[rtems commit] semopen.c: Address set but unused variable warning
Mon Sep 23 12:55:57 UTC 2013
On Sun, Sep 22, 2013 at 10:45 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> There is precedence for using the compiler attributes
> so I just added that and switched.
I think it might be better to avoid compiler attributes when there is
a language-level alternative that is compiler-agnostic. In this case,
the use of:
(void) var;
seems fine to me.
> Thanks for the feedback.
> If we have a print format string to use for mode_t and
> wchar_t, a few more cases would be fixed.
> On 9/22/2013 7:32 AM, Pavel Pisa wrote:
>> Hello Ralf and others,
>> On Sunday 22 of September 2013 05:01:49 Ralf Corsepius wrote:
>>>> diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
>>>> index b863080..e61fad0 100644
>>>> --- a/cpukit/posix/src/semopen.c
>>>> +++ b/cpukit/posix/src/semopen.c
>>>> @@ -43,6 +43,14 @@
>>>>    *        parameters must be present.
>>>> + * mode is set but never used. GCC gives a warning for this
>>>> + * and we need to tell GCC not to complain. But we have to
>>>> + * have it because we have to work through the variable
>>>> + * arguments to get to attr.
>>>> +#pragma GCC diagnostic push
>>>> +#pragma GCC diagnostic ignored "-Wunused-but-set-variable"
>>>>   sem_t *sem_open(
>>>>     const char *name,
>>>>     int         oflag,
>>>> @@ -137,3 +145,4 @@ return_id:
>>>>       return (sem_t *)&the_semaphore->Object.id;
>>>>     #endif
>>>> +#pragma GCC diagnostic pop
>>> Why this brutal and probably non-portable way to suppress warnings?
>>> Why doesn't __attribute__((unused)) or similar suffice?
>> I would prefer to see something like RTEMS_ATTR_UNUSED to support
>> multiple compilers. You can look at my collection of these in
>> uLUt definitions file
>> http://sourceforge.net/p/ulan/ulut/ci/master/tree/ulut/ul_utdefs.h
>> I declare file contents (by this e-mail) as free for public
>> domain use (uLUt as whole is is GPL/LGPL/MPL RTEMS compatible too).
>> As for the actual __attribute__((unused)) there is even portable
>> solution which does not depend on GCC extension.
>>   int my_unused_var;
>>   (void) my_unused_var;
>> This solution should be accepted by all compilers and is suggested
>> by some people as better option.
>> Best wishes,
>>              Pavel
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
