mrfs_fstime failure
Thu Apr 3 01:26:01 UTC 2014
On 3/04/2014 7:19 am, Joel Sherrill wrote:
> On 4/1/2014 5:03 PM, Chris Johns wrote:
>> On 2/04/2014 6:44 am, Joel Sherrill wrote:
>>> Hi
>>> I think this is a long standing failure.
>>> *** BEGIN OF TEST FSTIME RFS ***
>>> Initializing filesystem RFS
>>> Sleep a few seconds
>>> ../../../../../../../rtems/c/src/../../testsuites/fstests/mrfs_fstime/../fstime/test.c:
>>> 131 st.st_ctime == st.st_mtime
>>> When I break at end of stat, I see this.
>>> (gdb) p *buf
>>> $1 = {st_dev = 34401048, st_ino = 2, st_mode = 16877, st_nlink = 1,
>>> st_uid = 0, st_gid = 0, st_rdev = 0, st_size = 512, st_atim = {
>>>       tv_sec = 567993600, tv_nsec = 0}, st_mtim = {tv_sec = 567993600,
>>> tv_nsec = 0}, st_ctim = {tv_sec = 567993606, tv_nsec = 0},
>>>     st_blksize = 512, st_blocks = 1}
>>> Something is happening in test.c with gdb and I can't print the stat buf.
>>> Any ideas? Since this is a generic failure, it would be good to
>>> eliminate it.
>> It is specific to the RFS as far as I know. The code in the test says ...
>>      * If O_CREAT is set and the file did not previously exist, upon
>>      * successful completion, open() shall mark for update the st_atime,
>>      * st_ctime, and st_mtime fields of the file and the st_ctime and
>>      * st_mtime fields of the parent directory.
>> Does this apply to the creation of any node in the file system ?
> We would have to find the place in the POSIX standard. This statements
> like it is
> from http://pubs.opengroup.org/onlinepubs/009695399/functions/fopen.html.
> This would imply to me that it should but can the FAT filesystem support
> this?
No idea.
> Are you hinting that it is generic code which should be in the system
> call layer?
No, just wondering where I should look to make the change in the RFS.
