mrfs_fstime failure
Tue Apr 1 22:03:53 UTC 2014
On 2/04/2014 6:44 am, Joel Sherrill wrote:
> Hi
> I think this is a long standing failure.
> *** BEGIN OF TEST FSTIME RFS ***
> Initializing filesystem RFS
> Sleep a few seconds
> ../../../../../../../rtems/c/src/../../testsuites/fstests/mrfs_fstime/../fstime/test.c:
> 131 st.st_ctime == st.st_mtime
> When I break at end of stat, I see this.
> (gdb) p *buf
> $1 = {st_dev = 34401048, st_ino = 2, st_mode = 16877, st_nlink = 1,
> st_uid = 0, st_gid = 0, st_rdev = 0, st_size = 512, st_atim = {
>      tv_sec = 567993600, tv_nsec = 0}, st_mtim = {tv_sec = 567993600,
> tv_nsec = 0}, st_ctim = {tv_sec = 567993606, tv_nsec = 0},
>    st_blksize = 512, st_blocks = 1}
> Something is happening in test.c with gdb and I can't print the stat buf.
> Any ideas? Since this is a generic failure, it would be good to
> eliminate it.
It is specific to the RFS as far as I know. The code in the test says ...
    * If O_CREAT is set and the file did not previously exist, upon
    * successful completion, open() shall mark for update the st_atime,
    * st_ctime, and st_mtime fields of the file and the st_ctime and
    * st_mtime fields of the parent directory.
Does this apply to the creation of any node in the file system ?
