[PATCH] Adding support for whitespace directory names in check_submission
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Sep 23 13:28:41 UTC 2013
I just noticed that the bsp hooks like startup, predriver, etc which implement methods in bootcard.h don't always have it
This is also a compile warning so may not be worth a check.
Gedare Bloom <gedare at rtems.org> wrote:
committed. please verify.
On Sat, Sep 21, 2013 at 2:17 PM, Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
>  merge-helpers/check_submission | 382 ++++++++++++++++++++---------------------
>  1 file changed, 189 insertions(+), 193 deletions(-)
> diff --git a/merge-helpers/check_submission b/merge-helpers/check_submission
> index 90908f1..47ea6cf 100755
> --- a/merge-helpers/check_submission
> +++ b/merge-helpers/check_submission
> @@ -1,9 +1,7 @@
> -#! /bin/bash
>  # Bash Script to find discrepancies in BSP file organization.
>  # Author : Vipul Nayyar <nayyar_vipul at yahoo.com>
>  filename="0"
>  # Passing --verbose turns verbose to 1 & gives the whole story, otherwise '0' to give only important stuff.
>  verbose="0"
> @@ -12,7 +10,7 @@ faults="0"
>  warnings="0"
>  flag="0"
> -calling_path=`pwd`
> +calling_path=$(pwd)
>  path=""
>  important="1"
> @@ -25,17 +23,18 @@ format="1"
>  # Finds all rtems internal functions ( name starting with '_' & type specifier)
>  # that are defined in cpukit & libcpu
>  function find_rtems_internal(){
> -  if [[ $internal_done == "1" ]]; then
> +  if [[ "$internal_done" == "1" ]]; then
>      return
>    fi
>    echo "Compiling list of RTEMS Internal functions ..."
>    internal_files=""
> -  for k in `find -name *.c`
> +  for k in $(find -name *.c)
>    do
> -    for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k`
> +    for j in $(grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k)
>      do
> -      if [[ $j == "_"* ]]; then
> +      if [[ "$j" == "_"* ]]; then
>          j=${j%%\(}
>          internal_files="$j $internal_files"
>        fi
> @@ -43,11 +42,11 @@ function find_rtems_internal(){
>      done
>    done
> -  for k in `find ../c/src/lib/libcpu/ -name *.c`
> +  for k in $(find ../c/src/lib/libcpu/ -name *.c)
>    do
>      do
>          j=${j%%\(}
>        fi
> @@ -57,7 +56,7 @@ function find_rtems_internal(){
>    for k in $internal_files
>    do
> -    if echo $rtems_internal |grep -q $k ; then
> +    if echo $rtems_internal |grep -q "$k" ; then
>        echo > /dev/null
>      else
>        rtems_internal="$k $rtems_internal"
> @@ -69,39 +68,40 @@ function find_rtems_internal(){
>  # Finds all internal functions common in bsp and (cpukit + libcpu)
>  function find_bsp_internal(){
>    bsp_methods=""
>    common_internal_methods=""
> -# Searching for internal functions starting with '_' called(i.e ending with a ';')
> -  for i in `find -name *.c`
> +  # Searching for internal functions starting with '_' called(i.e ending with a ';')
> +  for i in $( find -name *.c )
>    do
> -    file_contents=`tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
> -    for j in `echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
> +    file_contents=$(tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;\{]*\)[ ]*;" | tr -d '\n')
> +    for j in $( echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\(" )
>      do
> -      if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
> +      if $(echo "$bsp_methods" | grep -q "${j%%\(}") ; then
>          echo > /dev/null
>        else
>          bsp_methods="${j%%\(} $bsp_methods"
>        fi
>      done
>    done
> -# Identifying common fucntions between $rtems_interval & $bsp_methods
> +  # Identifying common fucntions between $rtems_interval & $bsp_methods
>    for i in $rtems_internal
>    do
> -    if [[ $i == "__asm__" || $i == "__attribute__" || $i == "__volatile__" || $i == "__"* ]];then
> +    if [[ "$i" == "__asm__" || "$i" == "__attribute__" || "$i" == "__volatile__" || "$i" == "__"* ]];then
>        continue
>      fi
>      for j in $bsp_methods
>      do
> -      if [[ $i == $j ]]; then
> +      if [[ "$i" == "$j" ]]; then
>          common_internal_methods="$j $common_internal_methods"
>        fi
>      done
>    done
> -  if [[ $common_internal_methods != "" ]]; then
> +  if [[ "$common_internal_methods" != "" ]]; then
>      echo -e "$bsp : RTEMS Internal functions used : \c"
>      for i in $common_internal_methods
>      do
> @@ -111,10 +111,10 @@ function find_bsp_internal(){
>    fi
>  # Passing 1 initially to any check function states that the file/method/header
>  # being checked is of critical nature
>  function check_file(){
>    filename="0"
>    if [[ $1 == 1 ]]; then
>      important="1"
> @@ -123,27 +123,27 @@ function check_file(){
>      important="0"
>    fi
> -#Grabbing the path of file being evaluated from Makefile.am
> +  #Grabbing the path of file being evaluated from Makefile.am
>    if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
> -    file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
> -    cd `dirname $file_path`
> -    filename=$1
> -    file_path=`pwd`
> +    file_path="$(grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1)"
> +    cd "$(dirname $file_path)"
> +    filename="$1"
> +    file_path="$(pwd)"
>      cd - > /dev/null
>      shift
> -# Checking if file lies in correct directory path
> -    for i in $*
> +  # Checking if file lies in correct directory path
> +    for i in $@
>      do
> -      if [[ -d $i ]]; then
> -        cd $i
> +      if [[ -d "$i" ]]; then
> +        cd "$i"
>        else
>          continue
>        fi
> -      if [[ "$file_path" == `pwd` ]]; then
> +      if [[ "$file_path" == $(pwd) ]]; then
>          filename="$file_path/$filename"
>          cd - >/dev/null
>          return
> @@ -167,6 +167,7 @@ function check_file(){
>  # Checking presence of functions in specific files
>  function check_methods(){
>      important="1"
>      shift
> @@ -174,31 +175,31 @@ function check_methods(){
>      important="0"
>    fi
> -  for i in $*
> +  for i in $@
>    do
> -# When correct file for this function does not exist
> -    if [[ $filename == "0" ]];then
> +  # When correct file for this function does not exist
> +    if [[ "$filename" == "0" ]];then
>        if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
>           if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]];then
> -          echo $bsp : ${i%(*}"()" present in file `grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
> +          echo $bsp : ${i%(*}"()" present in file $(grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *)
>           fi
>        fi
>      else
> -# When correct file for this function exists
> -      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
> +  # When correct file for this function exists
> +      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" "$filename" ; then
>          if [[ $verbose -eq "1" ]] ;then
> -          echo "$bsp : `basename $filename` : ${i%(*}() present in file"
> +          echo "$bsp : $(basename $filename) : ${i%(*}() present in file"
>          fi
>        else
>             fi
>          else
>            if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]]; then
> -            echo "$bsp : `basename $filename` : ${i%(*}() function does not exist in $filename "
> +            echo "$bsp : $(basename $filename) : ${i%(*}() function does not exist in $filename "
>              flag="1"
>            fi
>              faults="1"
> @@ -211,6 +212,7 @@ function check_methods(){
>  # Checking presence of headers installed by bsp
>  function check_header(){
>      important="1"
>      shift
> @@ -218,15 +220,15 @@ function check_header(){
>      important="0"
>    fi
> -  for i in $*
> +  for i in $@
>    do
>      if  grep -wq "$i" Makefile.am ;then
>        if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
>          continue
>        fi
> -        cd `dirname $i`
> -        echo "$bsp : `basename $i` installed from directory" ${PWD##*/c/src/lib/}
> +        cd $(dirname $i)
> +        echo "$bsp : $(basename $i) installed from directory" ${PWD##*/c/src/lib/}
>          cd - > /dev/null
>        fi
>        return
> @@ -234,80 +236,77 @@ function check_header(){
>    done
> -    echo "${bsp%%[\ ]*} : `basename $1` not installed "
> +    echo "${bsp%%[\ ]*} : $(basename $1) not installed "
>      flag="1"
>    fi
>    filename="0"
>    faults="1"
>    return
> -test_its_there()
> -  if [ $# -ne 2 ] ; then
> +function test_its_there(){
> +  if [[ $# -ne 2 ]]; then
>      echo Usage: $0 FILE pattern
>    fi
>    grep ${2} ${1} >/dev/null
> -  if [ $? -ne 0 ] ; then
> +  if [[ $? -ne 0 ]]; then
>      echo "$bsp : ${2} is NOT in ${1##./}"
>    fi
> -test_its_there_all_case()
> +function test_its_there_all_case(){
>    fi
>    grep -i ${2} ${1} >/dev/null
>      echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
>    fi
> -test_its_NOT_there_all_case()
> -  if [ $# -lt 2 ] ; then
> +function test_its_NOT_there_all_case(){
> +  if [[ $# -lt 2 ]]; then
>    fi
>    FILE=$1
>    shift
>    grep -i "${*}" ${FILE} >/dev/null
> -  if [ $? -eq 0 ] ; then
> +  if [[ $? -eq 0 ]]; then
>      echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case independent check"
>    fi
> -test_its_NOT_there()
> +function test_its_NOT_there(){
>    fi
>    FILE=$1
>    shift
>    grep "${*}" ${FILE} >/dev/null
>      echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
>    fi
> -find_source()
> +function find_source(){
>    findArgs=
>    while getopts "cCdm" OPT
>    do
> -   case "$OPT" in
> -     c) findArgs="${findArgs} -o -name configure.ac" ;;
> -     C) findArgs="${findArgs} -o -name *.cfg" ;;
> -     d) findArgs="${findArgs} -o -name *.doc" ;;
> -     m) findArgs="${findArgs} -o -name Makefile.am" ;;
> -     *) echo "bad arg to find_source ($OPT)" ; exit 1 ;;
> -   esac
> +    case "$OPT" in
> +      c) findArgs="${findArgs} -o -name configure.ac" ;;
> +      C) findArgs="${findArgs} -o -name *.cfg" ;;
> +      d) findArgs="${findArgs} -o -name *.doc" ;;
> +      m) findArgs="${findArgs} -o -name Makefile.am" ;;
> +      *) echo "bad arg to find_source ($OPT)" ; exit 1 ;;
> +    esac
>    done
> -  shiftcount=`expr $OPTIND - 1`
> +  shiftcount=$(expr $OPTIND - 1)
>    shift $shiftcount
>    args=$*
> @@ -322,16 +321,16 @@ function check_format(){
>    find_source -m -c -C | while read f
>    do
>      grep  ".\{81,\}" ${f} >/dev/null
>        echo -e "\n$bsp : ${f#./} has more than 80 character lines"
> -      for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
> +      for i in $(grep -n '.\{80,\}' ${f} | cut -f1 -d:)
>        do
>          echo -e "$i \c"
> -    done
> +      done
>      fi
>    done
> -  # really need to make the copyright strings consistent in BSPs
> +  # Copyright strings should be consistent in BSPs
>    echo -e "\n=== Checking for copyright notices"
>    find_source | while read f
>    do
> @@ -356,7 +355,7 @@ function check_format(){
>    echo "=== Checking for spaces at the end of lines"
>    do
> -    egrep " +$" $f >/dev/null
> +    grep -E " +$" $f >/dev/null
>      test $? -eq 0 && echo -e "${f##./} \c"
>    done
> @@ -395,36 +394,36 @@ function main(){
>    fi
>    # We do not want stdio in a BSP
> -    echo "=== Checking for stdio"
> -    find_source -m -c -C | while read f
> -    do
> -      test_its_NOT_there ${f} printf
> -      test_its_NOT_there ${f} "puts("
> -    done
> +  echo "=== Checking for stdio"
> +  find_source -m -c -C | while read f
> +  do
> +    test_its_NOT_there ${f} printf
> +    test_its_NOT_there ${f} "puts("
> +  done
> -    # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
> -    #   RTEMS_BSP_BOOTCARD_OPTIONS
> -    if [ -r configure.ac ] ; then
> -      echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
> -      test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
> -      echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
> -      test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
> -    fi
> +  # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
> +  #   RTEMS_BSP_BOOTCARD_OPTIONS
> +  if [[ -r configure.ac ]]; then
> +    echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
> +    test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
> +    echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
> +    test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
> +  fi
> -    # If not using -O2, then we really want to know
> -    # BSPs should normally use -O2
> -    echo "=== Checking for not using -O2"
> -    grep -H "\-O[013456789]" make/custom/*.cfg
> +  # If not using -O2, then we really want to know
> +  # BSPs should normally use -O2
> +  echo "=== Checking for not using -O2"
> +  grep -H "\-O[013456789]" make/custom/*.cfg
> -    # BSPs should not turn on extra warnings
> -    echo "=== Checking for turning on extra GCC warning checks"
> -    grep -H "\-W" make/custom/*.cfg
> +  # BSPs should not turn on extra warnings
> +  echo "=== Checking for turning on extra GCC warning checks"
> +  grep -H "\-W" make/custom/*.cfg
> -    # Hopefully have some output from the tmtests
> -    echo "=== Checking for timing information"
> -    c=`ls -1 times* 2>/dev/null | wc -l`
> -    if [ ${c} -eq 0 ] ; then
> -      echo "Please run the timing tests and include the results."
> +  # Hopefully have some output from the tmtests
> +  echo "=== Checking for timing information"
> +  c=$(ls -1 times* 2>/dev/null | wc -l)
> +  if [[ ${c} -eq 0 ]]; then
> +    echo "Please run the timing tests and include the results."
>    fi
>    echo -e "\n=== Starting BSP Unified way checks"
> @@ -435,10 +434,10 @@ function main(){
>    if [[ $filename != "0" ]];then
>      if grep -wq "start" "$filename" || grep -wq "_start" "$filename"; then
> -        echo "$bsp : `basename $filename` start() present in $filename"
> +        echo "$bsp : $(basename $filename) start() present in $filename"
>        fi
>      else
> -      echo "$bsp : `basename $filename` start() does not exist in start.S"
> +      echo "$bsp : $(basename $filename) start() does not exist in start.S"
>      fi
>    fi
> @@ -448,7 +447,6 @@ function main(){
>    check_file 1 bspreset.c ../../shared/ ../shared/ startup/
>    check_methods 1 "bsp_reset"
>    check_file 1 bootcard.c ../../shared/
>    check_header ../../shared/include/bootcard.h
> @@ -458,7 +456,6 @@ function main(){
>    check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup ../shared/ ../shared/startup/ startup/
>    check_methods 1 "bsp_work_area_initialize"
>    check_file 1 bsplibc.c ../../shared/
>    check_methods "bsp_libc_init"
> @@ -468,13 +465,11 @@ function main(){
>    check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/ startup/
>    check_methods "bsp_predriver_hook"
>    check_file gnatinstallhandler.c ../../shared/
>    check_file sbrk.c ../../shared/ ../../shared/ startup/
>    check_methods "sbrk"
>    check_file stackalloc.c ../../shared/src/
>    check_methods "bsp_stack_allocate_init" "bsp_stack_allocate" "bsp_stack_free"
> @@ -486,9 +481,7 @@ function main(){
>    check_header 1 include/irq.h
>    # PIC Support
>    check_file irq-default-handler.c ../../shared/src/
>    check_file 1 irq-generic.c ../../shared/src/
>    check_header 1 ../../shared/include/irq-generic.h
> @@ -503,7 +496,6 @@ function main(){
>    check_file rtc-config.c rtc/
>    check_methods "bsp_rtc_initialize" "bsp_rtc_get_time" "bsp_rtc_set_time" "bsp_rtc_probe"
>    check_file 1 tod.c ../../shared/ tod/
>    # Benchmark Timers
> @@ -512,7 +504,6 @@ function main(){
>    # Standard Headers
>    check_header 1 include/bsp.h
>    check_header include/bspopts.h
>    check_header 1 ../../shared/include/coverhd.h include/coverhd.h
> @@ -530,86 +521,87 @@ function main(){
>      echo -e "\n"
>    fi
> -# Test specific checks
> -  if [ ${do_test} == "1" ] ; then
> +  # Test specific checks
> +  if [[ ${do_test} == "1" ]]; then
>      echo -e "\n=== Starting Test specific checks"
>      # find all the Makefile.am's with rtems_tests_PROGRAMS in them
> -    Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
> -    if [ "X${Makefiles}" = "X" ] ; then
> +    Makefiles=$(find . -name Makefile.am | xargs -e grep -l ^rtems_tests)
> +    if [[ "X${Makefiles}" = "X" ]]; then
>        echo -e "Unable to locate any test Makefile.am files.\n"
>        return
>      fi
>      echo "=== Checking for missing test support files"
>      for m in ${Makefiles}
>      do
> -      directory=`dirname ${m}`
> -      if [ ${directory} = "." ] ; then
> -        directory=`pwd`
> +      directory=$(dirname ${m})
> +      if [[ ${directory} = "." ]]; then
> +        directory=$(pwd)
>        fi
> -      testName=`basename ${directory}`
> +      testName=$(basename ${directory})
>        # Does this test have a .doc file?
> -      if [ ! -r ${directory}/${testName}.doc ] ; then
> +      if [[ ! -r ${directory}/${testName}.doc ]]; then
>          echo ${testName}.doc is not present
>        fi
>        case ${directory} in
> -        */*tmtests*) ;;
> -          # Does this test have a .scn file?
> -          if [ ! -r ${directory}/${testName}.scn ] ; then
> -            echo ${testName}.scn is not present
> -          fi
> +      */*tmtests*) ;;
> +        # Does this test have a .scn file?
> +        if [[ ! -r ${directory}/${testName}.scn ]]; then
> +        echo ${testName}.scn is not present
> +        fi
>        esac
>      done
>    fi
>  # Verifying if the directory given or pwd is a valid bsp, shared architecture, or libbsp directory
>  function check_given_dir(){
> -  if echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
> +  if echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
>      return 0
> -  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
> -# BSP given
> -    bsp=${cur_dir##*/}
> +  elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
> +    # BSP given
> +    bsp="${cur_dir##*/}"
> -    if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp == "no_bsp" ]]; then
> +    if [[ "$bsp" == "shared" || "$bsp" == "autom4te.cache" || "$bsp" == "no_bsp" ]]; then
>        return 0
>      else
>        main
>      fi
> -  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
> -# Shared architecture given
> -    for i in *
> +  elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
> +    # Shared architecture given
> +    for i in */Makefile.am
>      do
> -        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_bsp" ]]; then
> -          echo -n
> +      i="$(dirname $i)"
> +        if [[ "$i" == "shared" || "$i" == "autom4te.cache" || "$i" == "no_bsp" ]]; then
> +          echo -n > /dev/null
>          else
> -          bsp=$i
> +          bsp="$i"
> -          cd $bsp
> +          cd "$bsp"
>            main
>            cd .. > /dev/null
>          fi
>        fi
>      done
> -  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
> -# libbsp given
> +  elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp" ; then
> +    # libbsp given
>      for i in */*/Makefile.am
>      do
> -      i=`dirname $i`
> -        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_cpu/no_bsp" ]]; then
> +      i="$(dirname $i)"
> +        if [[ "$i" == "shared" || "$i" == "autom4te.cache" || "$i" == "no_cpu/no_bsp" ]]; then
>            echo -n
>          else
> -          bsp=$i
> +          bsp="$i"
> -          cd $bsp
> +          cd "$bsp"
>            main
>            cd ../../ > /dev/null
>          fi
> @@ -624,67 +616,71 @@ function check_given_dir(){
>  # Evaluating Command Line Arguments
>  function start(){
> -  for i in $*
> +  path="0"
> +  for i in "$@"
>    do
> -    case $i in
> -      "--verbose") verbose="1" # The whole story
> +    case "$i" in
> -      "--warnings") warnings="1" # All warnings
> -              verbose="0"
> +    "--verbose") # The whole story
> +      verbose="1"
> -      "--no_format") format="0" # Disabling format checks
> -              verbose="0"
> +    "--warnings") # All warnings
> +      warnings="1"
> +      verbose="0"
> -      "--tests") do_test="1"    # Enabling check of tests
> -             verbose="0"
> +    "--no_format") # Disabling format checks
> +      format="0"
> +      verbose="0"
> -      "--help") echo "Help to be provided"
> +    "--tests") # Enabling check of tests
> +      do_test="1"
> +      verbose="0"
> -      "--"* | "-"* ) echo "Invalid options provided"
> +    "--help")
> +      echo "Help to be provided"
> -      *) path="$path $i"  ;; # If not above options, then assumed to be a path for bsp
> -    esac
> -  done
> +      echo "Invalid options provided"
> -# No path given, search for bsp from pwd
> -  if [[ -z $path ]];then
> -    path=$PWD
> -    cur_dir=`pwd`
> -    check_given_dir
> -    if [[ $? -eq 1 ]];then
> -      echo "Current directory does not seem a valid RTEMS directory"
> -    fi
> -  else
> -    for i in $path
> -    do
> +      if [[ -d "$i" ]]; then   # If not above options, then assumed to be a path for bsp
>          echo > /dev/null
>        else
>          echo "$i is an invalid directory."
> -        continue
>        fi
> -      cd $i
> -      cur_dir=`pwd`
> +      cd "$i"
> +      cur_dir=$(pwd)
>        check_given_dir
>          echo "$i does not seem a valid RTEMS directory"
> +      else
> +        path="1"
>        fi
> -      cd $calling_path
> +      cd "$calling_path"
> +    esac
> +  done
> -    done
> +  # No path given, search for bsp from pwd
> +  if [[ "$path" == "0" ]];then
> +    cur_dir=$(pwd)
> +    check_given_dir
> +    if [[ $? -eq 1 ]];then
> +      echo "Current directory does not seem a valid RTEMS directory"
> +    fi
>    fi
>  # Let the Game begin !!
> -start $*
> +start "$@"
>  # End of Checks
>  if [[ $faults -eq "0" ]] ; then
> 1.7.11.7
> rtems-devel mailing list
> rtems-devel at rtems.org
