[PATCH 3/3] rename smpatomic08 to smpatomic01
WeiY wei.a.yang at gmail.com
Sat Sep 28 06:54:38 UTC 2013
 testsuites/smptests/Makefile.am                 |    2 +-
 testsuites/smptests/configure.ac                |    2 +-
 testsuites/smptests/smpatomic01/Makefile.am     |   19 +
 testsuites/smptests/smpatomic01/init.c          |  593 +++++++++++++++++++++++
 testsuites/smptests/smpatomic01/smpatomic01.doc |   12 +
 testsuites/smptests/smpatomic01/smpatomic01.scn |   29 ++
 testsuites/smptests/smpatomic08/Makefile.am     |   19 -
 testsuites/smptests/smpatomic08/init.c          |  593 -----------------------
 testsuites/smptests/smpatomic08/smpatomic08.doc |   12 -
 testsuites/smptests/smpatomic08/smpatomic08.scn |   23 -
 10 files changed, 655 insertions(+), 649 deletions(-)
 create mode 100644 testsuites/smptests/smpatomic01/Makefile.am
 create mode 100644 testsuites/smptests/smpatomic01/init.c
 create mode 100644 testsuites/smptests/smpatomic01/smpatomic01.doc
 create mode 100644 testsuites/smptests/smpatomic01/smpatomic01.scn
 delete mode 100644 testsuites/smptests/smpatomic08/Makefile.am
 delete mode 100644 testsuites/smptests/smpatomic08/init.c
 delete mode 100644 testsuites/smptests/smpatomic08/smpatomic08.doc
 delete mode 100644 testsuites/smptests/smpatomic08/smpatomic08.scn
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index d8b5a3e..3fa0d20 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -12,7 +12,7 @@ SUBDIRS += smp07
 SUBDIRS += smp08
 SUBDIRS += smp09
 if ATOMIC
-SUBDIRS += smpatomic08
+SUBDIRS += smpatomic01
 endif
 SUBDIRS += smplock01
 SUBDIRS += smpmigration01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 35f704d..3536c11 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -46,7 +46,7 @@ smp06/Makefile
 smp07/Makefile
 smp08/Makefile
 smp09/Makefile
-smpatomic08/Makefile
+smpatomic01/Makefile
 smplock01/Makefile
 smpmigration01/Makefile
 smppsxsignal01/Makefile
diff --git a/testsuites/smptests/smpatomic01/Makefile.am b/testsuites/smptests/smpatomic01/Makefile.am
new file mode 100644
index 0000000..f26cb54
--- /dev/null
+++ b/testsuites/smptests/smpatomic01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smpatomic01
+smpatomic01_SOURCES = init.c
+dist_rtems_tests_DATA = smpatomic01.scn smpatomic01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smpatomic01_OBJECTS)
+LINK_LIBS = $(smpatomic01_LDLIBS)
+smpatomic01$(EXEEXT): $(smpatomic01_OBJECTS) $(smpatomic01_DEPENDENCIES)
+	@rm -f smpatomic01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index 0000000..ac53527
--- /dev/null
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -0,0 +1,593 @@
+ * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/atomic.h>
+#include <rtems.h>
+#include <string.h>
+#include "tmacros.h"
+/* FIXME: Add barrier to Score */
+typedef struct {
+	Atomic_Ulong value;
+	Atomic_Ulong sense;
+} SMP_barrier_Control;
+typedef struct {
+	unsigned long sense;
+} SMP_barrier_State;
+#define SMP_BARRIER_CONTROL_INITIALIZER \
+  { ATOMIC_INITIALIZER_ULONG( 0 ), ATOMIC_INITIALIZER_ULONG( 0 ) }
+#define SMP_BARRIER_STATE_INITIALIZER { 0 }
+static void _SMP_barrier_Wait(
+  SMP_barrier_Control *control,
+  SMP_barrier_State *state,
+  unsigned long count
+  unsigned long sense = ~state->sense;
+  unsigned long previous_value;
+  state->sense = sense;
+  previous_value = _Atomic_Fetch_add_ulong(
+    &control->value,
+    1,
+    ATOMIC_ORDER_RELAXED
+  if ( previous_value + 1 == count ) {
+    _Atomic_Store_ulong( &control->value, 0, ATOMIC_ORDER_RELAXED );
+    _Atomic_Store_ulong( &control->sense, sense, ATOMIC_ORDER_RELEASE );
+  } else {
+    while (
+      _Atomic_Load_ulong( &control->sense, ATOMIC_ORDER_ACQUIRE ) != sense
+      /* Wait */
+#define MASTER_PRIORITY 1
+#define WORKER_PRIORITY 2
+#define CPU_COUNT 32
+typedef struct {
+  Atomic_Ulong stop;
+  SMP_barrier_Control barrier;
+  size_t worker_count;
+  rtems_id stop_worker_timer_id;
+  Atomic_Ulong atomic_value;
+  unsigned long per_worker_value[CPU_COUNT];
+  unsigned long normal_value;
+  Atomic_Flag global_flag;
+} test_context;
+typedef struct {
+  void (*init)(test_context *ctx);
+  void (*body)(test_context *ctx, size_t worker_index);
+  void (*fini)(test_context *ctx);
+} test_case;
+static test_context test_instance = {
+  .stop = ATOMIC_INITIALIZER_ULONG(0),
+  .barrier = SMP_BARRIER_CONTROL_INITIALIZER
+static bool stop(test_context *ctx)
+  return _Atomic_Load_ulong(&ctx->stop, ATOMIC_ORDER_RELAXED) != 0;
+static bool is_master_worker(size_t worker_index)
+  return worker_index == 0;
+static void test_fini(
+  test_context *ctx,
+  const char *test,
+  bool atomic
+  unsigned long expected_value = 0;
+  unsigned long actual_value;
+  size_t worker_index;
+  printf("=== atomic %s test case ==\n", test);
+  for (worker_index = 0; worker_index < ctx->worker_count; ++worker_index) {
+    unsigned long worker_value = ctx->per_worker_value[worker_index];
+    expected_value += worker_value;
+    printf(
+      "worker %zu value: %lu\n",
+      worker_index,
+      worker_value
+  if (atomic) {
+    actual_value = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
+  } else {
+    actual_value = ctx->normal_value;
+  printf(
+    "atomic value: expected = %lu, actual = %lu\n",
+    expected_value,
+    actual_value
+  rtems_test_assert(expected_value == actual_value);
+static void test_atomic_add_init(test_context *ctx)
+  _Atomic_Init_ulong(&ctx->atomic_value, 0);
+static void test_atomic_add_body(test_context *ctx, size_t worker_index)
+  unsigned long counter = 0;
+  while (!stop(ctx)) {
+    ++counter;
+    _Atomic_Fetch_add_ulong(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
+  ctx->per_worker_value[worker_index] = counter;
+static void test_atomic_add_fini(test_context *ctx)
+  test_fini(ctx, "add", true);
+static void test_atomic_flag_init(test_context *ctx)
+  _Atomic_Flag_clear(&ctx->global_flag, ATOMIC_ORDER_RELEASE);
+  ctx->normal_value = 0;
+static void test_atomic_flag_body(test_context *ctx, size_t worker_index)
+    while (_Atomic_Flag_test_and_set(&ctx->global_flag, ATOMIC_ORDER_ACQUIRE)) {
+      /* Wait */
+    ++counter;
+    ++ctx->normal_value;
+static void test_atomic_flag_fini(test_context *ctx)
+  test_fini(ctx, "flag", false);
+static void test_atomic_sub_init(test_context *ctx)
+static void test_atomic_sub_body(test_context *ctx, size_t worker_index)
+    --counter;
+    _Atomic_Fetch_sub_ulong(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
+static void test_atomic_sub_fini(test_context *ctx)
+  test_fini(ctx, "sub", true);
+static void test_atomic_compare_exchange_init(test_context *ctx)
+static void test_atomic_compare_exchange_body(test_context *ctx, size_t worker_index)
+    bool success;
+    do {
+      unsigned long zero = 0;
+      success = _Atomic_Compare_exchange_ulong(
+        &ctx->atomic_value,
+        &zero,
+        1,
+        ATOMIC_ORDER_ACQUIRE,
+    } while (!success);
+    ++counter;
+    _Atomic_Store_ulong(&ctx->atomic_value, 0, ATOMIC_ORDER_RELEASE);
+static void test_atomic_compare_exchange_fini(test_context *ctx)
+  test_fini(ctx, "compare exchange", false);
+static void test_atomic_or_and_init(test_context *ctx)
+static void test_atomic_or_and_body(test_context *ctx, size_t worker_index)
+  unsigned long the_bit = 1UL << worker_index;
+  unsigned long current_bit = 0;
+    unsigned long previous;
+    if (current_bit != 0) {
+      previous = _Atomic_Fetch_and_ulong(
+        ~the_bit,
+      current_bit = 0;
+    } else {
+      previous = _Atomic_Fetch_or_ulong(
+        the_bit,
+      current_bit = the_bit;
+    rtems_test_assert((previous & the_bit) != current_bit);
+  ctx->per_worker_value[worker_index] = current_bit;
+static void test_atomic_or_and_fini(test_context *ctx)
+  test_fini(ctx, "or/and", true);
+static const test_case test_cases[] = {
+    test_atomic_add_init,
+    test_atomic_add_body,
+    test_atomic_add_fini
+    test_atomic_flag_init,
+    test_atomic_flag_body,
+    test_atomic_flag_fini
+    test_atomic_sub_init,
+    test_atomic_sub_body,
+    test_atomic_sub_fini
+    test_atomic_compare_exchange_init,
+    test_atomic_compare_exchange_body,
+    test_atomic_compare_exchange_fini
+    test_atomic_or_and_init,
+    test_atomic_or_and_body,
+    test_atomic_or_and_fini
+#define TEST_COUNT RTEMS_ARRAY_SIZE(test_cases)
+static void stop_worker_timer(rtems_id timer_id, void *arg)
+  test_context *ctx = arg;
+  _Atomic_Store_ulong(&ctx->stop, 1, ATOMIC_ORDER_RELAXED);
+static void start_worker_stop_timer(test_context *ctx)
+  rtems_status_code sc;
+  _Atomic_Store_ulong(&ctx->stop, 0, ATOMIC_ORDER_RELEASE);
+  sc = rtems_timer_fire_after(
+    ctx->stop_worker_timer_id,
+    rtems_clock_get_ticks_per_second(),
+    stop_worker_timer,
+    ctx
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void run_tests(test_context *ctx, size_t worker_index)
+  SMP_barrier_State bs = SMP_BARRIER_STATE_INITIALIZER;
+  size_t test;
+  for (test = 0; test < TEST_COUNT; ++test) {
+    const test_case *tc = &test_cases[test];
+    if (is_master_worker(worker_index)) {
+      start_worker_stop_timer(ctx);
+      (*tc->init)(ctx);
+    _SMP_barrier_Wait(&ctx->barrier, &bs, ctx->worker_count);
+    (*tc->body)(ctx, worker_index);
+      (*tc->fini)(ctx);
+static void worker_task(size_t worker_index)
+  test_context *ctx = &test_instance;
+  run_tests(ctx, worker_index);
+  (void) rtems_task_suspend(RTEMS_SELF);
+  rtems_test_assert(0);
+static void test_static_and_dynamic_initialization(void)
+  static Atomic_Ulong static_ulong =
+    ATOMIC_INITIALIZER_ULONG(0xdeadbeefUL);
+  static Atomic_Pointer static_ptr =
+    ATOMIC_INITIALIZER_PTR(&static_ptr);
+  static Atomic_Flag static_flag = ATOMIC_INITIALIZER_FLAG;
+  Atomic_Ulong stack_ulong;
+  Atomic_Pointer stack_ptr;
+  Atomic_Flag stack_flag;
+  puts("=== static and dynamic initialization test case ===");
+  _Atomic_Init_ulong(&stack_ulong, 0xdeadbeefUL);
+  _Atomic_Init_ptr(&stack_ptr, &static_ptr);
+  _Atomic_Flag_clear(&stack_flag, ATOMIC_ORDER_RELAXED);
+    memcmp(&stack_ulong, &static_ulong, sizeof(stack_ulong)) == 0
+    memcmp(&stack_ptr, &static_ptr, sizeof(stack_ptr)) == 0
+    memcmp(&stack_flag, &static_flag, sizeof(stack_flag)) == 0
+    _Atomic_Load_ulong(&stack_ulong, ATOMIC_ORDER_RELAXED) == 0xdeadbeefUL
+    _Atomic_Load_ptr(&stack_ptr, ATOMIC_ORDER_RELAXED) == &static_ptr
+    !_Atomic_Flag_test_and_set(&stack_flag, ATOMIC_ORDER_RELAXED)
+static void test(void)
+  test_static_and_dynamic_initialization();
+  ctx->worker_count = rtems_smp_get_processor_count();
+  sc = rtems_timer_create(
+    rtems_build_name('S', 'T', 'O', 'P'),
+    &ctx->stop_worker_timer_id
+  for (worker_index = 1; worker_index < ctx->worker_count; ++worker_index) {
+    rtems_id worker_id;
+    sc = rtems_task_create(
+      rtems_build_name('W', 'O', 'R', 'K'),
+      WORKER_PRIORITY,
+      RTEMS_MINIMUM_STACK_SIZE,
+      RTEMS_DEFAULT_MODES,
+      RTEMS_DEFAULT_ATTRIBUTES,
+      &worker_id
+    sc = rtems_task_start(worker_id, worker_task, worker_index);
+  run_tests(ctx, 0);
+typedef void (*simple_test_body)(test_context *ctx);
+static void test_simple_atomic_add_body(test_context *ctx)
+  unsigned long a = 2, b = 1;
+  unsigned long c;
+  puts("=== atomic simple add test case ==\n");
+  _Atomic_Store_ulong(&ctx->atomic_value, a, ATOMIC_ORDER_RELAXED);
+  _Atomic_Fetch_add_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+  c = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
+  rtems_test_assert(c == (a + b));
+static void test_simple_atomic_sub_body(test_context *ctx)
+  unsigned long c;
+  puts("=== atomic simple sub test case ==\n");
+  _Atomic_Fetch_sub_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+  rtems_test_assert(c == (a - b));
+static void test_simple_atomic_or_body(test_context *ctx)
+  unsigned long c;
+  puts("=== atomic simple or test case ==\n");
+  _Atomic_Fetch_or_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+  rtems_test_assert(c == (a | b));
+static void test_simple_atomic_and_body(test_context *ctx)
+  unsigned long c;
+  puts("=== atomic simple and test case ==\n");
+  _Atomic_Fetch_and_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+  rtems_test_assert(c == (a & b));
+static void test_simple_atomic_exchange_body(test_context *ctx)
+  unsigned long c;
+  puts("=== atomic simple exchange test case ==\n");
+  _Atomic_Exchange_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+  rtems_test_assert(c == b);
+static void test_simple_atomic_compare_exchange_body(test_context *ctx)
+  unsigned long c;
+  puts("=== atomic simple compare exchange test case ==\n");
+  _Atomic_Compare_exchange_ulong(&ctx->atomic_value, &a, b,
+    ATOMIC_ORDER_RELAXED, ATOMIC_ORDER_RELAXED);
+static const simple_test_body simple_test_bodies[] = {
+  test_simple_atomic_add_body,
+  test_simple_atomic_sub_body,
+  test_simple_atomic_or_body,
+  test_simple_atomic_and_body,
+  test_simple_atomic_exchange_body,
+  test_simple_atomic_compare_exchange_body,
+#define SIMPLE_TEST_COUNT RTEMS_ARRAY_SIZE(simple_test_bodies)
+static void simple_tests(void)
+  size_t test;
+  for (test = 0; test < SIMPLE_TEST_COUNT; ++test) {
+    const simple_test_body *test_body = &simple_test_bodies[test];
+    (*test_body)(ctx);
+static void Init(rtems_task_argument arg)
+  puts("\n\n*** TEST SMPATOMIC 1 ***");
+  simple_tests();
+  test();
+  puts("*** END OF TEST SMPATOMIC 1 ***");
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_INIT_TASK_PRIORITY MASTER_PRIORITY
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpatomic01/smpatomic01.doc b/testsuites/smptests/smpatomic01/smpatomic01.doc
index 0000000..e4a0f51
--- /dev/null
+++ b/testsuites/smptests/smpatomic01/smpatomic01.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpatomic01
+directives:
+  - ATOMIC_*
+  - _Atomic_*
+concepts:
+  - Ensure that the atomic operations work.
diff --git a/testsuites/smptests/smpatomic01/smpatomic01.scn b/testsuites/smptests/smpatomic01/smpatomic01.scn
index 0000000..1122fae
--- /dev/null
+++ b/testsuites/smptests/smpatomic01/smpatomic01.scn
@@ -0,0 +1,29 @@
+*** TEST SMPATOMIC 1 ***
+=== atomic simple add test case ==
+=== atomic simple sub test case ==
+=== atomic simple or test case ==
+=== atomic simple and test case ==
+=== atomic simple exchange test case ==
+=== atomic simple compare exchange test case ==
+=== static and dynamic initialization test case ===
+=== atomic add test case ==
+worker 0 value: 16686
+worker 1 value: 36405
+atomic value: expected = 53091, actual = 53091
+=== atomic flag test case ==
+worker 0 value: 5588
+worker 1 value: 16019
+atomic value: expected = 21607, actual = 21607
+=== atomic sub test case ==
+worker 0 value: 4294950967
+worker 1 value: 4294930886
+atomic value: expected = 4294914557, actual = 4294914557
+=== atomic compare exchange test case ==
+worker 0 value: 2950
+worker 1 value: 22456
+atomic value: expected = 25406, actual = 25406
+=== atomic or/and test case ==
+worker 0 value: 1
+worker 1 value: 0
+atomic value: expected = 1, actual = 1
+*** END OF TEST SMPATOMIC 1 ***
diff --git a/testsuites/smptests/smpatomic08/Makefile.am b/testsuites/smptests/smpatomic08/Makefile.am
deleted file mode 100644
index f6abd55..0000000
--- a/testsuites/smptests/smpatomic08/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-rtems_tests_PROGRAMS = smpatomic08
-smpatomic08_SOURCES = init.c
-dist_rtems_tests_DATA = smpatomic08.scn smpatomic08.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(smpatomic08_OBJECTS)
-LINK_LIBS = $(smpatomic08_LDLIBS)
-smpatomic08$(EXEEXT): $(smpatomic08_OBJECTS) $(smpatomic08_DEPENDENCIES)
-	@rm -f smpatomic08$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smpatomic08/init.c b/testsuites/smptests/smpatomic08/init.c
index 5237a2f..0000000
--- a/testsuites/smptests/smpatomic08/init.c
+++ /dev/null
@@ -1,593 +0,0 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <rtems/score/atomic.h>
-#include <rtems.h>
-#include <string.h>
-#include "tmacros.h"
-/* FIXME: Add barrier to Score */
-typedef struct {
-	Atomic_Ulong value;
-	Atomic_Ulong sense;
-} SMP_barrier_Control;
-typedef struct {
-	unsigned long sense;
-} SMP_barrier_State;
-#define SMP_BARRIER_CONTROL_INITIALIZER \
-  { ATOMIC_INITIALIZER_ULONG( 0 ), ATOMIC_INITIALIZER_ULONG( 0 ) }
-#define SMP_BARRIER_STATE_INITIALIZER { 0 }
-static void _SMP_barrier_Wait(
-  SMP_barrier_Control *control,
-  SMP_barrier_State *state,
-  unsigned long count
-  unsigned long sense = ~state->sense;
-  unsigned long previous_value;
-  state->sense = sense;
-  previous_value = _Atomic_Fetch_add_ulong(
-    &control->value,
-    1,
-    ATOMIC_ORDER_RELAXED
-  if ( previous_value + 1 == count ) {
-    _Atomic_Store_ulong( &control->value, 0, ATOMIC_ORDER_RELAXED );
-    _Atomic_Store_ulong( &control->sense, sense, ATOMIC_ORDER_RELEASE );
-  } else {
-    while (
-      _Atomic_Load_ulong( &control->sense, ATOMIC_ORDER_ACQUIRE ) != sense
-      /* Wait */
-#define MASTER_PRIORITY 1
-#define WORKER_PRIORITY 2
-#define CPU_COUNT 32
-typedef struct {
-  Atomic_Ulong stop;
-  SMP_barrier_Control barrier;
-  size_t worker_count;
-  rtems_id stop_worker_timer_id;
-  Atomic_Ulong atomic_value;
-  unsigned long per_worker_value[CPU_COUNT];
-  unsigned long normal_value;
-  Atomic_Flag global_flag;
-} test_context;
-typedef struct {
-  void (*init)(test_context *ctx);
-  void (*body)(test_context *ctx, size_t worker_index);
-  void (*fini)(test_context *ctx);
-} test_case;
-static test_context test_instance = {
-  .stop = ATOMIC_INITIALIZER_ULONG(0),
-  .barrier = SMP_BARRIER_CONTROL_INITIALIZER
-static bool stop(test_context *ctx)
-  return _Atomic_Load_ulong(&ctx->stop, ATOMIC_ORDER_RELAXED) != 0;
-static bool is_master_worker(size_t worker_index)
-  return worker_index == 0;
-static void test_fini(
-  test_context *ctx,
-  const char *test,
-  bool atomic
-  unsigned long expected_value = 0;
-  unsigned long actual_value;
-  size_t worker_index;
-  printf("=== atomic %s test case ==\n", test);
-  for (worker_index = 0; worker_index < ctx->worker_count; ++worker_index) {
-    unsigned long worker_value = ctx->per_worker_value[worker_index];
-    expected_value += worker_value;
-    printf(
-      "worker %zu value: %lu\n",
-      worker_index,
-      worker_value
-  if (atomic) {
-    actual_value = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
-  } else {
-    actual_value = ctx->normal_value;
-  printf(
-    "atomic value: expected = %lu, actual = %lu\n",
-    expected_value,
-    actual_value
-  rtems_test_assert(expected_value == actual_value);
-static void test_atomic_add_init(test_context *ctx)
-  _Atomic_Init_ulong(&ctx->atomic_value, 0);
-static void test_atomic_add_body(test_context *ctx, size_t worker_index)
-  unsigned long counter = 0;
-  while (!stop(ctx)) {
-    ++counter;
-    _Atomic_Fetch_add_ulong(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
-  ctx->per_worker_value[worker_index] = counter;
-static void test_atomic_add_fini(test_context *ctx)
-  test_fini(ctx, "add", true);
-static void test_atomic_flag_init(test_context *ctx)
-  _Atomic_Flag_clear(&ctx->global_flag, ATOMIC_ORDER_RELEASE);
-  ctx->normal_value = 0;
-static void test_atomic_flag_body(test_context *ctx, size_t worker_index)
-    while (_Atomic_Flag_test_and_set(&ctx->global_flag, ATOMIC_ORDER_ACQUIRE)) {
-      /* Wait */
-    ++counter;
-    ++ctx->normal_value;
-static void test_atomic_flag_fini(test_context *ctx)
-  test_fini(ctx, "flag", false);
-static void test_atomic_sub_init(test_context *ctx)
-static void test_atomic_sub_body(test_context *ctx, size_t worker_index)
-    --counter;
-    _Atomic_Fetch_sub_ulong(&ctx->atomic_value, 1, ATOMIC_ORDER_RELAXED);
-static void test_atomic_sub_fini(test_context *ctx)
-  test_fini(ctx, "sub", true);
-static void test_atomic_compare_exchange_init(test_context *ctx)
-static void test_atomic_compare_exchange_body(test_context *ctx, size_t worker_index)
-    bool success;
-    do {
-      unsigned long zero = 0;
-      success = _Atomic_Compare_exchange_ulong(
-        &ctx->atomic_value,
-        &zero,
-        1,
-        ATOMIC_ORDER_ACQUIRE,
-    } while (!success);
-    ++counter;
-    _Atomic_Store_ulong(&ctx->atomic_value, 0, ATOMIC_ORDER_RELEASE);
-static void test_atomic_compare_exchange_fini(test_context *ctx)
-  test_fini(ctx, "compare exchange", false);
-static void test_atomic_or_and_init(test_context *ctx)
-static void test_atomic_or_and_body(test_context *ctx, size_t worker_index)
-  unsigned long the_bit = 1UL << worker_index;
-  unsigned long current_bit = 0;
-    unsigned long previous;
-    if (current_bit != 0) {
-      previous = _Atomic_Fetch_and_ulong(
-        ~the_bit,
-      current_bit = 0;
-    } else {
-      previous = _Atomic_Fetch_or_ulong(
-        the_bit,
-      current_bit = the_bit;
-    rtems_test_assert((previous & the_bit) != current_bit);
-  ctx->per_worker_value[worker_index] = current_bit;
-static void test_atomic_or_and_fini(test_context *ctx)
-  test_fini(ctx, "or/and", true);
-static const test_case test_cases[] = {
-    test_atomic_add_init,
-    test_atomic_add_body,
-    test_atomic_add_fini
-    test_atomic_flag_init,
-    test_atomic_flag_body,
-    test_atomic_flag_fini
-    test_atomic_sub_init,
-    test_atomic_sub_body,
-    test_atomic_sub_fini
-    test_atomic_compare_exchange_init,
-    test_atomic_compare_exchange_body,
-    test_atomic_compare_exchange_fini
-    test_atomic_or_and_init,
-    test_atomic_or_and_body,
-    test_atomic_or_and_fini
-#define TEST_COUNT RTEMS_ARRAY_SIZE(test_cases)
-static void stop_worker_timer(rtems_id timer_id, void *arg)
-  test_context *ctx = arg;
-  _Atomic_Store_ulong(&ctx->stop, 1, ATOMIC_ORDER_RELAXED);
-static void start_worker_stop_timer(test_context *ctx)
-  rtems_status_code sc;
-  _Atomic_Store_ulong(&ctx->stop, 0, ATOMIC_ORDER_RELEASE);
-  sc = rtems_timer_fire_after(
-    ctx->stop_worker_timer_id,
-    rtems_clock_get_ticks_per_second(),
-    stop_worker_timer,
-    ctx
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static void run_tests(test_context *ctx, size_t worker_index)
-  SMP_barrier_State bs = SMP_BARRIER_STATE_INITIALIZER;
-  size_t test;
-  for (test = 0; test < TEST_COUNT; ++test) {
-    const test_case *tc = &test_cases[test];
-    if (is_master_worker(worker_index)) {
-      start_worker_stop_timer(ctx);
-      (*tc->init)(ctx);
-    _SMP_barrier_Wait(&ctx->barrier, &bs, ctx->worker_count);
-    (*tc->body)(ctx, worker_index);
-      (*tc->fini)(ctx);
-static void worker_task(size_t worker_index)
-  test_context *ctx = &test_instance;
-  run_tests(ctx, worker_index);
-  (void) rtems_task_suspend(RTEMS_SELF);
-  rtems_test_assert(0);
-static void test_static_and_dynamic_initialization(void)
-  static Atomic_Ulong static_ulong =
-    ATOMIC_INITIALIZER_ULONG(0xdeadbeefUL);
-  static Atomic_Pointer static_ptr =
-    ATOMIC_INITIALIZER_PTR(&static_ptr);
-  static Atomic_Flag static_flag = ATOMIC_INITIALIZER_FLAG;
-  Atomic_Ulong stack_ulong;
-  Atomic_Pointer stack_ptr;
-  Atomic_Flag stack_flag;
-  puts("=== static and dynamic initialization test case ===");
-  _Atomic_Init_ulong(&stack_ulong, 0xdeadbeefUL);
-  _Atomic_Init_ptr(&stack_ptr, &static_ptr);
-  _Atomic_Flag_clear(&stack_flag, ATOMIC_ORDER_RELAXED);
-    memcmp(&stack_ulong, &static_ulong, sizeof(stack_ulong)) == 0
-    memcmp(&stack_ptr, &static_ptr, sizeof(stack_ptr)) == 0
-    memcmp(&stack_flag, &static_flag, sizeof(stack_flag)) == 0
-    _Atomic_Load_ulong(&stack_ulong, ATOMIC_ORDER_RELAXED) == 0xdeadbeefUL
-    _Atomic_Load_ptr(&stack_ptr, ATOMIC_ORDER_RELAXED) == &static_ptr
-    !_Atomic_Flag_test_and_set(&stack_flag, ATOMIC_ORDER_RELAXED)
-static void test(void)
-  test_static_and_dynamic_initialization();
-  ctx->worker_count = rtems_smp_get_processor_count();
-  sc = rtems_timer_create(
-    rtems_build_name('S', 'T', 'O', 'P'),
-    &ctx->stop_worker_timer_id
-  for (worker_index = 1; worker_index < ctx->worker_count; ++worker_index) {
-    rtems_id worker_id;
-    sc = rtems_task_create(
-      rtems_build_name('W', 'O', 'R', 'K'),
-      WORKER_PRIORITY,
-      RTEMS_MINIMUM_STACK_SIZE,
-      RTEMS_DEFAULT_MODES,
-      RTEMS_DEFAULT_ATTRIBUTES,
-      &worker_id
-    sc = rtems_task_start(worker_id, worker_task, worker_index);
-  run_tests(ctx, 0);
-typedef void (*simple_test_body)(test_context *ctx);
-static void test_simple_atomic_add_body(test_context *ctx)
-  unsigned long a = 2, b = 1;
-  unsigned long c;
-  puts("=== atomic simple add test case ==\n");
-  _Atomic_Store_ulong(&ctx->atomic_value, a, ATOMIC_ORDER_RELAXED);
-  _Atomic_Fetch_add_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
-  c = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
-  rtems_test_assert(c == (a + b));
-static void test_simple_atomic_sub_body(test_context *ctx)
-  unsigned long c;
-  puts("=== atomic simple sub test case ==\n");
-  _Atomic_Fetch_sub_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
-  rtems_test_assert(c == (a - b));
-static void test_simple_atomic_or_body(test_context *ctx)
-  unsigned long c;
-  puts("=== atomic simple or test case ==\n");
-  _Atomic_Fetch_or_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
-  rtems_test_assert(c == (a | b));
-static void test_simple_atomic_and_body(test_context *ctx)
-  unsigned long c;
-  puts("=== atomic simple and test case ==\n");
-  _Atomic_Fetch_and_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
-  rtems_test_assert(c == (a & b));
-static void test_simple_atomic_exchange_body(test_context *ctx)
-  unsigned long c;
-  puts("=== atomic simple exchange test case ==\n");
-  _Atomic_Exchange_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
-  rtems_test_assert(c == b);
-static void test_simple_atomic_compare_exchange_body(test_context *ctx)
-  unsigned long c;
-  puts("=== atomic simple compare exchange test case ==\n");
-  _Atomic_Compare_exchange_ulong(&ctx->atomic_value, &a, b,
-    ATOMIC_ORDER_RELAXED, ATOMIC_ORDER_RELAXED);
-static const simple_test_body simple_test_bodies[] = {
-  test_simple_atomic_add_body,
-  test_simple_atomic_sub_body,
-  test_simple_atomic_or_body,
-  test_simple_atomic_and_body,
-  test_simple_atomic_exchange_body,
-  test_simple_atomic_compare_exchange_body,
-#define SIMPLE_TEST_COUNT RTEMS_ARRAY_SIZE(simple_test_bodies)
-static void simple_tests(void)
-  size_t test;
-  for (test = 0; test < SIMPLE_TEST_COUNT; ++test) {
-    const simple_test_body *test_body = &simple_test_bodies[test];
-    (*test_body)(ctx);
-static void Init(rtems_task_argument arg)
-  puts("\n\n*** TEST SMPATOMIC 8 ***");
-  simple_tests();
-  test();
-  puts("*** END OF TEST SMPATOMIC 8 ***");
-  rtems_test_exit(0);
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_SMP_APPLICATION
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
-#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#define CONFIGURE_INIT_TASK_PRIORITY MASTER_PRIORITY
-#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
-#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpatomic08/smpatomic08.doc b/testsuites/smptests/smpatomic08/smpatomic08.doc
index 629e431..0000000
--- a/testsuites/smptests/smpatomic08/smpatomic08.doc
+++ /dev/null
@@ -1,12 +0,0 @@
-This file describes the directives and concepts tested by this test set.
-test set name: smpatomic08
-directives:
-  - ATOMIC_*
-  - _Atomic_*
-concepts:
-  - Ensure that the atomic operations work.
diff --git a/testsuites/smptests/smpatomic08/smpatomic08.scn b/testsuites/smptests/smpatomic08/smpatomic08.scn
index 28d4680..0000000
--- a/testsuites/smptests/smpatomic08/smpatomic08.scn
+++ /dev/null
@@ -1,23 +0,0 @@
-*** TEST SMPATOMIC 8 ***
-=== static and dynamic initialization test case ===
-=== atomic add test case ==
-worker 0 value: 16686
-worker 1 value: 36405
-atomic value: expected = 53091, actual = 53091
-=== atomic flag test case ==
-worker 0 value: 5588
-worker 1 value: 16019
-atomic value: expected = 21607, actual = 21607
-=== atomic sub test case ==
-worker 0 value: 4294950967
-worker 1 value: 4294930886
-atomic value: expected = 4294914557, actual = 4294914557
-=== atomic compare exchange test case ==
-worker 0 value: 2950
-worker 1 value: 22456
-atomic value: expected = 25406, actual = 25406
-=== atomic or/and test case ==
-worker 0 value: 1
-worker 1 value: 0
-atomic value: expected = 1, actual = 1
-*** END OF TEST SMPATOMIC 8 ***
1.7.9.5
