[PATCH] Bash script to review BSP File Organization
Vipul Nayyar nayyar_vipul at yahoo.com
Tue Sep 17 18:31:15 UTC 2013
Hello Joel,
As I was in the process of it, so I cloned the rtems-testing repo again from the rtems server after the patch was submitted. And I successfully executed the script on all the bsps by giving the path of libbsp directory and also on a single bsp too . The results obtained match with what I was getting earlier. :-)
Regards
Vipul Nayyar
________________________________
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: Gedare Bloom <gedare at rtems.org>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Tuesday, 17 September 2013 11:49 PM
Subject: Re: [PATCH] Bash script to review BSP File Organization
Vipul
Make sure it gives the same results after check in
that it did from your local version.
Paranoid sounding but better to be safe than sorry.
On 9/17/2013 1:12 PM, Vipul Nayyar wrote:
> Hello Gedare, Joel
> Thanks for committing it. I can see it
> here http://git.rtems.org/rtems-testing/commit/?id=3486c86b95341b50876a781f5c178229c52bf26b
> I hope it's visible to everyone :-)
> Regards
> Vipul Nayyar
> *From:* Gedare Bloom <gedare at rtems.org>
> *To:* Joel Sherrill <joel.sherrill at oarcorp.com>
> *Cc:* Vipul Nayyar <nayyar_vipul at yahoo.com>; "rtems-devel at rtems.org"
> *Sent:* Tuesday, 17 September 2013 11:39 PM
> *Subject:* Re: [PATCH] Bash script to review BSP File Organization
> Hey Joel and Vipul,
> I applied and committed it. Please verify.
> -Gedare
> On Tue, Sep 17, 2013 at 1:51 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>> I don't know what is wrong but it doesn't apply. :(
>> patching file merge-helpers/check_submission
>> patch: **** malformed patch at line 110: '0' to give only important stuff.
>> On 9/17/2013 12:24 PM, Vipul Nayyar wrote:
>>>  merge-helpers/check_submission | 776
>>>  1 file changed, 590 insertions(+), 186 deletions(-)
>>> diff --git a/merge-helpers/check_submission
> b/merge-helpers/check_submission
>>> index e838121..90908f1 100755
>>> --- a/merge-helpers/check_submission
>>> +++ b/merge-helpers/check_submission
>>> @@ -1,76 +1,247 @@
>>> -#  Script to test for various things we want in a BSP when it is
>>> -#  submitted.
>>> -#  Test for:
>>> -#    - XXX
>>> +#! /bin/bash
>>> -usage()
>>> -cat <<EOF
>>> -check_submission [options] directory
>>> -  -b - check assuming directory is a BSP
>>> -  -t - check assuming directory is a test
>>> -  -v - verbose
>>> -EOF
>>> +# Bash Script to find discrepancies in BSP file organization.
>>> +# Author : Vipul Nayyar <nayyar_vipul at yahoo.com
> <mailto:nayyar_vipul at yahoo.com>>
>>> -fatal()
>>> -  usage
>>> -  exit 1
>>> +filename="0"
>>> +# Passing --verbose turns verbose to 1 & gives the whole story,
> otherwise '0' to give only important stuff.
>>> +verbose="0"
>>> +faults="0"
>>> +# Passing --warnings turns warnings to 1 & gives all the critical &
> non-critical bsp file org. problems.
>>> +warnings="0"
>>> +flag="0"
>>> +calling_path=`pwd`
>>> +path=""
>>> +important="1"
>>> +rtems_internal=""
>>> +internal_done="0"
>>> +do_test="0"
>>> +format="1"
>>> +# Finds all rtems internal functions ( name starting with '_' & type
> specifier)
>>> +# that are defined in cpukit & libcpu
>>> +function find_rtems_internal(){
>>> +  if [[ $internal_done == "1" ]]; then
>>> +    return
>>> +  fi
>>> +  echo "Compiling list of RTEMS Internal functions ..."
>>> +  internal_files=""
>>> +  for k in `find -name *.c`
>>> +  do
>>> +    for j in `grep -oE "[a-z|A-Z|0-9|_]+[\ |^][_]+[a-z|A-Z|0-9|_]*[\
> ]*\(" $k`
>>> +    do
>>> +      if [[ $j == "_"* ]]; then
>>> +        j=${j%%\(}
>>> +        internal_files="$j $internal_files"
>>> +      fi
>>> +    done
>>> +  done
>>> +  for k in `find ../c/src/lib/libcpu/ -name *.c`
>>> +  do
> ]*\(" $k`
>>> +    do
>>> +        j=${j%%\(}
>>> +      fi
>>> +    done
>>> +  done
>>> +  for k in $internal_files
>>> +  do
>>> +    if echo $rtems_internal |grep -q $k ; then
>>> +      echo > /dev/null
>>> +    else
>>> +      rtems_internal="$k $rtems_internal"
>>> +    fi
>>> +  done
>>> +  internal_done="1"
>>> -toggle()
>>> -  case $1 in
>>> -    no)  echo "yes" ;;
>>> -    yes) echo "no" ;;
>>> -    *)  fatal "Unknown value to toggle ($1)" ;;
>>> -  esac
>>> +# Finds all internal functions common in bsp and (cpukit + libcpu)
>>> +function find_bsp_internal(){
>>> +  bsp_methods=""
>>> +  common_internal_methods=""
>>> +# Searching for internal functions starting with '_' called(i.e
> ending with a ';')
>>> +  for i in `find -name *.c`
>>> +  do
>>> +    file_contents=`tr -d '\n' < $i | grep -oE "[
> |^][_]+[a-z|A-Z|0-9|_]*[ ]*[\n]*\([^;]*\)[ ]*;" | tr -d '\n' `
>>> +    for j in `echo "$file_contents" | grep -oE
> "[_]+[a-z|A-Z|0-9|_]*[ ]*\("`
>>> +    do
>>> +      if `echo "$bsp_methods" |grep -q "${j%%\(}"` ; then
>>> +        echo > /dev/null
>>> +      else
>>> +        bsp_methods="${j%%\(} $bsp_methods"
>>> +      fi
>>> +    done
>>> +  done
>>> +# Identifying common fucntions between $rtems_interval & $bsp_methods
>>> +  for i in $rtems_internal
>>> +  do
>>> +    if [[ $i == "__asm__" || $i == "__attribute__" || $i ==
> "__volatile__" || $i == "__"* ]];then
>>> +      continue
>>> +    fi
>>> +    for j in $bsp_methods
>>> +    do
>>> +      if [[ $i == $j ]]; then
>>> +        common_internal_methods="$j $common_internal_methods"
>>> +      fi
>>> +    done
>>> +  done
>>> +  if [[ $common_internal_methods != "" ]]; then
>>> +    echo -e "$bsp : RTEMS Internal functions used : \c"
>>> +    for i in $common_internal_methods
>>> +    do
>>> +      echo -e "${i}() \c"
>>> +    done
>>> +    flag="1"
>>> +  fi
>>> -verbose="no"
>>> -do_bsp="no"
>>> -do_test="no"
>>> -while getopts vbt OPT
>>> -do
>>> -    case "$OPT" in
>>> -        b) do_bsp="yes" ; do_test="no"  ;;
>>> -        t) do_bsp="no"  ; do_test="yes" ;;
>>> -        v) verbose=`toggle ${verbose}` ;;
>>> -        *) fatal ;;
>>> -    esac
>>> -done
>>> -########################### Grab Directory ###########################
>>> +# Passing 1 initially to any check function states that the
> file/method/header
>>> +# being checked is of critical nature
>>> +function check_file(){
>>> +  filename="0"
>>> +  if [[ $1 == 1 ]]; then
>>> +    important="1"
>>> +    shift
>>> +  else
>>> +    important="0"
>>> +  fi
>>> -shiftcount=`expr $OPTIND - 1`
>>> -shift $shiftcount
>>> +#Grabbing the path of file being evaluated from Makefile.am
>>> +  if grep -wqE "[ ]*[^\ ]*/($1)" Makefile.am ; then
>>> +    file_path=`grep -woE "[ ]*[^\ ]*/($1)" Makefile.am | head --lines=1`
>>> +    cd `dirname $file_path`
>>> +    filename=$1
>>> +    file_path=`pwd`
>>> +    cd - > /dev/null
>>> +    shift
>>> +# Checking if file lies in correct directory path
>>> +    for i in $*
>>> +    do
>>> +      if [[ -d $i ]]; then
>>> +        cd $i
>>> +      else
>>> +        continue
>>> +      fi
>>> +      if [[ "$file_path" == `pwd` ]]; then
>>> +        filename="$file_path/$filename"
>>> +        cd - >/dev/null
>>> +        return
>>> +      fi
>>> +      cd - > /dev/null
>>> +    done
>>> +    echo "$bsp : $filename not present in correct path"
>>> +    return
>>> +  else
>>> +    if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq
> "1" ]]; then
>>> +      flag="1"
>>> +      echo "$bsp : $1 not compiled"
>>> +    fi
>>> +  fi
>>> -basedir=${1}
>>> +  filename="0"
>>> +  faults="1"
>>> +  return
>>> -if [ "${basedir}X" = "X" ] ; then
>>> -  basedir=.
>>> -fi
>>> +# Checking presence of functions in specific files
>>> +function check_methods(){
>>> +    important="1"
>>> +    shift
>>> +  else
>>> +    important="0"
>>> +  fi
>>> -if [ ${do_bsp} = "no" -a ${do_test} = "no" ] ; then
>>> -  fatal must select test or bsp check mode
>>> -fi
>>> +  for i in $*
>>> +  do
>>> -if [ ! -d ${basedir} ] ; then
>>> -  fatal ${basedir} is not a directory
>>> -fi
>>> +# When correct file for this function does not exist
>>> +    if [[ $filename == "0" ]];then
>>> +      if grep -rqlE "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" * ;then
> -eq "1" ]];then
>>> +          echo $bsp : ${i%(*}"()" present in file `grep -rlE
> "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" *`
>>> +        fi
>>> +      fi
>>> +    else
>>> +# When correct file for this function exists
>>> +      if grep -Eq "[a-z|A-Z|0-9|_]+[ ]*$i[ ]*\(" $filename ; then
>>> +        if [[ $verbose -eq "1" ]] ;then
>>> +          echo "$bsp : `basename $filename` : ${i%(*}() present in file"
>>> +        fi
>>> +      else
> -eq "1" ]];then
>>> +          fi
>>> +        else
> -eq "1" ]]; then
>>> +            echo "$bsp : `basename $filename` : ${i%(*}() function
> does not exist in $filename "
>>> +            flag="1"
>>> +          fi
>>> +            faults="1"
>>> +        fi
>>> +      fi
>>> +    fi
>>> +  done
>>> +# Checking presence of headers installed by bsp
>>> +function check_header(){
>>> +    important="1"
>>> +    shift
>>> +  else
>>> +    important="0"
>>> +  fi
>>> -cd ${basedir}
>>> -if [ $? -ne 0 ] ; then
>>> -  echo Unable to cd to ${basedir}
>>> -  exit 1
>>> -fi
>>> +  for i in $*
>>> +  do
>>> +    if  grep -wq "$i" Makefile.am ;then
>>> +      if [[ ! -f "$i" && ! -f "${i}.in" ]] ;then
>>> +        continue
>>> +      fi
>>> +        cd `dirname $i`
>>> +        echo "$bsp : `basename $i` installed from directory"
> ${PWD##*/c/src/lib/}
>>> +        cd - > /dev/null
>>> +      fi
>>> +      return
>>> +    fi
>>> +  done
>>> +  if [[ $warnings -eq "1" || $important -eq "1" || $verbose -eq "1"
> ]]; then
>>> +    echo "${bsp%%[\ ]*} : `basename $1` not installed "
>>> +    flag="1"
>>> +  fi
>>> +  filename="0"
>>> +  faults="1"
>>> +  return
>>>  test_its_there()
>>> @@ -79,7 +250,7 @@ test_its_there()
>>>    fi
>>>    grep ${2} ${1} >/dev/null
>>> -    echo "${2} is NOT in ${basedir}/${1}"
>>> +    echo "$bsp : ${2} is NOT in ${1##./}"
>>>    fi
>>> @@ -91,7 +262,7 @@ test_its_there_all_case()
>>>    fi
>>>    grep -i ${2} ${1} >/dev/null
>>> -    echo "${2} is NOT in ${basedir}/${1} - case independent check"
>>> +    echo "$bsp : ${2} is NOT in ${1##./} - case independent check"
>>>    fi
>>> @@ -105,7 +276,7 @@ test_its_NOT_there_all_case()
>>>    shift
>>>    grep -i "${*}" ${FILE} >/dev/null
>>>    if [ $? -eq 0 ] ; then
>>> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE} - case
> independent check"
>>> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./} - case
> independent check"
>>>    fi
>>> @@ -118,14 +289,14 @@ test_its_NOT_there()
>>>    shift
>>>    grep "${*}" ${FILE} >/dev/null
>>> -    echo "(${*}) SHOULD NOT BE IN ${basedir}/${FILE}"
>>> +    echo "$bsp : (${*}) SHOULD NOT BE IN ${FILE##./}"
>>>    fi
>>>  find_source()
>>>    findArgs=
>>> -  while getopts "cCm" OPT
>>> +  while getopts "cCdm" OPT
>>>    do
>>>    case "$OPT" in
>>>      c) findArgs="${findArgs} -o -name configure.ac" ;;
>>> @@ -144,145 +315,378 @@ find_source()
>>>    find . -name "*.[chS]" ${findArgs}
>>> -# Verify no lines longer than 80 columns
>>> -echo "=== Checking for lines greater than 79 columns"
>>> -find_source -m -c -C | while read f
>>> -do
>>> -  grep  ".\{80,\}" ${f} >/dev/null
>>> -  if [ $? -eq 0 ] ; then
>>> -    echo "*** ${basedir}/${f} has the following lines that are too long"
>>> -    grep -n '.\{80,\}' ${f}
>>> -  fi
>>> -done
>>> -# really need to make the copyright strings consistent in BSPs
>>> -echo "=== Checking for copyright notices"
>>> -find_source | while read f
>>> -do
>>> -  test_its_there_all_case ${f} COPYRIGHT
>>> -done
>>> -# We want CVS Id strings everywhere possible
>>> -echo "=== Checking for CVS Id strings"
>>> -find_source -d | while read f
>>> -do
>>> -  test_its_NOT_there ${f} "\$Id"
>>> -done
>>> -# We do not want the reformatted license notice
>>> -echo "=== Checking for reformatted RTEMS license notices"
>>> -do
>>> -  test_its_NOT_there ${f} "this file may be found in the file"
>>> -done
>>> -# We do not want spaces at the end of lines
>>> -echo "=== Checking for spaces at the end of lines"
>>> -do
>>> -  egrep " +$" $f >/dev/null
>>> -  test $? -eq 0 && echo "$f has spaces at the end of one or more lines."
>>> -done
>>> -# We do not want tabs in source files
>>> -echo "=== Checking for tabs in source files"
>>> -do
>>> -  grep -P '\t' $f >/dev/null
>>> -  if [ $? -eq 0 ]; then
>>> -    echo "*** ${basedir}/${f} has the following lines with tabs"
>>> -    grep -P '\t' $f
>>> -  fi
>>> -done
>>> -# We do not want GPL code
>>> -echo "=== Checking for hints of GPL code"
>>> -do
>>> -  test_its_NOT_there ${f} "Free Software Foundation"
>>> -  test_its_NOT_there ${f} "program is free software"
>>> -  test_its_NOT_there ${f} "General Public License"
>>> -done
>>> -# We do not want hints that there are things left to do
>>> -echo "=== Checking for TODO hints"
>>> -do
>>> -  test_its_NOT_there ${f} XXX
>>> -  test_its_NOT_there ${f} TODO
>>> -  test_its_NOT_there ${f} TBD
>>> -done
>>> +function check_format(){
>>> -# BSP specific checks
>>> -if [ ${do_bsp} = "yes" ] ; then
>>> -  # We do not want stdio in a BSP
>>> -  echo "=== Checking for stdio"
>>> +  # Verify no lines longer than 80 columns
>>> +  echo "=== Checking for lines greater than 80 columns"
>>> +  find_source -m -c -C | while read f
>>> +  do
>>> +    grep  ".\{81,\}" ${f} >/dev/null
>>> +    if [ $? -eq 0 ] ; then
>>> +      echo -e "\n$bsp : ${f#./} has more than 80 character lines"
>>> +      for i in `grep -n '.\{80,\}' ${f} | cut -f1 -d:`
>>> +      do
>>> +        echo -e "$i \c"
>>> +    done
>>> +    fi
>>> +  done
>>> +  # really need to make the copyright strings consistent in BSPs
>>> +  echo -e "\n=== Checking for copyright notices"
>>> +  find_source | while read f
>>> +  do
>>> +    test_its_there_all_case ${f} COPYRIGHT
>>> +  done
>>> +  # We want CVS Id strings everywhere possible
>>> +  echo "=== Checking for CVS Id strings"
>>> +  find_source -d | while read f
>>> +  do
>>> +    test_its_NOT_there ${f} "\$Id"
>>> +  done
>>> +  # We do not want the reformatted license notice
>>> +  echo "=== Checking for reformatted RTEMS license notices"
>>> +  do
>>> +    test_its_NOT_there ${f} "this file may be found in the file"
>>> +  done
>>> +  # We do not want spaces at the end of lines
>>> +  echo "=== Checking for spaces at the end of lines"
>>> +  do
>>> +    egrep " +$" $f >/dev/null
>>> +    test $? -eq 0 && echo -e "${f##./} \c"
>>> +  done
>>> +  # We do not want tabs in source files
>>> +  echo -e "\n=== Checking for tabs in source files"
>>> +  do
>>> +    grep -P '\t' $f >/dev/null
>>> +  done
>>> +  # We do not want GPL code
>>> +  echo -e "\n=== Checking for hints of GPL code"
>>>    do
>>> -    test_its_NOT_there ${f} printf
>>> -    test_its_NOT_there ${f} "puts("
>>> +    test_its_NOT_there ${f} "Free Software Foundation"
>>> +    test_its_NOT_there ${f} "program is free software"
>>> +    test_its_NOT_there ${f} "General Public License"
>>>    done
>>> -  # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>>> -  #  RTEMS_BSP_BOOTCARD_OPTIONS
>>> -  if [ -r configure.ac ] ; then
>>> -    echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP
> configure.ac"
>>> -    test_its_not_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>>> -    echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP
> configure.ac"
>>> -    test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>>> +  # We do not want hints that there are things left to do
>>> +  echo "=== Checking for TODO hints"
>>> +  do
>>> +    test_its_NOT_there ${f} XXX
>>> +    test_its_NOT_there ${f} TODO
>>> +    test_its_NOT_there ${f} TBD
>>> +  done
>>> +# Reviewing for a BSP Starts
>>> +function main(){
>>> +  if [[ $format -eq "1" ]]; then
>>> +    check_format
>>>    fi
>>> -  # If not using -O2, then we really want to know
>>> -  # BSPs should normally use -O2
>>> -  echo "=== Checking for not using -O2"
>>> -  grep -H "\-O[013456789]" make/custom/*.cfg
>>> +  # We do not want stdio in a BSP
>>> +    echo "=== Checking for stdio"
>>> +    do
>>> +      test_its_NOT_there ${f} printf
>>> +      test_its_NOT_there ${f} "puts("
>>> +    done
>>> +    # BSPs should include RTEMS_BSP_CLEANUP_OPTIONS and maybe
>>> +    #  RTEMS_BSP_BOOTCARD_OPTIONS
>>> +    if [ -r configure.ac ] ; then
>>> +      echo "=== Checking for RTEMS_BSP_BOOTCARD_OPTIONS in BSP
> configure.ac"
>>> +      test_its_NOT_there configure.ac RTEMS_BSP_BOOTCARD_OPTIONS
>>> +      echo "=== Checking for RTEMS_BSP_CLEANUP_OPTIONS in BSP
> configure.ac"
>>> +      test_its_there configure.ac RTEMS_BSP_CLEANUP_OPTIONS
>>> +    fi
>>> +    # If not using -O2, then we really want to know
>>> +    # BSPs should normally use -O2
>>> +    echo "=== Checking for not using -O2"
>>> +    grep -H "\-O[013456789]" make/custom/*.cfg
>>> -  # BSPs should not turn on extra warnings
>>> -  echo "=== Checking for turning on extra GCC warning checks"
>>> -  grep -H "\-W" make/custom/*.cfg
>>> +    # BSPs should not turn on extra warnings
>>> +    echo "=== Checking for turning on extra GCC warning checks"
>>> +    grep -H "\-W" make/custom/*.cfg
>>> -  # Hopefully have some output from the tmtests
>>> -  echo "=== Checking for timing information"
>>> -  c=`ls -1 times* 2>/dev/null | wc -l`
>>> -  if [ ${c} -eq 0 ] ; then
>>> -    echo "Please run the timing tests and include the results."
>>> +    # Hopefully have some output from the tmtests
>>> +    echo "=== Checking for timing information"
>>> +    c=`ls -1 times* 2>/dev/null | wc -l`
>>> +    if [ ${c} -eq 0 ] ; then
>>> +      echo "Please run the timing tests and include the results."
>>>    fi
>>> -fi  ## END OF IF BSP
>>> +  echo -e "\n=== Starting BSP Unified way checks"
>>> +  flag="0"
>>> +  check_file 1 start.S ../shared/start/ start/
>>> +  if [[ $filename != "0" ]];then
>>> +    if grep -wq "start" "$filename" || grep -wq "_start"
> "$filename"; then
>>> +        echo "$bsp : `basename $filename` start() present in $filename"
>>> +      fi
>>> +    else
>>> +      echo "$bsp : `basename $filename` start() does not exist in
> start.S"
>>> +    fi
>>> +  fi
>>> +  check_file 1 bspstart.c ../../shared/ ../shared/ startup/
>>> +  check_methods "bsp_start"
>>> +  check_file 1 bspreset.c ../../shared/ ../shared/ startup/
>>> +  check_methods 1 "bsp_reset"
>>> +  check_file 1 bootcard.c ../../shared/
>>> +  check_header ../../shared/include/bootcard.h
>>> +  check_file 1 bspclean.c ../../shared/ startup/
>>> +  check_methods "bsp_fatal_extension"
>>> +  check_file 1 bspgetworkarea.c ../../shared/ ../../shared/startup
> ../shared/ ../shared/startup/ startup/
>>> +  check_methods 1 "bsp_work_area_initialize"
>>> +  check_file 1 bsplibc.c ../../shared/
>>> +  check_methods "bsp_libc_init"
>>> +  check_file 1 bsppost.c ../../shared/
>>> +  check_methods "bsp_postdriver_hook"
>>> +  check_file 1 bsppredriverhook.c ../../shared/ ../shared/startup/
> startup/
>>> +  check_methods "bsp_predriver_hook"
>>> +  check_file gnatinstallhandler.c ../../shared/
>>> +  check_file sbrk.c ../../shared/ ../../shared/ startup/
>>> +  check_methods "sbrk"
>>> +  check_file stackalloc.c ../../shared/src/
>>> +  check_methods "bsp_stack_allocate_init" "bsp_stack_allocate"
> "bsp_stack_free"
>>> +  check_header ../../shared/include/stackalloc.h
>>> +  # Interrupt Files
>>> +  check_file 1 irq.c irq/
>>> +  check_methods "bsp_interrupt_vector_enable"
> "bsp_interrupt_vector_disable" "bsp_interrupt_facility_initialize"
> "bsp_interrupt_dispatch"
>>> +  check_header 1 include/irq.h
>>> +  # PIC Support
>>> +  check_file irq-default-handler.c ../../shared/src/
>>> +  check_file 1 irq-generic.c ../../shared/src/
>>> +  check_header 1 ../../shared/include/irq-generic.h
>>> +  check_file irq-info.c ../../shared/src/
>>> +  check_header ../../shared/include/irq-info.h
>>> +  check_file irq-legacy.c ../../shared/src/
>>> +  check_file irq-server.c ../../shared/src/
>>> +  check_file irq-shell.c ../../shared/src/
>>> +  # Real Time Clock
>>> +  check_file rtc-config.c rtc/
>>> +  check_methods "bsp_rtc_initialize" "bsp_rtc_get_time"
> "bsp_rtc_set_time" "bsp_rtc_probe"
>>> +  check_file 1 tod.c ../../shared/ tod/
>>> +  # Benchmark Timers
>>> +  check_file benchmark_timer.c benchmark_timer/
>>> +  check_methods "benchmark_timer_initialize" "benchmark_timer_read"
> "benchmark_timer_disable_subtracting_average_overhead"
>>> +  # Standard Headers
>>> +  check_header 1 include/bsp.h
>>> +  check_header include/bspopts.h
>>> +  check_header 1 ../../shared/include/coverhd.h include/coverhd.h
>>> +  check_header ../../shared/include/utility.h
>>> +  check_header 1 ../../shared/include/tm27.h include/tm27.h
>>> +  cd ../../../../../../cpukit
>>> +  find_rtems_internal
>>> +  cd - > /dev/null
>>> +  # Finding all internal functions being used in a bsp
>>> +  find_bsp_internal
>>> +  if [[ $flag == "1" ]]; then
>>> +    echo -e "\n"
>>> +  fi
>>>  # Test specific checks
>>> -if [ ${do_test} = "yes" ] ; then
>>> -  # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>>> -  Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>>> -  if [ "X${Makefiles}" = "X" ] ; then
>>> -    fatal "Unable to locate any test Makefile.am files."
>>> -  fi
>>> -  echo "=== Checking for missing test support files"
>>> -  for m in ${Makefiles}
>>> -  do
>>> -    directory=`dirname ${m}`
>>> -    if [ ${directory} = "." ] ; then
>>> -      directory=`pwd`
>>> +  if [ ${do_test} == "1" ] ; then
>>> +    echo -e "\n=== Starting Test specific checks"
>>> +    # find all the Makefile.am's with rtems_tests_PROGRAMS in them
>>> +    Makefiles=`find . -name Makefile.am | xargs -e grep -l ^rtems_tests`
>>> +    if [ "X${Makefiles}" = "X" ] ; then
>>> +      echo -e "Unable to locate any test Makefile.am files.\n"
>>> +      return
>>>      fi
>>> -    testName=`basename ${directory}`
>>> -    # Does this test have a .doc file?
>>> -    if [ ! -r ${directory}/${testName}.doc ] ; then
>>> -      echo ${testName}.doc is not present
>>> +    echo "=== Checking for missing test support files"
>>> +    for m in ${Makefiles}
>>> +    do
>>> +      directory=`dirname ${m}`
>>> +      if [ ${directory} = "." ] ; then
>>> +        directory=`pwd`
>>> +      fi
>>> +      testName=`basename ${directory}`
>>> +      # Does this test have a .doc file?
>>> +      if [ ! -r ${directory}/${testName}.doc ] ; then
>>> +        echo ${testName}.doc is not present
>>> +      fi
>>> +      case ${directory} in
>>> +        */*tmtests*) ;;
>>> +          # Does this test have a .scn file?
>>> +          if [ ! -r ${directory}/${testName}.scn ] ; then
>>> +            echo ${testName}.scn is not present
>>> +          fi
>>> +      esac
>>> +    done
>>> +  fi
>>> +# Verifying if the directory given or pwd is a valid bsp, shared
> architecture, or libbsp directory
>>> +function check_given_dir(){
>>> +  if echo $cur_dir | grep -Eq
> "c/src/lib/libbsp/([^/]+)/([^/]+)/([^/]+)*" ; then
>>> +    return 0
>>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)/([^/]+)" ;
> then
>>> +# BSP given
>>> +    bsp=${cur_dir##*/}
>>> +    if [[ $bsp == "shared" || $bsp == "autom4te.cache" || $bsp ==
> "no_bsp" ]]; then
>>> +      return 0
>>> +    else
>>> +      main
>>>      fi
>>> -    case ${directory} in
>>> -      */*tmtests*) ;;
>>> -        # Does this test have a .scn file?
>>> -        if [ ! -r ${directory}/${testName}.scn ] ; then
>>> -          echo ${testName}.scn is not present
>>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp/([^/]+)" ; then
>>> +# Shared architecture given
>>> +    for i in *
>>> +    do
>>> +        if [[ $i == "shared" || $i == "autom4te.cache" || $i ==
> "no_bsp" ]]; then
>>> +          echo -n
>>> +        else
>>> +          bsp=$i
>>> +          cd $bsp
>>> +          main
>>> +          cd .. > /dev/null
>>> +        fi
>>> +      fi
>>> +    done
>>> +  elif echo $cur_dir | grep -Eq "c/src/lib/libbsp" ; then
>>> +# libbsp given
>>> +    for i in */*/Makefile.am
>>> +    do
>>> +      i=`dirname $i`
> "no_cpu/no_bsp" ]]; then
>>> +          echo -n
>>> +        else
>>> +          bsp=$i
>>> +          cd $bsp
>>> +          main
>>> +          cd ../../ > /dev/null
>>>          fi
>>> +      fi
>>> +    done
>>> +  else
>>> +    return 0
>>> +  fi
>>> +# Evaluating Command Line Arguments
>>> +function start(){
>>> +  for i in $*
>>> +  do
>>> +    case $i in
>>> +      "--verbose") verbose="1" # The whole story
>>> +      "--warnings") warnings="1" # All warnings
>>> +              verbose="0"
>>> +      "--no_format") format="0" # Disabling format checks
>>> +              verbose="0"
>>> +      "--tests") do_test="1"    # Enabling check of tests
>>> +            verbose="0"
>>> +      "--help") echo "Help to be provided"
>>> +      "--"* | "-"* ) echo "Invalid options provided"
>>> +      *) path="$path $i"  ;; # If not above options, then assumed to
> be a path for bsp
>>>      esac
>>>    done
>>> -fi
>>> -exit 0
>>> +# No path given, search for bsp from pwd
>>> +  if [[ -z $path ]];then
>>> +    path=$PWD
>>> +    cur_dir=`pwd`
>>> +    check_given_dir
>>> +    if [[ $? -eq 1 ]];then
>>> +      echo "Current directory does not seem a valid RTEMS directory"
>>> +    fi
>>> +  else
>>> +    for i in $path
>>> +    do
>>> +        echo > /dev/null
>>> +      else
>>> +        echo "$i is an invalid directory."
>>> +        continue
>>> +      fi
>>> +      cd $i
>>> +      cur_dir=`pwd`
>>> +      check_given_dir
>>> +        echo "$i does not seem a valid RTEMS directory"
>>> +      fi
>>> +      cd $calling_path
>>> +    done
>>> +  fi
>>> +# Let the Game begin !!
>>> +start $*
>>> +# End of Checks
>>> +if [[ $faults -eq "0" ]] ; then
>>> +  echo -e "\nNo faults found in BSP organization"
>>> +fi
>>> 1.7.11.7
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Joel Sherrill, Ph.D.            Director of Research & Development
>> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>
> On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
joel.sherrill at OARcorp.com        On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130918/b198c5a8/attachment-0001.html>
