[PATCH 1/6] libmm-score-api. The high-level libmm API should be used by applications. It helps developers to manage memory by setting generic and target-independent protection and cache attributes for a region that has a start address, length, and desired memory attributes.
Fri Sep 13 15:27:59 UTC 2013
On 2013-09-12 08:59, Hesham AL-Matary wrote:
> + * @brief _Memory_management_Region Flags defs
> +#define RTEMS_MM_REGION_BIT_READ        0
> +#define RTEMS_MM_REGION_BIT_WRITE       1
> +#define RTEMS_MM_REGION_BIT_EXECUTE     2
> +#define RTEMS_MM_REGION_BIT_CACHE       3
> +#define RTEMS_MM_REGION_BIT_DEVICE      4
> +#define RTEMS_MM_REGION_BIT_SHARED      5
> +#define RTEMS_MM_REGION_READ    (1U << RTEMS_MM_REGION_BIT_READ)
> +#define RTEMS_MM_REGION_WRITE   (1U << RTEMS_MM_REGION_BIT_WRITE)
> +#define RTEMS_MM_REGION_EXECUTE (1U << RTEMS_MM_REGION_BIT_EXECUTE)
> +#define RTEMS_MM_REGION_CACHE   (1U << RTEMS_MM_REGION_BIT_CACHE)
> +#define RTEMS_MM_REGION_DEVICE  (1U << RTEMS_MM_REGION_BIT_DEVICE)
> +#define RTEMS_MM_REGION_SHARED  (1U << RTEMS_MM_REGION_BIT_SHARED)
I suggested to use such a schema, but now I am no longer sure if this was a
good idea.
What is the use case and benefit of this libmm?  Currently I see some low-level
changes, but what is the application or kernel level use case?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
