[PATCH 1/6] libmm-score-api. The high-level libmm API should be used by applications. It helps developers to manage memory by setting generic and target-independent protection and cache attributes for a region that has a start address, length, and desired memory attributes.
Hesham Moustafa
heshamelmatary at gmail.com
Tue Sep 17 08:43:53 UTC 2013
On Tue, Sep 17, 2013 at 9:51 AM, Sebastian Huber <
> On 2013-09-14 00:05, Chris Johns wrote:
>> Gedare Bloom wrote:
>>>> What is the use case and benefit of this libmm? Currently I see some
>>>> low-level changes, but what is the application or kernel level use case?
>>>> The immediate goal would be to support POSIX mprotect on BSPs that can
>>> (and to ignore it on those that don't). Other benefits may come in the
>>> future, as we can consider how real-time memory protection might be
>>> employed by applications.
>>> Currently we do not need this high-level interface, until mprotect shows
>>> up.
>> Dynamically loaded code could use it. The RTL code has support for custom
>> allocators to allow code to be loaded and then configured as
>> read-only/execute.
>> There will be systems that will have requirements on loaded code being
>> protected in this way.
> We should first formulate the high-level requirements before we start to
> tinker with an arbitrary low-level implementation and BSP initialization
> changes.
> If I use this mprotect() as an example we have the PROT_READ, PROT_WRITE,
> and PROT_EXEC flags. How does this map to
> +#define RTEMS_MM_REGION_BIT_READ 0
> +#define RTEMS_MM_REGION_BIT_WRITE 1
> +#define RTEMS_MM_REGION_BIT_EXECUTE 2
> +#define RTEMS_MM_REGION_BIT_CACHE 3
> +#define RTEMS_MM_REGION_BIT_DEVICE 4
> +#define RTEMS_MM_REGION_BIT_SHARED 5
I agree with you that these macros are not useful at high-level layer,
currently they are used only at low-level/BSP mm.c file, so I will move it
to BSP
layer to help in translating high-level attributes to CPU specific ones.
This is an initial implementation [1] of mprotect not included in these
patches.
Also, we (I and Gedare) agreed to delay this high-level layer patch
until we implement mprotect as a use-case.
[1]
https://github.com/heshamelmatary/rtems-gsoc2013/blob/low-level-libmm/cpukit/posix/src/mprotect.c
> I suggested to use such a scheme since I had only the BSP low-level stuff
> in mind. For a mprotect() support this is not a good approach. Here it
> makes more sense to specify high-level region properties and use an
> architecture provided mapping to low-level MMU bits. I think this was the
> original proposal by Hesham Moustafa.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130917/75738f02/attachment-0001.html>
