[PATCH] Bash script to review BSP File Organization
Tue Sep 17 18:19:55 UTC 2013
Vipul
Make sure it gives the same results after check in
that it did from your local version.
Paranoid sounding but better to be safe than sorry.
On 9/17/2013 1:12 PM, Vipul Nayyar wrote:
> Hello Gedare, Joel
> Thanks for committing it. I can see it
> here http://git.rtems.org/rtems-testing/commit/?id=3486c86b95341b50876a781f5c178229c52bf26b
> I hope it's visible to everyone :-)
> Regards
> Vipul Nayyar
> *From:* Gedare Bloom <gedare at rtems.org>
> *To:* Joel Sherrill <joel.sherrill at oarcorp.com>
> *Cc:* Vipul Nayyar <nayyar_vipul at yahoo.com>; "rtems-devel at rtems.org"
> <rtems-devel at rtems.org>
> *Sent:* Tuesday, 17 September 2013 11:39 PM
> *Subject:* Re: [PATCH] Bash script to review BSP File Organization
> Hey Joel and Vipul,
> I applied and committed it. Please verify.
> -Gedare
> On Tue, Sep 17, 2013 at 1:51 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>> I don't know what is wrong but it doesn't apply. :(
>> patching file merge-helpers/check_submission
>> patch: **** malformed patch at line 110: '0' to give only important stuff.
>> On 9/17/2013 12:24 PM, Vipul Nayyar wrote:
>>>  merge-helpers/check_submission | 776
>>>  1 file changed, 590 insertions(+), 186 deletions(-)
>>> diff --git a/merge-helpers/check_submission
> b/merge-helpers/check_submission
>>> index e838121..90908f1 100755
>>> --- a/merge-helpers/check_submission
>>> +++ b/merge-helpers/check_submission
>>> @@ -1,76 +1,247 @@
>>> -#  Script to test for various things we want in a BSP when it is
>>> -#  submitted.
>>> -#  Test for:
>>> -#    - XXX
>>> +#! /bin/bash
>>> -usage()
>>> -cat <<EOF
>>> -check_submission [options] directory
>>> -  -b - check assuming directory is a BSP
>>> -  -t - check assuming directory is a test
>>> -  -v - verbose
>>> -EOF
>>> +# Bash Script to find discrepancies in BSP file organization.
>>> +# Author : Vipul Nayyar <nayyar_vipul at yahoo.com
> <mailto:nayyar_vipul at yahoo.com>>
>>> -fatal()
>>> -  usage
>>> -  exit 1
>>> +filename="0"
>>> +# Passing --verbose turns verbose to 1 & gives the whole story,
> otherwise '0' to give only important stuff.
>>> +verbose="0"
>>> +faults="0"
>>> +# Passing --warnings turns warnings to 1 & gives all the critical &
> non-critical bsp file org. problems.
>>> +warnings="0"
>>> +flag="0"
>>> +calling_path=`pwd`
>>> +path=""
>>> +important="1"
>>> +rtems_internal=""
>>> +internal_done="0"
>>> +do_test="0"
>>> +format="1"
>>> +# Finds all rtems internal functions ( name starting with '_' & type
> specifier)
>>> +# that are defined in cpukit & libcpu
>>> +function find_rtems_internal(){
>>> +  if [[ $internal_done == "1" ]]; then
>>> +    return
>>> +  fi
>>> +  echo "Compiling list of RTEMS Internal functions ..."
>>> +  internal_files=""
>>> +  for k in `find -name *.c`
>>> +  do
>>> +    for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\
> ]*\(" $k`
>>> +    do
>>> +      if [[ $j == "_"* ]]; then
>>> +        j=${j%%\(}
>>> +        internal_files="$j $internal_files"
>>> +      fi
>>> +    done
>>> +  done
>>> +  for k in `find ../c/src/lib/libcpu/ -name *.c`
>>> +  do
> ]*\(" $k`
>>> +    do
>>> +        j=${j%%\(}
>>> +      fi
>>> +    done
>>> +  done
>>> +  for k in $internal_files
>>> +  do
>>> +    if echo $rtems_internal |grep -q $k ; then
>>> +      echo > /dev/null
>>> +    else
>>> +      rtems_internal="$k $rtems_internal"
>>> +    fi
>>> +  done
>>> +  internal_done="1"
>>> -toggle()
>>> -  case $1 in
>>> -    no)  echo "yes" ;;
>>> -    yes) echo "no" ;;
>>> -    *)  fatal "Unknown value to toggle ($1)" ;;
>>> -  esac
>>> +# Finds all internal functions common in bsp and (cpukit + libcpu)
>>> +function find_bsp_internal(){
>>> +  bsp_methods=""
>>> +  common_internal_methods=""
>>> +# Searching for internal functions starting with '_' called(i.e
> ending with a ';')
>>> +  for i in `find -name *.c`
>>> +  do
>>> +    file_contents=`tr -d '\n' < $i | grep -oE "[
> |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
>>> +    for j in `echo "$file_contents" | grep -oE
> "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
>>> +    do
>>> +      if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
>>> +        echo > /dev/null
>>> +      else
>>> +        bsp_methods="${j%%\(} $bsp_methods"
>>> +      fi
>>> +    done
>>> +  done
>>> +# Identifying common fucntions between $rtems_interval & $bsp_methods
>>> +  for i in $rtems_internal
>>> +  do
>>> +    if [[ $i == "__asm__" || $i == "__attribute__" || $i ==
> "__volatile__" || $i == "__"* ]];then
>>> +      continue
>>> +    fi
>>> +    for j in $bsp_methods
>>> +    do
>>> +      if [[ $i == $j ]]; then
>>> +        common_internal_methods="$j $common_internal_methods"
>>> +      fi
>>> +    done
>>> +  done
>>> +  if [[ $common_internal_methods != "" ]]; then
>>> +    echo -e "$bsp : RTEMS Internal functions used : \c"
>>> +    for i in $common_internal_methods
>>> +    do
>>> +      echo -e "${i}() \c"
>>> +    done
>>> +    flag="1"
>>> +  fi
>>> -verbose="no"
>>> -do_bsp="no"
>>> -do_test="no"
>>> -while getopts vbt OPT
>>> -do
>>> -    case "$OPT" in
>>> -        b) do_bsp="yes" ; do_test="no"  ;;
>>> -        t) do_bsp="no"  ; do_test="yes" ;;
>>> -        v) verbose=`toggle ${verbose}` ;;
>>> -        *) fatal ;;
>>> -    esac
>>> -done
>>> -########################### Grab Directory ###########################
>>> +# Passing 1 initially to any check function states that the
> file/method/header
>>> +# being checked is of critical nature
>>> +function check_file(){
>>> +  filename="0"
>>> +  if [[ $1 == 1 ]]; then
>>> +    important="1"
>>> +    shift
>>> +  else
>>> +    important="0"
>>> +  fi
>>> -shiftcount=`expr $OPTIND - 1`
>>> -shift $shiftcount
>>> +#Grabbing the path of file being evaluated from Makefile.am
>>> +  if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
>>> +    file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
>>> +    cd `dirname $file_path`
>>> +    filename=$1
>>> +    file_path=`pwd`
>>> +    cd - > /dev/null
>>> +    shift
>>> +# Checking if file lies in correct directory path
>>> +    for i in $*
>>> +    do
>>> +      if [[ -d $i ]]; then
>>> +        cd $i
>>> +      else
>>> +        continue
>>> +      fi
>>> +      if [[ "$file_path" == `pwd` ]]; then
>>> +        filename="$file_path/$filename"
>>> +        cd - >/dev/null
>>> +        return
>>> +      fi
>>> +      cd - > /dev/null
>>> +    done
>>> +    echo "$bsp : $filename not present in correct path"
>>> +    return
>>> +  else
>>> +    if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq
> "1" ]]; then
>>> +      flag="1"
>>> +      echo "$bsp : $1 not compiled"
>>> +    fi
>>> +  fi
>>> -basedir=${1}
>>> +  filename="0"
>>> +  faults="1"
>>> +  return
>>> -if [ "${basedir}X" = "X" ] ; then
>>> -  basedir=.
>>> -fi
>>> +# Checking presence of functions in specific files
>>> +function check_methods(){
>>> +    important="1"
>>> +    shift
>>> +  else
>>> +    important="0"
>>> +  fi
>>> -if [ ${do_bsp} = "no" -a ${do_test} = "no" ] ; then
>>> -  fatal must select test or bsp check mode
>>> -fi
>>> +  for i in $*
>>> +  do
>>> -if [ ! -d ${basedir} ] ; then
>>> -  fatal ${basedir} is not a directory
>>> -fi
>>> +# When correct file for this function does not exist
>>> +    if [[ $filename == "0" ]];then
>>> +      if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
> -eq "1" ]];then
>>> +          echo $bsp : ${i%(*}"()" present in file `grep -rlE
> "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
>>> +        fi
>>> +      fi
>>> +    else
>>> +# When correct file for this function exists
>>> +      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
>>> +        if [[ $verbose -eq "1" ]] ;then
>>> +          echo "$bsp : `basename $filename` : ${i%(*}() present in file"
>>> +        fi
>>> +      else
> -eq "1" ]];then
>>> +          fi
>>> +        else
> -eq "1" ]]; then
>>> +            echo "$bsp : `basename $filename` : ${i%(*}() function
> does not exist in $filename "
>>> +            flag="1"
>>> +          fi
>>> +            faults="1"
>>> +        fi
>>> +      fi
>>> +    fi
>>> +  done
>>> +# Checking presence of headers installed by bsp
>>> +function check_header(){
>>> +    important="1"
>>> +    shift
>>> +  else
>>> +    important="0"
>>> +  fi
>>> -cd ${basedir}
>>> -if [ $? -ne 0 ] ; then
>>> -  echo Unable to cd to ${basedir}
>>> -  exit 1
>>> -fi
>>> +  for i in $*
>>> +  do
>>> +    if  grep -wq "$i" Makefile.am ;then
>>> +      if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
>>> +        continue
>>> +      fi
>>> +        cd `dirname $i`
>>> +        echo "$bsp : `basename $i` installed from directory"
> ${PWD##*/c/src/lib/}
>>> +        cd - > /dev/null
>>> +      fi
>>> +      return
>>> +    fi
>>> +  done
>>> +  if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1"
> ]]; then
>>> +    echo "${bsp%%[\ ]*} : `basename $1` not installed "
>>> +    flag="1"
>>> +  fi
>>> +  filename="0"
>>> +  faults="1"
>>> +  return
>>>  test_its_there()
>>> @@ -79,7 +250,7 @@ test_its_there()
>>>    fi
>>>    grep ${2} ${1} >/dev/null
>>> -    echo "${2} is NOT in ${basedir}/${1}"
>>> +    echo "$bsp : ${2} is NOT in ${1##./}"
>>>    fi
>>> @@ -91,7 +262,7 @@ test_its_there_all_case()
>>>    fi
>>>    grep -i ${2} ${1} >/dev/null
>>> -    echo "${2} is NOT in ${basedir}/${1} - case independent check"
>>> +    echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
>>>    fi
>>> @@ -105,7 +276,7 @@ test_its_NOT_there_all_case()
>>>    shift
>>>    grep -i "${*}" ${FILE} >/dev/null
>>>    if [ $? -eq 0 ] ; then
>>> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE} - case
> independent check"
>>> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case
> independent check"
>>>    fi
>>> @@ -118,14 +289,14 @@ test_its_NOT_there()
>>>    shift
>>>    grep "${*}" ${FILE} >/dev/null
>>> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE}"
>>> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
>>>    fi
>>>  find_source()
>>>    findArgs=
>>> -  while getopts "cCm" OPT
>>> +  while getopts "cCdm" OPT
>>>    do
>>>    case "$OPT" in
>>>      c) findArgs="${findArgs} -o -name configure.ac" ;;
>>> @@ -144,145 +315,378 @@ find_source()
>>>    find . -name "*.[chS]" ${findArgs}
>>> -# Verify no lines longer than 80 columns
>>> -echo "=== Checking for lines greater than 79 columns"
>>> -find_source -m -c -C | while read f
>>> -do
>>> -  grep  ".\{80,\}" ${f} >/dev/null
>>> -  if [ $? -eq 0 ] ; then
>>> -    echo "*** ${basedir}/${f} has the following lines that are too long"
>>> -    grep -n '.\{80,\}' ${f}
>>> -  fi
>>> -done
>>> -# really need to make the copyright strings consistent in BSPs
>>> -echo "=== Checking for copyright notices"
>>> -find_source | while read f
>>> -do
>>> -  test_its_there_all_case ${f} COPYRIGHT
>>> -done
>>> -# We want CVS Id strings everywhere possible
>>> -echo "=== Checking for CVS Id strings"
>>> -find_source -d | while read f
>>> -do
>>> -  test_its_NOT_there ${f} "\$Id"
>>> -done
>>> -# We do not want the reformatted license notice
>>> -echo "=== Checking for reformatted RTEMS license notices"
>>> -do
>>> -  test_its_NOT_there ${f} "this file may be found in the file"
>>> -done
>>> -# We do not want spaces at the end of lines
>>> -echo "=== Checking for spaces at the end of lines"
>>> -do
>>> -  egrep " +$" $f >/dev/null
>>> -  test $? -eq 0 && echo "$f has spaces at the end of one or more lines."
>>> -done
>>> -# We do not want tabs in source files
>>> -echo "=== Checking for tabs in source files"
>>> -do
>>> -  grep -P '\t' $f >/dev/null
>>> -  if [ $? -eq 0 ]; then
>>> -    echo "*** ${basedir}/${f} has the following lines with tabs"
>>> -    grep -P '\t' $f
>>> -  fi
>>> -done
>>> -# We do not want GPL code
>>> -echo "=== Checking for hints of GPL code"
>>> -do
>>> -  test_its_NOT_there ${f} "Free Software Foundation"
>>> -  test_its_NOT_there ${f} "program is free software"
>>> -  test_its_NOT_there ${f} "General Public License"
>>> -done
>>> -# We do not want hints that there are things left to do
>>> -echo "=== Checking for TODO hints"
>>> -do
>>> -  test_its_NOT_there ${f} XXX
>>> -  test_its_NOT_there ${f} TODO
>>> -  test_its_NOT_there ${f} TBD
>>> -done
>>> +function check_format(){
>>> -# BSP specific checks
>>> -if [ ${do_bsp} = "yes" ] ; then
>>> -  # We do not want stdio in a BSP
>>> -  echo "=== Checking for stdio"
>>> +  # Verify no lines longer than 80 columns
>>> +  echo "=== Checking for lines greater than 80 columns"
>>> +  find_source -m -c -C | while read f
>>> +  do
>>> +    grep  ".\{81,\}" ${f} >/dev/null
>>> +    if [ $? -eq 0 ] ; then
>>> +      echo -e "\n$bsp : ${f#./} has more than 80 character lines"
>>> +      for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
>>> +      do
>>> +        echo -e "$i \c"
>>> +    done
>>> +    fi
>>> +  done
>>> +  # really need to make the copyright strings consistent in BSPs
>>> +  echo -e "\n=== Checking for copyright notices"
>>> +  find_source | while read f
>>> +  do
>>> +    test_its_there_all_case ${f} COPYRIGHT
>>> +  done
>>> +  # We want CVS Id strings everywhere possible
>>> +  echo "=== Checking for CVS Id strings"
>>> +  find_source -d | while read f
>>> +  do
>>> +    test_its_NOT_there ${f} "\$Id"
>>> +  done
>>> +  # We do not want the reformatted license notice
>>> +  echo "=== Checking for reformatted RTEMS license notices"
>>> +  do
>>> +    test_its_NOT_there ${f} "this file may be found in the file"
>>> +  done
>>> +  # We do not want spaces at the end of lines
>>> +  echo "=== Checking for spaces at the end of lines"
>>> +  do
>>> +    egrep " +$" $f >/dev/null
>>> +    test $? -eq 0 && echo -e "${f##./} \c"
>>> +  done
>>> +  # We do not want tabs in source files
>>> +  echo -e "\n=== Checking for tabs in source files"
>>> +  do
>>> +    grep -P '\t' $f >/dev/null
>>> +  done
>>> +  # We do not want GPL code
>>> +  echo -e "\n=== Checking for hints of GPL code"
>>>    do
>>> -    test_its_NOT_there ${f} printf
>>> -    test_its_NOT_there ${f} "puts("
>>> +    test_its_NOT_there ${f} "Free Software Foundation"
>>> +    test_its_NOT_there ${f} "program is free software"
>>> +    test_its_NOT_there ${f} "General Public License"
>>>    done
>>> -  # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>>> -  #  RTEMS_BSP_BOOTCARD_OPTIONS
>>> -  if [ -r configure.ac ] ; then
>>> -    echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP
> configure.ac"
>>> -    test_its_not_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>>> -    echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP
> configure.ac"
>>> -    test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>>> +  # We do not want hints that there are things left to do
>>> +  echo "=== Checking for TODO hints"
>>> +  do
>>> +    test_its_NOT_there ${f} XXX
>>> +    test_its_NOT_there ${f} TODO
>>> +    test_its_NOT_there ${f} TBD
>>> +  done
>>> +# Reviewing for a BSP Starts
>>> +function main(){
>>> +  if [[ $format -eq "1" ]]; then
>>> +    check_format
>>>    fi
>>> -  # If not using -O2, then we really want to know
>>> -  # BSPs should normally use -O2
>>> -  echo "=== Checking for not using -O2"
>>> -  grep -H "\-O[013456789]" make/custom/*.cfg
>>> +  # We do not want stdio in a BSP
>>> +    echo "=== Checking for stdio"
>>> +    do
>>> +      test_its_NOT_there ${f} printf
>>> +      test_its_NOT_there ${f} "puts("
>>> +    done
>>> +    # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>>> +    #  RTEMS_BSP_BOOTCARD_OPTIONS
>>> +    if [ -r configure.ac ] ; then
>>> +      echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP
> configure.ac"
>>> +      test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>>> +      echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP
> configure.ac"
>>> +      test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>>> +    fi
>>> +    # If not using -O2, then we really want to know
>>> +    # BSPs should normally use -O2
>>> +    echo "=== Checking for not using -O2"
>>> +    grep -H "\-O[013456789]" make/custom/*.cfg
>>> -  # BSPs should not turn on extra warnings
>>> -  echo "=== Checking for turning on extra GCC warning checks"
>>> -  grep -H "\-W" make/custom/*.cfg
>>> +    # BSPs should not turn on extra warnings
>>> +    echo "=== Checking for turning on extra GCC warning checks"
>>> +    grep -H "\-W" make/custom/*.cfg
>>> -  # Hopefully have some output from the tmtests
>>> -  echo "=== Checking for timing information"
>>> -  c=`ls -1 times* 2>/dev/null | wc -l`
>>> -  if [ ${c} -eq 0 ] ; then
>>> -    echo "Please run the timing tests and include the results."
>>> +    # Hopefully have some output from the tmtests
>>> +    echo "=== Checking for timing information"
>>> +    c=`ls -1 times* 2>/dev/null | wc -l`
>>> +    if [ ${c} -eq 0 ] ; then
>>> +      echo "Please run the timing tests and include the results."
>>>    fi
>>> -fi  ## END OF IF BSP
>>> +  echo -e "\n=== Starting BSP Unified way checks"
>>> +  flag="0"
>>> +  check_file 1 start.S ../shared/start/ start/
>>> +  if [[ $filename != "0" ]];then
>>> +    if grep -wq "start" "$filename" || grep -wq "_start"
> "$filename"; then
>>> +        echo "$bsp : `basename $filename` start() present in $filename"
>>> +      fi
>>> +    else
>>> +      echo "$bsp : `basename $filename` start() does not exist in
> start.S"
>>> +    fi
>>> +  fi
>>> +  check_file 1 bspstart.c ../../shared/ ../shared/ startup/
>>> +  check_methods "bsp_start"
>>> +  check_file 1 bspreset.c ../../shared/ ../shared/ startup/
>>> +  check_methods 1 "bsp_reset"
>>> +  check_file 1 bootcard.c ../../shared/
>>> +  check_header ../../shared/include/bootcard.h
>>> +  check_file 1 bspclean.c ../../shared/ startup/
>>> +  check_methods "bsp_fatal_extension"
>>> +  check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup
> ../shared/ ../shared/startup/ startup/
>>> +  check_methods 1 "bsp_work_area_initialize"
>>> +  check_file 1 bsplibc.c ../../shared/
>>> +  check_methods "bsp_libc_init"
>>> +  check_file 1 bsppost.c ../../shared/
>>> +  check_methods "bsp_postdriver_hook"
>>> +  check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/
> startup/
>>> +  check_methods "bsp_predriver_hook"
>>> +  check_file gnatinstallhandler.c ../../shared/
>>> +  check_file sbrk.c ../../shared/ ../../shared/ startup/
>>> +  check_methods "sbrk"
>>> +  check_file stackalloc.c ../../shared/src/
>>> +  check_methods "bsp_stack_allocate_init" "bsp_stack_allocate"
> "bsp_stack_free"
>>> +  check_header ../../shared/include/stackalloc.h
>>> +  # Interrupt Files
>>> +  check_file 1 irq.c irq/
>>> +  check_methods "bsp_interrupt_vector_enable"
> "bsp_interrupt_vector_disable" "bsp_interrupt_facility_initialize"
> "bsp_interrupt_dispatch"
>>> +  check_header 1 include/irq.h
>>> +  # PIC Support
>>> +  check_file irq-default-handler.c ../../shared/src/
>>> +  check_file 1 irq-generic.c ../../shared/src/
>>> +  check_header 1 ../../shared/include/irq-generic.h
>>> +  check_file irq-info.c ../../shared/src/
>>> +  check_header ../../shared/include/irq-info.h
>>> +  check_file irq-legacy.c ../../shared/src/
>>> +  check_file irq-server.c ../../shared/src/
>>> +  check_file irq-shell.c ../../shared/src/
>>> +  # Real Time Clock
>>> +  check_file rtc-config.c rtc/
>>> +  check_methods "bsp_rtc_initialize" "bsp_rtc_get_time"
> "bsp_rtc_set_time" "bsp_rtc_probe"
>>> +  check_file 1 tod.c ../../shared/ tod/
>>> +  # Benchmark Timers
>>> +  check_file benchmark_timer.c benchmark_timer/
>>> +  check_methods "benchmark_timer_initialize" "benchmark_timer_read"
> "benchmark_timer_disable_subtracting_average_overhead"
>>> +  # Standard Headers
>>> +  check_header 1 include/bsp.h
>>> +  check_header include/bspopts.h
>>> +  check_header 1 ../../shared/include/coverhd.h include/coverhd.h
>>> +  check_header ../../shared/include/utility.h
>>> +  check_header 1 ../../shared/include/tm27.h include/tm27.h
>>> +  cd ../../../../../../cpukit
>>> +  find_rtems_internal
>>> +  cd - > /dev/null
>>> +  # Finding all internal functions being used in a bsp
>>> +  find_bsp_internal
>>> +  if [[ $flag == "1" ]]; then
>>> +    echo -e "\n"
>>> +  fi
>>>  # Test specific checks
>>> -if [ ${do_test} = "yes" ] ; then
>>> -  # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>>> -  Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>>> -  if [ "X${Makefiles}" = "X" ] ; then
>>> -    fatal "Unable to locate any test Makefile.am files."
>>> -  fi
>>> -  echo "=== Checking for missing test support files"
>>> -  for m in ${Makefiles}
>>> -  do
>>> -    directory=`dirname ${m}`
>>> -    if [ ${directory} = "." ] ; then
>>> -      directory=`pwd`
>>> +  if [ ${do_test} == "1" ] ; then
>>> +    echo -e "\n=== Starting Test specific checks"
>>> +    # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>>> +    Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>>> +    if [ "X${Makefiles}" = "X" ] ; then
>>> +      echo -e "Unable to locate any test Makefile.am files.\n"
>>> +      return
>>>      fi
>>> -    testName=`basename ${directory}`
>>> -    # Does this test have a .doc file?
>>> -    if [ ! -r ${directory}/${testName}.doc ] ; then
>>> -      echo ${testName}.doc is not present
>>> +    echo "=== Checking for missing test support files"
>>> +    for m in ${Makefiles}
>>> +    do
>>> +      directory=`dirname ${m}`
>>> +      if [ ${directory} = "." ] ; then
>>> +        directory=`pwd`
>>> +      fi
>>> +      testName=`basename ${directory}`
>>> +      # Does this test have a .doc file?
>>> +      if [ ! -r ${directory}/${testName}.doc ] ; then
>>> +        echo ${testName}.doc is not present
>>> +      fi
>>> +      case ${directory} in
>>> +        */*tmtests*) ;;
>>> +          # Does this test have a .scn file?
>>> +          if [ ! -r ${directory}/${testName}.scn ] ; then
>>> +            echo ${testName}.scn is not present
>>> +          fi
>>> +      esac
>>> +    done
>>> +  fi
>>> +# Verifying if the directory given or pwd is a valid bsp, shared
> architecture, or libbsp directory
>>> +function check_given_dir(){
>>> +  if echo $cur_dir | grep -Eq
> "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
>>> +    return 0
>>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ;
> then
>>> +# BSP given
>>> +    bsp=${cur_dir##*/}
>>> +    if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp ==
> "no_bsp" ]]; then
>>> +      return 0
>>> +    else
>>> +      main
>>>      fi
>>> -    case ${directory} in
>>> -      */*tmtests*) ;;
>>> -        # Does this test have a .scn file?
>>> -        if [ ! -r ${directory}/${testName}.scn ] ; then
>>> -          echo ${testName}.scn is not present
>>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
>>> +# Shared architecture given
>>> +    for i in *
>>> +    do
>>> +        if [[ $i == "shared" || $i == "autom4te.cache" || $i ==
> "no_bsp" ]]; then
>>> +          echo -n
>>> +        else
>>> +          bsp=$i
>>> +          cd $bsp
>>> +          main
>>> +          cd .. > /dev/null
>>> +        fi
>>> +      fi
>>> +    done
>>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
>>> +# libbsp given
>>> +    for i in */*/Makefile.am
>>> +    do
>>> +      i=`dirname $i`
> "no_cpu/no_bsp" ]]; then
>>> +          echo -n
>>> +        else
>>> +          bsp=$i
>>> +          cd $bsp
>>> +          main
>>> +          cd ../../ > /dev/null
>>>          fi
>>> +      fi
>>> +    done
>>> +  else
>>> +    return 0
>>> +  fi
>>> +# Evaluating Command Line Arguments
>>> +function start(){
>>> +  for i in $*
>>> +  do
>>> +    case $i in
>>> +      "--verbose") verbose="1" # The whole story
>>> +      "--warnings") warnings="1" # All warnings
>>> +              verbose="0"
>>> +      "--no_format") format="0" # Disabling format checks
>>> +              verbose="0"
>>> +      "--tests") do_test="1"    # Enabling check of tests
>>> +            verbose="0"
>>> +      "--help") echo "Help to be provided"
>>> +      "--"* | "-"* ) echo "Invalid options provided"
>>> +      *) path="$path $i"  ;; # If not above options, then assumed to
> be a path for bsp
>>>      esac
>>>    done
>>> -fi
>>> -exit 0
>>> +# No path given, search for bsp from pwd
>>> +  if [[ -z $path ]];then
>>> +    path=$PWD
>>> +    cur_dir=`pwd`
>>> +    check_given_dir
>>> +    if [[ $? -eq 1 ]];then
>>> +      echo "Current directory does not seem a valid RTEMS directory"
>>> +    fi
>>> +  else
>>> +    for i in $path
>>> +    do
>>> +        echo > /dev/null
>>> +      else
>>> +        echo "$i is an invalid directory."
>>> +        continue
>>> +      fi
>>> +      cd $i
>>> +      cur_dir=`pwd`
>>> +      check_given_dir
>>> +        echo "$i does not seem a valid RTEMS directory"
>>> +      fi
>>> +      cd $calling_path
>>> +    done
>>> +  fi
>>> +# Let the Game begin !!
>>> +start $*
>>> +# End of Checks
>>> +if [[ $faults -eq "0" ]] ; then
>>> +  echo -e "\nNo faults found in BSP organization"
>>> +fi
>>> 1.7.11.7
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Joel Sherrill, Ph.D.            Director of Research & Development
>> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>
> On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
