[PATCH 4/6] libmm-libbsp-arm-shared. libmm low-level implementation that can be shared between many ARM targets. mminit.c contains initialization function for arm-cp15 and setup page tables. After that it enables MMU and Cache unit part of BSP initialization process. mm.c translates attributes from high-level to CPU specific attributes and apply them dynamically.
Thu Sep 12 18:33:44 UTC 2013
On Thu, Sep 12, 2013 at 2:26 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Thu, Sep 12, 2013 at 8:17 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Sep 12, 2013 at 2:10 PM, Hesham Moustafa
>> > On Thu, Sep 12, 2013 at 3:01 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Thu, Sep 12, 2013 at 2:59 AM, Hesham AL-Matary
>> >> >  .../lib/libbsp/arm/shared/include/arm-cp15-start.h | 11 ++++--
>> >> >  c/src/lib/libbsp/arm/shared/mm.c                   | 46
>> >> >  c/src/lib/libbsp/arm/shared/mminit.c               | 27
>> >> >  3 files changed, 80 insertions(+), 4 deletions(-)
>> >> >  create mode 100644 c/src/lib/libbsp/arm/shared/mm.c
>> >> >  create mode 100644 c/src/lib/libbsp/arm/shared/mminit.c
>> >> > diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>> >> > b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>> >> > index 01f3104..b463b1f 100644
>> >> > --- a/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>> >> > +++ b/c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h
>> >> > @@ -1,4 +1,5 @@
>> >> > + * Copyright (c) 2013 Hesham AL-Matary.
>> >> >   * Copyright (c) 2009-2013 embedded brains GmbH.  All rights
>> >> > reserved.
>> >> >   *  embedded brains GmbH
>> >> > @@ -89,7 +90,7 @@
>> >> > arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>> >> >    /* Initialize translation table with invalid entries */
>> >> Fix this comment (assuming the change below now populates the ttb with
>> >> valid entries).
>> >> >    for (i = 0; i < ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT; ++i) {
>> >> > -    ttb [i] = 0;
>> >> > +    ttb [i] = (i << ARM_MMU_SECT_BASE_SHIFT) |
>> >> > ARMV7_MMU_DATA_READ_WRITE;
>> >> >    for (i = 0; i < config_count; ++i) {
>> >> > @@ -97,11 +98,13 @@
>> >> >    /* Enable MMU and cache */
>> >> > -  ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
>> >> > +  ctrl |= ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_S | ARM_CP15_CTRL_I |
>> >> > +          ARM_CP15_CTRL_C | ARM_CP15_CTRL_M  | ARM_CP15_CTRL_XP;
>> >> >    arm_cp15_set_control(ctrl);
>> >> > -BSP_START_TEXT_SECTION static inline uint32_t
>> >> > +BSP_START_TEXT_SECTION inline uint32_t
>> >> undo this change.
>> > I already did, but that caused undefined reference to
>> > arm_cp15_start_setup_mmu_and_cache
>> > compilation error at arm-a9mpcore-start.h:89 when I was compiling
>> > realview
>> > with --enable-smp
>> > option.
>> You should figure out why that happened. Changing this function to
>> non-inline does not seem like the right answer.
>  The change is that it's not static anymore because it's called from
> another file too.
inline functions should be declared static. Then they can be included
in multiple .c files without causing multiple definitions of the same
function.
>> >> >  arm_cp15_start_setup_mmu_and_cache(uint32_t ctrl_clear, uint32_t
>> >> > ctrl_set)
>> >> >    uint32_t ctrl = arm_cp15_get_control();
>> >> > diff --git a/c/src/lib/libbsp/arm/shared/mm.c
>> >> > b/c/src/lib/libbsp/arm/shared/mm.c
>> >> > new file mode 100644
>> >> > index 0000000..36e90be
>> >> > --- /dev/null
>> >> > +++ b/c/src/lib/libbsp/arm/shared/mm.c
>> >> > @@ -0,0 +1,46 @@
>> >> > + * The license and distribution terms for this file may be
>> >> > + * found in the file LICENSE in this distribution or at
>> >> > + * http://www.rtems.com/license/LICENSE.
>> >> > +#include <bsp/mm.h>
>> >> > +#include <libcpu/arm-cp15.h>
>> >> > +#include <rtems/score/mm.h>
>> >> > +#define LIBMM_REGION_IS_CACHE_ENABLED(attr) \
>> >> > +  (((attr) >> RTEMS_MM_REGION_BIT_CACHE) & 1U)
>> >> > +#define LIBMM_REGION_IS_PROTECTION_WRITE_ENABLED(attr) \
>> >> > +  (((attr) >> RTEMS_MM_REGION_BIT_WRITE) & 1U)
>> >> > +#define LIBMM_REGION_IS_DEVICE_TYPE(attr) \
>> >> > +  (((attr) >> RTEMS_MM_REGION_BIT_DEVICE) & 1U)
>> >> > +#define LIBMM_REGION_IS_SHARED_MEMORY(attr) \
>> >> > +  (((attr) >> RTEMS_MM_REGION_BIT_SHARED) & 1U)
>> >> Should these macros be provided by the score/mm.h?
>> > mm.h or mmimpl.h whatever. It's used by applications calls as well as
>> > mm.c which used these definitions to translate attributes to CPU
>> > specific
>> > ones.
>> mm.h so that the macros are "visible".
> Yes for both application and low-level implementation code.
>> >> > +#define ARM_MMU_BIND_SECTION_TO_CLIENT_DOMAIN \
>> >> > +  (ARM_MMU_DEFAULT_CLIENT_DOMAIN << ARM_MMU_SECT_DOMAIN_SHIFT)
>> >> > +#define LIBMM_TRANSLATE_ATTRIBUTES_TO_CPU(attr) \
>> >> > +  ((ARM_MMU_BIND_SECTION_TO_CLIENT_DOMAIN) \
>> >> > +  | (ARM_MMU_SECT_AP_0) \
>> >> > +  | (LIBMM_REGION_IS_PROTECTION_WRITE_ENABLED(attr) ? \
>> >> > +  0U : (ARM_MMU_SECT_AP_2)) \
>> >> > +  | (LIBMM_REGION_IS_CACHE_ENABLED(attr) ? \
>> >> > +  (ARM_MMU_SECT_TEX_0|ARM_MMU_SECT_C|ARM_MMU_SECT_B) : 0U) \
>> >> > +  | (LIBMM_REGION_IS_DEVICE_TYPE(attr) ? ARM_MMU_SECT_B : 0U) \
>> >> > +  | (LIBMM_REGION_IS_SHARED_MEMORY(attr) ? ARM_MMU_SECT_S : 0U) \
>> >> > +  | (ARM_MMU_SECT_DEFAULT))
>> >> This macro could properly be named something simpler since it is local
>> >> to this .c file.
>> > Sure, I just wanted to give it a self-describing name.
>> >> > +void bsp_memory_management_set_attributes(
>> >> > +  uintptr_t base,
>> >> > +  size_t size,
>> >> > +  uint32_t attr
>> >> > +  uintptr_t end = (uint32_t)base + (uint32_t)size;
>> >> Don't cast base and size here.
>> >> > +  uint32_t section_flags = LIBMM_TRANSLATE_ATTRIBUTES_TO_CPU(attr);
>> >> > +  arm_cp15_set_translation_table_entries(base, end, section_flags);
>> >> > diff --git a/c/src/lib/libbsp/arm/shared/mminit.c
>> >> > b/c/src/lib/libbsp/arm/shared/mminit.c
>> >> > index 0000000..333d65c
>> >> > --- /dev/null
>> >> > +++ b/c/src/lib/libbsp/arm/shared/mminit.c
>> >> > @@ -0,0 +1,27 @@
>> >> > +#include <bsp/arm-cp15-start.h>
>> >> > +#include <bsp/linker-symbols.h>
>> >> > +#include <bsp/start.h>
>> >> > +extern const mm_init_start_config bsp_mm_config_table[];
>> >> > +extern const size_t bsp_mm_config_table_size;
>> >> > +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
>> >> > +  uint32_t ctrl = arm_cp15_get_control();
>> >> > +  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>> >> > +  ctrl,
>> >> > +  (uint32_t *) bsp_translation_table_base,
>> >> > +  ARM_MMU_DEFAULT_CLIENT_DOMAIN,
>> >> > +  &bsp_mm_config_table[0],
>> >> > +  bsp_mm_config_table_size
>> >> Fix indentation level of nested lines of arguments. Also, this
>> >> mminit.c file does not make sense until you add at least one of the
>> >> ARM bsps using it.
>> > realview, xilinx, and raspberry currently
>> > calls the initialization function within this
>> > mminit.c
>> Right, except they have not been added prior to this patch. Without
>> knowledge about them, this code does not make sense, right? Anyway, I
>> think it might be useful to re-arrange the order of these patches in
>> order to add the raspberrypi mmu handling first, and then show how to
>> consolidate the ARM MMU handling, and then offer some generic routines
>> in the bsp layer (e.g. bsp_memory_management_initialize) that can
>> unify the other BSPs like powerpc ones that will also have MMU/MPU
>> requirements.
> Sure, that means that the next set of patches should only include
> raspberrypi
> implementation only, Right ?
Yes I think it would be reasonable to start there.
>> >> > 1.8.3.1
>> >> > _______________________________________________
>> >> > rtems-devel mailing list
>> >> > rtems-devel at rtems.org
>> >> > http://www.rtems.org/mailman/listinfo/rtems-devel
