[SOCIS] Testing Framework
Rempel, Cynthia cynt6007 at vandals.uidaho.edu
Wed Sep 25 17:41:13 UTC 2013
>________________________________________
>From: Marcin Bujar [marcin.bujar at gmail.com]
>Sent: Wednesday, September 25, 2013 7:10 AM
>To: Joel Sherrill
>Cc: Rempel, Cynthia; rtems-devel at rtems.org
>Subject: Re: [SOCIS] Testing Framework
>Thank you for your feedback. I have emailed one of the maintainers Mark Vandervoord and he gave me some tips on how to improve my code. Once I make the changes he expressed interest in merging the code upstream.
That's great news! By pushing the changes upstream, we won't be locked into a particular version of Unity :)
>Once this is done I can start integrating the tool with rtems testing as mentioned I am planning to do.   If you are interested the code is here https://github.com/marcinbujar/Unity .
Do you have a blog related to this project as well? This looks interesting... once Unity has JSON support, will it be easier to display the results?
>Currently there is no support for output buffering but I could add it if it is required.
>Thanks,
Thank you!
Cindy
>Marcin
<snip />
