[PATCH 1/6] libmm-score-api. The high-level libmm API should be used by applications. It helps developers to manage memory by setting generic and target-independent protection and cache attributes for a region that has a start address, length, and desired memory attributes.
Fri Sep 13 22:05:34 UTC 2013
Gedare Bloom wrote:
>> What is the use case and benefit of this libmm?  Currently I see some
>> low-level changes, but what is the application or kernel level use case?
> The immediate goal would be to support POSIX mprotect on BSPs that can
> (and to ignore it on those that don't). Other benefits may come in the
> future, as we can consider how real-time memory protection might be
> employed by applications.
> Currently we do not need this high-level interface, until mprotect shows up.
Dynamically loaded code could use it. The RTL code has support for
custom allocators to allow code to be loaded and then configured as
read-only/execute. There will be systems that will have requirements on
loaded code being protected in this way.
