NOT_there ${f} "Free Software Foundation"
>> +    test_its_NOT_there ${f} "program is free software"
>> +    test_its_NOT_there ${f} "General Public License"
>>    done
>> -  # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>> -  #   RTEMS_BSP_BOOTCARD_OPTIONS
>> -  if [ -r configure.ac ] ; then
>> -    echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
>> -    test_its_not_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>> -    echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
>> -    test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>> +  # We do not want hints that there are things left to do
>> +  echo "=== Checking for TODO hints"
>> +  do
>> +    test_its_NOT_there ${f} XXX
>> +    test_its_NOT_there ${f} TODO
>> +    test_its_NOT_there ${f} TBD
>> +  done
>> +# Reviewing for a BSP Starts
>> +function main(){
>> +  if [[ $format -eq "1" ]]; then
>> +    check_format
>>    fi
>> -  # If not using -O2, then we really want to know
>> -  # BSPs should normally use -O2
>> -  echo "=== Checking for not using -O2"
>> -  grep -H "\-O[013456789]" make/custom/*.cfg
>> +  # We do not want stdio in a BSP
>> +    echo "=== Checking for stdio"
>> +    do
>> +      test_its_NOT_there ${f} printf
>> +      test_its_NOT_there ${f} "puts("
>> +    done
>> +    # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>> +    #   RTEMS_BSP_BOOTCARD_OPTIONS
>> +    if [ -r configure.ac ] ; then
>> +      echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
>> +      test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>> +      echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
>> +      test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>> +    fi
>> +    # If not using -O2, then we really want to know
>> +    # BSPs should normally use -O2
>> +    echo "=== Checking for not using -O2"
>> +    grep -H "\-O[013456789]" make/custom/*.cfg
>> -  # BSPs should not turn on extra warnings
>> -  echo "=== Checking for turning on extra GCC warning checks"
>> -  grep -H "\-W" make/custom/*.cfg
>> +    # BSPs should not turn on extra warnings
>> +    echo "=== Checking for turning on extra GCC warning checks"
>> +    grep -H "\-W" make/custom/*.cfg
>> -  # Hopefully have some output from the tmtests
>> -  echo "=== Checking for timing information"
>> -  c=`ls -1 times* 2>/dev/null | wc -l`
>> -  if [ ${c} -eq 0 ] ; then
>> -    echo "Please run the timing tests and include the results."
>> +    # Hopefully have some output from the tmtests
>> +    echo "=== Checking for timing information"
>> +    c=`ls -1 times* 2>/dev/null | wc -l`
>> +    if [ ${c} -eq 0 ] ; then
>> +      echo "Please run the timing tests and include the results."
>>    fi
>> -fi  ## END OF IF BSP
>> +  echo -e "\n=== Starting BSP Unified way checks"
>> +  flag="0"
>> +  check_file 1 start.S ../shared/start/ start/
>> +  if [[ $filename != "0" ]];then
>> +    if grep -wq "start" "$filename" || grep -wq "_start" "$filename"; then
>> +        echo "$bsp : `basename $filename` start() present in $filename"
>> +      fi
>> +    else
>> +      echo "$bsp : `basename $filename` start() does not exist in start.S"
>> +    fi
>> +  fi
>> +  check_file 1 bspstart.c ../../shared/ ../shared/ startup/
>> +  check_methods "bsp_start"
>> +  check_file 1 bspreset.c ../../shared/ ../shared/ startup/
>> +  check_methods 1 "bsp_reset"
>> +  check_file 1 bootcard.c ../../shared/
>> +  check_header ../../shared/include/bootcard.h
>> +  check_file 1 bspclean.c ../../shared/ startup/
>> +  check_methods "bsp_fatal_extension"
>> +  check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup ../shared/ ../shared/startup/ startup/
>> +  check_methods 1 "bsp_work_area_initialize"
>> +  check_file 1 bsplibc.c ../../shared/
>> +  check_methods "bsp_libc_init"
>> +  check_file 1 bsppost.c ../../shared/
>> +  check_methods "bsp_postdriver_hook"
>> +  check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/ startup/
>> +  check_methods "bsp_predriver_hook"
>> +  check_file gnatinstallhandler.c ../../shared/
>> +  check_file sbrk.c ../../shared/ ../../shared/ startup/
>> +  check_methods "sbrk"
>> +  check_file stackalloc.c ../../shared/src/
>> +  check_methods "bsp_stack_allocate_init" "bsp_stack_allocate" "bsp_stack_free"
>> +  check_header ../../shared/include/stackalloc.h
>> +  # Interrupt Files
>> +  check_file 1 irq.c irq/
>> +  check_methods "bsp_interrupt_vector_enable" "bsp_interrupt_vector_disable" "bsp_interrupt_facility_initialize" "bsp_interrupt_dispatch"
>> +  check_header 1 include/irq.h
>> +  # PIC Support
>> +  check_file irq-default-handler.c ../../shared/src/
>> +  check_file 1 irq-generic.c ../../shared/src/
>> +  check_header 1 ../../shared/include/irq-generic.h
>> +  check_file irq-info.c ../../shared/src/
>> +  check_header ../../shared/include/irq-info.h
>> +  check_file irq-legacy.c ../../shared/src/
>> +  check_file irq-server.c ../../shared/src/
>> +  check_file irq-shell.c ../../shared/src/
>> +  # Real Time Clock
>> +  check_file rtc-config.c rtc/
>> +  check_methods "bsp_rtc_initialize" "bsp_rtc_get_time" "bsp_rtc_set_time" "bsp_rtc_probe"
>> +  check_file 1 tod.c ../../shared/ tod/
>> +  # Benchmark Timers
>> +  check_file benchmark_timer.c benchmark_timer/
>> +  check_methods "benchmark_timer_initialize" "benchmark_timer_read" "benchmark_timer_disable_subtracting_average_overhead"
>> +  # Standard Headers
>> +  check_header 1 include/bsp.h
>> +  check_header include/bspopts.h
>> +  check_header 1 ../../shared/include/coverhd.h include/coverhd.h
>> +  check_header ../../shared/include/utility.h
>> +  check_header 1 ../../shared/include/tm27.h include/tm27.h
>> +  cd ../../../../../../cpukit
>> +  find_rtems_internal
>> +  cd - > /dev/null
>> +  # Finding all internal functions being used in a bsp
>> +  find_bsp_internal
>> +  if [[ $flag == "1" ]]; then
>> +    echo -e "\n"
>> +  fi
>>  # Test specific checks
>> -if [ ${do_test} = "yes" ] ; then
>> -  # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>> -  Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>> -  if [ "X${Makefiles}" = "X" ] ; then
>> -    fatal "Unable to locate any test Makefile.am files."
>> -  fi
>> -  echo "=== Checking for missing test support files"
>> -  for m in ${Makefiles}
>> -  do
>> -    directory=`dirname ${m}`
>> -    if [ ${directory} = "." ] ; then
>> -      directory=`pwd`
>> +  if [ ${do_test} == "1" ] ; then
>> +    echo -e "\n=== Starting Test specific checks"
>> +    # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>> +    Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>> +    if [ "X${Makefiles}" = "X" ] ; then
>> +      echo -e "Unable to locate any test Makefile.am files.\n"
>> +      return
>>      fi
>> -    testName=`basename ${directory}`
>> -    # Does this test have a .doc file?
>> -    if [ ! -r ${directory}/${testName}.doc ] ; then
>> -      echo ${testName}.doc is not present
>> +    echo "=== Checking for missing test support files"
>> +    for m in ${Makefiles}
>> +    do
>> +      directory=`dirname ${m}`
>> +      if [ ${directory} = "." ] ; then
>> +        directory=`pwd`
>> +      fi
>> +      testName=`basename ${directory}`
>> +      # Does this test have a .doc file?
>> +      if [ ! -r ${directory}/${testName}.doc ] ; then
>> +        echo ${testName}.doc is not present
>> +      fi
>> +      case ${directory} in
>> +        */*tmtests*) ;;
>> +          # Does this test have a .scn file?
>> +          if [ ! -r ${directory}/${testName}.scn ] ; then
>> +            echo ${testName}.scn is not present
>> +          fi
>> +      esac
>> +    done
>> +  fi
>> +# Verifying if the directory given or pwd is a valid bsp, shared architecture, or libbsp directory
>> +function check_given_dir(){
>> +  if echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
>> +    return 0
>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
>> +# BSP given
>> +    bsp=${cur_dir##*/}
>> +    if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp == "no_bsp" ]]; then
>> +      return 0
>> +    else
>> +      main
>>      fi
>> -    case ${directory} in
>> -      */*tmtests*) ;;
>> -        # Does this test have a .scn file?
>> -        if [ ! -r ${directory}/${testName}.scn ] ; then
>> -          echo ${testName}.scn is not present
>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
>> +# Shared architecture given
>> +    for i in *
>> +    do
>> +        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_bsp" ]]; then
>> +          echo -n
>> +        else
>> +          bsp=$i
>> +          cd $bsp
>> +          main
>> +          cd .. > /dev/null
>> +        fi
>> +      fi
>> +    done
>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
>> +# libbsp given
>> +    for i in */*/Makefile.am
>> +    do
>> +      i=`dirname $i`
>> +        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_cpu/no_bsp" ]]; then
>> +          echo -n
>> +        else
>> +          bsp=$i
>> +          cd $bsp
>> +          main
>> +          cd ../../ > /dev/null
>>          fi
>> +      fi
>> +    done
>> +  else
>> +    return 0
>> +  fi
>> +# Evaluating Command Line Arguments
>> +function start(){
>> +  for i in $*
>> +  do
>> +    case $i in
>> +      "--verbose") verbose="1" # The whole story
>> +      "--warnings") warnings="1" # All warnings
>> +              verbose="0"
>> +      "--no_format") format="0" # Disabling format checks
>> +              verbose="0"
>> +      "--tests") do_test="1"    # Enabling check of tests
>> +             verbose="0"
>> +      "--help") echo "Help to be provided"
>> +      "--"* | "-"* ) echo "Invalid options provided"
>> +      *) path="$path $i"  ;; # If not above options, then assumed to be a path for bsp
>>      esac
>>    done
>> -fi
>> -exit 0
>> +# No path given, search for bsp from pwd
>> +  if [[ -z $path ]];then
>> +    path=$PWD
>> +    cur_dir=`pwd`
>> +    check_given_dir
>> +    if [[ $? -eq 1 ]];then
>> +      echo "Current directory does not seem a valid RTEMS directory"
>> +    fi
>> +  else
>> +    for i in $path
>> +    do
>> +        echo > /dev/null
>> +      else
>> +        echo "$i is an invalid directory."
>> +        continue
>> +      fi
>> +      cd $i
>> +      cur_dir=`pwd`
>> +      check_given_dir
>> +        echo "$i does not seem a valid RTEMS directory"
>> +      fi
>> +      cd $calling_path
>> +    done
>> +  fi
>> +# Let the Game begin !!
>> +start $*
>> +# End of Checks
>> +if [[ $faults -eq "0" ]] ; then
>> +  echo -e "\nNo faults found in BSP organization"
>> +fi
>> 1.7.11.7
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
