[PATCH] Bash script to review BSP File Organization
Vipul Nayyar
nayyar_vipul at yahoo.com
Mon Sep 16 15:40:27 UTC 2013
Hello Joel,
Yeah, it makes sense to merge the scripts. I'll do it & submit the patch.
The script I wrote can evaluate a single bsp directory, all bsps in a cpu family or if you place it or give it the path of libbsp, then it'll evaluate all the RTEMS bsps.
Will have to determine how the previous script works & how it can be merged with mine. Will do that :-)
Regards
Vipul Nayyar
________________________________
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Monday, 16 September 2013 8:17 PM
Subject: Re: [PATCH] Bash script to review BSP File Organization
Does it make sense for this to be merged into the other script?
It already does some BSP specific checks and my original intention
was to have someone run it before submitting a new BSP. It seems
odd to ask them to run two scripts.
Can this be run on a single BSP directory?
I am trying to catch up this week. :)
On 9/14/2013 3:01 PM, Vipul Nayyar wrote:
> merge-helpers/review_bsp_files | 465 +++++++++++++++++++++++++++++++++++++++++
> 1 file changed, 465 insertions(+)
> create mode 100755 merge-helpers/review_bsp_files
> diff --git a/merge-helpers/review_bsp_files b/merge-helpers/review_bsp_files
> new file mode 100755
> index 0000000..422d256
> --- /dev/null
> +++ b/merge-helpers/review_bsp_files
> @@ -0,0 +1,465 @@
> +#! /bin/bash
> +# Bash Script to find discrepancies in BSP file organization
> +# Author : Vipul Nayyar <nayyar_vipul at yahoo.com>
> +filename="0"
> +# Passing --verbose turns verbose to 1 & gives the whole story, otherwise '0' to give only important stuff.
> +verbose="0"
> +faults="0"
> +# Passing --warnings turns warnings to 1 & gives all the critical & non-critical bsp file org. problems.
> +warnings="0"
> +flag="0"
> +calling_path=`pwd`
> +path=""
> +important="1"
> +rtems_internal=""
> +internal_done="0"
> +# Finds all rtems internal functions ( name starting with '_' & type specifier)
> +# that are defined in cpukit & libcpu
> +function find_rtems_internal(){
> + if [[ $internal_done == "1" ]]; then
> + return
> + fi
> + echo "Compiling list of RTEMS Internal functions ..."
> + internal_files=""
> + for k in `find -name *.c`
> + do
> + for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k`
> + do
> + if [[ $j == "_"* ]]; then
> + j=${j%%\(}
> + internal_files="$j $internal_files"
> + fi
> + done
> + done
> + for k in `find ../c/src/lib/libcpu/ -name *.c`
> + do
> + do
> + j=${j%%\(}
> + fi
> + done
> + done
> + for k in $internal_files
> + do
> + if echo $rtems_internal |grep -q $k ; then
> + echo > /dev/null
> + else
> + rtems_internal="$k $rtems_internal"
> + fi
> + done
> + internal_done="1"
> +# Finds all internal functions common in bsp and (cpukit + libcpu)
> +function find_bsp_internal(){
> + bsp_methods=""
> + common_internal_methods=""
> +# Searching for internal functions starting with '_' called(i.e ending with a ';')
> + for i in `find -name *.c`
> + do
> + file_contents=`tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
> + for j in `echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
> + do
> + if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
> + echo > /dev/null
> + else
> + bsp_methods="${j%%\(} $bsp_methods"
> + fi
> + done
> + done
> +# Identifying common fucntions between $rtems_interval & $bsp_methods
> + for i in $rtems_internal
> + do
> + if [[ $i == "__asm__" || $i == "__attribute__" || $i == "__volatile__" || $i == "__"* ]];then
> + continue
> + fi
> + for j in $bsp_methods
> + do
> + if [[ $i == $j ]]; then
> + common_internal_methods="$j $common_internal_methods"
> + fi
> + done
> + done
> + if [[ $common_internal_methods != "" ]]; then
> + echo -e "$bsp : RTEMS Internal functions used : \c"
> + for i in $common_internal_methods
> + do
> + echo -e "${i}() \c"
> + done
> + flag="1"
> + fi
> +# Passing 1 initially to any check function states that the file/method/header
> +# being checked is of critical nature
> +function check_file(){
> + filename="0"
> + if [[ $1 == 1 ]]; then
> + important="1"
> + shift
> + else
> + important="0"
> + fi
> +#Grabbing the path of file being evaluated from Makefile.am
> + if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
> + file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
> + cd `dirname $file_path`
> + filename=$1
> + file_path=`pwd`
> + cd - > /dev/null
> + shift
> +# Checking if file lies in correct directory path
> + for i in $*
> + do
> + if [[ -d $i ]]; then
> + cd $i
> + else
> + continue
> + fi
> + if [[ "$file_path" == `pwd` ]]; then
> + filename="$file_path/$filename"
> + cd - >/dev/null
> + return
> + fi
> + cd - > /dev/null
> + done
> + echo "$bsp : $filename not present in correct path"
> + return
> + else
> + if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]]; then
> + flag="1"
> + echo "$bsp : $1 not compiled"
> + fi
> + fi
> + filename="0"
> + faults="1"
> + return
> +# Checking presence of functions in specific files
> +function check_methods(){
> + important="1"
> + shift
> + else
> + important="0"
> + fi
> + for i in $*
> + do
> +# When correct file for this function does not exist
> + if [[ $filename == "0" ]];then
> + if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
> + if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]];then
> + echo $bsp : ${i%(*}"()" present in file `grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
> + fi
> + fi
> + else
> +# When correct file for this function exists
> + if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
> + if [[ $verbose -eq "1" ]] ;then
> + echo "$bsp : `basename $filename` : ${i%(*}() present in file"
> + fi
> + else
> + fi
> + else
> + echo "$bsp : `basename $filename` : ${i%(*}() function does not exist in $filename "
> + flag="1"
> + fi
> + faults="1"
> + fi
> + fi
> + fi
> + done
> +# Checking presence of headers installed by bsp
> +function check_header(){
> + important="1"
> + shift
> + else
> + important="0"
> + fi
> + for i in $*
> + do
> + if grep -wq "$i" Makefile.am ;then
> + if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
> + continue
> + fi
> + cd `dirname $i`
> + echo "$bsp : `basename $i` installed from directory" ${PWD##*/c/src/lib/}
> + cd - > /dev/null
> + fi
> + return
> + fi
> + done
> + echo "${bsp%%[\ ]*} : `basename $1` not installed "
> + flag="1"
> + fi
> + filename="0"
> + faults="1"
> + return
> +# Reviewing for a BSP Starts
> +function main(){
> + flag="0"
> + check_file 1 start.S ../shared/start/ start/
> + if [[ $filename != "0" ]];then
> + if grep -wq "start" "$filename" || grep -wq "_start" "$filename"; then
> + echo "$bsp : `basename $filename` start() present in $filename"
> + fi
> + else
> + echo "$bsp : `basename $filename` start() does not exist in start.S"
> + fi
> + fi
> + check_file 1 bspstart.c ../../shared/ ../shared/ startup/
> + check_methods "bsp_start"
> + check_file 1 bspreset.c ../../shared/ ../shared/ startup/
> + check_methods 1 "bsp_reset"
> + check_file 1 bootcard.c ../../shared/
> + check_header ../../shared/include/bootcard.h
> + check_file 1 bspclean.c ../../shared/ startup/
> + check_methods "bsp_fatal_extension"
> + check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup ../shared/ ../shared/startup/ startup/
> + check_methods 1 "bsp_work_area_initialize"
> + check_file 1 bsplibc.c ../../shared/
> + check_methods "bsp_libc_init"
> + check_file 1 bsppost.c ../../shared/
> + check_methods "bsp_postdriver_hook"
> + check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/ startup/
> + check_methods "bsp_predriver_hook"
> + check_file gnatinstallhandler.c ../../shared/
> + check_file sbrk.c ../../shared/ ../../shared/ startup/
> + check_methods "sbrk"
> + check_file stackalloc.c ../../shared/src/
> + check_methods "bsp_stack_allocate_init" "bsp_stack_allocate" "bsp_stack_free"
> + check_header ../../shared/include/stackalloc.h
> + # Interrupt Files
> + check_file 1 irq.c irq/
> + check_methods "bsp_interrupt_vector_enable" "bsp_interrupt_vector_disable" "bsp_interrupt_facility_initialize" "bsp_interrupt_dispatch"
> + check_header 1 include/irq.h
> + # PIC Support
> + check_file irq-default-handler.c ../../shared/src/
> + check_file 1 irq-generic.c ../../shared/src/
> + check_header 1 ../../shared/include/irq-generic.h
> + check_file irq-info.c ../../shared/src/
> + check_header ../../shared/include/irq-info.h
> + check_file irq-legacy.c ../../shared/src/
> + check_file irq-server.c ../../shared/src/
> + check_file irq-shell.c ../../shared/src/
> + # Real Time Clock
> + check_file rtc-config.c rtc/
> + check_methods "bsp_rtc_initialize" "bsp_rtc_get_time" "bsp_rtc_set_time" "bsp_rtc_probe"
> + check_file 1 tod.c ../../shared/ tod/
> + # Benchmark Timers
> + check_file benchmark_timer.c benchmark_timer/
> + check_methods "benchmark_timer_initialize" "benchmark_timer_read" "benchmark_timer_disable_subtracting_average_overhead"
> + # Standard Headers
> + check_header 1 include/bsp.h
> + check_header include/bspopts.h
> + check_header 1 ../../shared/include/coverhd.h include/coverhd.h
> + check_header ../../shared/include/utility.h
> + check_header 1 ../../shared/include/tm27.h include/tm27.h
> + # Finding all internal functions being used in a bsp
> + find_bsp_internal
> + if [[ $flag == "1" ]]; then
> + echo -e "\n"
> + fi
> +# Verifying if the directory given or pwd is a valid bsp, shared architecture, or libbsp directory
> +function check_given_dir(){
> + if echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
> + return 0
> + elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
> +# BSP given
> + cd ../../../../../../cpukit
> + find_rtems_internal
> + cd - > /dev/null
> + bsp=${cur_dir##*/}
> + if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp == "no_bsp" ]]; then
> + return 0
> + else
> + main
> + fi
> + elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
> +# Shared architecture given
> + for i in *
> + do
> + if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_bsp" ]]; then
> + echo -n
> + else
> + cd ../../../../../cpukit
> + cd - > /dev/null
> + bsp=$i
> + cd $bsp
> + main
> + cd .. > /dev/null
> + fi
> + fi
> + done
> + elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
> +# libbsp given
> + for i in */*/Makefile.am
> + do
> + i=`dirname $i`
> + if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_cpu/no_bsp" ]]; then
> + echo -n
> + else
> + cd ../../../../cpukit
> + cd - > /dev/null
> + bsp=$i
> + cd $bsp
> + main
> + cd ../../ > /dev/null
> + fi
> + fi
> + done
> + else
> + return 0
> + fi
> +# Evaluating Command Line Arguments
> +function start(){
> + for i in $*
> + do
> + case $i in
> + "--verbose") verbose="1" # The whole story
> + "--warnings") warnings="1" # All warnings
> + verbose="0"
> + "--help") echo "Help to be provided"
> + *) path="$path $i" ;; # If not above options, then assumed to be a path for bsp
> + esac
> + done
> +# No path given, search for bsp from pwd
> + if [[ -z $path ]];then
> + path=$PWD
> + cur_dir=`pwd`
> + check_given_dir
> + if [[ $? -eq 1 ]];then
> + echo "Current directory does not seem a valid RTEMS directory"
> + fi
> + else
> + for i in $path
> + do
> + echo > /dev/null
> + else
> + echo "$i is an invalid directory."
> + continue
> + fi
> + cd $i
> + cur_dir=`pwd`
> + check_given_dir
> + echo "$i does not seem a valid RTEMS directory"
> + fi
> + cd $calling_path
> + done
> + fi
> +# Let the Game begin !!
> +start $*
> +# End of Checks
> +if [[ $faults -eq "0" ]] ; then
> + echo -e "\nNo faults found in BSP organization"
> +fi
> 1.7.11.7
> rtems-devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130916/fdc5abcb/attachment-0001.html>
