[PATCH 1/5] JFFS2: Import from Linux
Gedare Bloom
gedare at rtems.org
Fri Sep 13 19:29:56 UTC 2013
By separated, I mean in separate subdirectories.. You have already
separated the commits, thanks!
On Fri, Sep 13, 2013 at 3:29 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Would it make sense to keep the portions that are imported from Linux
> and from eCos separated for easier upkeep?
> These patches introduce a mess of code, but it all seems pretty well
> isolated under the jffs library.
> -Gedare
> On Fri, Sep 13, 2013 at 11:09 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Import of Journalling Flash File System, Version 2 from Linux 3.11.
>> This part of the Linux kernel is under a separate license which is
>> similar to the RTEMS license.
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
