[PATCH 1/5] score: Delete _Thread_Maximum_extensions
Sebastian Huber
Fri Apr 4 15:07:37 UTC 2014
Use the Configuration instead. Fix an off-by-one error in the
allocation and initialization.
cpukit/sapi/include/confdefs.h | 2 +-
cpukit/score/include/rtems/score/threadimpl.h | 7 -------
cpukit/score/src/thread.c | 4 ----
cpukit/score/src/threadinitialize.c | 10 ++++------
testsuites/sptests/spsize/size.c | 1 -
5 files changed, 5 insertions(+), 19 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 4bfe4e8..1ee3b21 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2080,7 +2080,7 @@ const rtems_libio_helper rtems_fs_init_helper =
+ CONFIGURE_MEMORY_PER_TASK_FOR_POSIX_API \
+ CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER \
+ _Configure_From_workspace( \
- (CONFIGURE_MAXIMUM_USER_EXTENSIONS + 1) * sizeof(void *) \
+ CONFIGURE_MAXIMUM_USER_EXTENSIONS * sizeof(void *) \
+ _Configure_Max_Objects(_number_FP_tasks) \
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 6d4ca9f..f109d39 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -58,13 +58,6 @@ SCORE_EXTERN void *rtems_ada_self;
SCORE_EXTERN Objects_Information _Thread_Internal_information;
- * The following holds how many user extensions are in the system. This
- * is used to determine how many user extension data areas to allocate
- * per thread.
-SCORE_EXTERN uint32_t _Thread_Maximum_extensions;
* The following is used to manage the length of a timeslice quantum.
SCORE_EXTERN uint32_t _Thread_Ticks_per_timeslice;
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index 5063c78..589e474 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -25,8 +25,6 @@ void _Thread_Handler_initialization(void)
uint32_t ticks_per_timeslice =
rtems_configuration_get_ticks_per_timeslice();
- uint32_t maximum_extensions =
- rtems_configuration_get_maximum_extensions();
rtems_stack_allocate_init_hook stack_allocate_init_hook =
rtems_configuration_get_stack_allocate_init_hook();
#if defined(RTEMS_MULTIPROCESSING)
@@ -52,8 +50,6 @@ void _Thread_Handler_initialization(void)
_Thread_Allocated_fp = NULL;
#endif
- _Thread_Maximum_extensions = maximum_extensions;
_Thread_Ticks_per_timeslice = ticks_per_timeslice;
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index cf96c24..490fc25 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -155,9 +155,9 @@ bool _Thread_Initialize(
* Allocate the extensions area for this thread
- if ( _Thread_Maximum_extensions ) {
+ if ( rtems_configuration_get_maximum_extensions() ) {
extensions_area = _Workspace_Allocate(
- (_Thread_Maximum_extensions + 1) * sizeof( void * )
+ rtems_configuration_get_maximum_extensions() * sizeof( void * )
if ( !extensions_area )
goto failed;
@@ -171,10 +171,8 @@ bool _Thread_Initialize(
* so they cannot rely on the thread create user extension
* call.
- if ( the_thread->extensions ) {
- for ( i = 0; i <= _Thread_Maximum_extensions ; i++ )
- the_thread->extensions[i] = NULL;
+ for ( i = 0 ; i < rtems_configuration_get_maximum_extensions() ; i++ )
+ the_thread->extensions[i] = NULL;
* General initialization
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index f24bc9b..1d4c96b 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -385,7 +385,6 @@ uninitialized =
/*tasksimpl.h*/ (sizeof _RTEMS_tasks_Information) +
/*thread.h*/ (sizeof _Thread_Dispatch_disable_level) +
- (sizeof _Thread_Maximum_extensions) +
(sizeof _Thread_Ticks_per_timeslice) +
(sizeof _Thread_Executing) +
(sizeof _Thread_Heir) +
1.7.7
