[PATCH] Adding support for whitespace directory names in check_submission
Vipul Nayyar
nayyar_vipul at yahoo.com
Sat Sep 21 18:17:37 UTC 2013
merge-helpers/check_submission | 382 ++++++++++++++++++++---------------------
1 file changed, 189 insertions(+), 193 deletions(-)
diff --git a/merge-helpers/check_submission b/merge-helpers/check_submission
index 90908f1..47ea6cf 100755
--- a/merge-helpers/check_submission
+++ b/merge-helpers/check_submission
@@ -1,9 +1,7 @@
-#! /bin/bash
# Bash Script to find discrepancies in BSP file organization.
# Author : Vipul Nayyar <nayyar_vipul at yahoo.com>
filename="0"
# Passing --verbose turns verbose to 1 & gives the whole story, otherwise '0' to give only important stuff.
verbose="0"
@@ -12,7 +10,7 @@ faults="0"
warnings="0"
flag="0"
-calling_path=`pwd`
+calling_path=$(pwd)
path=""
important="1"
@@ -25,17 +23,18 @@ format="1"
# Finds all rtems internal functions ( name starting with '_' & type specifier)
# that are defined in cpukit & libcpu
function find_rtems_internal(){
- if [[ $internal_done == "1" ]]; then
+ if [[ "$internal_done" == "1" ]]; then
return
fi
echo "Compiling list of RTEMS Internal functions ..."
internal_files=""
- for k in `find -name *.c`
+ for k in $(find -name *.c)
do
- for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k`
+ for j in $(grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k)
do
- if [[ $j == "_"* ]]; then
+ if [[ "$j" == "_"* ]]; then
j=${j%%\(}
internal_files="$j $internal_files"
fi
@@ -43,11 +42,11 @@ function find_rtems_internal(){
done
done
- for k in `find ../c/src/lib/libcpu/ -name *.c`
+ for k in $(find ../c/src/lib/libcpu/ -name *.c)
do
do
j=${j%%\(}
fi
@@ -57,7 +56,7 @@ function find_rtems_internal(){
for k in $internal_files
do
- if echo $rtems_internal |grep -q $k ; then
+ if echo $rtems_internal |grep -q "$k" ; then
echo > /dev/null
else
rtems_internal="$k $rtems_internal"
@@ -69,39 +68,40 @@ function find_rtems_internal(){
# Finds all internal functions common in bsp and (cpukit + libcpu)
function find_bsp_internal(){
bsp_methods=""
common_internal_methods=""
-# Searching for internal functions starting with '_' called(i.e ending with a ';')
- for i in `find -name *.c`
+ # Searching for internal functions starting with '_' called(i.e ending with a ';')
+ for i in $( find -name *.c )
do
- file_contents=`tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
- for j in `echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
+ file_contents=$(tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;\{]*\)[ ]*;" | tr -d '\n')
+ for j in $( echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\(" )
do
- if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
+ if $(echo "$bsp_methods" | grep -q "${j%%\(}") ; then
echo > /dev/null
else
bsp_methods="${j%%\(} $bsp_methods"
fi
done
done
-# Identifying common fucntions between $rtems_interval & $bsp_methods
+ # Identifying common fucntions between $rtems_interval & $bsp_methods
for i in $rtems_internal
do
- if [[ $i == "__asm__" || $i == "__attribute__" || $i == "__volatile__" || $i == "__"* ]];then
+ if [[ "$i" == "__asm__" || "$i" == "__attribute__" || "$i" == "__volatile__" || "$i" == "__"* ]];then
continue
fi
for j in $bsp_methods
do
- if [[ $i == $j ]]; then
+ if [[ "$i" == "$j" ]]; then
common_internal_methods="$j $common_internal_methods"
fi
done
done
- if [[ $common_internal_methods != "" ]]; then
+ if [[ "$common_internal_methods" != "" ]]; then
echo -e "$bsp : RTEMS Internal functions used : \c"
for i in $common_internal_methods
do
@@ -111,10 +111,10 @@ function find_bsp_internal(){
fi
# Passing 1 initially to any check function states that the file/method/header
# being checked is of critical nature
function check_file(){
filename="0"
if [[ $1 == 1 ]]; then
important="1"
@@ -123,27 +123,27 @@ function check_file(){
important="0"
fi
-#Grabbing the path of file being evaluated from Makefile.am
+ #Grabbing the path of file being evaluated from Makefile.am
if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
- file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
- cd `dirname $file_path`
- filename=$1
- file_path=`pwd`
+ file_path="$(grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1)"
+ cd "$(dirname $file_path)"
+ filename="$1"
+ file_path="$(pwd)"
cd - > /dev/null
shift
-# Checking if file lies in correct directory path
- for i in $*
+ # Checking if file lies in correct directory path
+ for i in $@
do
- if [[ -d $i ]]; then
- cd $i
+ if [[ -d "$i" ]]; then
+ cd "$i"
else
continue
fi
- if [[ "$file_path" == `pwd` ]]; then
+ if [[ "$file_path" == $(pwd) ]]; then
filename="$file_path/$filename"
cd - >/dev/null
return
@@ -167,6 +167,7 @@ function check_file(){
# Checking presence of functions in specific files
function check_methods(){
important="1"
shift
@@ -174,31 +175,31 @@ function check_methods(){
important="0"
fi
- for i in $*
+ for i in $@
do
-# When correct file for this function does not exist
- if [[ $filename == "0" ]];then
+ # When correct file for this function does not exist
+ if [[ "$filename" == "0" ]];then
if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]];then
- echo $bsp : ${i%(*}"()" present in file `grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
+ echo $bsp : ${i%(*}"()" present in file $(grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *)
fi
fi
else
-# When correct file for this function exists
- if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
+ # When correct file for this function exists
+ if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" "$filename" ; then
if [[ $verbose -eq "1" ]] ;then
- echo "$bsp : `basename $filename` : ${i%(*}() present in file"
+ echo "$bsp : $(basename $filename) : ${i%(*}() present in file"
fi
else
fi
else
if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]]; then
- echo "$bsp : `basename $filename` : ${i%(*}() function does not exist in $filename "
+ echo "$bsp : $(basename $filename) : ${i%(*}() function does not exist in $filename "
flag="1"
fi
faults="1"
@@ -211,6 +212,7 @@ function check_methods(){
# Checking presence of headers installed by bsp
function check_header(){
important="1"
shift
@@ -218,15 +220,15 @@ function check_header(){
important="0"
fi
- for i in $*
+ for i in $@
do
if grep -wq "$i" Makefile.am ;then
if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
continue
fi
- cd `dirname $i`
- echo "$bsp : `basename $i` installed from directory" ${PWD##*/c/src/lib/}
+ cd $(dirname $i)
+ echo "$bsp : $(basename $i) installed from directory" ${PWD##*/c/src/lib/}
cd - > /dev/null
fi
return
@@ -234,80 +236,77 @@ function check_header(){
done
- echo "${bsp%%[\ ]*} : `basename $1` not installed "
+ echo "${bsp%%[\ ]*} : $(basename $1) not installed "
flag="1"
fi
filename="0"
faults="1"
return
-test_its_there()
- if [ $# -ne 2 ] ; then
+function test_its_there(){
+ if [[ $# -ne 2 ]]; then
echo Usage: $0 FILE pattern
fi
grep ${2} ${1} >/dev/null
- if [ $? -ne 0 ] ; then
+ if [[ $? -ne 0 ]]; then
echo "$bsp : ${2} is NOT in ${1##./}"
fi
-test_its_there_all_case()
+function test_its_there_all_case(){
fi
grep -i ${2} ${1} >/dev/null
echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
fi
-test_its_NOT_there_all_case()
- if [ $# -lt 2 ] ; then
+function test_its_NOT_there_all_case(){
+ if [[ $# -lt 2 ]]; then
fi
FILE=$1
shift
grep -i "${*}" ${FILE} >/dev/null
- if [ $? -eq 0 ] ; then
+ if [[ $? -eq 0 ]]; then
echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case independent check"
fi
-test_its_NOT_there()
+function test_its_NOT_there(){
fi
FILE=$1
shift
grep "${*}" ${FILE} >/dev/null
echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
fi
-find_source()
+function find_source(){
findArgs=
while getopts "cCdm" OPT
do
- case "$OPT" in
- c) findArgs="${findArgs} -o -name configure.ac" ;;
- C) findArgs="${findArgs} -o -name *.cfg" ;;
- d) findArgs="${findArgs} -o -name *.doc" ;;
- m) findArgs="${findArgs} -o -name Makefile.am" ;;
- *) echo "bad arg to find_source ($OPT)" ; exit 1 ;;
- esac
+ case "$OPT" in
+ c) findArgs="${findArgs} -o -name configure.ac" ;;
+ C) findArgs="${findArgs} -o -name *.cfg" ;;
+ d) findArgs="${findArgs} -o -name *.doc" ;;
+ m) findArgs="${findArgs} -o -name Makefile.am" ;;
+ *) echo "bad arg to find_source ($OPT)" ; exit 1 ;;
+ esac
done
- shiftcount=`expr $OPTIND - 1`
+ shiftcount=$(expr $OPTIND - 1)
shift $shiftcount
args=$*
@@ -322,16 +321,16 @@ function check_format(){
find_source -m -c -C | while read f
do
grep ".\{81,\}" ${f} >/dev/null
echo -e "\n$bsp : ${f#./} has more than 80 character lines"
- for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
+ for i in $(grep -n '.\{80,\}' ${f} | cut -f1 -d:)
do
echo -e "$i \c"
- done
+ done
fi
done
- # really need to make the copyright strings consistent in BSPs
+ # Copyright strings should be consistent in BSPs
echo -e "\n=== Checking for copyright notices"
find_source | while read f
do
@@ -356,7 +355,7 @@ function check_format(){
echo "=== Checking for spaces at the end of lines"
do
- egrep " +$" $f >/dev/null
+ grep -E " +$" $f >/dev/null
test $? -eq 0 && echo -e "${f##./} \c"
done
@@ -395,36 +394,36 @@ function main(){
fi
# We do not want stdio in a BSP
- echo "=== Checking for stdio"
- find_source -m -c -C | while read f
- do
- test_its_NOT_there ${f} printf
- test_its_NOT_there ${f} "puts("
- done
+ echo "=== Checking for stdio"
+ find_source -m -c -C | while read f
+ do
+ test_its_NOT_there ${f} printf
+ test_its_NOT_there ${f} "puts("
+ done
- # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
- # RTEMS_BSP_BOOTCARD_OPTIONS
- if [ -r configure.ac ] ; then
- echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
- test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
- echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
- test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
- fi
+ # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
+ # RTEMS_BSP_BOOTCARD_OPTIONS
+ if [[ -r configure.ac ]]; then
+ echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
+ test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
+ echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
+ test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
+ fi
- # If not using -O2, then we really want to know
- # BSPs should normally use -O2
- echo "=== Checking for not using -O2"
- grep -H "\-O[013456789]" make/custom/*.cfg
+ # If not using -O2, then we really want to know
+ # BSPs should normally use -O2
+ echo "=== Checking for not using -O2"
+ grep -H "\-O[013456789]" make/custom/*.cfg
- # BSPs should not turn on extra warnings
- echo "=== Checking for turning on extra GCC warning checks"
- grep -H "\-W" make/custom/*.cfg
+ # BSPs should not turn on extra warnings
+ echo "=== Checking for turning on extra GCC warning checks"
+ grep -H "\-W" make/custom/*.cfg
- # Hopefully have some output from the tmtests
- echo "=== Checking for timing information"
- c=`ls -1 times* 2>/dev/null | wc -l`
- if [ ${c} -eq 0 ] ; then
- echo "Please run the timing tests and include the results."
+ # Hopefully have some output from the tmtests
+ echo "=== Checking for timing information"
+ c=$(ls -1 times* 2>/dev/null | wc -l)
+ if [[ ${c} -eq 0 ]]; then
+ echo "Please run the timing tests and include the results."
fi
echo -e "\n=== Starting BSP Unified way checks"
@@ -435,10 +434,10 @@ function main(){
if [[ $filename != "0" ]];then
if grep -wq "start" "$filename" || grep -wq "_start" "$filename"; then
- echo "$bsp : `basename $filename` start() present in $filename"
+ echo "$bsp : $(basename $filename) start() present in $filename"
fi
else
- echo "$bsp : `basename $filename` start() does not exist in start.S"
+ echo "$bsp : $(basename $filename) start() does not exist in start.S"
fi
fi
@@ -448,7 +447,6 @@ function main(){
check_file 1 bspreset.c ../../shared/ ../shared/ startup/
check_methods 1 "bsp_reset"
check_file 1 bootcard.c ../../shared/
check_header ../../shared/include/bootcard.h
@@ -458,7 +456,6 @@ function main(){
check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup ../shared/ ../shared/startup/ startup/
check_methods 1 "bsp_work_area_initialize"
check_file 1 bsplibc.c ../../shared/
check_methods "bsp_libc_init"
@@ -468,13 +465,11 @@ function main(){
check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/ startup/
check_methods "bsp_predriver_hook"
check_file gnatinstallhandler.c ../../shared/
check_file sbrk.c ../../shared/ ../../shared/ startup/
check_methods "sbrk"
check_file stackalloc.c ../../shared/src/
check_methods "bsp_stack_allocate_init" "bsp_stack_allocate" "bsp_stack_free"
@@ -486,9 +481,7 @@ function main(){
check_header 1 include/irq.h
# PIC Support
check_file irq-default-handler.c ../../shared/src/
check_file 1 irq-generic.c ../../shared/src/
check_header 1 ../../shared/include/irq-generic.h
@@ -503,7 +496,6 @@ function main(){
check_file rtc-config.c rtc/
check_methods "bsp_rtc_initialize" "bsp_rtc_get_time" "bsp_rtc_set_time" "bsp_rtc_probe"
check_file 1 tod.c ../../shared/ tod/
# Benchmark Timers
@@ -512,7 +504,6 @@ function main(){
# Standard Headers
check_header 1 include/bsp.h
check_header include/bspopts.h
check_header 1 ../../shared/include/coverhd.h include/coverhd.h
@@ -530,86 +521,87 @@ function main(){
echo -e "\n"
fi
-# Test specific checks
- if [ ${do_test} == "1" ] ; then
+ # Test specific checks
+ if [[ ${do_test} == "1" ]]; then
echo -e "\n=== Starting Test specific checks"
# find all the Makefile.am's with rtems_tests_PROGRAMS in them
- Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
- if [ "X${Makefiles}" = "X" ] ; then
+ Makefiles=$(find . -name Makefile.am | xargs -e grep -l ^rtems_tests)
+ if [[ "X${Makefiles}" = "X" ]]; then
echo -e "Unable to locate any test Makefile.am files.\n"
return
fi
echo "=== Checking for missing test support files"
for m in ${Makefiles}
do
- directory=`dirname ${m}`
- if [ ${directory} = "." ] ; then
- directory=`pwd`
+ directory=$(dirname ${m})
+ if [[ ${directory} = "." ]]; then
+ directory=$(pwd)
fi
- testName=`basename ${directory}`
+ testName=$(basename ${directory})
# Does this test have a .doc file?
- if [ ! -r ${directory}/${testName}.doc ] ; then
+ if [[ ! -r ${directory}/${testName}.doc ]]; then
echo ${testName}.doc is not present
fi
case ${directory} in
- */*tmtests*) ;;
- # Does this test have a .scn file?
- if [ ! -r ${directory}/${testName}.scn ] ; then
- echo ${testName}.scn is not present
- fi
+ */*tmtests*) ;;
+ # Does this test have a .scn file?
+ if [[ ! -r ${directory}/${testName}.scn ]]; then
+ echo ${testName}.scn is not present
+ fi
esac
done
fi
# Verifying if the directory given or pwd is a valid bsp, shared architecture, or libbsp directory
function check_given_dir(){
- if echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
+ if echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
return 0
- elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
-# BSP given
- bsp=${cur_dir##*/}
+ elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
+ # BSP given
+ bsp="${cur_dir##*/}"
- if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp == "no_bsp" ]]; then
+ if [[ "$bsp" == "shared" || "$bsp" == "autom4te.cache" || "$bsp" == "no_bsp" ]]; then
return 0
else
main
fi
- elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
-# Shared architecture given
- for i in *
+ elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
+ # Shared architecture given
+ for i in */Makefile.am
do
- if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_bsp" ]]; then
- echo -n
+ i="$(dirname $i)"
+ if [[ "$i" == "shared" || "$i" == "autom4te.cache" || "$i" == "no_bsp" ]]; then
+ echo -n > /dev/null
else
- bsp=$i
+ bsp="$i"
- cd $bsp
+ cd "$bsp"
main
cd .. > /dev/null
fi
fi
done
- elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
-# libbsp given
+ elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp" ; then
+ # libbsp given
for i in */*/Makefile.am
do
- i=`dirname $i`
- if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_cpu/no_bsp" ]]; then
+ i="$(dirname $i)"
+ if [[ "$i" == "shared" || "$i" == "autom4te.cache" || "$i" == "no_cpu/no_bsp" ]]; then
echo -n
else
- bsp=$i
+ bsp="$i"
- cd $bsp
+ cd "$bsp"
main
cd ../../ > /dev/null
fi
@@ -624,67 +616,71 @@ function check_given_dir(){
# Evaluating Command Line Arguments
function start(){
- for i in $*
+ path="0"
+ for i in "$@"
do
- case $i in
- "--verbose") verbose="1" # The whole story
+ case "$i" in
- "--warnings") warnings="1" # All warnings
- verbose="0"
+ "--verbose") # The whole story
+ verbose="1"
- "--no_format") format="0" # Disabling format checks
- verbose="0"
+ "--warnings") # All warnings
+ warnings="1"
+ verbose="0"
- "--tests") do_test="1" # Enabling check of tests
- verbose="0"
+ "--no_format") # Disabling format checks
+ format="0"
+ verbose="0"
- "--help") echo "Help to be provided"
+ "--tests") # Enabling check of tests
+ do_test="1"
+ verbose="0"
- "--"* | "-"* ) echo "Invalid options provided"
+ "--help")
+ echo "Help to be provided"
- *) path="$path $i" ;; # If not above options, then assumed to be a path for bsp
- esac
- done
+ echo "Invalid options provided"
-# No path given, search for bsp from pwd
- if [[ -z $path ]];then
- path=$PWD
- cur_dir=`pwd`
- check_given_dir
- if [[ $? -eq 1 ]];then
- echo "Current directory does not seem a valid RTEMS directory"
- fi
- else
- for i in $path
- do
+ if [[ -d "$i" ]]; then # If not above options, then assumed to be a path for bsp
echo > /dev/null
else
echo "$i is an invalid directory."
- continue
fi
- cd $i
- cur_dir=`pwd`
+ cd "$i"
+ cur_dir=$(pwd)
check_given_dir
echo "$i does not seem a valid RTEMS directory"
+ else
+ path="1"
fi
- cd $calling_path
+ cd "$calling_path"
+ esac
+ done
- done
+ # No path given, search for bsp from pwd
+ if [[ "$path" == "0" ]];then
+ cur_dir=$(pwd)
+ check_given_dir
+ if [[ $? -eq 1 ]];then
+ echo "Current directory does not seem a valid RTEMS directory"
+ fi
fi
# Let the Game begin !!
-start $*
+start "$@"
# End of Checks
if [[ $faults -eq "0" ]] ; then
1.7.11.7
