[PATCH] Bash script to review BSP File Organization
Vipul Nayyar
nayyar_vipul at yahoo.com
Tue Sep 17 18:12:33 UTC 2013
Hello Gedare, Joel
Thanks for committing it. I can see it here http://git.rtems.org/rtems-testing/commit/?id=3486c86b95341b50876a781f5c178229c52bf26b
I hope it's visible to everyone :-)
Regards
Vipul Nayyar
________________________________
To: Joel Sherrill <joel.sherrill at oarcorp.com>
Cc: Vipul Nayyar <nayyar_vipul at yahoo.com>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Tuesday, 17 September 2013 11:39 PM
Subject: Re: [PATCH] Bash script to review BSP File Organization
Hey Joel and Vipul,
I applied and committed it. Please verify.
-Gedare
On Tue, Sep 17, 2013 at 1:51 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I don't know what is wrong but it doesn't apply. :(
> patching file merge-helpers/check_submission
> patch: **** malformed patch at line 110: '0' to give only important stuff.
> On 9/17/2013 12:24 PM, Vipul Nayyar wrote:
>> merge-helpers/check_submission | 776 +++++++++++++++++++++++++++++++----------
>> 1 file changed, 590 insertions(+), 186 deletions(-)
>> diff --git a/merge-helpers/check_submission b/merge-helpers/check_submission
>> index e838121..90908f1 100755
>> --- a/merge-helpers/check_submission
>> +++ b/merge-helpers/check_submission
>> @@ -1,76 +1,247 @@
>> -# Script to test for various things we want in a BSP when it is
>> -# submitted.
>> -# Test for:
>> -# - XXX
>> +#! /bin/bash
>> -usage()
>> -cat <<EOF
>> -check_submission [options] directory
>> - -b - check assuming directory is a BSP
>> - -t - check assuming directory is a test
>> - -v - verbose
>> -EOF
>> +# Bash Script to find discrepancies in BSP file organization.
>> +# Author : Vipul Nayyar <nayyar_vipul at yahoo.com>
>> -fatal()
>> - usage
>> - exit 1
>> +filename="0"
>> +# Passing --verbose turns verbose to 1 & gives the whole story, otherwise '0' to give only important stuff.
>> +verbose="0"
>> +faults="0"
>> +# Passing --warnings turns warnings to 1 & gives all the critical & non-critical bsp file org. problems.
>> +warnings="0"
>> +flag="0"
>> +calling_path=`pwd`
>> +path=""
>> +important="1"
>> +rtems_internal=""
>> +internal_done="0"
>> +do_test="0"
>> +format="1"
>> +# Finds all rtems internal functions ( name starting with '_' & type specifier)
>> +# that are defined in cpukit & libcpu
>> +function find_rtems_internal(){
>> + if [[ $internal_done == "1" ]]; then
>> + return
>> + fi
>> + echo "Compiling list of RTEMS Internal functions ..."
>> + internal_files=""
>> + for k in `find -name *.c`
>> + do
>> + for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\ ]*\(" $k`
>> + do
>> + if [[ $j == "_"* ]]; then
>> + j=${j%%\(}
>> + internal_files="$j $internal_files"
>> + fi
>> + done
>> + done
>> + for k in `find ../c/src/lib/libcpu/ -name *.c`
>> + do
>> + do
>> + j=${j%%\(}
>> + fi
>> + done
>> + done
>> + for k in $internal_files
>> + do
>> + if echo $rtems_internal |grep -q $k ; then
>> + echo > /dev/null
>> + else
>> + rtems_internal="$k $rtems_internal"
>> + fi
>> + done
>> + internal_done="1"
>> -toggle()
>> - case $1 in
>> - no) echo "yes" ;;
>> - yes) echo "no" ;;
>> - *) fatal "Unknown value to toggle ($1)" ;;
>> - esac
>> +# Finds all internal functions common in bsp and (cpukit + libcpu)
>> +function find_bsp_internal(){
>> + bsp_methods=""
>> + common_internal_methods=""
>> +# Searching for internal functions starting with '_' called(i.e ending with a ';')
>> + for i in `find -name *.c`
>> + do
>> + file_contents=`tr -d '\n' < $i | grep -oE "[ |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
>> + for j in `echo "$file_contents" | grep -oE "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
>> + do
>> + if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
>> + echo > /dev/null
>> + else
>> + bsp_methods="${j%%\(} $bsp_methods"
>> + fi
>> + done
>> + done
>> +# Identifying common fucntions between $rtems_interval & $bsp_methods
>> + for i in $rtems_internal
>> + do
>> + if [[ $i == "__asm__" || $i == "__attribute__" || $i == "__volatile__" || $i == "__"* ]];then
>> + continue
>> + fi
>> + for j in $bsp_methods
>> + do
>> + if [[ $i == $j ]]; then
>> + common_internal_methods="$j $common_internal_methods"
>> + fi
>> + done
>> + done
>> + if [[ $common_internal_methods != "" ]]; then
>> + echo -e "$bsp : RTEMS Internal functions used : \c"
>> + for i in $common_internal_methods
>> + do
>> + echo -e "${i}() \c"
>> + done
>> + flag="1"
>> + fi
>> -verbose="no"
>> -do_bsp="no"
>> -do_test="no"
>> -while getopts vbt OPT
>> -do
>> - case "$OPT" in
>> - b) do_bsp="yes" ; do_test="no" ;;
>> - t) do_bsp="no" ; do_test="yes" ;;
>> - v) verbose=`toggle ${verbose}` ;;
>> - *) fatal ;;
>> - esac
>> -done
>> -########################### Grab Directory ###########################
>> +# Passing 1 initially to any check function states that the file/method/header
>> +# being checked is of critical nature
>> +function check_file(){
>> + filename="0"
>> + if [[ $1 == 1 ]]; then
>> + important="1"
>> + shift
>> + else
>> + important="0"
>> + fi
>> -shiftcount=`expr $OPTIND - 1`
>> -shift $shiftcount
>> +#Grabbing the path of file being evaluated from Makefile.am
>> + if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
>> + file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
>> + cd `dirname $file_path`
>> + filename=$1
>> + file_path=`pwd`
>> + cd - > /dev/null
>> + shift
>> +# Checking if file lies in correct directory path
>> + for i in $*
>> + do
>> + if [[ -d $i ]]; then
>> + cd $i
>> + else
>> + continue
>> + fi
>> + if [[ "$file_path" == `pwd` ]]; then
>> + filename="$file_path/$filename"
>> + cd - >/dev/null
>> + return
>> + fi
>> + cd - > /dev/null
>> + done
>> + echo "$bsp : $filename not present in correct path"
>> + return
>> + else
>> + if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]]; then
>> + flag="1"
>> + echo "$bsp : $1 not compiled"
>> + fi
>> + fi
>> -basedir=${1}
>> + filename="0"
>> + faults="1"
>> + return
>> -if [ "${basedir}X" = "X" ] ; then
>> - basedir=.
>> -fi
>> +# Checking presence of functions in specific files
>> +function check_methods(){
>> + important="1"
>> + shift
>> + else
>> + important="0"
>> + fi
>> -if [ ${do_bsp} = "no" -a ${do_test} = "no" ] ; then
>> - fatal must select test or bsp check mode
>> -fi
>> + for i in $*
>> + do
>> -if [ ! -d ${basedir} ] ; then
>> - fatal ${basedir} is not a directory
>> -fi
>> +# When correct file for this function does not exist
>> + if [[ $filename == "0" ]];then
>> + if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
>> + if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1" ]];then
>> + echo $bsp : ${i%(*}"()" present in file `grep -rlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
>> + fi
>> + fi
>> + else
>> +# When correct file for this function exists
>> + if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
>> + if [[ $verbose -eq "1" ]] ;then
>> + echo "$bsp : `basename $filename` : ${i%(*}() present in file"
>> + fi
>> + else
>> + fi
>> + else
>> + echo "$bsp : `basename $filename` : ${i%(*}() function does not exist in $filename "
>> + flag="1"
>> + fi
>> + faults="1"
>> + fi
>> + fi
>> + fi
>> + done
>> +# Checking presence of headers installed by bsp
>> +function check_header(){
>> + important="1"
>> + shift
>> + else
>> + important="0"
>> + fi
>> -cd ${basedir}
>> -if [ $? -ne 0 ] ; then
>> - echo Unable to cd to ${basedir}
>> - exit 1
>> -fi
>> + for i in $*
>> + do
>> + if grep -wq "$i" Makefile.am ;then
>> + if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
>> + continue
>> + fi
>> + cd `dirname $i`
>> + echo "$bsp : `basename $i` installed from directory" ${PWD##*/c/src/lib/}
>> + cd - > /dev/null
>> + fi
>> + return
>> + fi
>> + done
>> + echo "${bsp%%[\ ]*} : `basename $1` not installed "
>> + flag="1"
>> + fi
>> + filename="0"
>> + faults="1"
>> + return
>> test_its_there()
>> @@ -79,7 +250,7 @@ test_its_there()
>> fi
>> grep ${2} ${1} >/dev/null
>> - echo "${2} is NOT in ${basedir}/${1}"
>> + echo "$bsp : ${2} is NOT in ${1##./}"
>> fi
>> @@ -91,7 +262,7 @@ test_its_there_all_case()
>> fi
>> grep -i ${2} ${1} >/dev/null
>> - echo "${2} is NOT in ${basedir}/${1} - case independent check"
>> + echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
>> fi
>> @@ -105,7 +276,7 @@ test_its_NOT_there_all_case()
>> shift
>> grep -i "${*}" ${FILE} >/dev/null
>> if [ $? -eq 0 ] ; then
>> - echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE} - case independent check"
>> + echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case independent check"
>> fi
>> @@ -118,14 +289,14 @@ test_its_NOT_there()
>> shift
>> grep "${*}" ${FILE} >/dev/null
>> - echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE}"
>> + echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
>> fi
>> find_source()
>> findArgs=
>> - while getopts "cCm" OPT
>> + while getopts "cCdm" OPT
>> do
>> case "$OPT" in
>> c) findArgs="${findArgs} -o -name configure.ac" ;;
>> @@ -144,145 +315,378 @@ find_source()
>> find . -name "*.[chS]" ${findArgs}
>> -# Verify no lines longer than 80 columns
>> -echo "=== Checking for lines greater than 79 columns"
>> -find_source -m -c -C | while read f
>> -do
>> - grep ".\{80,\}" ${f} >/dev/null
>> - if [ $? -eq 0 ] ; then
>> - echo "*** ${basedir}/${f} has the following lines that are too long"
>> - grep -n '.\{80,\}' ${f}
>> - fi
>> -done
>> -# really need to make the copyright strings consistent in BSPs
>> -echo "=== Checking for copyright notices"
>> -find_source | while read f
>> -do
>> - test_its_there_all_case ${f} COPYRIGHT
>> -done
>> -# We want CVS Id strings everywhere possible
>> -echo "=== Checking for CVS Id strings"
>> -find_source -d | while read f
>> -do
>> - test_its_NOT_there ${f} "\$Id"
>> -done
>> -# We do not want the reformatted license notice
>> -echo "=== Checking for reformatted RTEMS license notices"
>> -do
>> - test_its_NOT_there ${f} "this file may be found in the file"
>> -done
>> -# We do not want spaces at the end of lines
>> -echo "=== Checking for spaces at the end of lines"
>> -do
>> - egrep " +$" $f >/dev/null
>> - test $? -eq 0 && echo "$f has spaces at the end of one or more lines."
>> -done
>> -# We do not want tabs in source files
>> -echo "=== Checking for tabs in source files"
>> -do
>> - grep -P '\t' $f >/dev/null
>> - if [ $? -eq 0 ]; then
>> - echo "*** ${basedir}/${f} has the following lines with tabs"
>> - grep -P '\t' $f
>> - fi
>> -done
>> -# We do not want GPL code
>> -echo "=== Checking for hints of GPL code"
>> -do
>> - test_its_NOT_there ${f} "Free Software Foundation"
>> - test_its_NOT_there ${f} "program is free software"
>> - test_its_NOT_there ${f} "General Public License"
>> -done
>> -# We do not want hints that there are things left to do
>> -echo "=== Checking for TODO hints"
>> -do
>> - test_its_NOT_there ${f} XXX
>> - test_its_NOT_there ${f} TODO
>> - test_its_NOT_there ${f} TBD
>> -done
>> +function check_format(){
>> -# BSP specific checks
>> -if [ ${do_bsp} = "yes" ] ; then
>> - # We do not want stdio in a BSP
>> - echo "=== Checking for stdio"
>> + # Verify no lines longer than 80 columns
>> + echo "=== Checking for lines greater than 80 columns"
>> + find_source -m -c -C | while read f
>> + do
>> + grep ".\{81,\}" ${f} >/dev/null
>> + if [ $? -eq 0 ] ; then
>> + echo -e "\n$bsp : ${f#./} has more than 80 character lines"
>> + for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
>> + do
>> + echo -e "$i \c"
>> + done
>> + fi
>> + done
>> + # really need to make the copyright strings consistent in BSPs
>> + echo -e "\n=== Checking for copyright notices"
>> + find_source | while read f
>> + do
>> + test_its_there_all_case ${f} COPYRIGHT
>> + done
>> + # We want CVS Id strings everywhere possible
>> + echo "=== Checking for CVS Id strings"
>> + find_source -d | while read f
>> + do
>> + test_its_NOT_there ${f} "\$Id"
>> + done
>> + # We do not want the reformatted license notice
>> + echo "=== Checking for reformatted RTEMS license notices"
>> + do
>> + test_its_NOT_there ${f} "this file may be found in the file"
>> + done
>> + # We do not want spaces at the end of lines
>> + echo "=== Checking for spaces at the end of lines"
>> + do
>> + egrep " +$" $f >/dev/null
>> + test $? -eq 0 && echo -e "${f##./} \c"
>> + done
>> + # We do not want tabs in source files
>> + echo -e "\n=== Checking for tabs in source files"
>> + do
>> + grep -P '\t' $f >/dev/null
>> + done
>> + # We do not want GPL code
>> + echo -e "\n=== Checking for hints of GPL code"
>> do
>> - test_its_NOT_there ${f} printf
>> - test_its_NOT_there ${f} "puts("
>> + test_its_NOT_there ${f} "Free Software Foundation"
>> + test_its_NOT_there ${f} "program is free software"
>> + test_its_NOT_there ${f} "General Public License"
>> done
>> - # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>> - # RTEMS_BSP_BOOTCARD_OPTIONS
>> - if [ -r configure.ac ] ; then
>> - echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
>> - test_its_not_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>> - echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
>> - test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>> + # We do not want hints that there are things left to do
>> + echo "=== Checking for TODO hints"
>> + do
>> + test_its_NOT_there ${f} XXX
>> + test_its_NOT_there ${f} TODO
>> + test_its_NOT_there ${f} TBD
>> + done
>> +# Reviewing for a BSP Starts
>> +function main(){
>> + if [[ $format -eq "1" ]]; then
>> + check_format
>> fi
>> - # If not using -O2, then we really want to know
>> - # BSPs should normally use -O2
>> - echo "=== Checking for not using -O2"
>> - grep -H "\-O[013456789]" make/custom/*.cfg
>> + # We do not want stdio in a BSP
>> + echo "=== Checking for stdio"
>> + do
>> + test_its_NOT_there ${f} printf
>> + test_its_NOT_there ${f} "puts("
>> + done
>> + # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>> + # RTEMS_BSP_BOOTCARD_OPTIONS
>> + if [ -r configure.ac ] ; then
>> + echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP configure.ac"
>> + test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>> + echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP configure.ac"
>> + test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>> + fi
>> + # If not using -O2, then we really want to know
>> + # BSPs should normally use -O2
>> + echo "=== Checking for not using -O2"
>> + grep -H "\-O[013456789]" make/custom/*.cfg
>> - # BSPs should not turn on extra warnings
>> - echo "=== Checking for turning on extra GCC warning checks"
>> - grep -H "\-W" make/custom/*.cfg
>> + # BSPs should not turn on extra warnings
>> + echo "=== Checking for turning on extra GCC warning checks"
>> + grep -H "\-W" make/custom/*.cfg
>> - # Hopefully have some output from the tmtests
>> - echo "=== Checking for timing information"
>> - c=`ls -1 times* 2>/dev/null | wc -l`
>> - if [ ${c} -eq 0 ] ; then
>> - echo "Please run the timing tests and include the results."
>> + # Hopefully have some output from the tmtests
>> + echo "=== Checking for timing information"
>> + c=`ls -1 times* 2>/dev/null | wc -l`
>> + if [ ${c} -eq 0 ] ; then
>> + echo "Please run the timing tests and include the results."
>> fi
>> -fi ## END OF IF BSP
>> + echo -e "\n=== Starting BSP Unified way checks"
>> + flag="0"
>> + check_file 1 start.S ../shared/start/ start/
>> + if [[ $filename != "0" ]];then
>> + if grep -wq "start" "$filename" || grep -wq "_start" "$filename"; then
>> + echo "$bsp : `basename $filename` start() present in $filename"
>> + fi
>> + else
>> + echo "$bsp : `basename $filename` start() does not exist in start.S"
>> + fi
>> + fi
>> + check_file 1 bspstart.c ../../shared/ ../shared/ startup/
>> + check_methods "bsp_start"
>> + check_file 1 bspreset.c ../../shared/ ../shared/ startup/
>> + check_methods 1 "bsp_reset"
>> + check_file 1 bootcard.c ../../shared/
>> + check_header ../../shared/include/bootcard.h
>> + check_file 1 bspclean.c ../../shared/ startup/
>> + check_methods "bsp_fatal_extension"
>> + check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup ../shared/ ../shared/startup/ startup/
>> + check_methods 1 "bsp_work_area_initialize"
>> + check_file 1 bsplibc.c ../../shared/
>> + check_methods "bsp_libc_init"
>> + check_file 1 bsppost.c ../../shared/
>> + check_methods "bsp_postdriver_hook"
>> + check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/ startup/
>> + check_methods "bsp_predriver_hook"
>> + check_file gnatinstallhandler.c ../../shared/
>> + check_file sbrk.c ../../shared/ ../../shared/ startup/
>> + check_methods "sbrk"
>> + check_file stackalloc.c ../../shared/src/
>> + check_methods "bsp_stack_allocate_init" "bsp_stack_allocate" "bsp_stack_free"
>> + check_header ../../shared/include/stackalloc.h
>> + # Interrupt Files
>> + check_file 1 irq.c irq/
>> + check_methods "bsp_interrupt_vector_enable" "bsp_interrupt_vector_disable" "bsp_interrupt_facility_initialize" "bsp_interrupt_dispatch"
>> + check_header 1 include/irq.h
>> + # PIC Support
>> + check_file irq-default-handler.c ../../shared/src/
>> + check_file 1 irq-generic.c ../../shared/src/
>> + check_header 1 ../../shared/include/irq-generic.h
>> + check_file irq-info.c ../../shared/src/
>> + check_header ../../shared/include/irq-info.h
>> + check_file irq-legacy.c ../../shared/src/
>> + check_file irq-server.c ../../shared/src/
>> + check_file irq-shell.c ../../shared/src/
>> + # Real Time Clock
>> + check_file rtc-config.c rtc/
>> + check_methods "bsp_rtc_initialize" "bsp_rtc_get_time" "bsp_rtc_set_time" "bsp_rtc_probe"
>> + check_file 1 tod.c ../../shared/ tod/
>> + # Benchmark Timers
>> + check_file benchmark_timer.c benchmark_timer/
>> + check_methods "benchmark_timer_initialize" "benchmark_timer_read" "benchmark_timer_disable_subtracting_average_overhead"
>> + # Standard Headers
>> + check_header 1 include/bsp.h
>> + check_header include/bspopts.h
>> + check_header 1 ../../shared/include/coverhd.h include/coverhd.h
>> + check_header ../../shared/include/utility.h
>> + check_header 1 ../../shared/include/tm27.h include/tm27.h
>> + cd ../../../../../../cpukit
>> + find_rtems_internal
>> + cd - > /dev/null
>> + # Finding all internal functions being used in a bsp
>> + find_bsp_internal
>> + if [[ $flag == "1" ]]; then
>> + echo -e "\n"
>> + fi
>> # Test specific checks
>> -if [ ${do_test} = "yes" ] ; then
>> - # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>> - Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>> - if [ "X${Makefiles}" = "X" ] ; then
>> - fatal "Unable to locate any test Makefile.am files."
>> - fi
>> - echo "=== Checking for missing test support files"
>> - for m in ${Makefiles}
>> - do
>> - directory=`dirname ${m}`
>> - if [ ${directory} = "." ] ; then
>> - directory=`pwd`
>> + if [ ${do_test} == "1" ] ; then
>> + echo -e "\n=== Starting Test specific checks"
>> + # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>> + Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>> + if [ "X${Makefiles}" = "X" ] ; then
>> + echo -e "Unable to locate any test Makefile.am files.\n"
>> + return
>> fi
>> - testName=`basename ${directory}`
>> - # Does this test have a .doc file?
>> - if [ ! -r ${directory}/${testName}.doc ] ; then
>> - echo ${testName}.doc is not present
>> + echo "=== Checking for missing test support files"
>> + for m in ${Makefiles}
>> + do
>> + directory=`dirname ${m}`
>> + if [ ${directory} = "." ] ; then
>> + directory=`pwd`
>> + fi
>> + testName=`basename ${directory}`
>> + # Does this test have a .doc file?
>> + if [ ! -r ${directory}/${testName}.doc ] ; then
>> + echo ${testName}.doc is not present
>> + fi
>> + case ${directory} in
>> + */*tmtests*) ;;
>> + # Does this test have a .scn file?
>> + if [ ! -r ${directory}/${testName}.scn ] ; then
>> + echo ${testName}.scn is not present
>> + fi
>> + esac
>> + done
>> + fi
>> +# Verifying if the directory given or pwd is a valid bsp, shared architecture, or libbsp directory
>> +function check_given_dir(){
>> + if echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
>> + return 0
>> + elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ; then
>> +# BSP given
>> + bsp=${cur_dir##*/}
>> + if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp == "no_bsp" ]]; then
>> + return 0
>> + else
>> + main
>> fi
>> - case ${directory} in
>> - */*tmtests*) ;;
>> - # Does this test have a .scn file?
>> - if [ ! -r ${directory}/${testName}.scn ] ; then
>> - echo ${testName}.scn is not present
>> + elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
>> +# Shared architecture given
>> + for i in *
>> + do
>> + if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_bsp" ]]; then
>> + echo -n
>> + else
>> + bsp=$i
>> + cd $bsp
>> + main
>> + cd .. > /dev/null
>> + fi
>> + fi
>> + done
>> + elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
>> +# libbsp given
>> + for i in */*/Makefile.am
>> + do
>> + i=`dirname $i`
>> + if [[ $i == "shared" || $i == "autom4te.cache" || $i == "no_cpu/no_bsp" ]]; then
>> + echo -n
>> + else
>> + bsp=$i
>> + cd $bsp
>> + main
>> + cd ../../ > /dev/null
>> fi
>> + fi
>> + done
>> + else
>> + return 0
>> + fi
>> +# Evaluating Command Line Arguments
>> +function start(){
>> + for i in $*
>> + do
>> + case $i in
>> + "--verbose") verbose="1" # The whole story
>> + "--warnings") warnings="1" # All warnings
>> + verbose="0"
>> + "--no_format") format="0" # Disabling format checks
>> + verbose="0"
>> + "--tests") do_test="1" # Enabling check of tests
>> + verbose="0"
>> + "--help") echo "Help to be provided"
>> + "--"* | "-"* ) echo "Invalid options provided"
>> + *) path="$path $i" ;; # If not above options, then assumed to be a path for bsp
>> esac
>> done
>> -fi
>> -exit 0
>> +# No path given, search for bsp from pwd
>> + if [[ -z $path ]];then
>> + path=$PWD
>> + cur_dir=`pwd`
>> + check_given_dir
>> + if [[ $? -eq 1 ]];then
>> + echo "Current directory does not seem a valid RTEMS directory"
>> + fi
>> + else
>> + for i in $path
>> + do
>> + echo > /dev/null
>> + else
>> + echo "$i is an invalid directory."
>> + continue
>> + fi
>> + cd $i
>> + cur_dir=`pwd`
>> + check_given_dir
>> + echo "$i does not seem a valid RTEMS directory"
>> + fi
>> + cd $calling_path
>> + done
>> + fi
>> +# Let the Game begin !!
>> +start $*
>> +# End of Checks
>> +if [[ $faults -eq "0" ]] ; then
>> + echo -e "\nNo faults found in BSP organization"
>> +fi
>> 1.7.11.7
>> rtems-devel mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130918/e756046c/attachment-0001.html>
