[PATCH] Adding support for whitespace directory names in check_submission
Mon Sep 23 13:32:58 UTC 2013
If we are going to require a fix for the warning, we should enforce
the check at bsp submission time instead to reduce maintenance
overhead.
On Mon, Sep 23, 2013 at 9:28 AM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> I just noticed that the bsp hooks like startup, predriver, etc which implement methods in bootcard.h don't always have it
> This is also a compile warning so may not be worth a check.
> Gedare Bloom <gedare at rtems.org> wrote:
> committed. please verify.
> On Sat, Sep 21, 2013 at 2:17 PM, Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
>>  merge-helpers/check_submission | 382 ++++++++++++++++++++---------------------
>>  1 file changed, 189 insertions(+), 193 deletions(-)
>> diff --git a/merge-helpers/check_submission b/merge-helpers/check_submission
>> index 90908f1..47ea6cf 100755
>> --- a/merge-helpers/check_submission
>> +++ b/merge-helpers/check_submission
>> @@ -1,9 +1,7 @@
>> -#! /bin/bash
>>  # Bash Script to find discrepancies in BSP file organization.
>>  # Author : Vipul Nayyar <nayyar_vipul at yahoo.com>
>>  filename="0"
>>  # Passing --verbose turns verbose to 1 & gives the whole story, otherwise '0' to give only important stuff.
>>  verbose="0"
>> @@ -12,7 +10,7 @@ faults="0"
>>  warnings="0"
>>  flag="0"
>> -calling_path=`pwd`
>> +calling_path=$(pwd)
>>  path=""
>>  important="1"
>> @@ -25,17 +23,18 @@ format="1"
>>  # Finds all rtems internal functions ( name starting with '_' & type specifier)
>>  # that are defined in cpukit & libcpu
>>  function find_rtems_internal(){
>> -  if [[ $internal_done == "1" ]]; then
>> +  if [[ "$internal_done" == "1" ]]; then
>>      return
>>    fi
>>    echo "Compiling list of RTEMS Internal functions ..."
>>    internal_files=""
>> -  for k in `find -name *.c`
>> +  for k in $(find -name *.c)
>>    do
>> -    for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k`
>> +    for j in $(grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k)
>>      do
>> -      if [[ $j == "_"* ]]; then
>> +      if [[ "$j" == "_"* ]]; then
>>          j=${j%%\(}
>>          internal_files="$j $internal_files"
>>        fi
>> @@ -43,11 +42,11 @@ function find_rtems_internal(){
>>      done
>>    done
>> -  for k in `find ../c/src/lib/libcpu/ -name *.c`
>> +  for k in $(find ../c/src/lib/libcpu/ -name *.c)
>>    do
>>      do
>>          j=${j%%\(}
>>        fi
>> @@ -57,7 +56,7 @@ function find_rtems_internal(){
>>    for k in $internal_files
>>    do
>> -    if echo $rtems_internal |grep -q $k ; then
>> +    if echo $rtems_internal |grep -q "$k" ; then
>>        echo > /dev/null
>>      else
>>        rtems_internal="$k $rtems_internal"
>> @@ -69,39 +68,40 @@ function find_rtems_internal(){
>>  # Finds all internal functions common in bsp and (cpukit + libcpu)
>>  function find_bsp_internal(){
>>    bsp_methods=""
>>    common_internal_methods=""
>> -# Searching for internal functions starting with '_' called(i.e ending with a ';')
>> -  for i in `find -name *.c`
>> +  # Searching for internal functions starting with '_' called(i.e ending with a ';')
>> +  for i in $( find -name *.c )
>>    do
>> -    file_contents=`tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
>> -    for j in `echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
>> +    file_contents=$(tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;\{]*\)[ ]*;" | tr -d '\n')
>> +    for j in $( echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\(" )
>>      do
>> -      if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
>> +      if $(echo "$bsp_methods" | grep -q "${j%%\(}") ; then
>>          echo > /dev/null
>>        else
>>          bsp_methods="${j%%\(} $bsp_methods"
>>        fi
>>      done
>>    done
>> -# Identifying common fucntions between $rtems_interval & $bsp_methods
>> +  # Identifying common fucntions between $rtems_interval & $bsp_methods
>>    for i in $rtems_internal
>>    do
>> -    if [[ $i == "__asm__" || $i == "__attribute__" || $i == "__volatile__" || $i == "__"* ]];then
>> +    if [[ "$i" == "__asm__" || "$i" == "__attribute__" || "$i" == "__volatile__" || "$i" == "__"* ]];then
>>        continue
>>      fi
>>      for j in $bsp_methods
>>      do
>> -      if [[ $i == $j ]]; then
>> +      if [[ "$i" == "$j" ]]; then
>>          common_internal_methods="$j $common_internal_methods"
>>        fi
>>      done
>>    done
>> -  if [[ $common_internal_methods != "" ]]; then
>> +  if [[ "$common_internal_methods" != "" ]]; then
>>      echo -e "$bsp : RTEMS Internal functions used : \c"
>>      for i in $common_internal_methods
>>      do
>> @@ -111,10 +111,10 @@ function find_bsp_internal(){
>>    fi
>>  # Passing 1 initially to any check function states that the file/method/header
>>  # being checked is of critical nature
>>  function check_file(){
>>    filename="0"
>>    if [[ $1 == 1 ]]; then
>>      important="1"
>> @@ -123,27 +123,27 @@ function check_file(){
>>      important="0"
>>    fi
>> -#Grabbing the path of file being evaluated from Makefile.am
>> +  #Grabbing the path of file being evaluated from Makefile.am
>>    if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
>> -    file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
>> -    cd `dirname $file_path`
>> -    filename=$1
>> -    file_path=`pwd`
>> +    file_path="$(grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1)"
>> +    cd "$(dirname $file_path)"
>> +    filename="$1"
>> +    file_path="$(pwd)"
>>      cd - > /dev/null
>>      shift
>> -# Checking if file lies in correct directory path
>> -    for i in $*
>> +  # Checking if file lies in correct directory path
>> +    for i in $@
>>      do
>> -      if [[ -d $i ]]; then
>> -        cd $i
>> +      if [[ -d "$i" ]]; then
>> +        cd "$i"
>>        else
>>          continue
>>        fi
>> -      if [[ "$file_path" == `pwd` ]]; then
>> +      if [[ "$file_path" == $(pwd) ]]; then
>>          filename="$file_path/$filename"
>>          cd - >/dev/null
>>          return
>> @@ -167,6 +167,7 @@ function check_file(){
>>  # Checking presence of functions in specific files
>>  function check_methods(){
>>      important="1"
>>      shift
>> @@ -174,31 +175,31 @@ function check_methods(){
>>      important="0"
>>    fi
>> -  for i in $*
>> +  for i in $@
>>    do
>> -# When correct file for this function does not exist
>> -    if [[ $filename == "0" ]];then
>> +  # When correct file for this function does not exist
>> +    if [[ "$filename" == "0" ]];then
>>        if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
>>           if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]];then
>> -          echo $bsp : ${i%(*}"()" present in file `grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
>> +          echo $bsp : ${i%(*}"()" present in file $(grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *)
>>           fi
>>        fi
>>      else
>> -# When correct file for this function exists
>> -      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
>> +  # When correct file for this function exists
>> +      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" "$filename" ; then
>>          if [[ $verbose -eq "1" ]] ;then
>> -          echo "$bsp : `basename $filename` : ${i%(*}() present in file"
>> +          echo "$bsp : $(basename $filename) : ${i%(*}() present in file"
>>          fi
>>        else
>>             fi
>>          else
>>            if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]]; then
>> -            echo "$bsp : `basename $filename` : ${i%(*}() function does not exist in $filename "
>> +            echo "$bsp : $(basename $filename) : ${i%(*}() function does not exist in $filename "
>>              flag="1"
>>            fi
>>              faults="1"
>> @@ -211,6 +212,7 @@ function check_methods(){
>>  # Checking presence of headers installed by bsp
>>  function check_header(){
>>      important="1"
>>      shift
>> @@ -218,15 +220,15 @@ function check_header(){
>>      important="0"
>>    fi
>> -  for i in $*
>> +  for i in $@
>>    do
>>      if  grep -wq "$i" Makefile.am ;then
>>        if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
>>          continue
>>        fi
>> -        cd `dirname $i`
>> -        echo "$bsp : `basename $i` installed from directory" ${PWD##*/c/src/lib/}
>> +        cd $(dirname $i)
>> +        echo "$bsp : $(basename $i) installed from directory" ${PWD##*/c/src/lib/}
>>          cd - > /dev/null
>>        fi
>>        return
>> @@ -234,80 +236,77 @@ function check_header(){
>>    done
>> -    echo "${bsp%%[\ ]*} : `basename $1` not installed "
>> +    echo "${bsp%%[\ ]*} : $(basename $1) not installed "
>>      flag="1"
>>    fi
>>    filename="0"
>>    faults="1"
>>    return
>> -test_its_there()
>> -  if [ $# -ne 2 ] ; then
>> +function test_its_there(){
>> +  if [[ $# -ne 2 ]]; then
>>      echo Usage: $0 FILE pattern
>>    fi
>>    grep ${2} ${1} >/dev/null
>> -  if [ $? -ne 0 ] ; then
>> +  if [[ $? -ne 0 ]]; then
>>      echo "$bsp : ${2} is NOT in ${1##./}"
>>    fi
>> -test_its_there_all_case()
>> +function test_its_there_all_case(){
>>    fi
>>    grep -i ${2} ${1} >/dev/null
>>      echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
>>    fi
>> -test_its_NOT_there_all_case()
>> -  if [ $# -lt 2 ] ; then
>> +function test_its_NOT_there_all_case(){
>> +  if [[ $# -lt 2 ]]; then
>>    fi
>>    FILE=$1
>>    shift
>>    grep -i "${*}" ${FILE} >/dev/null
>> -  if [ $? -eq 0 ] ; then
>> +  if [[ $? -eq 0 ]]; then
>>      echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case independent check"
>>    fi
>> -test_its_NOT_there()
>> +function test_its_NOT_there(){
>>    fi
>>    FILE=$1
>>    shift
>>    grep "${*}" ${FILE} >/dev/null
>>      echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
>>    fi
>> -find_source()
>> +function find_source(){
>>    findArgs=
>>    while getopts "cCdm" OPT
>>    do
>> -   case "$OPT" in
>> -     c) findArgs="${findArgs} -o -name configure.ac" ;;
>> -     C) findArgs="${findArgs} -o -name *.cfg" ;;
>> -     d) findArgs="${findArgs} -o -name *.doc" ;;
>> -     m) findArgs="${findArgs} -o -name Makefile.am" ;;
>> -     *) echo "bad arg to find_source ($OPT)" ; exit 1 ;;
>> -   esac
>> +    case "$OPT" in
>> +      c) findArgs="${findArgs} -o -name configure.ac" ;;
>> +      C) findArgs="${findArgs} -o -name *.cfg" ;;
>> +      d) findArgs="${findArgs} -o -name *.doc" ;;
>> +      m) findArgs="${findArgs} -o -name Makefile.am" ;;
>> +      *) echo "bad arg to find_source ($OPT)" ; exit 1 ;;
>> +    esac
>>    done
>> -  shiftcount=`expr $OPTIND - 1`
>> +  shiftcount=$(expr $OPTIND - 1)
>>    shift $shiftcount
>>    args=$*
>> @@ -322,16 +321,16 @@ function check_format(){
>>    find_source -m -c -C | while read f
>>    do
>>      grep  ".\{81,\}" ${f} >/dev/null
>>        echo -e "\n$bsp : ${f#./} has more than 80 character lines"
>> -      for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
>> +      for i in $(grep -n '.\{80,\}' ${f} | cut -f1 -d:)
>>        do
>>          echo -e "$i \c"
>> -    done
>> +      done
>>      fi
>>    done
>> -  # really need to make the copyright strings consistent in BSPs
>> +  # Copyright strings should be consistent in BSPs
>>    echo -e "\n=== Checking for copyright notices"
>>    find_source | while read f
>>    do
>> @@ -356,7 +355,7 @@ function check_format(){
>>    echo "=== Checking for spaces at the end of lines"
>>    do
>> -    egrep " +$" $f >/dev/null
>> +    grep -E " +$" $f >/dev/null
>>      test $? -eq 0 && echo -e "${f##./} \c"
>>    done
>> @@ -395,36 +394,36 @@ function main(){
>>    fi
>>    # We do not want stdio in a BSP
>> -    echo "=== Checking for stdio"
>> -    find_source -m -c -C | while read f
>> -    do
>> -      test_its_NOT_there ${f} printf
>> -      test_its_NOT_there ${f} "puts("
>> -    done
>> +  echo "=== Checking for stdio"
>> +  find_source -m -c -C | while read f
>> +  do
>> +    test_its_NOT_there ${f} printf
>> +    test_its_NOT_there ${f} "puts("
>> +  done
>> -    # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>> -    #   RTEMS_BSP_BOOTCARD_OPTIONS
>> -    if [ -r configure.ac ] ; then
>> -      echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
>> -      test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>> -      echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
>> -      test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>> -    fi
>> +  # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>> +  #   RTEMS_BSP_BOOTCARD_OPTIONS
>> +  if [[ -r configure.ac ]]; then
>> +    echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
>> +    test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>> +    echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
>> +    test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>> +  fi
>> -    # If not using -O2, then we really want to know
>> -    # BSPs should normally use -O2
>> -    echo "=== Checking for not using -O2"
>> -    grep -H "\-O[013456789]" make/custom/*.cfg
>> +  # If not using -O2, then we really want to know
>> +  # BSPs should normally use -O2
>> +  echo "=== Checking for not using -O2"
>> +  grep -H "\-O[013456789]" make/custom/*.cfg
>> -    # BSPs should not turn on extra warnings
>> -    echo "=== Checking for turning on extra GCC warning checks"
>> -    grep -H "\-W" make/custom/*.cfg
>> +  # BSPs should not turn on extra warnings
>> +  echo "=== Checking for turning on extra GCC warning checks"
>> +  grep -H "\-W" make/custom/*.cfg
>> -    # Hopefully have some output from the tmtests
>> -    echo "=== Checking for timing information"
>> -    c=`ls -1 times* 2>/dev/null | wc -l`
>> -    if [ ${c} -eq 0 ] ; then
>> -      echo "Please run the timing tests and include the results."
>> +  # Hopefully have some output from the tmtests
>> +  echo "=== Checking for timing information"
>> +  c=$(ls -1 times* 2>/dev/null | wc -l)
>> +  if [[ ${c} -eq 0 ]]; then
>> +    echo "Please run the timing tests and include the results."
>>    fi
>>    echo -e "\n=== Starting BSP Unified way checks"
>> @@ -435,10 +434,10 @@ function main(){
>>    if [[ $filename != "0" ]];then
>>      if grep -wq "start" "$filename" || grep -wq "_start" "$filename"; then
>> -        echo "$bsp : `basename $filename` start() present in $filename"
>> +        echo "$bsp : $(basename $filename) start() present in $filename"
>>        fi
>>      else
>> -      echo "$bsp : `basename $filename` start() does not exist in start.S"
>> +      echo "$bsp : $(basename $filename) start() does not exist in start.S"
>>      fi
>>    fi
>> @@ -448,7 +447,6 @@ function main(){
>>    check_file 1 bspreset.c ../../shared/ ../shared/ startup/
>>    check_methods 1 "bsp_reset"
>>    check_file 1 bootcard.c ../../shared/
>>    check_header ../../shared/include/bootcard.h
>> @@ -458,7 +456,6 @@ function main(){
>>    check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup ../shared/ ../shared/startup/ startup/
>>    check_methods 1 "bsp_work_area_initialize"
>>    check_file 1 bsplibc.c ../../shared/
>>    check_methods "bsp_libc_init"
>> @@ -468,13 +465,11 @@ function main(){
>>    check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/ startup/
>>    check_methods "bsp_predriver_hook"
>>    check_file gnatinstallhandler.c ../../shared/
>>    check_file sbrk.c ../../shared/ ../../shared/ startup/
>>    check_methods "sbrk"
>>    check_file stackalloc.c ../../shared/src/
>>    check_methods "bsp_stack_allocate_init" "bsp_stack_allocate" "bsp_stack_free"
>> @@ -486,9 +481,7 @@ function main(){
>>    check_header 1 include/irq.h
>>    # PIC Support
>>    check_file irq-default-handler.c ../../shared/src/
>>    check_file 1 irq-generic.c ../../shared/src/
>>    check_header 1 ../../shared/include/irq-generic.h
>> @@ -503,7 +496,6 @@ function main(){
>>    check_file rtc-config.c rtc/
>>    check_methods "bsp_rtc_initialize" "bsp_rtc_get_time" "bsp_rtc_set_time" "bsp_rtc_probe"
>>    check_file 1 tod.c ../../shared/ tod/
>>    # Benchmark Timers
>> @@ -512,7 +504,6 @@ function main(){
>>    # Standard Headers
>>    check_header 1 include/bsp.h
>>    check_header include/bspopts.h
>>    check_header 1 ../../shared/include/coverhd.h include/coverhd.h
>> @@ -530,86 +521,87 @@ function main(){
>>      echo -e "\n"
>>    fi
>> -# Test specific checks
>> -  if [ ${do_test} == "1" ] ; then
>> +  # Test specific checks
>> +  if [[ ${do_test} == "1" ]]; then
>>      echo -e "\n=== Starting Test specific checks"
>>      # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>> -    Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>> -    if [ "X${Makefiles}" = "X" ] ; then
>> +    Makefiles=$(find . -name Makefile.am | xargs -e grep -l ^rtems_tests)
>> +    if [[ "X${Makefiles}" = "X" ]]; then
>>        echo -e "Unable to locate any test Makefile.am files.\n"
>>        return
>>      fi
>>      echo "=== Checking for missing test support files"
>>      for m in ${Makefiles}
>>      do
>> -      directory=`dirname ${m}`
>> -      if [ ${directory} = "." ] ; then
>> -        directory=`pwd`
>> +      directory=$(dirname ${m})
>> +      if [[ ${directory} = "." ]]; then
>> +        directory=$(pwd)
>>        fi
>> -      testName=`basename ${directory}`
>> +      testName=$(basename ${directory})
>>        # Does this test have a .doc file?
>> -      if [ ! -r ${directory}/${testName}.doc ] ; then
>> +      if [[ ! -r ${directory}/${testName}.doc ]]; then
>>          echo ${testName}.doc is not present
>>        fi
>>        case ${directory} in
>> -        */*tmtests*) ;;
>> -          # Does this test have a .scn file?
>> -          if [ ! -r ${directory}/${testName}.scn ] ; then
>> -            echo ${testName}.scn is not present
>> -          fi
>> +      */*tmtests*) ;;
>> +        # Does this test have a .scn file?
>> +        if [[ ! -r ${directory}/${testName}.scn ]]; then
>> +        echo ${testName}.scn is not present
>> +        fi
>>        esac
>>      done
>>    fi
>>  # Verifying if the directory given or pwd is a valid bsp, shared architecture, or libbsp directory
>>  function check_given_dir(){
>> -  if echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
>> +  if echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
>>      return 0
>> -  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
>> -# BSP given
>> -    bsp=${cur_dir##*/}
>> +  elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
>> +    # BSP given
>> +    bsp="${cur_dir##*/}"
>> -    if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp == "no_bsp" ]]; then
>> +    if [[ "$bsp" == "shared" || "$bsp" == "autom4te.cache" || "$bsp" == "no_bsp" ]]; then
>>        return 0
>>      else
>>        main
>>      fi
>> -  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
>> -# Shared architecture given
>> -    for i in *
>> +  elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
>> +    # Shared architecture given
>> +    for i in */Makefile.am
>>      do
>> -        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_bsp" ]]; then
>> -          echo -n
>> +      i="$(dirname $i)"
>> +        if [[ "$i" == "shared" || "$i" == "autom4te.cache" || "$i" == "no_bsp" ]]; then
>> +          echo -n > /dev/null
>>          else
>> -          bsp=$i
>> +          bsp="$i"
>> -          cd $bsp
>> +          cd "$bsp"
>>            main
>>            cd .. > /dev/null
>>          fi
>>        fi
>>      done
>> -  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
>> -# libbsp given
>> +  elif echo "$cur_dir" | grep -Eq "c/src/lib/libbsp" ; then
>> +    # libbsp given
>>      for i in */*/Makefile.am
>>      do
>> -      i=`dirname $i`
>> -        if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_cpu/no_bsp" ]]; then
>> +      i="$(dirname $i)"
>> +        if [[ "$i" == "shared" || "$i" == "autom4te.cache" || "$i" == "no_cpu/no_bsp" ]]; then
>>            echo -n
>>          else
>> -          bsp=$i
>> +          bsp="$i"
>> -          cd $bsp
>> +          cd "$bsp"
>>            main
>>            cd ../../ > /dev/null
>>          fi
>> @@ -624,67 +616,71 @@ function check_given_dir(){
>>  # Evaluating Command Line Arguments
>>  function start(){
>> -  for i in $*
>> +  path="0"
>> +  for i in "$@"
>>    do
>> -    case $i in
>> -      "--verbose") verbose="1" # The whole story
>> +    case "$i" in
>> -      "--warnings") warnings="1" # All warnings
>> -              verbose="0"
>> +    "--verbose") # The whole story
>> +      verbose="1"
>> -      "--no_format") format="0" # Disabling format checks
>> -              verbose="0"
>> +    "--warnings") # All warnings
>> +      warnings="1"
>> +      verbose="0"
>> -      "--tests") do_test="1"    # Enabling check of tests
>> -             verbose="0"
>> +    "--no_format") # Disabling format checks
>> +      format="0"
>> +      verbose="0"
>> -      "--help") echo "Help to be provided"
>> +    "--tests") # Enabling check of tests
>> +      do_test="1"
>> +      verbose="0"
>> -      "--"* | "-"* ) echo "Invalid options provided"
>> +    "--help")
>> +      echo "Help to be provided"
>> -      *) path="$path $i"  ;; # If not above options, then assumed to be a path for bsp
>> -    esac
>> -  done
>> +      echo "Invalid options provided"
>> -# No path given, search for bsp from pwd
>> -  if [[ -z $path ]];then
>> -    path=$PWD
>> -    cur_dir=`pwd`
>> -    check_given_dir
>> -    if [[ $? -eq 1 ]];then
>> -      echo "Current directory does not seem a valid RTEMS directory"
>> -    fi
>> -  else
>> -    for i in $path
>> -    do
>> +      if [[ -d "$i" ]]; then   # If not above options, then assumed to be a path for bsp
>>          echo > /dev/null
>>        else
>>          echo "$i is an invalid directory."
>> -        continue
>>        fi
>> -      cd $i
>> -      cur_dir=`pwd`
>> +      cd "$i"
>> +      cur_dir=$(pwd)
>>        check_given_dir
>>          echo "$i does not seem a valid RTEMS directory"
>> +      else
>> +        path="1"
>>        fi
>> -      cd $calling_path
>> +      cd "$calling_path"
>> +    esac
>> +  done
>> -    done
>> +  # No path given, search for bsp from pwd
>> +  if [[ "$path" == "0" ]];then
>> +    cur_dir=$(pwd)
>> +    check_given_dir
>> +    if [[ $? -eq 1 ]];then
>> +      echo "Current directory does not seem a valid RTEMS directory"
>> +    fi
>>    fi
>>  # Let the Game begin !!
>> -start $*
>> +start "$@"
>>  # End of Checks
>>  if [[ $faults -eq "0" ]] ; then
>> 1.7.11.7
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
