[PATCH 3/6] libmm-libbsp-shared. Files shared between all target BSPs and low-level implementations for libmm. These shared files contain mm.h which is a link between high-level score api and low-level implemenation of libmm. mm.h contains function declarations which should be implemented by target BSP to support libmm. no_memorymanagement.c contains stubs for BSPs that do not support libmm.
Gedare Bloom
gedare at rtems.org
Thu Sep 12 12:55:38 UTC 2013
On Thu, Sep 12, 2013 at 2:59 AM, Hesham AL-Matary
<heshamelmatary at gmail.com> wrote:
> c/src/lib/libbsp/shared/include/mm.h | 36 +++++++++++++++++++++++
> c/src/lib/libbsp/shared/src/no_memorymanagement.c | 21 +++++++++++++
> 2 files changed, 57 insertions(+)
> create mode 100644 c/src/lib/libbsp/shared/include/mm.h
> create mode 100644 c/src/lib/libbsp/shared/src/no_memorymanagement.c
> diff --git a/c/src/lib/libbsp/shared/include/mm.h b/c/src/lib/libbsp/shared/include/mm.h
> new file mode 100644
> index 0000000..f2ac71c
> --- /dev/null
> +++ b/c/src/lib/libbsp/shared/include/mm.h
> @@ -0,0 +1,36 @@
> + * Copyright (c) 2013 Gedare Bloom.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifndef __LIBBSP_MM_H
> +#define __LIBBSP_MM_H
> +#include <stdint.h>
> +#include <stdlib.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +typedef struct {
> + uint32_t begin;
> + uint32_t end;
> + uint32_t flags;
> +} mm_init_start_config;
Should begin/end be uintptr_t? This structure appears to be unused
here, so perhaps it should be left out?
> +void bsp_memory_management_initialize(void);
> +void bsp_memory_management_set_attributes(
> + uintptr_t base,
> + size_t size,
> + uint32_t attr
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libbsp/shared/src/no_memorymanagement.c b/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> index 0000000..1a5fc63
> --- /dev/null
> +++ b/c/src/lib/libbsp/shared/src/no_memorymanagement.c
> @@ -0,0 +1,21 @@
> + * Copyright (c) 2013 Hesham AL-Matary
> +#include <rtems.h>
> +#include <libbsp/mm.h>
> +void bsp_memory_management_initialize( void ) { }
> + uintptr_t base,
> + size_t size,
> + uint32_t flags
> 1.8.3.1
> rtems-devel mailing list
> rtems-devel at rtems.org
