[PATCH 3/3] MMU support for RaspberryPi BSP
Fri Sep 27 19:09:58 UTC 2013
On Mon, Sep 16, 2013 at 12:20 PM, Hesham AL-Matary
<heshamelmatary at gmail.com> wrote:
>  c/src/lib/libbsp/arm/raspberrypi/Makefile.am       |  9 ++-
>  c/src/lib/libbsp/arm/raspberrypi/preinstall.am     |  8 +++
>  .../libbsp/arm/raspberrypi/startup/bspstarthooks.c | 22 +------
>  c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds  |  4 +-
>  .../arm/raspberrypi/startup/mm_config_table.c      | 70 ++++++++++++++++++++++
>  5 files changed, 92 insertions(+), 21 deletions(-)
>  create mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> index 24d396c..a06979a 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> @@ -27,6 +27,7 @@ nodist_include_HEADERS = ../../shared/include/coverhd.h \
>  nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
> +include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
>  include_bsp_HEADERS += ../../shared/include/utility.h
>  include_bsp_HEADERS += ../../shared/include/irq-generic.h
>  include_bsp_HEADERS += ../../shared/include/irq-info.h
> @@ -35,6 +36,7 @@ include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>  include_bsp_HEADERS += ../../shared/tod.h
>  include_bsp_HEADERS += ../shared/include/linker-symbols.h
>  include_bsp_HEADERS += ../shared/include/start.h
> +include_bsp_HEADERS += ../shared/include/arm-cp15-start.h
>  include_bsp_HEADERS += ../shared/lpc/include/lpc-timer.h
>  include_bsp_HEADERS += ../shared/lpc/include/lpc-dma.h
>  include_bsp_HEADERS += include/irq.h
> @@ -83,7 +85,7 @@ libbsp_a_SOURCES += ../../shared/sbrk.c
>  libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>  libbsp_a_SOURCES += ../shared/abort/simple_abort.c
>  libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
> +libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
>  # Startup
>  libbsp_a_SOURCES += startup/bspreset.c
> @@ -91,6 +93,7 @@ libbsp_a_SOURCES += startup/bspstart.c
>  # IRQ
>  libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
> +libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
>  libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>  libbsp_a_SOURCES += ../../shared/src/irq-info.c
>  libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
> @@ -127,6 +130,10 @@ libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
>  # Start hooks
>  libbsp_a_SOURCES += startup/bspstarthooks.c
> +# LIBMM
> +libbsp_a_SOURCES += startup/mm_config_table.c
> +libbsp_a_SOURCES += ../shared/mminit.c
>  # Network                                                    #
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> index 056c5f1..a638e64 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> +++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
> @@ -62,6 +62,10 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INC
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
> +$(PROJECT_INCLUDE)/bsp/mm.h: ../../../libbsp/shared/include/mm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mm.h
>  $(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
> @@ -94,6 +98,10 @@ $(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h $(PROJECT_INCLUDE)/bsp
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
> +$(PROJECT_INCLUDE)/bsp/arm-cp15-start.h: ../shared/include/arm-cp15-start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/arm-cp15-start.h
>  $(PROJECT_INCLUDE)/bsp/lpc-timer.h: ../shared/lpc/include/lpc-timer.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-timer.h
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
> index a224168..71b2ff1 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
> @@ -7,6 +7,7 @@
> + * Copyright (c) 2013. Hesham AL-Matary
>   * Copyright (c) 2013 by Alan Cudmore
>   * based on work by:
>   * Copyright (c) 2009
> @@ -24,33 +25,16 @@
>  #include <bspopts.h>
>  #include <bsp/start.h>
>  #include <bsp/raspberrypi.h>
> -#include <bsp/mmu.h>
> -static void BSP_START_TEXT_SECTION raspberrypi_cache_setup(void)
> -  uint32_t ctrl = 0;
> -  /* Disable MMU and cache, basic settings */
> -  ctrl = arm_cp15_get_control();
> -  ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
> -    | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
> -  ctrl |= ARM_CP15_CTRL_S;
> -  arm_cp15_set_control(ctrl);
> -  arm_cp15_cache_invalidate();
> -  arm_cp15_tlb_invalidate();
> +#include <bsp/mm.h>
>  void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
> -  raspberrypi_cache_setup();
>  void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
>    bsp_start_copy_sections();
> +  bsp_memory_management_initialize();
>    bsp_start_clear_bss();
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> index b9a0dd8..c12b348 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds
> @@ -35,7 +35,8 @@
>  MEMORY {
>          VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 0x8000
> -        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 0x8000
> +        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M - 48K
> +       RAM_MMU        (AIW) : ORIGIN = 128M - 16k, LENGTH = 16k
>  REGION_ALIAS ("REGION_START", RAM);
> @@ -58,5 +59,6 @@ bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size : 4096;
>  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
>  bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1M;
> +bsp_translation_table_base = ORIGIN (RAM_MMU);
>  INCLUDE linkcmds.armv4
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
This file probably should be included with the previous patch, since
it defines the needed "config_table" variables. You should also put an
extern declaration of those variables somewhere useful, perhaps in
arm-cp15-start.h if you intend to generalize the rest of the arm-cp15
BSPs to use the same variables.
> new file mode 100644
> index 0000000..fd85513
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> @@ -0,0 +1,70 @@
> + * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <info at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#include <bsp/start.h>
> +#include <bsp/arm-cp15-start.h>
> +#ifdef RTEMS_SMP
> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
> +#else
> +  #define MMU_DATA_READ_WRITE ARMV7_MMU_DATA_READ_WRITE_CACHED
> +#endif
> +BSP_START_DATA_SECTION const arm_cp15_start_section_config
> +bsp_mm_config_table[] = {
> +    .begin = (uint32_t) bsp_section_fast_text_begin,
> +    .end = (uint32_t) bsp_section_fast_text_end,
> +    .flags = ARMV7_MMU_CODE_CACHED
> +    .begin = (uint32_t) bsp_section_fast_data_begin,
> +    .end = (uint32_t) bsp_section_fast_data_end,
> +    .flags = MMU_DATA_READ_WRITE
> +    .begin = (uint32_t) bsp_section_start_begin,
> +    .end = (uint32_t) bsp_section_start_end,
> +    .begin = (uint32_t) bsp_section_vector_begin,
> +    .end = (uint32_t) bsp_section_vector_end,
> +    .begin = (uint32_t) bsp_section_text_begin,
> +    .end = (uint32_t) bsp_section_text_end,
> +    .begin = (uint32_t) bsp_section_rodata_begin,
> +    .end = (uint32_t) bsp_section_rodata_end,
> +    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
> +    .begin = (uint32_t) bsp_section_data_begin,
> +    .end = (uint32_t) bsp_section_data_end,
> +    .begin = (uint32_t) bsp_section_bss_begin,
> +    .end = (uint32_t) bsp_section_bss_end,
> +    .begin = (uint32_t) bsp_section_work_begin,
> +    .end = (uint32_t) bsp_section_work_end,
> +    .begin = (uint32_t) bsp_section_stack_begin,
> +    .end = (uint32_t) bsp_section_stack_end,
> +BSP_START_DATA_SECTION const size_t bsp_mm_config_table_size =
> +RTEMS_ARRAY_SIZE(&bsp_mm_config_table);
> 1.8.3.1
> rtems-devel mailing list
> rtems-devel at rtems.org
