[PATCH 3/5] score: Use const scheduler operations
Fri Apr 4 15:07:39 UTC 2014
This helps to hide implementation details of the scheduler from the
application configuration.  The scheduler operations table is now
read-only and thus can reside in flash memory.  The run-time overhead
due to this indirection is negligible.  On SMP configurations with
clustered/partitioned scheduling this reduces also the memory overhead.
 cpukit/sapi/include/confdefs.h                     |   18 +-
 cpukit/score/Makefile.am                           |    6 +
 cpukit/score/include/rtems/score/scheduler.h       |  216 +----------------
 cpukit/score/include/rtems/score/schedulercbs.h    |  239 +------------------
 .../score/include/rtems/score/schedulercbsimpl.h   |  246 +++++++++++++++++++
 cpukit/score/include/rtems/score/scheduleredf.h    |  202 +----------------
 .../score/include/rtems/score/scheduleredfimpl.h   |  177 ++++++++++++++
 cpukit/score/include/rtems/score/schedulerimpl.h   |  252 ++++++++++++++++++--
 .../score/include/rtems/score/schedulerpriority.h  |  189 +---------------
 .../rtems/score/schedulerpriorityaffinitysmp.h     |   74 +------
 .../include/rtems/score/schedulerpriorityimpl.h    |  158 ++++++++++++
 .../include/rtems/score/schedulerprioritysmp.h     |   76 +------
 .../include/rtems/score/schedulerprioritysmpimpl.h |   87 +++++++
 cpukit/score/include/rtems/score/schedulersimple.h |  157 +------------
 .../include/rtems/score/schedulersimpleimpl.h      |  133 ++++++++++
 .../score/include/rtems/score/schedulersimplesmp.h |   65 +-----
 cpukit/score/include/rtems/score/schedulersmp.h    |   15 +-
 cpukit/score/preinstall.am                         |    8 +
 cpukit/score/src/scheduler.c                       |    2 +-
 cpukit/score/src/schedulercbs.c                    |    2 +-
 cpukit/score/src/schedulercbsallocate.c            |    6 +-
 cpukit/score/src/schedulercbsattachthread.c        |    2 +-
 cpukit/score/src/schedulercbscleanup.c             |    2 +-
 cpukit/score/src/schedulercbscreateserver.c        |    2 +-
 cpukit/score/src/schedulercbsdestroyserver.c       |    2 +-
 cpukit/score/src/schedulercbsdetachthread.c        |    2 +-
 cpukit/score/src/schedulercbsgetapprovedbudget.c   |    5 +-
 cpukit/score/src/schedulercbsgetexecutiontime.c    |    2 +-
 cpukit/score/src/schedulercbsgetparameters.c       |    5 +-
 cpukit/score/src/schedulercbsgetremainingbudget.c  |    2 +-
 cpukit/score/src/schedulercbsgetserverid.c         |    5 +-
 cpukit/score/src/schedulercbsops.c                 |   38 +++
 cpukit/score/src/schedulercbssetparameters.c       |    5 +-
 cpukit/score/src/schedulercbsunblock.c             |    4 +-
 cpukit/score/src/schedulerdefaultallocatefree.c    |    2 +-
 cpukit/score/src/schedulerdefaultreleasejob.c      |    2 +-
 cpukit/score/src/schedulerdefaultupdate.c          |    2 +-
 cpukit/score/src/scheduleredf.c                    |    4 +-
 cpukit/score/src/scheduleredfallocate.c            |    5 +-
 cpukit/score/src/scheduleredfenqueuefirst.c        |    4 +-
 cpukit/score/src/scheduleredffree.c                |    5 +-
 cpukit/score/src/scheduleredfops.c                 |   38 +++
 cpukit/score/src/scheduleredfprioritycompare.c     |    4 +-
 cpukit/score/src/scheduleredfreleasejob.c          |    2 +-
 cpukit/score/src/scheduleredfunblock.c             |    3 +-
 cpukit/score/src/scheduleredfupdate.c              |    7 +-
 cpukit/score/src/schedulerpriorityaffinitysmp.c    |   34 ++-
 cpukit/score/src/schedulerpriorityallocate.c       |    3 +-
 cpukit/score/src/schedulerpriorityops.c            |   38 +++
 cpukit/score/src/schedulerprioritysmp.c            |   20 ++
 cpukit/score/src/schedulersimple.c                 |    2 +-
 cpukit/score/src/schedulersimpleenqueue.c          |    6 +-
 cpukit/score/src/schedulersimpleenqueuefirst.c     |    5 +-
 cpukit/score/src/schedulersimpleextract.c          |    3 +-
 cpukit/score/src/schedulersimpleops.c              |   39 +++
 cpukit/score/src/schedulersimplesmp.c              |   80 ++++---
 cpukit/score/src/schedulersimpleunblock.c          |    5 +-
 testsuites/rhealstone/rhilatency/ilatency.c        |    2 +-
 testsuites/sptests/spinternalerror01/init.c        |    2 +-
 testsuites/tmtests/tm26/task1.c                    |    2 +-
 testsuites/tmtests/tm27/task1.c                    |    2 +-
 61 files changed, 1372 insertions(+), 1353 deletions(-)
 create mode 100644 cpukit/score/include/rtems/score/schedulercbsimpl.h
 create mode 100644 cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
 create mode 100644 cpukit/score/src/schedulercbsops.c
 create mode 100644 cpukit/score/src/scheduleredfops.c
 create mode 100644 cpukit/score/src/schedulerpriorityops.c
 create mode 100644 cpukit/score/src/schedulersimpleops.c
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 1ee3b21..2a94654 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -640,7 +640,7 @@ const rtems_libio_helper rtems_fs_init_helper =
  * An application can define its own scheduling policy by defining
  * CONFIGURE_SCHEDULER_USER and the following:
- *    - CONFIGURE_SCHEDULER_ENTRY_POINTS
+ *    - CONFIGURE_SCHEDULER_OPERATIONS
  *    - CONFIGURE_MEMORY_FOR_SCHEDULER - base memory
  *    - CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER - per task memory
@@ -671,7 +671,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if defined(CONFIGURE_SCHEDULER_PRIORITY)
   #include <rtems/score/schedulerpriority.h>
-  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_PRIORITY_ENTRY_POINTS
+  #define CONFIGURE_SCHEDULER_OPERATIONS &_Scheduler_priority_Operations
    * This defines the memory used by the priority scheduler.
@@ -691,7 +691,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if defined(CONFIGURE_SCHEDULER_PRIORITY_SMP)
   #include <rtems/score/schedulerprioritysmp.h>
-  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_PRIORITY_SMP_ENTRY_POINTS
+  #define CONFIGURE_SCHEDULER_OPERATIONS &_Scheduler_priority_SMP_Operations
@@ -711,7 +711,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP)
   #include <rtems/score/schedulerpriorityaffinitysmp.h>
-  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS
+  #define CONFIGURE_SCHEDULER_OPERATIONS &_Scheduler_priority_affinity_SMP_Operations
@@ -730,7 +730,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if defined(CONFIGURE_SCHEDULER_SIMPLE)
   #include <rtems/score/schedulersimple.h>
-  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_SIMPLE_ENTRY_POINTS
+  #define CONFIGURE_SCHEDULER_OPERATIONS &_Scheduler_simple_Operations
    * define the memory used by the simple scheduler
@@ -746,7 +746,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if defined(CONFIGURE_SCHEDULER_SIMPLE_SMP)
   #include <rtems/score/schedulersimplesmp.h>
-  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_SIMPLE_SMP_ENTRY_POINTS
+  #define CONFIGURE_SCHEDULER_OPERATIONS &_Scheduler_simple_SMP_Operations
    * Define the memory used by the Simple SMP Scheduler
@@ -764,7 +764,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if defined(CONFIGURE_SCHEDULER_EDF)
   #include <rtems/score/scheduleredf.h>
-  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_EDF_ENTRY_POINTS
+  #define CONFIGURE_SCHEDULER_OPERATIONS &_Scheduler_EDF_Operations
    * define the memory used by the EDF scheduler
@@ -780,7 +780,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #if defined(CONFIGURE_SCHEDULER_CBS)
   #include <rtems/score/schedulercbs.h>
-  #define CONFIGURE_SCHEDULER_ENTRY_POINTS SCHEDULER_CBS_ENTRY_POINTS
+  #define CONFIGURE_SCHEDULER_OPERATIONS &_Scheduler_CBS_Operations
   #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
     #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS
@@ -810,7 +810,7 @@ const rtems_libio_helper rtems_fs_init_helper =
 #ifdef CONFIGURE_INIT
   Scheduler_Control  _Scheduler = {
     NULL,                             /* Scheduler Specific Data Pointer */
-    CONFIGURE_SCHEDULER_ENTRY_POINTS  /* Scheduler Operations */
+    CONFIGURE_SCHEDULER_OPERATIONS    /* Scheduler Operations */
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 07cb520..9db4295 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -52,11 +52,13 @@ include_rtems_score_HEADERS += include/rtems/score/rbtreeimpl.h
 include_rtems_score_HEADERS += include/rtems/score/scheduler.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulercbs.h
+include_rtems_score_HEADERS += include/rtems/score/schedulercbsimpl.h
 include_rtems_score_HEADERS += include/rtems/score/scheduleredf.h
 include_rtems_score_HEADERS += include/rtems/score/scheduleredfimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerpriority.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerpriorityimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulerprioritysmp.h
+include_rtems_score_HEADERS += include/rtems/score/schedulerprioritysmpimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulersimple.h
 include_rtems_score_HEADERS += include/rtems/score/schedulersimpleimpl.h
 include_rtems_score_HEADERS += include/rtems/score/schedulersmp.h
@@ -209,6 +211,7 @@ libscore_a_SOURCES += src/schedulerpriority.c \
     src/schedulerpriorityenqueuefirst.c \
     src/schedulerpriorityextract.c \
     src/schedulerpriorityfree.c \
+    src/schedulerpriorityops.c \
     src/schedulerpriorityprioritycompare.c \
     src/schedulerpriorityschedule.c \
     src/schedulerpriorityunblock.c \
@@ -224,6 +227,7 @@ libscore_a_SOURCES += src/schedulersimple.c \
     src/schedulersimplereadyqueueenqueue.c \
     src/schedulersimplereadyqueueenqueuefirst.c \
     src/schedulersimpleschedule.c \
+    src/schedulersimpleops.c \
     src/schedulersimpleunblock.c \
     src/schedulersimpleyield.c
@@ -235,6 +239,7 @@ libscore_a_SOURCES += src/scheduleredf.c \
     src/scheduleredfenqueuefirst.c \
     src/scheduleredfextract.c \
     src/scheduleredffree.c \
+    src/scheduleredfops.c \
     src/scheduleredfprioritycompare.c \
     src/scheduleredfreleasejob.c \
     src/scheduleredfschedule.c \
@@ -255,6 +260,7 @@ libscore_a_SOURCES += src/schedulercbs.c \
     src/schedulercbsgetparameters.c \
     src/schedulercbsgetremainingbudget.c \
     src/schedulercbsgetserverid.c \
+    src/schedulercbsops.c \
     src/schedulercbssetparameters.c \
     src/schedulercbsreleasejob.c \
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index b975fc4..e16bab6 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -19,12 +19,7 @@
 #ifndef _RTEMS_SCORE_SCHEDULER_H
 #define _RTEMS_SCORE_SCHEDULER_H
-#include <rtems/score/percpu.h>
-#include <rtems/score/chain.h>
-#include <rtems/score/priority.h>
-#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) && defined(RTEMS_SMP)
-  #include <sys/cpuset.h>
-#endif
+#include <stdbool.h>
 #ifdef __cplusplus
 extern "C" {
@@ -40,103 +35,11 @@ extern "C" {
-typedef struct Scheduler_Control Scheduler_Control;
- * function jump table that holds pointers to the functions that
- * implement specific schedulers.
-typedef struct {
-  /** Implements the scheduling decision logic (policy). */
-  void ( *initialize )(void);
-  void ( *schedule )( Scheduler_Control *, Thread_Control *);
-   * @brief Voluntarily yields the processor per the scheduling policy.
-   * @see _Scheduler_Yield().
-  void ( *yield )( Scheduler_Control *, Thread_Control *);
-  /** Removes the given thread from scheduling decisions. */
-  void ( *block )( Scheduler_Control *, Thread_Control * );
-  /** Adds the given thread to scheduling decisions. */
-  void ( *unblock )( Scheduler_Control *, Thread_Control * );
-  /** allocates the scheduler field of the given thread */
-  void * ( *allocate )( Scheduler_Control *, Thread_Control * );
-  /** frees the scheduler field of the given thread */
-  void ( *free )( Scheduler_Control *, Thread_Control * );
-  /** updates the scheduler field of the given thread -- primarily used
-   * when changing the thread's priority. */
-  void ( *update )( Scheduler_Control *, Thread_Control * );
-  /** enqueue a thread as the last of its priority group */
-  void ( *enqueue )( Scheduler_Control *, Thread_Control * );
-  /** enqueue a thread as the first of its priority group */
-  void ( *enqueue_first )( Scheduler_Control *, Thread_Control * );
+/* Allow forward declarations */
-  /** extract a thread from the ready set */
-  void ( *extract )( Scheduler_Control *, Thread_Control * );
-   * Compares two priorities (returns >0 for higher priority, 0 for equal
-   * and <0 for lower priority).
-  int ( *priority_compare )(
-    Priority_Control,
-    Priority_Control
-  /** This routine is called upon release of a new job. */
-  void ( *release_job ) ( Scheduler_Control *, Thread_Control *, uint32_t );
-  /** perform scheduler update actions required at each clock tick */
-  void ( *tick )( Scheduler_Control * );
-   * @brief Starts the idle thread for a particular processor.
-   * @see _Scheduler_Start_idle().
-  void ( *start_idle )(
-    Scheduler_Control *,
-    Thread_Control *,
-    Per_CPU_Control *
+typedef struct Scheduler_Control Scheduler_Control;
-   * @brief Obtain the processor affinity for a thread.
-   * @see _Scheduler_Get_affinity().
-  bool ( *get_affinity )(
-    Thread_Control *,
-    size_t,
-    cpu_set_t *
-   * @brief Set the processor affinity for a thread.
-   * @see _Scheduler_Set_affinity().
-  bool ( *set_affinity )(
-    Thread_Control *,
-    size_t,
-    const cpu_set_t *
-#endif
-} Scheduler_Operations;
+typedef struct Scheduler_Operations Scheduler_Operations;
  * This is the structure used to manage the scheduler.
@@ -150,7 +53,7 @@ struct Scheduler_Control {
   void                   *information;
   /** The jump table for scheduler-specific functions */
-  Scheduler_Operations    Operations;
+  const Scheduler_Operations *operations;
@@ -163,115 +66,6 @@ struct Scheduler_Control {
 extern Scheduler_Control  _Scheduler;
- * @brief Returns an arbitrary non-NULL value.
- * @param[in] scheduler Unused.
- * @param[in] the_thread Unused.
- * @return An arbitrary non-NULL value.
-void *_Scheduler_default_Allocate(
-  Scheduler_Control *scheduler,
-  Thread_Control    *the_thread
- * @brief Does nothing.
-void _Scheduler_default_Free(
-void _Scheduler_default_Update(
- * @param[in] deadline Unused.
-void _Scheduler_default_Release_job(
-  Thread_Control    *the_thread,
-  uint32_t           deadline
- * @brief Performs tick operations depending on the CPU budget algorithm for
- * each executing thread.
- * This routine is invoked as part of processing each clock tick.
- * @param[in] scheduler The scheduler.
-void _Scheduler_default_Tick( Scheduler_Control *scheduler );
- * @brief Starts an idle thread.
- * @param[in] the_thread An idle thread.
- * @param[in] cpu This parameter is unused.
-void _Scheduler_default_Start_idle(
-  Per_CPU_Control   *cpu
-   * @brief Get affinity for the default scheduler.
-   * @param[in] thread The associated thread.
-   * @param[in] cpusetsize The size of the cpuset.
-   * @param[out] cpuset Affinity set containing all CPUs.
-   * @retval 0 Successfully got cpuset
-   * @retval -1 The cpusetsize is invalid for the system
-  bool _Scheduler_default_Get_affinity(
-    Thread_Control    *thread,
-    size_t             cpusetsize,
-    cpu_set_t         *cpuset
-   * @brief Set affinity for the default scheduler.
-   * @param[in] cpuset Affinity new affinity set.
-   *  This method always returns successful and does not save
-   *  the cpuset.
-  bool _Scheduler_default_Set_affinity(
-    const cpu_set_t   *cpuset
-#endif
  * See also PR2174: Memory corruption with EDF scheduler and thread priority
  * queues.
diff --git a/cpukit/score/include/rtems/score/schedulercbs.h b/cpukit/score/include/rtems/score/schedulercbs.h
index f654225..8217d55 100644
--- a/cpukit/score/include/rtems/score/schedulercbs.h
+++ b/cpukit/score/include/rtems/score/schedulercbs.h
@@ -39,31 +39,6 @@ extern "C" {
- *  Entry points for the Constant Bandwidth Server Scheduler.
- *  @note: The CBS scheduler is an enhancement of EDF scheduler,
- *         therefor some routines are similar.
-#define SCHEDULER_CBS_ENTRY_POINTS \
-    _Scheduler_EDF_Initialize,       /* initialize entry point */ \
-    _Scheduler_EDF_Schedule,         /* schedule entry point */ \
-    _Scheduler_EDF_Yield,            /* yield entry point */ \
-    _Scheduler_EDF_Block,            /* block entry point */ \
-    _Scheduler_CBS_Unblock,          /* unblock entry point */ \
-    _Scheduler_CBS_Allocate,         /* allocate entry point */ \
-    _Scheduler_EDF_Free,             /* free entry point */ \
-    _Scheduler_EDF_Update,           /* update entry point */ \
-    _Scheduler_EDF_Enqueue,          /* enqueue entry point */ \
-    _Scheduler_EDF_Enqueue_first,    /* enqueue_first entry point */ \
-    _Scheduler_EDF_Extract,          /* extract entry point */ \
-    _Scheduler_EDF_Priority_compare, /* compares two priorities */ \
-    _Scheduler_CBS_Release_job,      /* new period of task */ \
-    _Scheduler_default_Tick,         /* tick entry point */ \
-    _Scheduler_default_Start_idle    /* start idle entry point */ \
 /* Return values for CBS server. */
 #define SCHEDULER_CBS_OK                        0
 #define SCHEDULER_CBS_ERROR_GENERIC            -16
@@ -127,220 +102,8 @@ typedef struct {
   Scheduler_CBS_Server         *cbs_server;
 } Scheduler_CBS_Per_thread;
+extern const Scheduler_Operations _Scheduler_CBS_Operations;
- * List of servers. The @a Scheduler_CBS_Server is the index to the array
- * of pointers to @a _Scheduler_CBS_Server_list.
-extern Scheduler_CBS_Server **_Scheduler_CBS_Server_list;
- *  @brief Unblocks a thread from the queue.
- *  This routine adds @a the_thread to the scheduling decision, that is,
- *  adds it to the ready queue and updates any appropriate scheduling
- *  variables, for example the heir thread. It is checked whether the
- *  remaining budget is sufficient. If not, the thread continues as a
- *  new job in order to protect concurrent threads.
- *  @param[in] the_thread will be unblocked.
- *  @note This has to be asessed as missed deadline of the current job.
-void _Scheduler_CBS_Unblock(
- *  @brief Called when a new job of task is released.
- *  This routine is called when a new job of task is released.
- *  It is called only from Rate Monotonic manager in the beginning
- *  of new period. Deadline has to be shifted and budget replenished.
- *  @param[in] the_thread is the owner of the job.
- *  @param[in] length of the new job from now. If equal to 0,
- *             the job was cancelled or deleted.
-void _Scheduler_CBS_Release_job (
-  uint32_t           length
- *  @brief _Scheduler_CBS_Initialize
- *  Initializes the CBS library.
- *  @retval status code.
-int _Scheduler_CBS_Initialize(void);
- *  @brief Attach a task to an already existing server.
- *  Attach a task to an already existing server.
-int _Scheduler_CBS_Attach_thread (
-  Scheduler_CBS_Server_id server_id,
-  rtems_id                task_id
- *  @brief Detach from the CBS Server.
- *  Detach from the CBS Server.
-int _Scheduler_CBS_Detach_thread (
-  rtems_id                task_id
- *  @brief Cleanup resources associated to the CBS Library.
- *  Cleanup resources associated to the CBS Library.
-int _Scheduler_CBS_Cleanup (void);
- *  @brief Create a new server with specified parameters.
- *  Create a new server with specified parameters.
-int _Scheduler_CBS_Create_server (
-  Scheduler_CBS_Parameters     *params,
-  Scheduler_CBS_Budget_overrun  budget_overrun_callback,
-  rtems_id                     *server_id
- *  @brief Detach all tasks from a server and destroy it.
- *  Detach all tasks from a server and destroy it.
- *  @param[in] server_id is the ID of the server
-int _Scheduler_CBS_Destroy_server (
- *  @brief Retrieve the approved budget.
- *  Retrieve the budget that has been approved for the subsequent
- *  server instances.
-int _Scheduler_CBS_Get_approved_budget (
-  time_t                  *approved_budget
- *  @brief Retrieve remaining budget for the current server instance.
- *  Retrieve remaining budget for the current server instance.
-int _Scheduler_CBS_Get_remaining_budget (
-  time_t                  *remaining_budget
- *  @brief Get relative time info.
- *  Retrieve time info relative to @a server_id. The server status code is returned.
- *  @param[in] server_id is the server to get the status code from.
- *  @param[in] exec_time is the execution time.
- *  @param[in] abs_time is not apparently used.
-int _Scheduler_CBS_Get_execution_time (
-  time_t                   *exec_time,
-  time_t                   *abs_time
- *  @brief Retrieve CBS scheduling parameters.
- *  Retrieve CBS scheduling parameters.
-int _Scheduler_CBS_Get_parameters (
- *  @brief Get a thread server id.
- *  Get a thread server id, or SCHEDULER_CBS_ERROR_NOT_FOUND if it is not
- *  attached to any server.
-int _Scheduler_CBS_Get_server_id (
-  rtems_id                 task_id,
-  Scheduler_CBS_Server_id *server_id
- *  @brief Set parameters for CBS scheduling.
- *  Change CBS scheduling parameters.
- *  @param[in] server_id is the ID of the server.
- *  @param[in] parameters are the parameters to set.
-int _Scheduler_CBS_Set_parameters (
-  Scheduler_CBS_Parameters *parameters
- *  @brief Invoked when a limited time quantum is exceeded.
- *  This routine is invoked when a limited time quantum is exceeded.
-void _Scheduler_CBS_Budget_callout(
- *  @brief Allocates CBS specific information of @a the_thread.
- *  This routine allocates CBS specific information of @a the_thread.
- *  @param[in] the_thread is the thread the scheduler is allocating
- *             management memory for.
-void *_Scheduler_CBS_Allocate(
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/include/rtems/score/schedulercbsimpl.h b/cpukit/score/include/rtems/score/schedulercbsimpl.h
new file mode 100644
index 0000000..c1ed4df
--- /dev/null
+++ b/cpukit/score/include/rtems/score/schedulercbsimpl.h
@@ -0,0 +1,246 @@
+ * @file
+ * @ingroup ScoreSchedulerPrioritySMP
+ * @brief Deterministic Priority SMP Scheduler API
+ *  Copryight (c) 2011 Petr Benes.
+ *  Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
+#ifndef _RTEMS_SCORE_SCHEDULERCBSIMPL_H
+#define _RTEMS_SCORE_SCHEDULERCBSIMPL_H
+#include <rtems/score/schedulercbs.h>
+#include <rtems/score/scheduleredfimpl.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * List of servers. The @a Scheduler_CBS_Server is the index to the array
+ * of pointers to @a _Scheduler_CBS_Server_list.
+extern Scheduler_CBS_Server **_Scheduler_CBS_Server_list;
+ *  @brief Unblocks a thread from the queue.
+ *  This routine adds @a the_thread to the scheduling decision, that is,
+ *  adds it to the ready queue and updates any appropriate scheduling
+ *  variables, for example the heir thread. It is checked whether the
+ *  remaining budget is sufficient. If not, the thread continues as a
+ *  new job in order to protect concurrent threads.
+ *  @param[in] the_thread will be unblocked.
+ *  @note This has to be asessed as missed deadline of the current job.
+void _Scheduler_CBS_Unblock(
+  Scheduler_Control *scheduler,
+  Thread_Control    *the_thread
+ *  @brief Called when a new job of task is released.
+ *  This routine is called when a new job of task is released.
+ *  It is called only from Rate Monotonic manager in the beginning
+ *  of new period. Deadline has to be shifted and budget replenished.
+ *  @param[in] the_thread is the owner of the job.
+ *  @param[in] length of the new job from now. If equal to 0,
+ *             the job was cancelled or deleted.
+void _Scheduler_CBS_Release_job (
+  Thread_Control    *the_thread,
+  uint32_t           length
+ *  @brief _Scheduler_CBS_Initialize
+ *  Initializes the CBS library.
+ *  @retval status code.
+int _Scheduler_CBS_Initialize(void);
+ *  @brief Attach a task to an already existing server.
+ *  Attach a task to an already existing server.
+int _Scheduler_CBS_Attach_thread (
+  Scheduler_CBS_Server_id server_id,
+  rtems_id                task_id
+ *  @brief Detach from the CBS Server.
+ *  Detach from the CBS Server.
+int _Scheduler_CBS_Detach_thread (
+  rtems_id                task_id
+ *  @brief Cleanup resources associated to the CBS Library.
+ *  Cleanup resources associated to the CBS Library.
+int _Scheduler_CBS_Cleanup (void);
+ *  @brief Create a new server with specified parameters.
+ *  Create a new server with specified parameters.
+int _Scheduler_CBS_Create_server (
+  Scheduler_CBS_Parameters     *params,
+  Scheduler_CBS_Budget_overrun  budget_overrun_callback,
+  rtems_id                     *server_id
+ *  @brief Detach all tasks from a server and destroy it.
+ *  Detach all tasks from a server and destroy it.
+ *  @param[in] server_id is the ID of the server
+int _Scheduler_CBS_Destroy_server (
+ *  @brief Retrieve the approved budget.
+ *  Retrieve the budget that has been approved for the subsequent
+ *  server instances.
+int _Scheduler_CBS_Get_approved_budget (
+  time_t                  *approved_budget
+ *  @brief Retrieve remaining budget for the current server instance.
+ *  Retrieve remaining budget for the current server instance.
+int _Scheduler_CBS_Get_remaining_budget (
+  time_t                  *remaining_budget
+ *  @brief Get relative time info.
+ *  Retrieve time info relative to @a server_id. The server status code is returned.
+ *  @param[in] server_id is the server to get the status code from.
+ *  @param[in] exec_time is the execution time.
+ *  @param[in] abs_time is not apparently used.
+int _Scheduler_CBS_Get_execution_time (
+  time_t                   *exec_time,
+  time_t                   *abs_time
+ *  @brief Retrieve CBS scheduling parameters.
+ *  Retrieve CBS scheduling parameters.
+int _Scheduler_CBS_Get_parameters (
+ *  @brief Get a thread server id.
+ *  Get a thread server id, or SCHEDULER_CBS_ERROR_NOT_FOUND if it is not
+ *  attached to any server.
+int _Scheduler_CBS_Get_server_id (
+  rtems_id                 task_id,
+  Scheduler_CBS_Server_id *server_id
+ *  @brief Set parameters for CBS scheduling.
+ *  Change CBS scheduling parameters.
+ *  @param[in] server_id is the ID of the server.
+ *  @param[in] parameters are the parameters to set.
+int _Scheduler_CBS_Set_parameters (
+  Scheduler_CBS_Parameters *parameters
+ *  @brief Invoked when a limited time quantum is exceeded.
+ *  This routine is invoked when a limited time quantum is exceeded.
+void _Scheduler_CBS_Budget_callout(
+ *  @brief Allocates CBS specific information of @a the_thread.
+ *  This routine allocates CBS specific information of @a the_thread.
+ *  @param[in] the_thread is the thread the scheduler is allocating
+ *             management memory for.
+void *_Scheduler_CBS_Allocate(
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_SCHEDULERCBSIMPL_H */
diff --git a/cpukit/score/include/rtems/score/scheduleredf.h b/cpukit/score/include/rtems/score/scheduleredf.h
index 16d46a4..8ccf60f 100644
--- a/cpukit/score/include/rtems/score/scheduleredf.h
+++ b/cpukit/score/include/rtems/score/scheduleredf.h
@@ -19,10 +19,9 @@
 #ifndef _RTEMS_SCORE_SCHEDULEREDF_H
 #define _RTEMS_SCORE_SCHEDULEREDF_H
-#include <rtems/score/schedulerpriority.h>
 #include <rtems/score/rbtree.h>
+#include <rtems/score/thread.h>
 #ifdef __cplusplus
 extern "C" {
@@ -36,28 +35,6 @@ extern "C" {
- *  Entry points for the Earliest Deadline First Scheduler.
-#define SCHEDULER_EDF_ENTRY_POINTS \
-    _Scheduler_EDF_Unblock,          /* unblock entry point */ \
-    _Scheduler_EDF_Allocate,         /* allocate entry point */ \
-    _Scheduler_EDF_Release_job,      /* new period of task */ \
  * This is just a most significant bit of Priority_Control type. It
  * distinguishes threads which are deadline driven (priority
  * represented by a lower number than @a SCHEDULER_EDF_PRIO_MSB) from those
@@ -103,182 +80,7 @@ typedef struct {
   Scheduler_EDF_Queue_state queue_state;
 } Scheduler_EDF_Per_thread;
- * @brief Initialize EDF scheduler.
- * This routine initializes the EDF scheduler.
-void _Scheduler_EDF_Initialize( void );
- *  @brief Removes thread from ready queue.
- *  This routine removes @a the_thread from the scheduling decision,
- *  that is, removes it from the ready queue.  It performs
- *  any necessary scheduling operations including the selection of
- *  a new heir thread.
- *  @param[in] the_thread is the thread to be blocked.
-void _Scheduler_EDF_Block(
- *  @brief Sets the heir thread to be the next ready thread
- *  in the rbtree ready queue.
- *  This kernel routine sets the heir thread to be the next ready thread
-void _Scheduler_EDF_Schedule(
- *  @brief Allocates EDF specific information of @a the_thread.
- *  This routine allocates EDF specific information of @a the_thread.
-void *_Scheduler_EDF_Allocate(
- *  @brief Frees EDF information of a thread.
- *  This routine frees the EDF specific information of @a the_thread.
- *  @param[in] the_thread is the thread whose scheduler specific information
- *             will be deallocated.
-void _Scheduler_EDF_Free(
- *  @brief Updates position in the ready queue of @a the_thread.
- *  This routine updates position in the ready queue of @a the_thread.
- *  @param[in] the_thread will have its scheduler specific information
- *             structure updated.
-void _Scheduler_EDF_Update(
- *  @brief Adds @a the_thread to the scheduling decision.
-void _Scheduler_EDF_Unblock(
- *  @brief invoked when a thread wishes to voluntarily
- *  transfer control of the processor to another thread
- *  with equal deadline.
- *  This routine is invoked when a thread wishes to voluntarily
- *  transfer control of the processor to another thread in the queue with
- *  equal deadline. This does not have to happen very often.
- *  This routine will remove the specified THREAD from the ready queue
- *  and place it back. The rbtree ready queue is responsible for FIFO ordering
- *  in such a case.
- *  @param[in,out] thread The yielding thread.
-void _Scheduler_EDF_Yield(
- *  @brief Put @a the_thread to the rbtree ready queue.
- *  This routine puts @a the_thread to the rbtree ready queue.
- *  @param[in] the_thread will be enqueued to the ready queue.
-void _Scheduler_EDF_Enqueue(
- *  @brief Enqueue a thread to the ready queue.
- *  For the EDF scheduler this is the same as @a _Scheduler_EDF_Enqueue.
-void _Scheduler_EDF_Enqueue_first(
- *  @brief Remove a specific thread from the scheduler's set
- *  of ready threads.
- *  This routine removes a specific thread from the scheduler's set
- *  @param[in] the_thread will be extracted from the ready set.
-void _Scheduler_EDF_Extract(
- *  @brief Explicitly compare absolute dedlines (priorities) of threads.
- * This routine explicitly compares absolute dedlines (priorities) of threads.
- * In case of EDF scheduling time overflow is taken into account.
- * @retval >0 for p1 > p2; 0 for p1 == p2; <0 for p1 < p2.
-int _Scheduler_EDF_Priority_compare (
-  Priority_Control p1,
-  Priority_Control p2
- *  of new period.
- *  @param[in] deadline of the new job from now. If equal to 0,
- *             the job was cancelled or deleted, thus a running task
- *             has to be suspended.
-void _Scheduler_EDF_Release_job (
-  uint32_t           deadline
+extern const Scheduler_Operations _Scheduler_EDF_Operations;
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/scheduleredfimpl.h b/cpukit/score/include/rtems/score/scheduleredfimpl.h
index bfeff63..d36f322 100644
--- a/cpukit/score/include/rtems/score/scheduleredfimpl.h
+++ b/cpukit/score/include/rtems/score/scheduleredfimpl.h
@@ -31,6 +31,183 @@ extern "C" {
+ * @brief Initialize EDF scheduler.
+ * This routine initializes the EDF scheduler.
+void _Scheduler_EDF_Initialize( void );
+ *  @brief Removes thread from ready queue.
+ *  This routine removes @a the_thread from the scheduling decision,
+ *  that is, removes it from the ready queue.  It performs
+ *  any necessary scheduling operations including the selection of
+ *  a new heir thread.
+ *  @param[in] the_thread is the thread to be blocked.
+void _Scheduler_EDF_Block(
+ *  @brief Sets the heir thread to be the next ready thread
+ *  in the rbtree ready queue.
+ *  This kernel routine sets the heir thread to be the next ready thread
+void _Scheduler_EDF_Schedule(
+ *  @brief Allocates EDF specific information of @a the_thread.
+ *  This routine allocates EDF specific information of @a the_thread.
+void *_Scheduler_EDF_Allocate(
+ *  @brief Frees EDF information of a thread.
+ *  This routine frees the EDF specific information of @a the_thread.
+ *  @param[in] the_thread is the thread whose scheduler specific information
+ *             will be deallocated.
+void _Scheduler_EDF_Free(
+ *  @brief Updates position in the ready queue of @a the_thread.
+ *  This routine updates position in the ready queue of @a the_thread.
+ *  @param[in] the_thread will have its scheduler specific information
+ *             structure updated.
+void _Scheduler_EDF_Update(
+ *  @brief Adds @a the_thread to the scheduling decision.
+void _Scheduler_EDF_Unblock(
+ *  @brief invoked when a thread wishes to voluntarily
+ *  transfer control of the processor to another thread
+ *  with equal deadline.
+ *  This routine is invoked when a thread wishes to voluntarily
+ *  transfer control of the processor to another thread in the queue with
+ *  equal deadline. This does not have to happen very often.
+ *  This routine will remove the specified THREAD from the ready queue
+ *  and place it back. The rbtree ready queue is responsible for FIFO ordering
+ *  in such a case.
+ *  @param[in,out] thread The yielding thread.
+void _Scheduler_EDF_Yield(
+ *  @brief Put @a the_thread to the rbtree ready queue.
+ *  This routine puts @a the_thread to the rbtree ready queue.
+ *  @param[in] the_thread will be enqueued to the ready queue.
+void _Scheduler_EDF_Enqueue(
+ *  @brief Enqueue a thread to the ready queue.
+ *  For the EDF scheduler this is the same as @a _Scheduler_EDF_Enqueue.
+void _Scheduler_EDF_Enqueue_first(
+ *  @brief Remove a specific thread from the scheduler's set
+ *  of ready threads.
+ *  This routine removes a specific thread from the scheduler's set
+ *  @param[in] the_thread will be extracted from the ready set.
+void _Scheduler_EDF_Extract(
+ *  @brief Explicitly compare absolute dedlines (priorities) of threads.
+ * This routine explicitly compares absolute dedlines (priorities) of threads.
+ * In case of EDF scheduling time overflow is taken into account.
+ * @retval >0 for p1 > p2; 0 for p1 == p2; <0 for p1 < p2.
+int _Scheduler_EDF_Priority_compare (
+  Priority_Control p1,
+  Priority_Control p2
+ *  of new period.
+ *  @param[in] deadline of the new job from now. If equal to 0,
+ *             the job was cancelled or deleted, thus a running task
+ *             has to be suspended.
+void _Scheduler_EDF_Release_job (
+  uint32_t           deadline
 RTEMS_INLINE_ROUTINE Scheduler_EDF_Control *
   _Scheduler_EDF_Self_from_base( Scheduler_Control *scheduler_base )
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 6687fcf..32b4535 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -20,7 +20,12 @@
 #define _RTEMS_SCORE_SCHEDULERIMPL_H
+#include <rtems/score/percpu.h>
+#include <rtems/score/priority.h>
+#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) && defined(RTEMS_SMP)
+  #include <sys/cpuset.h>
+#endif
 #ifdef __cplusplus
 extern "C" {
@@ -32,6 +37,102 @@ extern "C" {
+ * function jump table that holds pointers to the functions that
+ * implement specific schedulers.
+struct Scheduler_Operations {
+  /** Implements the scheduling decision logic (policy). */
+  void ( *initialize )(void);
+  void ( *schedule )( Scheduler_Control *, Thread_Control *);
+   * @brief Voluntarily yields the processor per the scheduling policy.
+   * @see _Scheduler_Yield().
+  void ( *yield )( Scheduler_Control *, Thread_Control *);
+  /** Removes the given thread from scheduling decisions. */
+  void ( *block )( Scheduler_Control *, Thread_Control * );
+  /** Adds the given thread to scheduling decisions. */
+  void ( *unblock )( Scheduler_Control *, Thread_Control * );
+  /** allocates the scheduler field of the given thread */
+  void * ( *allocate )( Scheduler_Control *, Thread_Control * );
+  /** frees the scheduler field of the given thread */
+  void ( *free )( Scheduler_Control *, Thread_Control * );
+  /** updates the scheduler field of the given thread -- primarily used
+   * when changing the thread's priority. */
+  void ( *update )( Scheduler_Control *, Thread_Control * );
+  /** enqueue a thread as the last of its priority group */
+  void ( *enqueue )( Scheduler_Control *, Thread_Control * );
+  /** enqueue a thread as the first of its priority group */
+  void ( *enqueue_first )( Scheduler_Control *, Thread_Control * );
+  /** extract a thread from the ready set */
+  void ( *extract )( Scheduler_Control *, Thread_Control * );
+   * Compares two priorities (returns >0 for higher priority, 0 for equal
+   * and <0 for lower priority).
+  int ( *priority_compare )(
+    Priority_Control,
+    Priority_Control
+  /** This routine is called upon release of a new job. */
+  void ( *release_job ) ( Scheduler_Control *, Thread_Control *, uint32_t );
+  /** perform scheduler update actions required at each clock tick */
+  void ( *tick )( Scheduler_Control * );
+   * @brief Starts the idle thread for a particular processor.
+   * @see _Scheduler_Start_idle().
+  void ( *start_idle )(
+    Scheduler_Control *,
+    Thread_Control *,
+    Per_CPU_Control *
+   * @brief Obtain the processor affinity for a thread.
+   * @see _Scheduler_Get_affinity().
+  bool ( *get_affinity )(
+    Thread_Control *,
+    size_t,
+    cpu_set_t *
+   * @brief Set the processor affinity for a thread.
+   * @see _Scheduler_Set_affinity().
+  bool ( *set_affinity )(
+    Thread_Control *,
+    size_t,
+    const cpu_set_t *
+#endif
  *  @brief Initializes the scheduler to the policy chosen by the user.
  *  This routine initializes the scheduler to the policy chosen by the user
@@ -68,7 +169,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Schedule(
-  ( *scheduler->Operations.schedule )( scheduler, the_thread );
+  ( *scheduler->operations->schedule )( scheduler, the_thread );
@@ -84,7 +185,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Yield(
-  ( *scheduler->Operations.yield )( scheduler, the_thread );
+  ( *scheduler->operations->yield )( scheduler, the_thread );
@@ -100,7 +201,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Block(
-  ( *scheduler->Operations.block )( scheduler, the_thread );
+  ( *scheduler->operations->block )( scheduler, the_thread );
@@ -116,7 +217,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Unblock(
-  ( *scheduler->Operations.unblock )( scheduler, the_thread );
+  ( *scheduler->operations->unblock )( scheduler, the_thread );
@@ -129,7 +230,7 @@ RTEMS_INLINE_ROUTINE void* _Scheduler_Allocate(
-  return ( *scheduler->Operations.allocate )( scheduler, the_thread );
+  return ( *scheduler->operations->allocate )( scheduler, the_thread );
@@ -142,7 +243,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Free(
-  ( *scheduler->Operations.free )( scheduler, the_thread );
+  ( *scheduler->operations->free )( scheduler, the_thread );
@@ -155,7 +256,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Update(
-  ( *scheduler->Operations.update )( scheduler, the_thread );
+  ( *scheduler->operations->update )( scheduler, the_thread );
@@ -168,7 +269,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Enqueue(
-  ( *scheduler->Operations.enqueue )( scheduler, the_thread );
+  ( *scheduler->operations->enqueue )( scheduler, the_thread );
@@ -181,7 +282,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Enqueue_first(
-  ( *scheduler->Operations.enqueue_first )( scheduler, the_thread );
+  ( *scheduler->operations->enqueue_first )( scheduler, the_thread );
@@ -194,7 +295,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Extract(
-  ( *scheduler->Operations.extract )( scheduler, the_thread );
+  ( *scheduler->operations->extract )( scheduler, the_thread );
@@ -208,7 +309,7 @@ RTEMS_INLINE_ROUTINE int _Scheduler_Priority_compare(
   Priority_Control p2
-  return ( *scheduler->Operations.priority_compare )( p1, p2 );
+  return ( *scheduler->operations->priority_compare )( p1, p2 );
@@ -222,7 +323,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Release_job(
   uint32_t           length
-  ( *scheduler->Operations.release_job )( scheduler, the_thread, length );
+  ( *scheduler->operations->release_job )( scheduler, the_thread, length );
@@ -235,7 +336,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Release_job(
 RTEMS_INLINE_ROUTINE void _Scheduler_Tick( Scheduler_Control *scheduler )
-  ( *scheduler->Operations.tick )( scheduler );
+  ( *scheduler->operations->tick )( scheduler );
@@ -252,7 +353,7 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Start_idle(
-  ( *scheduler->Operations.start_idle )( scheduler, the_thread, cpu );
+  ( *scheduler->operations->start_idle )( scheduler, the_thread, cpu );
@@ -262,14 +363,14 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Start_idle(
    * @param[in,out] thread The thread.
    * @parma[out] cpuset The processor affinity for this thread
-  RTEMS_INLINE_ROUTINE int _Scheduler_Get_affinity(
+  RTEMS_INLINE_ROUTINE bool _Scheduler_Get_affinity(
     size_t             cpusetsize,
     cpu_set_t         *cpuset
-    return ( *scheduler->Operations.get_affinity )(
+    return ( *scheduler->operations->get_affinity )(
       scheduler,
       thread,
       cpusetsize,
@@ -283,14 +384,14 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Start_idle(
    * @parma[in] cpuset The processor affinity for this thread
-  RTEMS_INLINE_ROUTINE int _Scheduler_Set_affinity(
+  RTEMS_INLINE_ROUTINE bool _Scheduler_Set_affinity(
     size_t             cpusetsize,
-    return ( *scheduler->Operations.set_affinity )(
+    return ( *scheduler->operations->set_affinity )(
       scheduler,
       thread,
       cpusetsize,
@@ -411,6 +512,121 @@ RTEMS_INLINE_ROUTINE Scheduler_Control *_Scheduler_Get(
   return &_Scheduler;
+ * @brief Returns an arbitrary non-NULL value.
+ * @param[in] scheduler Unused.
+ * @param[in] the_thread Unused.
+ * @return An arbitrary non-NULL value.
+void *_Scheduler_default_Allocate(
+ * @brief Does nothing.
+void _Scheduler_default_Free(
+void _Scheduler_default_Update(
+ * @param[in] deadline Unused.
+void _Scheduler_default_Release_job(
+  uint32_t           deadline
+ * @brief Performs tick operations depending on the CPU budget algorithm for
+ * each executing thread.
+ * This routine is invoked as part of processing each clock tick.
+ * @param[in] scheduler The scheduler.
+void _Scheduler_default_Tick( Scheduler_Control *scheduler );
+ * @brief Starts an idle thread.
+ * @param[in] the_thread An idle thread.
+ * @param[in] cpu This parameter is unused.
+void _Scheduler_default_Start_idle(
+  Per_CPU_Control   *cpu
+   * @brief Get affinity for the default scheduler.
+   * @param[in] thread The associated thread.
+   * @param[in] cpusetsize The size of the cpuset.
+   * @param[out] cpuset Affinity set containing all CPUs.
+   * @retval 0 Successfully got cpuset
+   * @retval -1 The cpusetsize is invalid for the system
+  bool _Scheduler_default_Get_affinity(
+    Thread_Control    *thread,
+    size_t             cpusetsize,
+    cpu_set_t         *cpuset
+   * @brief Set affinity for the default scheduler.
+   * @param[in] cpuset Affinity new affinity set.
+   *  This method always returns successful and does not save
+   *  the cpuset.
+  bool _Scheduler_default_Set_affinity(
+    const cpu_set_t   *cpuset
+  #define SCHEDULER_DEFAULT_AFFINITY_OPERATIONS \
+    .get_affinity = _Scheduler_default_Get_affinity, \
+    .set_affinity = _Scheduler_default_Set_affinity,
+#else
+#endif
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulerpriority.h b/cpukit/score/include/rtems/score/schedulerpriority.h
index 1e4e91b..33a7710 100644
--- a/cpukit/score/include/rtems/score/schedulerpriority.h
+++ b/cpukit/score/include/rtems/score/schedulerpriority.h
@@ -34,37 +34,6 @@ extern "C" {
-  #define SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
-    _Scheduler_default_Get_affinity,     /* get affinity entry point */ \
-    _Scheduler_default_Set_affinity      /* set affinity entry point */
-#else
-#endif
- *  Entry points for the Deterministic Priority Based Scheduler.
-#define SCHEDULER_PRIORITY_ENTRY_POINTS \
-    _Scheduler_priority_Initialize,       /* initialize entry point */ \
-    _Scheduler_priority_Schedule,         /* schedule entry point */ \
-    _Scheduler_priority_Yield,            /* yield entry point */ \
-    _Scheduler_priority_Block,            /* block entry point */ \
-    _Scheduler_priority_Unblock,          /* unblock entry point */ \
-    _Scheduler_priority_Allocate,         /* allocate entry point */ \
-    _Scheduler_priority_Free,             /* free entry point */ \
-    _Scheduler_priority_Update,           /* update entry point */ \
-    _Scheduler_priority_Enqueue,          /* enqueue entry point */ \
-    _Scheduler_priority_Enqueue_first,    /* enqueue_first entry point */ \
-    _Scheduler_priority_Extract,          /* extract entry point */ \
-    _Scheduler_priority_Priority_compare, /* compares two priorities */ \
-    _Scheduler_default_Release_job,       /* new period of task */ \
-    _Scheduler_default_Start_idle,        /* start idle entry point */ \
-    SCHEDULER_PRIORITY_ADDITIONAL_SMP_ENTRY_POINTS \
 typedef struct {
    * @brief Bit map to indicate non-empty ready queues.
@@ -88,163 +57,7 @@ typedef struct {
   Priority_bit_map_Information          Priority_map;
 } Scheduler_priority_Per_thread;
- * @brief Initializes the priority scheduler.
- * This routine initializes the priority scheduler.
-void _Scheduler_priority_Initialize(void);
- *  @brief Removes @a the_thread from the scheduling decision.
-void _Scheduler_priority_Block(
- *  @brief Sets the heir thread to be the next ready thread.
- *  by invoking the_scheduler->ready_queue->operations->first().
-void _Scheduler_priority_Schedule(
- *  @brief Allocates @a the_thread->scheduler.
- *  This routine allocates @a the_thread->scheduler.
-void * _Scheduler_priority_Allocate(
- *  @brief Frees @a the_thread->scheduler.
- *  This routine frees @a the_thread->scheduler.
-void _Scheduler_priority_Free(
- *  @brief Update the scheduler priority.
- *  This routine updates @a the_thread->scheduler based on @a the_scheduler
- *  structures and thread state.
-void _Scheduler_priority_Update(
- *  @brief Add @a the_thread to the scheduling decision.
- *  that is, adds it to the ready queue and
- *  updates any appropriate scheduling variables, for example the heir thread.
-void _Scheduler_priority_Unblock(
- *  @brief The specified THREAD yields.
- *  transfer control of the processor to another thread in the queue.
- *  and place it immediately at the rear of this chain.  Reset timeslice
- *  and yield the processor functions both use this routine, therefore if
- *  reset is true and this is the only thread on the queue then the
- *  timeslice counter is reset.  The heir THREAD will be updated if the
- *  running is also the currently the heir.
- *  - INTERRUPT LATENCY:
- *    + ready chain
- *    + select heir
-void _Scheduler_priority_Yield(
- *  @brief Puts @a the_thread on to the priority-based ready queue.
- *  This routine puts @a the_thread on to the priority-based ready queue.
- *  @param[in] the_thread will be enqueued at the TAIL of its priority.
-void _Scheduler_priority_Enqueue(
- *  @brief Puts @a the_thread to the head of the ready queue.
- *  This routine puts @a the_thread to the head of the ready queue.
- *  For priority-based ready queues, the thread will be the first thread
- *  at its priority level.
- *  @param[in] the_thread will be enqueued at the HEAD of its priority.
-void _Scheduler_priority_Enqueue_first(
- *  @brief Remove a specific thread from scheduler.
-void _Scheduler_priority_Extract(
- *  @brief Compare two priorities.
- *  This routine compares two priorities.
-int _Scheduler_priority_Priority_compare(
+extern const Scheduler_Operations _Scheduler_priority_Operations;
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
index 8f9d081..1d9602e 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
@@ -18,9 +18,6 @@
 #ifndef _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
 #define _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
-#include <rtems/score/scheduler.h>
-#include <rtems/score/schedulersmp.h>
 #include <rtems/score/cpuset.h>
@@ -45,75 +42,6 @@ extern "C" {
- * @brief Entry points for the Deterministic Priority Affinity SMP Scheduler.
-#define SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS \
-    _Scheduler_priority_SMP_Initialize, \
-    _Scheduler_priority_SMP_Schedule, \
-    _Scheduler_priority_SMP_Yield, \
-    _Scheduler_priority_SMP_Block, \
-    _Scheduler_priority_SMP_Enqueue_fifo, \
-    _Scheduler_priority_affinity_SMP_Allocate, \
-    _Scheduler_priority_Free, \
-    _Scheduler_priority_SMP_Update, \
-    _Scheduler_priority_SMP_Enqueue_lifo, \
-    _Scheduler_priority_SMP_Extract, \
-    _Scheduler_priority_Priority_compare, \
-    _Scheduler_default_Release_job, \
-    _Scheduler_default_Tick, \
-    _Scheduler_priority_SMP_Start_idle, \
-    _Scheduler_priority_affinity_SMP_Get_affinity, \
-    _Scheduler_priority_affinity_SMP_Set_affinity \
-void * _Scheduler_priority_affinity_SMP_Allocate( Thread_Control *the_thread );
- * @brief Get affinity for the priority affinity smp scheduler.
- * @param[in] scheduler The scheduler of the thread.
- * @param[in,out] cpuset The associated affinity set.
-bool _Scheduler_priority_affinity_SMP_Get_affinity(
-  cpu_set_t         *cpuset
- * @brief Set affinity for the priority affinity smp scheduler.
-bool _Scheduler_priority_affinity_SMP_Set_affinity(
-  cpu_set_t         *cpuset
  * This structure handles affinity specific data of a thread.
  * @note The attribute priority_sched_info must remain
@@ -134,6 +62,8 @@ typedef struct {
   CPU_set_Control Affinity;
 } Scheduler_priority_affinity_SMP_Per_thread;
+extern const Scheduler_Operations _Scheduler_priority_affinity_SMP_Operations;
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
index 7861df5..ceda148 100644
--- a/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerpriorityimpl.h
@@ -35,6 +35,164 @@ extern "C" {
+ * @brief Initializes the priority scheduler.
+ * This routine initializes the priority scheduler.
+void _Scheduler_priority_Initialize(void);
+ *  @brief Removes @a the_thread from the scheduling decision.
+void _Scheduler_priority_Block(
+ *  @brief Sets the heir thread to be the next ready thread.
+ *  by invoking the_scheduler->ready_queue->operations->first().
+void _Scheduler_priority_Schedule(
+ *  @brief Allocates @a the_thread->scheduler.
+ *  This routine allocates @a the_thread->scheduler.
+void * _Scheduler_priority_Allocate(
+ *  @brief Frees @a the_thread->scheduler.
+ *  This routine frees @a the_thread->scheduler.
+void _Scheduler_priority_Free(
+ *  @brief Update the scheduler priority.
+ *  This routine updates @a the_thread->scheduler based on @a the_scheduler
+ *  structures and thread state.
+void _Scheduler_priority_Update(
+ *  @brief Add @a the_thread to the scheduling decision.
+ *  that is, adds it to the ready queue and
+ *  updates any appropriate scheduling variables, for example the heir thread.
+void _Scheduler_priority_Unblock(
+ *  @brief The specified THREAD yields.
+ *  transfer control of the processor to another thread in the queue.
+ *  and place it immediately at the rear of this chain.  Reset timeslice
+ *  and yield the processor functions both use this routine, therefore if
+ *  reset is true and this is the only thread on the queue then the
+ *  timeslice counter is reset.  The heir THREAD will be updated if the
+ *  running is also the currently the heir.
+ *  - INTERRUPT LATENCY:
+ *    + ready chain
+ *    + select heir
+void _Scheduler_priority_Yield(
+ *  @brief Puts @a the_thread on to the priority-based ready queue.
+ *  This routine puts @a the_thread on to the priority-based ready queue.
+ *  @param[in] the_thread will be enqueued at the TAIL of its priority.
+void _Scheduler_priority_Enqueue(
+ *  @brief Puts @a the_thread to the head of the ready queue.
+ *  This routine puts @a the_thread to the head of the ready queue.
+ *  For priority-based ready queues, the thread will be the first thread
+ *  at its priority level.
+ *  @param[in] the_thread will be enqueued at the HEAD of its priority.
+void _Scheduler_priority_Enqueue_first(
+ *  @brief Remove a specific thread from scheduler.
+void _Scheduler_priority_Extract(
+ *  @brief Compare two priorities.
+ *  This routine compares two priorities.
+int _Scheduler_priority_Priority_compare(
 RTEMS_INLINE_ROUTINE Scheduler_priority_Control *
   _Scheduler_priority_Self_from_base( Scheduler_Control *scheduler_base )
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmp.h b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
index 905549d..88c5985 100644
--- a/cpukit/score/include/rtems/score/schedulerprioritysmp.h
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmp.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -23,9 +23,8 @@
 #ifndef _RTEMS_SCORE_SCHEDULERPRIORITYSMP_H
 #define _RTEMS_SCORE_SCHEDULERPRIORITYSMP_H
+#include <rtems/score/schedulerpriority.h>
 #ifdef __cplusplus
 extern "C" {
@@ -47,72 +46,13 @@ extern "C" {
- * @brief Entry points for the Priority SMP Scheduler.
-#define SCHEDULER_PRIORITY_SMP_ENTRY_POINTS \
-    _Scheduler_priority_Allocate, \
-    _Scheduler_default_Get_affinity, \
-    _Scheduler_default_Set_affinity \
-void _Scheduler_priority_SMP_Initialize( void );
-void _Scheduler_priority_SMP_Schedule(
-  Scheduler_Control *base,
-void _Scheduler_priority_SMP_Block(
-void _Scheduler_priority_SMP_Update(
-void _Scheduler_priority_SMP_Enqueue_fifo(
-void _Scheduler_priority_SMP_Enqueue_lifo(
-void _Scheduler_priority_SMP_Extract(
-void _Scheduler_priority_SMP_Yield(
+typedef struct {
+  Scheduler_SMP_Control    Base;
+  Priority_bit_map_Control Bit_map;
+  Chain_Control            Ready[ 1 ];
+} Scheduler_priority_SMP_Control;
-void _Scheduler_priority_SMP_Start_idle(
+extern const Scheduler_Operations _Scheduler_priority_SMP_Operations;
diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
index 0000000..eb8c569
--- /dev/null
+++ b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
@@ -0,0 +1,87 @@
+ * @file
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef _RTEMS_SCORE_SCHEDULERPRIORITYSMPIMPL_H
+#define _RTEMS_SCORE_SCHEDULERPRIORITYSMPIMPL_H
+#include <rtems/score/schedulerimpl.h>
+#ifdef __cplusplus
+extern "C" {
+ * @addtogroup ScoreSchedulerPrioritySMP
+void _Scheduler_priority_SMP_Initialize( void );
+void _Scheduler_priority_SMP_Schedule(
+  Scheduler_Control *base,
+void _Scheduler_priority_SMP_Block(
+void _Scheduler_priority_SMP_Update(
+void _Scheduler_priority_SMP_Enqueue_fifo(
+void _Scheduler_priority_SMP_Enqueue_lifo(
+void _Scheduler_priority_SMP_Extract(
+void _Scheduler_priority_SMP_Yield(
+void _Scheduler_priority_SMP_Start_idle(
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_SCHEDULERPRIORITYSMPIMPL_H */
diff --git a/cpukit/score/include/rtems/score/schedulersimple.h b/cpukit/score/include/rtems/score/schedulersimple.h
index 889c5a7..e27c41c 100644
--- a/cpukit/score/include/rtems/score/schedulersimple.h
+++ b/cpukit/score/include/rtems/score/schedulersimple.h
@@ -18,8 +18,8 @@
 #ifndef _RTEMS_SCORE_SCHEDULERSIMPLE_H
 #define _RTEMS_SCORE_SCHEDULERSIMPLE_H
+#include <rtems/score/chain.h>
 #ifdef __cplusplus
 extern "C" {
@@ -33,28 +33,6 @@ extern "C" {
- *  Entry points for Scheduler Simple
-#define SCHEDULER_SIMPLE_ENTRY_POINTS \
-    _Scheduler_simple_Initialize,         /* initialize entry point */ \
-    _Scheduler_simple_Schedule,           /* schedule entry point */ \
-    _Scheduler_simple_Yield,              /* yield entry point */ \
-    _Scheduler_simple_Block,              /* block entry point */ \
-    _Scheduler_simple_Unblock,            /* unblock entry point */ \
-    _Scheduler_default_Allocate,          /* allocate entry point */ \
-    _Scheduler_default_Free,              /* free entry point */ \
-    _Scheduler_default_Update,            /* update entry point */ \
-    _Scheduler_simple_Enqueue,            /* enqueue entry point */ \
-    _Scheduler_simple_Enqueue_first,      /* enqueue_first entry point */ \
-    _Scheduler_simple_Extract,            /* extract entry point */ \
  * @brief Simple scheduler control.
 typedef struct {
@@ -64,138 +42,7 @@ typedef struct {
   Chain_Control Ready;
 } Scheduler_simple_Control;
- *  @brief Initialize simple scheduler.
- *  This routine initializes the simple scheduler.
-void _Scheduler_simple_Initialize( void );
- *  This routine sets the heir thread to be the next ready thread
- *  on the ready queue by getting the first node in the scheduler
- *  information.
-void _Scheduler_simple_Schedule(
- *  @brief Invoked when a thread wishes to voluntarily
- *  It will remove the specified THREAD from the scheduler.informaiton
- *  (where the ready queue is stored) and place it immediately at the
- *  between the last entry of its priority and the next priority thread.
- *  Reset timeslice and yield the processor functions both use this routine,
- *  therefore if reset is true and this is the only thread on the queue then
- *  the timeslice counter is reset.  The heir THREAD will be updated if the
-void _Scheduler_simple_Yield(
- *  @brief Remove a simple-priority-based thread from the queue.
- *  @param[in] the_thread is the thread that is to be blocked
-void _Scheduler_simple_Block(
- *  @brief Unblock a simple-priority-based thread.
- *  @param[in] the_thread is the thread that is to be unblocked
-void _Scheduler_simple_Unblock(
- *  @brief Removes a simple-priority-based thread from a simple queue.
- *  This routine removes a specific thread from the specified
- *  simple-based ready queue.
-void _Scheduler_simple_Extract(
- *  @brief Puts simple-priority-based thread onto the ready queue.
- *  This routine puts @a the_thread on to the ready queue.
- *  @param[in] the_thread is the thread to be enqueued
-void _Scheduler_simple_Enqueue(
- *  @brief Put simple-priority-based @a the_thread to
- *  the head of the ready queue.
- *  The thread will be the first thread at its priority level.
-void _Scheduler_simple_Enqueue_first(
- *  _Scheduler_simple_Ready_queue_enqueue
- *  This routine puts @a the_thread on the ready queue
- *  at the end of its priority group.
- *  @param[in] the_thread - pointer to a thread control block
-void _Scheduler_simple_Ready_queue_enqueue(
- *  @brief Puts simple-priority-based @a the_thread on to the ready queue
- *  at the beginning of its priority group.
-void _Scheduler_simple_Ready_queue_enqueue_first(
+extern const Scheduler_Operations _Scheduler_simple_Operations;
diff --git a/cpukit/score/include/rtems/score/schedulersimpleimpl.h b/cpukit/score/include/rtems/score/schedulersimpleimpl.h
index 8ad142f..0834e43 100644
--- a/cpukit/score/include/rtems/score/schedulersimpleimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersimpleimpl.h
@@ -32,6 +32,139 @@ extern "C" {
+ *  @brief Initialize simple scheduler.
+ *  This routine initializes the simple scheduler.
+void _Scheduler_simple_Initialize( void );
+ *  This routine sets the heir thread to be the next ready thread
+ *  on the ready queue by getting the first node in the scheduler
+ *  information.
+void _Scheduler_simple_Schedule(
+ *  @brief Invoked when a thread wishes to voluntarily
+ *  It will remove the specified THREAD from the scheduler.informaiton
+ *  (where the ready queue is stored) and place it immediately at the
+ *  between the last entry of its priority and the next priority thread.
+ *  Reset timeslice and yield the processor functions both use this routine,
+ *  therefore if reset is true and this is the only thread on the queue then
+ *  the timeslice counter is reset.  The heir THREAD will be updated if the
+void _Scheduler_simple_Yield(
+ *  @brief Remove a simple-priority-based thread from the queue.
+ *  @param[in] the_thread is the thread that is to be blocked
+void _Scheduler_simple_Block(
+ *  @brief Unblock a simple-priority-based thread.
+ *  @param[in] the_thread is the thread that is to be unblocked
+void _Scheduler_simple_Unblock(
+ *  @brief Removes a simple-priority-based thread from a simple queue.
+ *  This routine removes a specific thread from the specified
+ *  simple-based ready queue.
+void _Scheduler_simple_Extract(
+ *  @brief Puts simple-priority-based thread onto the ready queue.
+ *  This routine puts @a the_thread on to the ready queue.
+ *  @param[in] the_thread is the thread to be enqueued
+void _Scheduler_simple_Enqueue(
+ *  @brief Put simple-priority-based @a the_thread to
+ *  the head of the ready queue.
+ *  The thread will be the first thread at its priority level.
+void _Scheduler_simple_Enqueue_first(
+ *  _Scheduler_simple_Ready_queue_enqueue
+ *  This routine puts @a the_thread on the ready queue
+ *  at the end of its priority group.
+ *  @param[in] the_thread - pointer to a thread control block
+void _Scheduler_simple_Ready_queue_enqueue(
+ *  @brief Puts simple-priority-based @a the_thread on to the ready queue
+ *  at the beginning of its priority group.
+void _Scheduler_simple_Ready_queue_enqueue_first(
 RTEMS_INLINE_ROUTINE Scheduler_simple_Control *
   _Scheduler_simple_Self_from_base( Scheduler_Control *scheduler_base )
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index a6d8262..bdf5471 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -49,67 +49,12 @@ extern "C" {
- * @brief Entry points for the Simple SMP Scheduler.
-#define SCHEDULER_SIMPLE_SMP_ENTRY_POINTS \
-    _Scheduler_simple_smp_Initialize, \
-    _Scheduler_simple_smp_Schedule, \
-    _Scheduler_simple_smp_Yield, \
-    _Scheduler_simple_smp_Block, \
-    _Scheduler_simple_smp_Enqueue_priority_fifo, \
-    _Scheduler_default_Allocate, \
-    _Scheduler_default_Free, \
-    _Scheduler_default_Update, \
-    _Scheduler_simple_smp_Enqueue_priority_lifo, \
-    _Scheduler_simple_smp_Extract, \
-    _Scheduler_simple_smp_Start_idle, \
-void _Scheduler_simple_smp_Initialize( void );
-void _Scheduler_simple_smp_Block(
-void _Scheduler_simple_smp_Enqueue_priority_fifo(
-void _Scheduler_simple_smp_Enqueue_priority_lifo(
-void _Scheduler_simple_smp_Extract(
-void _Scheduler_simple_smp_Yield(
-void _Scheduler_simple_smp_Schedule(
+typedef struct {
+  Chain_Control         Ready;
+} Scheduler_simple_SMP_Control;
-void _Scheduler_simple_smp_Start_idle(
+extern const Scheduler_Operations _Scheduler_simple_SMP_Operations;
diff --git a/cpukit/score/include/rtems/score/schedulersmp.h b/cpukit/score/include/rtems/score/schedulersmp.h
index 458a312..214d157 100644
--- a/cpukit/score/include/rtems/score/schedulersmp.h
+++ b/cpukit/score/include/rtems/score/schedulersmp.h
@@ -24,9 +24,7 @@
 #define _RTEMS_SCORE_SCHEDULERSMP_H
-#include <rtems/score/prioritybitmap.h>
-#include <rtems/score/thread.h>
+#include <rtems/score/scheduler.h>
 #ifdef __cplusplus
 extern "C" {
@@ -44,17 +42,6 @@ typedef struct {
   Chain_Control Scheduled;
 } Scheduler_SMP_Control;
-typedef struct {
-  Scheduler_SMP_Control Base;
-  Chain_Control         Ready;
-} Scheduler_simple_SMP_Control;
-typedef struct {
-  Priority_bit_map_Control Bit_map;
-  Chain_Control            Ready[ 1 ];
-} Scheduler_priority_SMP_Control;
 #ifdef __cplusplus
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index efbe37d..e357eaf 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -191,6 +191,10 @@ $(PROJECT_INCLUDE)/rtems/score/schedulercbs.h: include/rtems/score/schedulercbs.
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulercbs.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulercbs.h
+$(PROJECT_INCLUDE)/rtems/score/schedulercbsimpl.h: include/rtems/score/schedulercbsimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulercbsimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulercbsimpl.h
 $(PROJECT_INCLUDE)/rtems/score/scheduleredf.h: include/rtems/score/scheduleredf.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/scheduleredf.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/scheduleredf.h
@@ -211,6 +215,10 @@ $(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmp.h: include/rtems/score/sched
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmp.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmp.h
+$(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmpimpl.h: include/rtems/score/schedulerprioritysmpimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmpimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmpimpl.h
 $(PROJECT_INCLUDE)/rtems/score/schedulersimple.h: include/rtems/score/schedulersimple.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulersimple.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulersimple.h
diff --git a/cpukit/score/src/scheduler.c b/cpukit/score/src/scheduler.c
index 7705472..70e2f42 100644
--- a/cpukit/score/src/scheduler.c
+++ b/cpukit/score/src/scheduler.c
@@ -22,5 +22,5 @@
 void _Scheduler_Handler_initialization(void)
-  (*_Scheduler.Operations.initialize)();
+  ( *_Scheduler.operations->initialize )();
diff --git a/cpukit/score/src/schedulercbs.c b/cpukit/score/src/schedulercbs.c
index c427c52..105015c 100644
--- a/cpukit/score/src/schedulercbs.c
+++ b/cpukit/score/src/schedulercbs.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
-#include <rtems/score/schedulercbs.h>
+#include <rtems/score/schedulercbsimpl.h>
diff --git a/cpukit/score/src/schedulercbsallocate.c b/cpukit/score/src/schedulercbsallocate.c
index 908ea90..b94ac9a 100644
--- a/cpukit/score/src/schedulercbsallocate.c
+++ b/cpukit/score/src/schedulercbsallocate.c
@@ -18,11 +18,7 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/config.h>
-#include <rtems/score/scheduleredf.h>
diff --git a/cpukit/score/src/schedulercbsattachthread.c b/cpukit/score/src/schedulercbsattachthread.c
index ad92791..f0745d5 100644
--- a/cpukit/score/src/schedulercbsattachthread.c
+++ b/cpukit/score/src/schedulercbsattachthread.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbscleanup.c b/cpukit/score/src/schedulercbscleanup.c
index 795b16a..f19930d 100644
--- a/cpukit/score/src/schedulercbscleanup.c
+++ b/cpukit/score/src/schedulercbscleanup.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbscreateserver.c b/cpukit/score/src/schedulercbscreateserver.c
index 85ed6d4..c9aff91 100644
--- a/cpukit/score/src/schedulercbscreateserver.c
+++ b/cpukit/score/src/schedulercbscreateserver.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsdestroyserver.c b/cpukit/score/src/schedulercbsdestroyserver.c
index d8885a8..f221ef7 100644
--- a/cpukit/score/src/schedulercbsdestroyserver.c
+++ b/cpukit/score/src/schedulercbsdestroyserver.c
@@ -19,7 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsdetachthread.c b/cpukit/score/src/schedulercbsdetachthread.c
index f8a5e32..f9c3847 100644
--- a/cpukit/score/src/schedulercbsdetachthread.c
+++ b/cpukit/score/src/schedulercbsdetachthread.c
@@ -19,7 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsgetapprovedbudget.c b/cpukit/score/src/schedulercbsgetapprovedbudget.c
index 560849e..c73ec44 100644
--- a/cpukit/score/src/schedulercbsgetapprovedbudget.c
+++ b/cpukit/score/src/schedulercbsgetapprovedbudget.c
@@ -18,10 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsgetexecutiontime.c b/cpukit/score/src/schedulercbsgetexecutiontime.c
index 325c759..49083d5 100644
--- a/cpukit/score/src/schedulercbsgetexecutiontime.c
+++ b/cpukit/score/src/schedulercbsgetexecutiontime.c
@@ -19,7 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsgetparameters.c b/cpukit/score/src/schedulercbsgetparameters.c
index 12c9489..74241ef 100644
--- a/cpukit/score/src/schedulercbsgetparameters.c
+++ b/cpukit/score/src/schedulercbsgetparameters.c
@@ -18,10 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsgetremainingbudget.c b/cpukit/score/src/schedulercbsgetremainingbudget.c
index df4709d..624fc38 100644
--- a/cpukit/score/src/schedulercbsgetremainingbudget.c
+++ b/cpukit/score/src/schedulercbsgetremainingbudget.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsgetserverid.c b/cpukit/score/src/schedulercbsgetserverid.c
index 0711bae..7665ebb 100644
--- a/cpukit/score/src/schedulercbsgetserverid.c
+++ b/cpukit/score/src/schedulercbsgetserverid.c
@@ -18,10 +18,7 @@
 #include "config.h"
 #endif
   rtems_id                 task_id,
diff --git a/cpukit/score/src/schedulercbsops.c b/cpukit/score/src/schedulercbsops.c
index 0000000..6d943e3
--- /dev/null
+++ b/cpukit/score/src/schedulercbsops.c
@@ -0,0 +1,38 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+const Scheduler_Operations _Scheduler_CBS_Operations = {
+  SCHEDULER_DEFAULT_AFFINITY_OPERATIONS
+  .initialize = _Scheduler_EDF_Initialize,
+  .schedule = _Scheduler_EDF_Schedule,
+  .yield = _Scheduler_EDF_Yield,
+  .block = _Scheduler_EDF_Block,
+  .unblock = _Scheduler_CBS_Unblock,
+  .allocate = _Scheduler_CBS_Allocate,
+  .free = _Scheduler_EDF_Free,
+  .update = _Scheduler_EDF_Update,
+  .enqueue = _Scheduler_EDF_Enqueue,
+  .enqueue_first = _Scheduler_EDF_Enqueue_first,
+  .extract = _Scheduler_EDF_Extract,
+  .priority_compare = _Scheduler_EDF_Priority_compare,
+  .release_job = _Scheduler_CBS_Release_job,
+  .tick = _Scheduler_default_Tick,
+  .start_idle = _Scheduler_default_Start_idle
diff --git a/cpukit/score/src/schedulercbssetparameters.c b/cpukit/score/src/schedulercbssetparameters.c
index 8c45232..4c5fa25 100644
--- a/cpukit/score/src/schedulercbssetparameters.c
+++ b/cpukit/score/src/schedulercbssetparameters.c
@@ -19,10 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulercbsunblock.c b/cpukit/score/src/schedulercbsunblock.c
index 11465f2..5ba49a3 100644
--- a/cpukit/score/src/schedulercbsunblock.c
+++ b/cpukit/score/src/schedulercbsunblock.c
@@ -19,8 +19,8 @@
 #include "config.h"
 #endif
-#include <rtems/score/schedulerimpl.h>
diff --git a/cpukit/score/src/schedulerdefaultallocatefree.c b/cpukit/score/src/schedulerdefaultallocatefree.c
index 7ffade2..46cbe81 100644
--- a/cpukit/score/src/schedulerdefaultallocatefree.c
+++ b/cpukit/score/src/schedulerdefaultallocatefree.c
@@ -19,7 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulerdefaultreleasejob.c b/cpukit/score/src/schedulerdefaultreleasejob.c
index 10ebf84..81c0fd8 100644
--- a/cpukit/score/src/schedulerdefaultreleasejob.c
+++ b/cpukit/score/src/schedulerdefaultreleasejob.c
@@ -19,7 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulerdefaultupdate.c b/cpukit/score/src/schedulerdefaultupdate.c
index c1b62b2..435bc1c 100644
--- a/cpukit/score/src/schedulerdefaultupdate.c
+++ b/cpukit/score/src/schedulerdefaultupdate.c
@@ -19,7 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/scheduleredf.c b/cpukit/score/src/scheduleredf.c
index 502a2a1..fb317cb 100644
--- a/cpukit/score/src/scheduleredf.c
+++ b/cpukit/score/src/scheduleredf.c
@@ -18,9 +18,7 @@
 #include "config.h"
 #endif
 static int _Scheduler_EDF_RBTree_compare_function
diff --git a/cpukit/score/src/scheduleredfallocate.c b/cpukit/score/src/scheduleredfallocate.c
index 73df5b8..a8c65c5 100644
--- a/cpukit/score/src/scheduleredfallocate.c
+++ b/cpukit/score/src/scheduleredfallocate.c
@@ -18,10 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/scheduleredfenqueuefirst.c b/cpukit/score/src/scheduleredfenqueuefirst.c
index bcf70b4..5761f4c 100644
--- a/cpukit/score/src/scheduleredfenqueuefirst.c
+++ b/cpukit/score/src/scheduleredfenqueuefirst.c
@@ -19,9 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/scheduleredffree.c b/cpukit/score/src/scheduleredffree.c
index d9493cc..a612121 100644
--- a/cpukit/score/src/scheduleredffree.c
+++ b/cpukit/score/src/scheduleredffree.c
@@ -19,10 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/scheduleredfops.c b/cpukit/score/src/scheduleredfops.c
index 0000000..03d1827
--- /dev/null
+++ b/cpukit/score/src/scheduleredfops.c
@@ -0,0 +1,38 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+const Scheduler_Operations _Scheduler_EDF_Operations = {
+  .unblock = _Scheduler_EDF_Unblock,
+  .allocate = _Scheduler_EDF_Allocate,
+  .release_job = _Scheduler_EDF_Release_job,
diff --git a/cpukit/score/src/scheduleredfprioritycompare.c b/cpukit/score/src/scheduleredfprioritycompare.c
index 0fbfaa6..d34edeb 100644
--- a/cpukit/score/src/scheduleredfprioritycompare.c
+++ b/cpukit/score/src/scheduleredfprioritycompare.c
@@ -19,9 +19,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/scheduleredfreleasejob.c b/cpukit/score/src/scheduleredfreleasejob.c
index 37ff2d5..c2592b9 100644
--- a/cpukit/score/src/scheduleredfreleasejob.c
+++ b/cpukit/score/src/scheduleredfreleasejob.c
@@ -18,7 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/scheduleredfunblock.c b/cpukit/score/src/scheduleredfunblock.c
index 0640e8c..387a78a 100644
--- a/cpukit/score/src/scheduleredfunblock.c
+++ b/cpukit/score/src/scheduleredfunblock.c
@@ -18,8 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/scheduleredfupdate.c b/cpukit/score/src/scheduleredfupdate.c
index 3069068..1a5ce13 100644
--- a/cpukit/score/src/scheduleredfupdate.c
+++ b/cpukit/score/src/scheduleredfupdate.c
@@ -18,12 +18,7 @@
 #include "config.h"
 #endif
-#include <rtems/score/priority.h>
diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
index 08b6e82..2f8fe42 100644
--- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
+++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
@@ -20,18 +20,18 @@
 #endif
 #include <rtems/score/schedulerpriorityaffinitysmp.h>
+#include <rtems/score/cpusetimpl.h>
 #include <rtems/score/schedulerpriorityimpl.h>
-#include <rtems/score/schedulersmpimpl.h>
+#include <rtems/score/schedulerprioritysmpimpl.h>
-#include <rtems/score/cpusetimpl.h>
-RTEMS_INLINE_ROUTINE Scheduler_priority_affinity_SMP_Per_thread *
+static Scheduler_priority_affinity_SMP_Per_thread *
 _Scheduler_priority_affinity_Get_scheduler_info( Thread_Control *thread )
   return ( Scheduler_priority_affinity_SMP_Per_thread * ) thread->scheduler_info;
+static void * _Scheduler_priority_affinity_SMP_Allocate(
@@ -47,7 +47,7 @@ void * _Scheduler_priority_affinity_SMP_Allocate(
   return info;
+static bool _Scheduler_priority_affinity_SMP_Get_affinity(
   size_t             cpusetsize,
@@ -67,11 +67,11 @@ bool _Scheduler_priority_affinity_SMP_Get_affinity(
   return true;
+static bool _Scheduler_priority_affinity_SMP_Set_affinity(
   size_t             cpusetsize,
-  cpu_set_t         *cpuset
   Scheduler_priority_affinity_SMP_Per_thread *info =
@@ -87,3 +87,23 @@ bool _Scheduler_priority_affinity_SMP_Set_affinity(
   return true;
+const Scheduler_Operations _Scheduler_priority_affinity_SMP_Operations = {
+  .initialize = _Scheduler_priority_SMP_Initialize,
+  .schedule = _Scheduler_priority_SMP_Schedule,
+  .yield = _Scheduler_priority_SMP_Yield,
+  .block = _Scheduler_priority_SMP_Block,
+  .unblock = _Scheduler_priority_SMP_Enqueue_fifo,
+  .allocate = _Scheduler_priority_affinity_SMP_Allocate,
+  .free = _Scheduler_priority_Free,
+  .update = _Scheduler_priority_SMP_Update,
+  .enqueue = _Scheduler_priority_SMP_Enqueue_fifo,
+  .enqueue_first = _Scheduler_priority_SMP_Enqueue_lifo,
+  .extract = _Scheduler_priority_SMP_Extract,
+  .priority_compare = _Scheduler_priority_Priority_compare,
+  .release_job = _Scheduler_default_Release_job,
+  .start_idle = _Scheduler_priority_SMP_Start_idle,
+  .get_affinity = _Scheduler_priority_affinity_SMP_Get_affinity,
+  .set_affinity = _Scheduler_priority_affinity_SMP_Set_affinity
diff --git a/cpukit/score/src/schedulerpriorityallocate.c b/cpukit/score/src/schedulerpriorityallocate.c
index 2225d3d..db362e7 100644
--- a/cpukit/score/src/schedulerpriorityallocate.c
+++ b/cpukit/score/src/schedulerpriorityallocate.c
@@ -18,8 +18,7 @@
 #include "config.h"
 #endif
+#include <rtems/score/schedulerpriorityimpl.h>
 void *_Scheduler_priority_Allocate (
diff --git a/cpukit/score/src/schedulerpriorityops.c b/cpukit/score/src/schedulerpriorityops.c
index 0000000..9d16aeb
--- /dev/null
+++ b/cpukit/score/src/schedulerpriorityops.c
@@ -0,0 +1,38 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+const Scheduler_Operations _Scheduler_priority_Operations = {
+  .initialize = _Scheduler_priority_Initialize,
+  .schedule = _Scheduler_priority_Schedule,
+  .yield = _Scheduler_priority_Yield,
+  .block = _Scheduler_priority_Block,
+  .unblock = _Scheduler_priority_Unblock,
+  .allocate = _Scheduler_priority_Allocate,
+  .update = _Scheduler_priority_Update,
+  .enqueue = _Scheduler_priority_Enqueue,
+  .enqueue_first = _Scheduler_priority_Enqueue_first,
+  .extract = _Scheduler_priority_Extract,
diff --git a/cpukit/score/src/schedulerprioritysmp.c b/cpukit/score/src/schedulerprioritysmp.c
index 5361023..d19a570 100644
--- a/cpukit/score/src/schedulerprioritysmp.c
+++ b/cpukit/score/src/schedulerprioritysmp.c
@@ -26,6 +26,7 @@
 #include <rtems/score/schedulerprioritysmp.h>
@@ -291,3 +292,22 @@ void _Scheduler_priority_SMP_Start_idle(
   _Scheduler_SMP_Start_idle( &self->Base, thread, cpu );
+const Scheduler_Operations _Scheduler_priority_SMP_Operations = {
diff --git a/cpukit/score/src/schedulersimple.c b/cpukit/score/src/schedulersimple.c
index b825b29..b425e55 100644
--- a/cpukit/score/src/schedulersimple.c
+++ b/cpukit/score/src/schedulersimple.c
@@ -19,7 +19,7 @@
 #include "config.h"
 #endif
-#include <rtems/score/schedulersimple.h>
+#include <rtems/score/schedulersimpleimpl.h>
diff --git a/cpukit/score/src/schedulersimpleenqueue.c b/cpukit/score/src/schedulersimpleenqueue.c
index b0d4992..843a2c3 100644
--- a/cpukit/score/src/schedulersimpleenqueue.c
+++ b/cpukit/score/src/schedulersimpleenqueue.c
@@ -19,11 +19,7 @@
 #include "config.h"
 #endif
-#include <rtems/score/chain.h>
-#include <rtems/score/isr.h>
diff --git a/cpukit/score/src/schedulersimpleenqueuefirst.c b/cpukit/score/src/schedulersimpleenqueuefirst.c
index b9005a7..84c41b5 100644
--- a/cpukit/score/src/schedulersimpleenqueuefirst.c
+++ b/cpukit/score/src/schedulersimpleenqueuefirst.c
@@ -18,10 +18,7 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulersimpleextract.c b/cpukit/score/src/schedulersimpleextract.c
index 7bb4339..5b5cde7 100644
--- a/cpukit/score/src/schedulersimpleextract.c
+++ b/cpukit/score/src/schedulersimpleextract.c
@@ -19,9 +19,8 @@
 #include "config.h"
 #endif
diff --git a/cpukit/score/src/schedulersimpleops.c b/cpukit/score/src/schedulersimpleops.c
index 0000000..3dd36b5
--- /dev/null
+++ b/cpukit/score/src/schedulersimpleops.c
@@ -0,0 +1,39 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+const Scheduler_Operations _Scheduler_simple_Operations = {
+  .initialize = _Scheduler_simple_Initialize,
+  .schedule = _Scheduler_simple_Schedule,
+  .yield = _Scheduler_simple_Yield,
+  .block = _Scheduler_simple_Block,
+  .unblock = _Scheduler_simple_Unblock,
+  .allocate = _Scheduler_default_Allocate,
+  .free = _Scheduler_default_Free,
+  .update = _Scheduler_default_Update,
+  .enqueue = _Scheduler_simple_Enqueue,
+  .enqueue_first = _Scheduler_simple_Enqueue_first,
+  .extract = _Scheduler_simple_Extract,
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index 20a35af..7ea5f6f 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -19,6 +19,7 @@
 #endif
 #include <rtems/score/schedulersimplesmp.h>
@@ -35,7 +36,7 @@ _Scheduler_simple_SMP_Self_from_SMP_base( Scheduler_SMP_Control *smp_base )
     ( (char *) smp_base - offsetof( Scheduler_simple_SMP_Control, Base ) );
+static void _Scheduler_simple_SMP_Initialize( void )
   Scheduler_simple_SMP_Control *self =
     _Workspace_Allocate_or_fatal_error( sizeof( *self ) );
@@ -46,7 +47,7 @@ void _Scheduler_simple_smp_Initialize( void )
   _Scheduler.information = self;
-static Thread_Control *_Scheduler_simple_smp_Get_highest_ready(
+static Thread_Control *_Scheduler_simple_SMP_Get_highest_ready(
@@ -62,7 +63,7 @@ static Thread_Control *_Scheduler_simple_smp_Get_highest_ready(
   return highest_ready;
-static void _Scheduler_simple_smp_Move_from_scheduled_to_ready(
+static void _Scheduler_simple_SMP_Move_from_scheduled_to_ready(
   Scheduler_SMP_Control *smp_base,
   Thread_Control *scheduled_to_ready
@@ -77,7 +78,7 @@ static void _Scheduler_simple_smp_Move_from_scheduled_to_ready(
-static void _Scheduler_simple_smp_Move_from_ready_to_scheduled(
+static void _Scheduler_simple_SMP_Move_from_ready_to_scheduled(
   Thread_Control *ready_to_scheduled
@@ -89,7 +90,7 @@ static void _Scheduler_simple_smp_Move_from_ready_to_scheduled(
-static void _Scheduler_simple_smp_Insert_ready_lifo(
+static void _Scheduler_simple_SMP_Insert_ready_lifo(
@@ -104,7 +105,7 @@ static void _Scheduler_simple_smp_Insert_ready_lifo(
-static void _Scheduler_simple_smp_Insert_ready_fifo(
+static void _Scheduler_simple_SMP_Insert_ready_fifo(
@@ -119,7 +120,7 @@ static void _Scheduler_simple_smp_Insert_ready_fifo(
-static void _Scheduler_simple_smp_Do_extract(
+static void _Scheduler_simple_SMP_Do_extract(
@@ -132,7 +133,7 @@ static void _Scheduler_simple_smp_Do_extract(
   _Chain_Extract_unprotected( &thread->Object.Node );
+static void _Scheduler_simple_SMP_Block(
@@ -143,13 +144,13 @@ void _Scheduler_simple_smp_Block(
   _Scheduler_SMP_Block(
     &self->Base,
     thread,
-    _Scheduler_simple_smp_Do_extract,
-    _Scheduler_simple_smp_Get_highest_ready,
-    _Scheduler_simple_smp_Move_from_ready_to_scheduled
+    _Scheduler_simple_SMP_Do_extract,
+    _Scheduler_simple_SMP_Get_highest_ready,
+    _Scheduler_simple_SMP_Move_from_ready_to_scheduled
-static void _Scheduler_simple_smp_Enqueue_ordered(
+static void _Scheduler_simple_SMP_Enqueue_ordered(
   Chain_Node_order order,
@@ -161,15 +162,15 @@ static void _Scheduler_simple_smp_Enqueue_ordered(
     smp_base,
     thread,
     order,
     insert_ready,
     insert_scheduled,
-    _Scheduler_simple_smp_Move_from_ready_to_scheduled,
-    _Scheduler_simple_smp_Move_from_scheduled_to_ready
+    _Scheduler_simple_SMP_Move_from_ready_to_scheduled,
+    _Scheduler_simple_SMP_Move_from_scheduled_to_ready
+static void _Scheduler_simple_SMP_Enqueue_priority_lifo(
@@ -177,16 +178,16 @@ void _Scheduler_simple_smp_Enqueue_priority_lifo(
     _Scheduler_simple_SMP_Self_from_base( base );
-  _Scheduler_simple_smp_Enqueue_ordered(
+  _Scheduler_simple_SMP_Enqueue_ordered(
     &self->Base,
     thread,
     _Scheduler_simple_Insert_priority_lifo_order,
-    _Scheduler_simple_smp_Insert_ready_lifo,
+    _Scheduler_simple_SMP_Insert_ready_lifo,
     _Scheduler_SMP_Insert_scheduled_lifo
+static void _Scheduler_simple_SMP_Enqueue_priority_fifo(
@@ -194,16 +195,16 @@ void _Scheduler_simple_smp_Enqueue_priority_fifo(
     &self->Base,
     thread,
     _Scheduler_simple_Insert_priority_fifo_order,
-    _Scheduler_simple_smp_Insert_ready_fifo,
+    _Scheduler_simple_SMP_Insert_ready_fifo,
     _Scheduler_SMP_Insert_scheduled_fifo
+static void _Scheduler_simple_SMP_Extract(
@@ -214,11 +215,11 @@ void _Scheduler_simple_smp_Extract(
   _Scheduler_SMP_Extract(
     &self->Base,
     thread,
+static void _Scheduler_simple_SMP_Yield(
@@ -227,13 +228,13 @@ void _Scheduler_simple_smp_Yield(
   _ISR_Disable( level );
-  _Scheduler_simple_smp_Extract( base, thread );
-  _Scheduler_simple_smp_Enqueue_priority_fifo( base, thread );
+  _Scheduler_simple_SMP_Extract( base, thread );
+  _Scheduler_simple_SMP_Enqueue_priority_fifo( base, thread );
   _ISR_Enable( level );
+static void _Scheduler_simple_SMP_Schedule(
@@ -244,12 +245,12 @@ void _Scheduler_simple_smp_Schedule(
   _Scheduler_SMP_Schedule(
     &self->Base,
     thread,
+static void _Scheduler_simple_SMP_Start_idle(
@@ -260,3 +261,22 @@ void _Scheduler_simple_smp_Start_idle(
+const Scheduler_Operations _Scheduler_simple_SMP_Operations = {
+  .initialize = _Scheduler_simple_SMP_Initialize,
+  .schedule = _Scheduler_simple_SMP_Schedule,
+  .yield = _Scheduler_simple_SMP_Yield,
+  .block = _Scheduler_simple_SMP_Block,
+  .unblock = _Scheduler_simple_SMP_Enqueue_priority_fifo,
+  .enqueue = _Scheduler_simple_SMP_Enqueue_priority_fifo,
+  .enqueue_first = _Scheduler_simple_SMP_Enqueue_priority_lifo,
+  .extract = _Scheduler_simple_SMP_Extract,
+  .start_idle = _Scheduler_simple_SMP_Start_idle
diff --git a/cpukit/score/src/schedulersimpleunblock.c b/cpukit/score/src/schedulersimpleunblock.c
index c669a9b..94d9694 100644
--- a/cpukit/score/src/schedulersimpleunblock.c
+++ b/cpukit/score/src/schedulersimpleunblock.c
@@ -18,10 +18,7 @@
 #include "config.h"
 #endif
   Scheduler_Control *scheduler,
diff --git a/testsuites/rhealstone/rhilatency/ilatency.c b/testsuites/rhealstone/rhilatency/ilatency.c
index b7f5a1a..b028ada 100644
--- a/testsuites/rhealstone/rhilatency/ilatency.c
+++ b/testsuites/rhealstone/rhilatency/ilatency.c
@@ -58,7 +58,7 @@ rtems_task Init(
   puts( "*** START OF RHILATENCY ***" );
-  if (_Scheduler.Operations.initialize != _Scheduler_priority_Initialize) {
+  if (_Scheduler.operations != &_Scheduler_priority_Operations) {
     puts( "  Error ==> " );
     puts( "Test only supported for deterministic priority scheduler\n" );
     rtems_test_exit( 0 );
diff --git a/testsuites/sptests/spinternalerror01/init.c b/testsuites/sptests/spinternalerror01/init.c
index 15a2315..71f9f68 100644
--- a/testsuites/sptests/spinternalerror01/init.c
+++ b/testsuites/sptests/spinternalerror01/init.c
@@ -70,7 +70,7 @@ static void *idle_body(uintptr_t ignored)
 #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
-#define CONFIGURE_SCHEDULER_ENTRY_POINTS NULL
+#define CONFIGURE_SCHEDULER_OPERATIONS NULL
 #define CONFIGURE_SCHEDULER_USER
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index 6325516..41c62a2 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -223,7 +223,7 @@ rtems_task Init(
   TEST_BEGIN();
     puts("  Error ==> " );
     puts("Test only supported for deterministic priority scheduler\n" );
     TEST_END();
diff --git a/testsuites/tmtests/tm27/task1.c b/testsuites/tmtests/tm27/task1.c
index a639327..13b878f 100644
--- a/testsuites/tmtests/tm27/task1.c
+++ b/testsuites/tmtests/tm27/task1.c
@@ -55,7 +55,7 @@ rtems_task Init(
   Print_Warning();
   TEST_BEGIN();
     TEST_END();
1.7.7
