[PATCH 2/2] Shared MMU initialization for ARM BSPs and RaspberryPi MMU support
Sat Sep 28 16:07:03 UTC 2013
Looks good on my end. Alan or Sebastian have any comments?
-Gedare
On Sat, Sep 28, 2013 at 4:08 AM, Hesham AL-Matary
<heshamelmatary at gmail.com> wrote:
> The newly added ORed flag: ARM_CP15_CTRL_XP is vital to get RaspberryPi
> MMU working properly and to share the container function between various
> ARM BSPs. The new ORed flags do not affect the current BSPs that make use
> of arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function.
> The rest is of the patch targets MMU initialization for ARM architectures,
> desgined to be shared. Later patches make use of shared mminit implementation.
>  c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  9 ++-
>  c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |  8 +++
>  .../libbsp/arm/raspberrypi/startup/bspstarthooks.c | 22 +------
>  c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds  |  4 +-
>  .../arm/raspberrypi/startup/mm_config_table.c      | 70 ++++++++++++++++++++++
>  .../lib/libbsp/arm/shared/include/arm-cp15-start.h | 15 +++--
>  c/src/lib/libbsp/arm/shared/mminit.c               | 24 ++++++++
>  c/src/lib/libbsp/shared/include/mm.h               | 25 ++++++++
>  8 files changed, 151 insertions(+), 26 deletions(-)
>  create mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>  create mode 100644 c/src/lib/libbsp/arm/shared/mminit.c
>  create mode 100644 c/src/lib/libbsp/shared/include/mm.h
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> index 24d396c..a06979a 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> @@ -27,6 +27,7 @@ nodist_include_HEADERS = ../../shared/include/coverhd.h \
>  nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
> +include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
>  include_bsp_HEADERS += ../../shared/include/utility.h
>  include_bsp_HEADERS += ../../shared/include/irq-generic.h
>  include_bsp_HEADERS += ../../shared/include/irq-info.h
> @@ -35,6 +36,7 @@ include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>  include_bsp_HEADERS += ../../shared/tod.h
>  include_bsp_HEADERS += ../shared/include/linker-symbols.h
>  include_bsp_HEADERS += ../shared/include/start.h
> +include_bsp_HEADERS += ../shared/include/arm-cp15-start.h
>  include_bsp_HEADERS += ../shared/lpc/include/lpc-timer.h
>  include_bsp_HEADERS += ../shared/lpc/include/lpc-dma.h
>  include_bsp_HEADERS += include/irq.h
> @@ -83,7 +85,7 @@ libbsp_a_SOURCES += ../../shared/sbrk.c
>  libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>  libbsp_a_SOURCES += ../shared/abort/simple_abort.c
>  libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
> +libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
>  # Startup
>  libbsp_a_SOURCES += startup/bspreset.c
> @@ -91,6 +93,7 @@ libbsp_a_SOURCES += startup/bspstart.c
>  # IRQ
>  libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
> +libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
>  libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>  libbsp_a_SOURCES += ../../shared/src/irq-info.c
>  libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
> @@ -127,6 +130,10 @@ libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
>  # Start hooks
>  libbsp_a_SOURCES += startup/bspstarthooks.c
> +# LIBMM
> +libbsp_a_SOURCES += startup/mm_config_table.c
> +libbsp_a_SOURCES += ../shared/mminit.c
>  # Network                                                    #
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> index 056c5f1..a638e64 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> @@ -62,6 +62,10 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INC
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
> +$(PROJECT_INCLUDE)/bsp/mm.h: ../../../libbsp/shared/include/mm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mm.h
>  $(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
> @@ -94,6 +98,10 @@ $(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h $(PROJECT_INCLUDE)/bsp
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
> +$(PROJECT_INCLUDE)/bsp/arm-cp15-start.h: ../shared/include/arm-cp15-start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
>  $(PROJECT_INCLUDE)/bsp/lpc-timer.h: ../shared/lpc/include/lpc-timer.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-timer.h
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
> index a224168..71b2ff1 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
> @@ -7,6 +7,7 @@
> + * Copyright (c) 2013. Hesham AL-Matary
>   * Copyright (c) 2013 by Alan Cudmore
>   * based on work by:
>   * Copyright (c) 2009
> @@ -24,33 +25,16 @@
>  #include <bspopts.h>
>  #include <bsp/start.h>
>  #include <bsp/raspberrypi.h>
> -#include <bsp/mmu.h>
> -static void BSP_START_TEXT_SECTION raspberrypi_cache_setup(void)
> -  uint32_t ctrl = 0;
> -  /* Disable MMU and cache, basic settings */
> -  ctrl = arm_cp15_get_control();
> -  ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
> -    | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
> -  ctrl |= ARM_CP15_CTRL_S;
> -  arm_cp15_set_control(ctrl);
> -  arm_cp15_cache_invalidate();
> -  arm_cp15_tlb_invalidate();
> +#include <bsp/mm.h>
>  void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
> -  raspberrypi_cache_setup();
>  void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
>    bsp_start_copy_sections();
> +  bsp_memory_management_initialize();
>    bsp_start_clear_bss();
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> index b9a0dd8..c12b348 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> @@ -35,7 +35,8 @@
>  MEMORY {
>          VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 0x8000
> -        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 0x8000
> +        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 48K
> +       RAM_MMU        (AIW) : ORIGIN = 128M - 16k, LENGTH = 16k
>  REGION_ALIAS ("REGION_START", RAM);
> @@ -58,5 +59,6 @@ bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 4096;
>  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
>  bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1M;
> +bsp_translation_table_base = ORIGIN (RAM_MMU);
>  INCLUDE linkcmds.armv4
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> new file mode 100644
> index 0000000..fd85513
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> @@ -0,0 +1,70 @@
> + * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <info at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#include <bsp/start.h>
> +#include <bsp/arm-cp15-start.h>
> +#ifdef RTEMS_SMP
> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
> +#else
> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_CACHED
> +#endif
> +BSP_START_DATA_SECTION const arm_cp15_start_section_config
> +bsp_mm_config_table[] = {
> +    .begin = (uint32_t) bsp_section_fast_text_begin,
> +    .end = (uint32_t) bsp_section_fast_text_end,
> +    .flags = ARMV7_MMU_CODE_CACHED
> +    .begin = (uint32_t) bsp_section_fast_data_begin,
> +    .end = (uint32_t) bsp_section_fast_data_end,
> +    .flags = MMU_DATA_READ_WRITE
> +    .begin = (uint32_t) bsp_section_start_begin,
> +    .end = (uint32_t) bsp_section_start_end,
> +    .begin = (uint32_t) bsp_section_vector_begin,
> +    .end = (uint32_t) bsp_section_vector_end,
> +    .begin = (uint32_t) bsp_section_text_begin,
> +    .end = (uint32_t) bsp_section_text_end,
> +    .begin = (uint32_t) bsp_section_rodata_begin,
> +    .end = (uint32_t) bsp_section_rodata_end,
> +    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
> +    .begin = (uint32_t) bsp_section_data_begin,
> +    .end = (uint32_t) bsp_section_data_end,
> +    .begin = (uint32_t) bsp_section_bss_begin,
> +    .end = (uint32_t) bsp_section_bss_end,
> +    .begin = (uint32_t) bsp_section_work_begin,
> +    .end = (uint32_t) bsp_section_work_end,
> +    .begin = (uint32_t) bsp_section_stack_begin,
> +    .end = (uint32_t) bsp_section_stack_end,
> +BSP_START_DATA_SECTION const size_t bsp_mm_config_table_size =
> +RTEMS_ARRAY_SIZE(&bsp_mm_config_table);
> diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> index 01f3104..6a2598b 100644
> --- a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> +++ b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
> @@ -1,4 +1,5 @@
> + * Copyright (c) 2013 Hesham AL-Matary.
>   * Copyright (c) 2009-2013 embedded brains GmbH.  All rights reserved.
> @@ -16,13 +17,15 @@
>  #define LIBBSP_ARM_SHARED_ARM_CP15_START_H
>  #include <libcpu/arm-cp15.h>
>  #ifdef __cplusplus
>  extern "C" {
>  #endif /* __cplusplus */
> +extern const arm_cp15_start_section_config bsp_mm_config_table[];
> +extern const size_t bsp_mm_config_table_size;
>  BSP_START_TEXT_SECTION static inline void
>  arm_cp15_set_domain_access_control(uint32_t val);
> @@ -87,9 +90,9 @@ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>    arm_cp15_set_domain_access_control(dac);
>    arm_cp15_set_translation_table_base(ttb);
> -  /* Initialize translation table with invalid entries */
> +  /* Initialize translation table with fixed-map read-write entries */
>    for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
> -    ttb [i] = 0;
> +    ttb [i] = (i << ARM_MMU_SECT_BASE_SHIFT) | ARMV7_MMU_DATA_READ_WRITE;
>    for (i = 0; i < config_count; ++i) {
> @@ -97,7 +100,9 @@ arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>    /* Enable MMU and cache */
> -  ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
> +  ctrl |= ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_S | ARM_CP15_CTRL_I |
> +          ARM_CP15_CTRL_C | ARM_CP15_CTRL_M  | ARM_CP15_CTRL_XP;
> diff --git a/c/src/lib/libbsp/arm/shared/mminit.c b/c/src/lib/libbsp/arm/shared/mminit.c
> index 0000000..0ea9805
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/shared/mminit.c
> @@ -0,0 +1,24 @@
> +#include <bsp/linker-symbols.h>
> +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
> +  uint32_t ctrl = arm_cp15_get_control();
> +  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> +    ctrl,
> +    (uint32_t *) bsp_translation_table_base,
> +    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
> +    &bsp_mm_config_table[0],
> +    bsp_mm_config_table_size
> diff --git a/c/src/lib/libbsp/shared/include/mm.h b/c/src/lib/libbsp/shared/include/mm.h
> index 0000000..1a1eb7f
> --- /dev/null
> +++ b/c/src/lib/libbsp/shared/include/mm.h
> @@ -0,0 +1,25 @@
> + * Copyright (c) 2013 Gedare Bloom.
> +#ifndef __LIBBSP_MM_H
> +#define __LIBBSP_MM_H
> +#include <stdint.h>
> +#include <stdlib.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +void bsp_memory_management_initialize(void);
> +#ifdef __cplusplus
> +#endif
> +#endif
> 1.8.3.1
> rtems-devel mailing list
> rtems-devel at rtems.org
