[rtems commit] semopen.c: Address set but unused variable warning
Joel Sherrill
Joel.Sherrill at OARcorp.com
Mon Sep 23 13:37:12 UTC 2013
If you see any other patches which could use a better approach just ping me. I will try to fix in the plane.
Gedare Bloom <gedare at rtems.org> wrote:
You can't always win.
On Mon, Sep 23, 2013 at 9:15 AM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> You get a statement with no effect warning.
> Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> Does that work or generate an warning about statement with no effect?
> On Sun, Sep 22, 2013 at 10:45 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> There is precedence for using the compiler attributes
>> so I just added that and switched.
> I think it might be better to avoid compiler attributes when there is
> a language-level alternative that is compiler-agnostic. In this case,
> the use of:
> (void) var;
> seems fine to me.
>> Thanks for the feedback.
>> If we have a print format string to use for mode_t and
>> wchar_t, a few more cases would be fixed.
>> On 9/22/2013 7:32 AM, Pavel Pisa wrote:
>>> Hello Ralf and others,
>>> On Sunday 22 of September 2013 05:01:49 Ralf Corsepius wrote:
>>>>> diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
>>>>> index b863080..e61fad0 100644
>>>>> --- a/cpukit/posix/src/semopen.c
>>>>> +++ b/cpukit/posix/src/semopen.c
>>>>> @@ -43,6 +43,14 @@
>>>>> * parameters must be present.
>>>>> + * mode is set but never used. GCC gives a warning for this
>>>>> + * and we need to tell GCC not to complain. But we have to
>>>>> + * have it because we have to work through the variable
>>>>> + * arguments to get to attr.
>>>>> +#pragma GCC diagnostic push
>>>>> +#pragma GCC diagnostic ignored "-Wunused-but-set-variable"
>>>>> sem_t *sem_open(
>>>>> const char *name,
>>>>> int oflag,
>>>>> @@ -137,3 +145,4 @@ return_id:
>>>>> return (sem_t *)&the_semaphore->Object.id;
>>>>> #endif
>>>>> +#pragma GCC diagnostic pop
>>>> Why this brutal and probably non-portable way to suppress warnings?
>>>> Why doesn't __attribute__((unused)) or similar suffice?
>>> I would prefer to see something like RTEMS_ATTR_UNUSED to support
>>> multiple compilers. You can look at my collection of these in
>>> uLUt definitions file
>>> http://sourceforge.net/p/ulan/ulut/ci/master/tree/ulut/ul_utdefs.h
>>> I declare file contents (by this e-mail) as free for public
>>> domain use (uLUt as whole is is GPL/LGPL/MPL RTEMS compatible too).
>>> As for the actual __attribute__((unused)) there is even portable
>>> solution which does not depend on GCC extension.
>>> int my_unused_var;
>>> (void) my_unused_var;
>>> This solution should be accepted by all compilers and is suggested
>>> by some people as better option.
>>> Best wishes,
>>> Pavel
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
