[PATCH 2/2] score: Move priority bit map to scheduler instance
Tue Apr 1 12:36:14 UTC 2014
Delete global variables _Priority_Major_bit_map and _Priority_Bit_map.
This makes it possible to use multiple priority scheduler instances for
example with clustered/partitioned scheduling on SMP.
 cpukit/sapi/include/confdefs.h                     |    5 +-
 cpukit/score/Makefile.am                           |    2 -
 cpukit/score/include/rtems/score/prioritybitmap.h  |   18 +++
 .../score/include/rtems/score/prioritybitmapimpl.h |  108 +++++++------------
 .../score/include/rtems/score/schedulerpriority.h  |   12 ++
 .../include/rtems/score/schedulerpriorityimpl.h    |   66 ++++++++----
 .../include/rtems/score/schedulerprioritysmp.h     |    7 +-
 .../score/include/rtems/score/schedulersimplesmp.h |    2 +-
 cpukit/score/include/rtems/score/schedulersmp.h    |    9 +-
 .../score/include/rtems/score/schedulersmpimpl.h   |   16 ++-
 cpukit/score/src/prioritybitmap.c                  |   27 -----
 cpukit/score/src/schedulerpriority.c               |   10 +-
 cpukit/score/src/schedulerpriorityblock.c          |    6 +-
 cpukit/score/src/schedulerpriorityenqueue.c        |    4 +-
 cpukit/score/src/schedulerpriorityenqueuefirst.c   |    7 +-
 cpukit/score/src/schedulerpriorityextract.c        |    6 +-
 cpukit/score/src/schedulerprioritysmp.c            |  111 ++++++++++++++-----
 cpukit/score/src/schedulerpriorityunblock.c        |    4 +-
 cpukit/score/src/schedulerpriorityupdate.c         |    8 +-
 cpukit/score/src/schedulersimplesmp.c              |   25 ++++-
 cpukit/score/src/schedulersmpstartidle.c           |   40 -------
 testsuites/sptests/spsize/size.c                   |    7 +-
 testsuites/tmtests/tm26/task1.c                    |   31 +++---
 testsuites/tmtests/tm27/task1.c                    |   11 +-
 24 files changed, 291 insertions(+), 251 deletions(-)
 delete mode 100644 cpukit/score/src/prioritybitmap.c
 delete mode 100644 cpukit/score/src/schedulersmpstartidle.c
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index d8cf2af..6f69dc4 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -676,7 +676,8 @@ const rtems_libio_helper rtems_fs_init_helper =
   #define CONFIGURE_MEMORY_FOR_SCHEDULER ( \
     _Configure_From_workspace( \
-      ((CONFIGURE_MAXIMUM_PRIORITY+1) * sizeof(Chain_Control)) ) \
+      sizeof(Scheduler_priority_Control) +  \
+      ((CONFIGURE_MAXIMUM_PRIORITY) * sizeof(Chain_Control)) ) \
   #define CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER ( \
     _Configure_From_workspace(sizeof(Scheduler_priority_Per_thread)) )
@@ -695,7 +696,7 @@ const rtems_libio_helper rtems_fs_init_helper =
-      sizeof(Scheduler_SMP_Control) +  \
+      sizeof(Scheduler_priority_SMP_Control) +  \
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 852360c..6c9e682 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -127,7 +127,6 @@ if HAS_SMP
 libscore_a_SOURCES += src/profilingsmplock.c
 libscore_a_SOURCES += src/schedulerprioritysmp.c
 libscore_a_SOURCES += src/schedulersimplesmp.c
-libscore_a_SOURCES += src/schedulersmpstartidle.c
 libscore_a_SOURCES += src/smp.c
 libscore_a_SOURCES += src/cpuset.c
 libscore_a_SOURCES += src/cpusetprintsupport.c
@@ -191,7 +190,6 @@ libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
 ## SCHEDULER_C_FILES
 libscore_a_SOURCES += src/log2table.c
-libscore_a_SOURCES += src/prioritybitmap.c
 libscore_a_SOURCES += src/scheduler.c
 libscore_a_SOURCES += src/schedulerdefaultallocatefree.c
 libscore_a_SOURCES += src/schedulerdefaultreleasejob.c
diff --git a/cpukit/score/include/rtems/score/prioritybitmap.h b/cpukit/score/include/rtems/score/prioritybitmap.h
index 2ef78be..f363fe4 100644
--- a/cpukit/score/include/rtems/score/prioritybitmap.h
+++ b/cpukit/score/include/rtems/score/prioritybitmap.h
@@ -37,6 +37,24 @@ extern "C" {
+typedef struct {
+   * @brief Each sixteen bit entry in this word is associated with one of the
+   * sixteen entries in the bit map.
+  Priority_bit_map_Word major_bit_map;
+   * @brief Each bit in the bit map indicates whether or not there are threads
+   * ready at a particular priority.
+   * The mapping of individual priority levels to particular bits is processor
+   * dependent as is the value of each bit used to indicate that threads are
+   * ready at that priority.
+  Priority_bit_map_Word bit_map[ 16 ];
+} Priority_bit_map_Control;
  *  The following record defines the information associated with
  *  each thread to manage its interaction with the priority bit maps.
diff --git a/cpukit/score/include/rtems/score/prioritybitmapimpl.h b/cpukit/score/include/rtems/score/prioritybitmapimpl.h
index df65fb4..de90ef7 100644
--- a/cpukit/score/include/rtems/score/prioritybitmapimpl.h
+++ b/cpukit/score/include/rtems/score/prioritybitmapimpl.h
@@ -22,6 +22,8 @@
 #include <rtems/score/prioritybitmap.h>
 #include <rtems/score/priority.h>
+#include <string.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -31,26 +33,6 @@ extern "C" {
- * The Priority_bit_map_Word variables are instantiated only
- * if using the bit map handler.
- *  Each sixteen bit entry in this array is associated with one of
- *  the sixteen entries in the Priority Bit map.
-extern volatile Priority_bit_map_Word _Priority_Major_bit_map;
-/** Each bit in the Priority Bitmap indicates whether or not there are
- *  threads ready at a particular priority.  The mapping of
- *  individual priority levels to particular bits is processor
- *  dependent as is the value of each bit used to indicate that
- *  threads are ready at that priority.
-extern Priority_bit_map_Word
-               _Priority_Bit_map[16] CPU_STRUCTURE_ALIGNMENT;
 #if ( CPU_USE_GENERIC_BITFIELD_DATA == TRUE )
@@ -188,74 +170,67 @@ RTEMS_INLINE_ROUTINE uint32_t   _Priority_Bits_index (
 #endif
- * Priority Queue implemented by bit map
- *  This is the minor bit map.
-extern Priority_bit_map_Word _Priority_Bit_map[16] CPU_STRUCTURE_ALIGNMENT;
+RTEMS_INLINE_ROUTINE void _Priority_bit_map_Initialize(
+  Priority_bit_map_Control *bit_map
+  memset( bit_map, 0, sizeof( *bit_map ) );
- * This routine uses the_priority_map to update the priority
- * bit maps to indicate that a thread has been readied.
+ * Priority Queue implemented by bit map
 RTEMS_INLINE_ROUTINE void _Priority_bit_map_Add (
-  Priority_bit_map_Information *the_priority_map
+  Priority_bit_map_Control     *bit_map,
+  Priority_bit_map_Information *bit_map_info
-  *the_priority_map->minor |= the_priority_map->ready_minor;
-  _Priority_Major_bit_map  |= the_priority_map->ready_major;
+  *bit_map_info->minor |= bit_map_info->ready_minor;
+  bit_map->major_bit_map |= bit_map_info->ready_major;
- * bit maps to indicate that a thread has been removed from the
- * ready state.
 RTEMS_INLINE_ROUTINE void _Priority_bit_map_Remove (
-  *the_priority_map->minor &= the_priority_map->block_minor;
-  if ( *the_priority_map->minor == 0 )
-    _Priority_Major_bit_map &= the_priority_map->block_major;
+  *bit_map_info->minor &= bit_map_info->block_minor;
+  if ( *bit_map_info->minor == 0 )
+    bit_map->major_bit_map &= bit_map_info->block_major;
- * This function returns the priority of the highest priority
- * ready thread.
-RTEMS_INLINE_ROUTINE Priority_Control _Priority_bit_map_Get_highest( void )
+RTEMS_INLINE_ROUTINE Priority_Control _Priority_bit_map_Get_highest(
+  const Priority_bit_map_Control *bit_map
   Priority_bit_map_Word minor;
   Priority_bit_map_Word major;
-  _Bitfield_Find_first_bit( _Priority_Major_bit_map, major );
-  _Bitfield_Find_first_bit( _Priority_Bit_map[major], minor );
+  /* Avoid problems with some inline ASM statements */
+  Priority_bit_map_Word tmp;
+  tmp = bit_map->major_bit_map;
+  _Bitfield_Find_first_bit( tmp, major );
+  tmp = bit_map->bit_map[ major ];
+  _Bitfield_Find_first_bit( tmp, minor );
   return (_Priority_Bits_index( major ) << 4) +
           _Priority_Bits_index( minor );
-RTEMS_INLINE_ROUTINE bool _Priority_bit_map_Is_empty( void )
+RTEMS_INLINE_ROUTINE bool _Priority_bit_map_Is_empty(
-  return _Priority_Major_bit_map == 0;
+  return bit_map->major_bit_map == 0;
- * This routine initializes the_priority_map so that it
- * contains the information necessary to manage a thread
- * at new_priority.
 RTEMS_INLINE_ROUTINE void _Priority_bit_map_Initialize_information(
-  Priority_bit_map_Information *the_priority_map,
-  Priority_Control      new_priority
+  Priority_bit_map_Information *bit_map_info,
+  Priority_Control              new_priority
@@ -265,18 +240,17 @@ RTEMS_INLINE_ROUTINE void _Priority_bit_map_Initialize_information(
   major = _Priority_Major( new_priority );
   minor = _Priority_Minor( new_priority );
-  the_priority_map->minor =
-    &_Priority_Bit_map[ _Priority_Bits_index(major) ];
+  bit_map_info->minor = &bit_map->bit_map[ _Priority_Bits_index( major ) ];
   mask = _Priority_Mask( major );
-  the_priority_map->ready_major = mask;
+  bit_map_info->ready_major = mask;
   /* Add _Priority_Mask_invert to non-generic bitfield then change this code. */
-  the_priority_map->block_major = (Priority_bit_map_Word)(~((uint32_t)mask));
+  bit_map_info->block_major = (Priority_bit_map_Word)(~((uint32_t)mask));
   mask = _Priority_Mask( minor );
-  the_priority_map->ready_minor = mask;
+  bit_map_info->ready_minor = mask;
-  the_priority_map->block_minor = (Priority_bit_map_Word)(~((uint32_t)mask));
+  bit_map_info->block_minor = (Priority_bit_map_Word)(~((uint32_t)mask));
diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
index 605ab39..9128e0b 100644
--- a/cpukit/score/include/rtems/score/schedulerpriority.h
+++ b/cpukit/score/include/rtems/score/schedulerpriority.h
@@ -56,6 +56,18 @@ extern "C" {
     _Scheduler_default_Start_idle         /* start idle entry point */ \
+typedef struct {
+   * @brief Bit map to indicate non-empty ready queues.
+  Priority_bit_map_Control Bit_map;
+   * @brief One ready queue per priority level.
+  Chain_Control ready[ 1 ];
+} Scheduler_priority_Control;
  * Per-thread data related to the _Scheduler_PRIORITY scheduling policy.
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
index 7869675..8042285 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
@@ -35,16 +35,16 @@ extern "C" {
-RTEMS_INLINE_ROUTINE Chain_Control *
-_Scheduler_priority_Get_ready_queues( void )
+RTEMS_INLINE_ROUTINE Scheduler_priority_Control *
+  _Scheduler_priority_Instance( void )
-  return ( Chain_Control * ) _Scheduler.information;
+  return _Scheduler.information;
  * @brief Ready queue initialization.
- * This routine initializes @a the_ready_queue for priority-based scheduling.
+ * This routine initializes @a ready_queues for priority-based scheduling.
 RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_initialize(
   Chain_Control *ready_queues
@@ -68,10 +68,12 @@ _Scheduler_priority_Get_scheduler_info( Thread_Control *thread )
  * This routine puts @a the_thread on to the priority-based ready queue.
- * @param[in] the_thread is a pointer to the thread
+ * @param[in] the_thread The thread to enqueue.
+ * @param[in] bit_map The priority bit map of the scheduler instance.
 RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue(
-  Thread_Control                  *the_thread
+  Thread_Control           *the_thread,
   Scheduler_priority_Per_thread *sched_info_of_thread =
@@ -79,7 +81,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue(
   Chain_Control *ready_chain = sched_info_of_thread->ready_chain;
   _Chain_Append_unprotected( ready_chain, &the_thread->Object.Node );
-  _Priority_bit_map_Add( &sched_info_of_thread->Priority_map );
+  _Priority_bit_map_Add( bit_map, &sched_info_of_thread->Priority_map );
@@ -89,10 +91,12 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue(
  * For priority-based ready queues, the thread will be the first thread
  * at its priority level.
- * @param[in] the_thread is a pointer to the thread.
 RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue_first(
@@ -100,7 +104,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue_first(
   _Chain_Prepend_unprotected( ready_chain, &the_thread->Object.Node );
@@ -109,10 +113,12 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_enqueue_first(
  * This routine removes a specific thread from the specified
  * priority-based ready queue.
+ * @param[in] the_thread The thread to extract.
 RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_extract(
@@ -121,28 +127,39 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Ready_queue_extract(
   if ( _Chain_Has_only_one_node( ready_chain ) ) {
     _Chain_Initialize_empty( ready_chain );
-    _Priority_bit_map_Remove( &sched_info_of_thread->Priority_map );
+    _Priority_bit_map_Remove( bit_map, &sched_info_of_thread->Priority_map );
   } else {
     _Chain_Extract_unprotected( &the_thread->Object.Node );
+RTEMS_INLINE_ROUTINE void _Scheduler_priority_Extract_body(
+  Scheduler_priority_Control *scheduler = _Scheduler_priority_Instance();
+  _Scheduler_priority_Ready_queue_extract( the_thread, &scheduler->Bit_map );
  * @brief Return a pointer to the first thread.
- * This routines returns a pointer to the first thread on @a the_ready_queue.
+ * This routines returns a pointer to the first thread on @a ready_queues.
- * @param[in] the_ready_queue - pointer to thread queue
+ * @param[in] ready_queues The ready queues of the scheduler instance.
  * @return This method returns the first thread or NULL
 RTEMS_INLINE_ROUTINE Thread_Control *_Scheduler_priority_Ready_queue_first(
-  Chain_Control       *the_ready_queue
+  Chain_Control            *ready_queues
-  Priority_Control index = _Priority_bit_map_Get_highest();
+  Priority_Control index = _Priority_bit_map_Get_highest( bit_map );
-  return (Thread_Control *) _Chain_First( &the_ready_queue[ index ] );
+  return (Thread_Control *) _Chain_First( &ready_queues[ index ] );
@@ -178,8 +195,11 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Schedule_body(
   bool force_dispatch
-  Chain_Control *ready_queues = _Scheduler_priority_Get_ready_queues();
-  Thread_Control *heir = _Scheduler_priority_Ready_queue_first( ready_queues );
+  Thread_Control *heir = _Scheduler_priority_Ready_queue_first(
+    &scheduler->Bit_map,
+    &scheduler->ready[ 0 ]
   ( void ) thread;
@@ -187,8 +207,9 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Schedule_body(
 RTEMS_INLINE_ROUTINE void _Scheduler_priority_Update_body(
-  Thread_Control *thread,
+  Thread_Control           *thread,
@@ -198,6 +219,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_priority_Update_body(
     &ready_queues[ thread->current_priority ];
+    bit_map,
     &sched_info_of_thread->Priority_map,
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index b0e5fad..f30b706 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -66,7 +66,7 @@ extern "C" {
     _Scheduler_priority_Priority_compare, \
     _Scheduler_default_Release_job, \
     _Scheduler_default_Tick, \
-    _Scheduler_SMP_Start_idle \
+    _Scheduler_priority_SMP_Start_idle \
 void _Scheduler_priority_SMP_Initialize( void );
@@ -85,6 +85,11 @@ void _Scheduler_priority_SMP_Extract( Thread_Control *thread );
 void _Scheduler_priority_SMP_Yield( Thread_Control *thread );
+void _Scheduler_priority_SMP_Start_idle(
+  Per_CPU_Control *cpu
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index 1a69358..cf3c261 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -68,7 +68,7 @@ extern "C" {
+    _Scheduler_simple_smp_Start_idle \
 void _Scheduler_simple_smp_Initialize( void );
diff --git a/cpukit/score/include/rtems/score/schedulersmp.h b/cpukit/score/include/rtems/score/schedulersmp.h
index 7107e0e..c7c9b14 100644
--- a/cpukit/score/include/rtems/score/schedulersmp.h
+++ b/cpukit/score/include/rtems/score/schedulersmp.h
@@ -25,6 +25,7 @@
+#include <rtems/score/prioritybitmap.h>
 #ifdef __cplusplus
@@ -44,10 +45,10 @@ typedef struct {
 } Scheduler_SMP_Control;
-void _Scheduler_SMP_Start_idle(
-  Per_CPU_Control *cpu
+typedef struct {
+  Scheduler_SMP_Control    Base;
+} Scheduler_priority_SMP_Control;
diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
index d977b3f..1009b24 100644
--- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
@@ -57,11 +57,6 @@ typedef void ( *Scheduler_SMP_Move )(
   Thread_Control *thread_to_move
-static inline Scheduler_SMP_Control *_Scheduler_SMP_Instance( void )
-  return _Scheduler.information;
 static inline void _Scheduler_SMP_Allocate_processor(
   Thread_Control *scheduled,
   Thread_Control *victim
@@ -262,6 +257,17 @@ static inline void _Scheduler_SMP_Insert_scheduled_fifo(
+static inline void _Scheduler_SMP_Start_idle(
+  Scheduler_SMP_Control *self,
+  thread->is_scheduled = true;
+  _Thread_Set_CPU( thread, cpu );
+  _Chain_Append_unprotected( &self->scheduled, &thread->Object.Node );
 #ifdef __cplusplus
diff --git a/cpukit/score/src/prioritybitmap.c b/cpukit/score/src/prioritybitmap.c
deleted file mode 100644
index d05ede1..0000000
--- a/cpukit/score/src/prioritybitmap.c
+++ /dev/null
@@ -1,27 +0,0 @@
- * @file
- * @brief Priority Bit Map Implementation
- * @ingroup ScorePriorityBitmap
- *  Copyright (C) 2010 Gedare Bloom.
- *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/prioritybitmapimpl.h>
-Priority_bit_map_Word          _Priority_Bit_map[16] CPU_STRUCTURE_ALIGNMENT;
-/* Instantiate any global variables needed by the priority scheduler */
-volatile Priority_bit_map_Word _Priority_Major_bit_map;
diff --git a/cpukit/score/src/schedulerpriority.c b/cpukit/score/src/schedulerpriority.c
index f393f4f..95d4609 100644
--- a/cpukit/score/src/schedulerpriority.c
+++ b/cpukit/score/src/schedulerpriority.c
@@ -23,12 +23,12 @@
 void _Scheduler_priority_Initialize(void)
-  /* allocate ready queue structures */
-  Chain_Control *ready_queues = _Workspace_Allocate_or_fatal_error(
-    ((size_t) PRIORITY_MAXIMUM + 1) * sizeof(Chain_Control)
+  Scheduler_priority_Control *self = _Workspace_Allocate_or_fatal_error(
+    sizeof( *self ) + PRIORITY_MAXIMUM * sizeof( Chain_Control )
-  _Scheduler_priority_Ready_queue_initialize( ready_queues );
+  _Priority_bit_map_Initialize( &self->Bit_map );
+  _Scheduler_priority_Ready_queue_initialize( &self->ready[ 0 ] );
-  _Scheduler.information = ready_queues;
+  _Scheduler.information = self;
diff --git a/cpukit/score/src/schedulerpriorityblock.c b/cpukit/score/src/schedulerpriorityblock.c
index 7d24d17..259d6f0 100644
--- a/cpukit/score/src/schedulerpriorityblock.c
+++ b/cpukit/score/src/schedulerpriorityblock.c
@@ -22,12 +22,10 @@
 #include <rtems/score/schedulerpriorityimpl.h>
-void _Scheduler_priority_Block(
+void _Scheduler_priority_Block( Thread_Control *the_thread )
   _Scheduler_Generic_block(
-    _Scheduler_priority_Ready_queue_extract,
+    _Scheduler_priority_Extract_body,
     _Scheduler_priority_Schedule_body,
     the_thread
diff --git a/cpukit/score/src/schedulerpriorityenqueue.c b/cpukit/score/src/schedulerpriorityenqueue.c
index ff1c69d..c40416f 100644
--- a/cpukit/score/src/schedulerpriorityenqueue.c
+++ b/cpukit/score/src/schedulerpriorityenqueue.c
@@ -24,5 +24,7 @@ void _Scheduler_priority_Enqueue(
-   _Scheduler_priority_Ready_queue_enqueue( the_thread );
+   _Scheduler_priority_Ready_queue_enqueue( the_thread, &scheduler->Bit_map );
diff --git a/cpukit/score/src/schedulerpriorityenqueuefirst.c b/cpukit/score/src/schedulerpriorityenqueuefirst.c
index b9065cc..8de06fa 100644
--- a/cpukit/score/src/schedulerpriorityenqueuefirst.c
+++ b/cpukit/score/src/schedulerpriorityenqueuefirst.c
@@ -24,6 +24,11 @@ void _Scheduler_priority_Enqueue_first(
-  _Scheduler_priority_Ready_queue_enqueue_first( the_thread );
+  _Scheduler_priority_Ready_queue_enqueue_first(
+    the_thread,
diff --git a/cpukit/score/src/schedulerpriorityextract.c b/cpukit/score/src/schedulerpriorityextract.c
index 7e45527..e5888dc 100644
--- a/cpukit/score/src/schedulerpriorityextract.c
+++ b/cpukit/score/src/schedulerpriorityextract.c
@@ -21,9 +21,7 @@
-void _Scheduler_priority_Extract(
+void _Scheduler_priority_Extract( Thread_Control *the_thread )
-  _Scheduler_priority_Ready_queue_extract( the_thread );
+  _Scheduler_priority_Extract_body( the_thread );
diff --git a/cpukit/score/src/schedulerprioritysmp.c b/cpukit/score/src/schedulerprioritysmp.c
index dedd270..7ed4446 100644
--- a/cpukit/score/src/schedulerprioritysmp.c
+++ b/cpukit/score/src/schedulerprioritysmp.c
@@ -29,80 +29,123 @@
 #include <rtems/score/schedulersmpimpl.h>
+static Scheduler_priority_SMP_Control *_Scheduler_priority_SMP_Instance( void )
+static Scheduler_priority_SMP_Control *_Scheduler_priority_SMP_Base_to_self(
+  Scheduler_SMP_Control *base
+  return (Scheduler_priority_SMP_Control *)
+    ( (char *) base - offsetof( Scheduler_priority_SMP_Control, Base ) );
-  Scheduler_SMP_Control *self = _Workspace_Allocate_or_fatal_error(
+  Scheduler_priority_SMP_Control *self = _Workspace_Allocate_or_fatal_error(
-  _Chain_Initialize_empty( &self->scheduled );
-  _Scheduler_priority_Ready_queue_initialize( &self->ready[ 0 ] );
+  _Chain_Initialize_empty( &self->Base.scheduled );
+  _Scheduler_priority_Ready_queue_initialize( &self->Base.ready[ 0 ] );
 void _Scheduler_priority_SMP_Update( Thread_Control *thread )
-  Scheduler_SMP_Control *self = _Scheduler_SMP_Instance();
+  Scheduler_priority_SMP_Control *self = _Scheduler_priority_SMP_Instance();
-  _Scheduler_priority_Update_body( thread, &self->ready[ 0 ] );
+  _Scheduler_priority_Update_body(
+    thread,
+    &self->Bit_map,
+    &self->Base.ready[ 0 ]
 static Thread_Control *_Scheduler_priority_SMP_Get_highest_ready(
+    _Scheduler_priority_SMP_Base_to_self( base );
   Thread_Control *highest_ready = NULL;
-  if ( !_Priority_bit_map_Is_empty() ) {
-    highest_ready = _Scheduler_priority_Ready_queue_first( &self->ready[ 0 ] );
+  if ( !_Priority_bit_map_Is_empty( &self->Bit_map ) ) {
+    highest_ready = _Scheduler_priority_Ready_queue_first(
+      &self->Bit_map,
   return highest_ready;
 static void _Scheduler_priority_SMP_Move_from_scheduled_to_ready(
-  Scheduler_SMP_Control *self,
+  Scheduler_SMP_Control *base,
   Thread_Control *scheduled_to_ready
   _Chain_Extract_unprotected( &scheduled_to_ready->Object.Node );
-  _Scheduler_priority_Ready_queue_enqueue_first( scheduled_to_ready );
+    scheduled_to_ready,
+    &self->Bit_map
 static void _Scheduler_priority_SMP_Move_from_ready_to_scheduled(
   Thread_Control *ready_to_scheduled
-  _Scheduler_priority_Ready_queue_extract( ready_to_scheduled );
+    ready_to_scheduled,
+    &self->Bit_map
   _Scheduler_simple_Insert_priority_fifo(
-    &self->scheduled,
+    &self->Base.scheduled,
     ready_to_scheduled
 static void _Scheduler_priority_SMP_Insert_ready_lifo(
-  _Scheduler_priority_Ready_queue_enqueue( thread );
+  _Scheduler_priority_Ready_queue_enqueue( thread, &self->Bit_map );
 static void _Scheduler_priority_SMP_Insert_ready_fifo(
-  _Scheduler_priority_Ready_queue_enqueue_first( thread );
+  _Scheduler_priority_Ready_queue_enqueue_first( thread, &self->Bit_map );
 static void _Scheduler_priority_SMP_Do_extract(
   bool is_scheduled = thread->is_scheduled;
   ( void ) self;
@@ -113,16 +156,16 @@ static void _Scheduler_priority_SMP_Do_extract(
   if ( is_scheduled ) {
     _Chain_Extract_unprotected( &thread->Object.Node );
   } else {
-    _Scheduler_priority_Ready_queue_extract( thread );
+    _Scheduler_priority_Ready_queue_extract( thread, &self->Bit_map );
 void _Scheduler_priority_SMP_Block( Thread_Control *thread )
   _Scheduler_SMP_Block(
-    self,
+    &self->Base,
     thread,
     _Scheduler_priority_SMP_Do_extract,
     _Scheduler_priority_SMP_Get_highest_ready,
@@ -152,10 +195,10 @@ static void _Scheduler_priority_SMP_Enqueue_ordered(
 void _Scheduler_priority_SMP_Enqueue_lifo( Thread_Control *thread )
-    self,
+    &self->Base,
     thread,
     _Scheduler_simple_Insert_priority_lifo_order,
     _Scheduler_priority_SMP_Insert_ready_lifo,
@@ -165,10 +208,10 @@ void _Scheduler_priority_SMP_Enqueue_lifo( Thread_Control *thread )
 void _Scheduler_priority_SMP_Enqueue_fifo( Thread_Control *thread )
-    self,
+    &self->Base,
     thread,
     _Scheduler_simple_Insert_priority_fifo_order,
     _Scheduler_priority_SMP_Insert_ready_fifo,
@@ -178,10 +221,10 @@ void _Scheduler_priority_SMP_Enqueue_fifo( Thread_Control *thread )
   _Scheduler_SMP_Extract(
-    self,
+    &self->Base,
     thread,
@@ -201,12 +244,22 @@ void _Scheduler_priority_SMP_Yield( Thread_Control *thread )
 void _Scheduler_priority_SMP_Schedule( Thread_Control *thread )
   _Scheduler_SMP_Schedule(
-    self,
+    &self->Base,
     thread,
+  _Scheduler_SMP_Start_idle( &self->Base, thread, cpu );
diff --git a/cpukit/score/src/schedulerpriorityunblock.c b/cpukit/score/src/schedulerpriorityunblock.c
index ad26820..f69c1e2 100644
--- a/cpukit/score/src/schedulerpriorityunblock.c
+++ b/cpukit/score/src/schedulerpriorityunblock.c
@@ -26,7 +26,9 @@ void _Scheduler_priority_Unblock (
-  _Scheduler_priority_Ready_queue_enqueue(the_thread);
   /* TODO: flash critical section? */
diff --git a/cpukit/score/src/schedulerpriorityupdate.c b/cpukit/score/src/schedulerpriorityupdate.c
index 8ebaac7..b3b898f 100644
--- a/cpukit/score/src/schedulerpriorityupdate.c
+++ b/cpukit/score/src/schedulerpriorityupdate.c
@@ -25,7 +25,11 @@ void _Scheduler_priority_Update(
-  _Scheduler_priority_Update_body( the_thread, ready_queues );
+    the_thread,
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index f4a20c1..08e2b2d 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -22,6 +22,11 @@
+static Scheduler_SMP_Control *_Scheduler_simple_SMP_Instance( void )
@@ -110,7 +115,7 @@ static void _Scheduler_simple_smp_Do_extract(
 void _Scheduler_simple_smp_Block( Thread_Control *thread )
+  Scheduler_SMP_Control *self = _Scheduler_simple_SMP_Instance();
     self,
@@ -143,7 +148,7 @@ static void _Scheduler_simple_smp_Enqueue_ordered(
 void _Scheduler_simple_smp_Enqueue_priority_lifo( Thread_Control *thread )
     self,
@@ -156,7 +161,7 @@ void _Scheduler_simple_smp_Enqueue_priority_lifo( Thread_Control *thread )
 void _Scheduler_simple_smp_Enqueue_priority_fifo( Thread_Control *thread )
     self,
@@ -169,7 +174,7 @@ void _Scheduler_simple_smp_Enqueue_priority_fifo( Thread_Control *thread )
 void _Scheduler_simple_smp_Extract( Thread_Control *thread )
     self,
@@ -192,7 +197,7 @@ void _Scheduler_simple_smp_Yield( Thread_Control *thread )
 void _Scheduler_simple_smp_Schedule( Thread_Control *thread )
     self,
@@ -201,3 +206,13 @@ void _Scheduler_simple_smp_Schedule( Thread_Control *thread )
     _Scheduler_simple_smp_Move_from_ready_to_scheduled
+void _Scheduler_simple_smp_Start_idle(
+  _Scheduler_SMP_Start_idle( self, thread, cpu );
diff --git a/cpukit/score/src/schedulersmpstartidle.c b/cpukit/score/src/schedulersmpstartidle.c
index 75d1c8f..0000000
--- a/cpukit/score/src/schedulersmpstartidle.c
+++ /dev/null
@@ -1,40 +0,0 @@
- * @file
- * @brief SMP Scheduler Start Idle Operation
- * @ingroup ScoreSchedulerSMP
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
-#if HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <rtems/score/schedulersmpimpl.h>
-#include <rtems/score/chainimpl.h>
-  thread->is_scheduled = true;
-  _Thread_Set_CPU( thread, cpu );
-  _Chain_Append_unprotected( &self->scheduled, &thread->Object.Node );
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index 3dff3d3..f24bc9b 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -85,9 +85,7 @@ void print_formula(void);
 #include <rtems/score/schedulerpriority.h>
 /* Priority scheduling uninitialized (globals) consumption */
-#define SCHEDULER_OVHD     ((sizeof _Scheduler)              + \
-                           (sizeof _Priority_Major_bit_map) + \
-                           (sizeof _Priority_Bit_map))
+#define SCHEDULER_OVHD      (sizeof _Scheduler)
 /* Priority scheduling per-thread consumption. Gets
  * included in the PER_TASK consumption.
@@ -100,7 +98,8 @@ void print_formula(void);
  * including _Scheduler in SCHEDULER_OVHD.
 #define SCHEDULER_WKSP_SIZE  \
-    ((RTEMS_MAXIMUM_PRIORITY + 1) * sizeof(Chain_Control ))
+    (sizeof(Scheduler_priority_Control) + \
+     RTEMS_MAXIMUM_PRIORITY * sizeof(Chain_Control ))
 /****** END OF MEMORY USAGE OF DEFAULT PRIORITY SCHEDULER ******/
 #define PER_TASK      \
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index f6cdddf..416403d 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -19,6 +19,7 @@
 #include <tmacros.h>
 #include <timesys.h>
+#include <rtems/score/schedulerpriorityimpl.h>
 #if defined( RTEMS_SMP ) && defined( RTEMS_DEBUG )
@@ -370,7 +371,7 @@ rtems_task Middle_task(
   rtems_task_argument argument
-  Chain_Control   *ready_queues;
   thread_dispatch_no_fp_time = benchmark_timer_read();
@@ -378,9 +379,8 @@ rtems_task Middle_task(
   Middle_tcb   = _Thread_Get_executing();
-  ready_queues      = (Chain_Control *) _Scheduler.information;
   set_thread_executing(
-    (Thread_Control *) _Chain_First(&ready_queues[LOW_PRIORITY])
+    (Thread_Control *) _Chain_First(&scheduler->ready[LOW_PRIORITY])
   /* do not force context switch */
@@ -403,10 +403,8 @@ rtems_task Low_task(
-  Thread_Control *executing;
+  Thread_Control             *executing;
   context_switch_no_fp_time = benchmark_timer_read();
@@ -424,7 +422,7 @@ rtems_task Low_task(
   context_switch_another_task_time = benchmark_timer_read();
-    (Thread_Control *) _Chain_First(&ready_queues[FP1_PRIORITY])
+    (Thread_Control *) _Chain_First(&scheduler->ready[FP1_PRIORITY])
@@ -447,17 +445,16 @@ rtems_task Floating_point_task_1(
   FP_DECLARE;
   context_switch_restore_1st_fp_time = benchmark_timer_read();
   executing = _Thread_Get_executing();
-    (Thread_Control *) _Chain_First(&ready_queues[FP2_PRIORITY])
+    (Thread_Control *) _Chain_First(&scheduler->ready[FP2_PRIORITY])
@@ -483,9 +480,8 @@ rtems_task Floating_point_task_1(
   benchmark_timer_initialize();
@@ -504,17 +500,16 @@ rtems_task Floating_point_task_2(
   FP_DECLARE;
   context_switch_save_restore_idle_time = benchmark_timer_read();
   FP_LOAD( 1.0 );
diff --git a/testsuites/tmtests/tm27/task1.c b/testsuites/tmtests/tm27/task1.c
index 0062a73..13c3858 100644
--- a/testsuites/tmtests/tm27/task1.c
+++ b/testsuites/tmtests/tm27/task1.c
@@ -20,6 +20,7 @@
 #define CONFIGURE_INIT
 #include "system.h"
 #include <bsp.h>
 #define _RTEMS_TMTEST27
@@ -101,10 +102,10 @@ rtems_task Task_1(
 #if defined(RTEMS_SMP)
   rtems_interrupt_level level;
 #endif
   Install_tm27_vector( Isr_handler );
@@ -185,9 +186,8 @@ rtems_task Task_1(
   _ISR_Disable_without_giant(level);
 #endif
   _Thread_Executing =
-        (Thread_Control *) _Chain_First(&ready_queues[LOW_PRIORITY]);
+        (Thread_Control *) _Chain_First(&scheduler->ready[LOW_PRIORITY]);
   _Thread_Dispatch_necessary = 1;
@@ -219,10 +219,10 @@ rtems_task Task_2(
 #endif
 #if (MUST_WAIT_FOR_INTERRUPT == 1)
   while ( Interrupt_occurred == 0 );
@@ -255,9 +255,8 @@ rtems_task Task_2(
   rtems_interrupt_disable(level);
 #endif
   _Thread_Executing =
1.7.7
